path: root/arch/mips/Makefile
2010-08-05MIPS: Clean up arch/mips/MakefileSam Ravnborg
- Drop CLEAN_FILES assignments that is no longer required - Add $(Q) in a few rules Signed-off-by: Sam Ravnborg <sam@ravnborg.org> To: linux-mips <linux-mips@linux-mips.org> To: Wu Zhangjin <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/1305/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Refactor arch/mips/boot/compressed/MakefileSam Ravnborg
- use hostprogs-y for the elf2ecoff - list all *.o file in targets - renamed obj-y to vmlinuzobjs-y (it was confusing to re-use a kbuild variable) - fix all uses of if_changed/cmd - use kbuild rules to beautify output - update clean-file to clean vmlinuz.* in top-level directory - simplied logic in arch/mips/Makefile for compressed targets The net result is a more kbuild conformant Makefile but readability did not increase. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> To: linux-mips <linux-mips@linux-mips.org> To: Wu Zhangjin <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/1304/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Refactor arch/mips/boot/MakefileSam Ravnborg
- remove stuff that is not needed VMLINUX assignment, all: rule - use hostprogs-y for the host program - use kbuild rules for the three targets - to beautify output - drop clean-files - it is no longer needed - simplify arch/mips/Makefile when calling targets in boot/Makefile Signed-off-by: Sam Ravnborg <sam@ravnborg.org> To: linux-mips <linux-mips@linux-mips.org> To: Wu Zhangjin <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/1303/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: PNX8550: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: PNX833x: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: STB8550: Move boards over to obj-yRalf Baechle
Preparatory cleanup for moving Alchemy over to new MIPS Platform build system support. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: STB22x: Move boards over to obj-yRalf Baechle
2010-08-05MIPS: PNX8550: Move code one directory level up.Ralf Baechle
It was sharing the nxp directory but no code with pnx833x and will fit better into the new platform makefile scheme, if moved. Also after the pnx833x code has been moved up, the pnx8550 Code was the last users of the nxp dir. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: PNX833x: Move code one directory level up.Ralf Baechle
It was sharing the nxp directory but no code with pnx8550 and will fit better into the new platform makefile scheme, if moved. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: EMMA: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: TXx9: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: Sibyte: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: Octeon: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: BCM63xx: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: BCM47xx: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: Lasat: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: PowerTV: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: WRPPMC: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: WRPPMC: Move code one directory level up.Ralf Baechle
It was the last platform under gt64120 and will fit better into the new platform makefile scheme, if moved. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: RB532: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: IP32: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: Malta: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: IP22, IP28: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: SNI: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: DECstation: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: Jazz: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: PMC-Sierra: Move board Makefile parts to their own Platform fileShane McDonald
Signed-off-by: Shane McDonald <mcdonald.shane@gmail.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1354/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Move VR41xx Makefile parts to their own Platform fileYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/1322/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Move Cobalt Makefile parts to their own Platform fileYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/1321/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: IP27: Migrate to new Platform fileRalf Baechle
2010-08-05MIPS: Move Alchemy Makefile parts to their own Platform file.Manuel Lauss
[Ralf: Remove a forgotten -Werror in Pb1200 Makefile.] Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Patchwork: https://patchwork.linux-mips.org/patch/1319/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Alchemy: move boards over to obj-yManuel Lauss
Preparatory step for moving Alchemy over to new MIPS Platform build system support. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/1318/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: MIPSsim: Migrate to new Platform fileRalf Baechle
2010-08-05MIPS: Loongson: Migrate makefile to new Platform fileWu Zhangjin
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> To: linux-mips <linux-mips@linux-mips.org> Cc: Alexander Clouter <alex@digriz.org.uk> Cc: Manuel Lauss <manuel.lauss@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org>, Patchwork: https://patchwork.linux-mips.org/patch/1313/ Patchwork: https://patchwork.linux-mips.org/patch/1326/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Introduce support for Platform definitionsSam Ravnborg
Move platform specific definitions to the platfrom directories. Each platform shall do the following: 1) include an entry in arch/mips/Kbuild.platforms 2) add relevant definitions to arch/mips/<platform>/Platform This commits changes ar7 to the new scheme as an example. Introducing a platform speecific Platfrom file has following advantages: 1) decentralization of platfrom definitions 2) simplification af arch/mips/Makefile 3) force all platfrom to build with -Werror (done in arch/mips/Kbuild) [Ralf: Remove forgotten -Werror from AR7 Makefile] Signed-off-by: Sam Ravnborg <sam@ravnborg.org> To: linux-mips <linux-mips@linux-mips.org> To: Wu Zhangjin <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/1302/ Patchwork: http://patchwork.linux-mips.org/patch/1308/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Introduce arch/mips/KbuildSam Ravnborg
Signed-off-by: Sam Ravnborg <sam@ravnborg.org> To: linux-mips <linux-mips@linux-mips.org> To: Wu Zhangjin <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/1300/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-04-30MIPS: Loongson 2F: Enable fixups of the latest binutilsWu Zhangjin
With the "Fixups of Loongson2F" patch [1] having been applied to binutils for binutils 2.20.1 we now can use it's time to enable the options provided by the patch to compile the kernel. Without these fixups, the system may hang if the erratum is triggered. For more information on these fixups please refer to the following references. [1] "Fixups of Loongson2F" patch for binutils(actually for gas) http://sourceware.org/ml/binutils/2009-11/msg00387.html [2] Chapter 15 of "Loongson2F User Manual"(Chinese Version) http://www.loongson.cn/uploadfile/file/200808211 [3] Chapter 15 of the English version Loongson 2F User Manual http://groups.google.com.hk/group/loongson-dev/msg/e0d2e220958f10a6?dmode=source Signed-off-by: Zhang Le <r0bertz@gentoo.org> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Zhang Le <r0bertz@gentoo.org> Cc: linux-mips <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/1106/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: Loongson: arch/mips/Makefile: Add missing whitespaceWu Zhangjin
This patch add missing whitespace after every "+=" in the loongson related part of arch/mips/Makefile. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: linux-mips@linux-mips.org Cc: yanh@lemote.com Cc: huhb@lemote.com Cc: zhangfx@lemote.com Patchwork: http://patchwork.linux-mips.org/patch/827/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: Fix build error for uncompressed non-plain vmlinux kernelsRalf Baechle
Seen on rm200_defconfig for example: CC arch/mips/boot/compressed/decompress.o /home/ralf/src/linux/upstream-linus/arch/mips/boot/compressed/decompress.c: In function ‘decompress_kernel’: /home/ralf/src/linux/upstream-linus/arch/mips/boot/compressed/decompress.c:116: error: implicit declaration of function ‘decompress’ make[3]: *** [arch/mips/boot/compressed/decompress.o] Error 1 make[2]: *** [vmlinuz.ecoff] Error 2 make[1]: *** [sub-make] Error 2 make: *** [all] Error 2 Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: eXcite: Remove platform.Ralf Baechle
The platform has never been fully merged Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Thomas Koeller <thomas.koeller@baslerweb.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: linux-kernel@vger.kernel.org Cc: linux-mtd@lists.infradead.org Acked-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Wim Van Sebroeck <wim@iguana.be>
2009-12-17MIPS: Tracing: Make function graph tracer work with -mmcount-ra-addressWu Zhangjin
That thread "MIPS: Add option to pass return address location to _mcount" from "David Daney <ddaney@caviumnetworks.com>" have added a new option -mmcount-ra-address to gcc(4.5) for MIPS to transfer the location of the return address to _mcount. Benefit from this new feature, function graph tracer on MIPS will be easier and safer to hijack the return address of the kernel function, which will save some overhead and make the whole thing more reliable. In this patch, at first, try to enable the option -mmcount-ra-address in arch/mips/Makefile with cc-option, if gcc support it, it will be enabled, otherwise, no side effect. and then, we need to support this new option of gcc 4.5 and also support the old gcc versions. with _mcount in the old gcc versions, it's not easy to get the location of return address(tracing: add function graph tracer support for MIPS), so, we do it in a C function: ftrace_get_parent_addr(ftrace.c), but with -mmcount-ra-address, only several instructions need to get what we want, so, I put into asm(mcount.S). and also, as the $12(t0) is used by -mmcount-ra-address for transferring the localtion of return address to _mcount, we need to save it into the stack and restore it when enabled dynamic function tracer, 'Cause we have called "ftrace_call" before "ftrace_graph_caller", which may destroy $12(t0). (Thanks to David for providing that -mcount-ra-address and giving the idea of KBUILD_MCOUNT_RA_ADDRESS, both of them have made the whole thing more beautiful!) Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Nicholas Mc Guire <der.herr@hofr.at> Cc: zhangfx@lemote.com Cc: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/681/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Tracing: Add static function tracer support for MIPSWu Zhangjin
If -pg of gcc is enabled with CONFIG_FUNCTION_TRACER=y. a calling to _mcount will be inserted into each kernel function. so, there is a possibility to trace the kernel functions in _mcount. This patch add the MIPS specific _mcount support for static function tracing. by default, ftrace_trace_function is initialized as ftrace_stub(an empty function), so, the default _mcount will introduce very little overhead. after enabling ftrace in user-space, it will jump to a real tracing function and do static function tracing for us. and -ffunction-sections is incompatible with -pg, so, disable it when ftracer is enabled. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: Nicholas Mc Guire <der.herr@hofr.at> Cc: zhangfx@lemote.com Cc: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/672/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: PowerTV: Base files for Cisco PowerTV platformDavid VomLehn
Add the Cisco Powertv cable settop box to the MIPS tree. This platform is based on a MIPS 24Kc processor with various devices integrated on the same ASIC. There are multiple models of this box, with differing configuration but the same kernel runs across the product line. Signed-off-by: David VomLehn <dvomlehn@cisco.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/132/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Lemote 2F: Add a LEMOTE_MACH2F kernel optionWu Zhangjin
Add a new kernel option for Lemote Loongson 2F family machines. Lemote loongson2f family machines utilize the 2f revision of loongson processor and the AMD CS5536 south bridge. Family members include Fuloong 2F mini PC, Yeeloong 2F notebook, LingLoong all-in-one PC and others. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: zhangfx@lemote.com Cc: yanh@lemote.com Cc: huhb@lemote.com Cc: Nicholas Mc Guire <hofrat@hofr.at> Cc: Arnaud Patard <apatard@mandriva.com> Cc: loongson-dev@googlegroups.com Cc: linux-mips@linux-mips.org Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Loongson: Add basic Loongson 2F supportWu Zhangjin
Loongson 2F has built-in DDR2 and PCI-X controller. The PCI-X controller has a programming interface similiar to the the FPGA northbridge used on Loongson 2E. The main differences between Loongson 2E and Loongson 2F include: 1. Loongson 2F has an extra address window configuration module, which is used to map CPU address space to DDR or PCI address space, or map the PCI-DMA address space to DDR or LIO address space. 2. Loongson 2F supports 8 levels of software configurable CPu frequency which can be configured in the LOONGSON_CHIPCFG0 register. The coming cpufreq and standby support are based on this feature. Loongson.h abstracts the modules and corresponding methods are abstracted. Add other Loongson-2F-specific source code including gcc 4.4 support, PCI memory space, PCI IO space, DMA address. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: linux-mips@linux-mips.org Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Add support for GZIP / BZIP2 / LZMA compressed kernel imagesWu Zhangjin
This patch helps to generate smaller kernel images for linux-MIPS, Here is the effect when using lzma: $ ls -sh vmlinux 7.1M vmlinux $ ls -sh vmlinuz 1.5M vmlinuz Have tested the 32bit kernel on Qemu/Malta and 64bit kernel on FuLoong Mini PC. both of them work well. and also, tested by Alexander Clouter on an AR7 based Linksys WAG54Gv2, and by Manuel Lauss on an Alchemy board. This -v2 version incorporate the feedback from Ralf, and add the following changes: 1. add .ecoff, .bin, .erec format support 2. only enable it and the debug source code for the machines we tested 3. a dozen of fixups and cleanups and if you want to enable it for your board, please try to select SYS_SUPPORTS_ZBOOT for it, and if the board have an 16550 compatible uart, you can select SYS_SUPPORTS_ZBOOT_UART16550 directly. and then sending the relative patches to Ralf. Tested-by: Manuel Lauss <manuel.lauss@googlemail.com> Tested-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-20arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0Sam Ravnborg
Albin Tonnerre <albin.tonnerre@free-electrons.com> reported: Bash 4 filters out variables which contain a dot in them. This happends to be the case of CPPFLAGS_vmlinux.lds. This is rather unfortunate, as it now causes build failures when using SHELL=/bin/bash to compile, or when bash happens to be used by make (eg when it's /bin/sh) Remove the common definition of CPPFLAGS_vmlinux.lds by pushing relevant stuff to either Makefile.build or the arch specific kernel/Makefile where we build the linker script. This is also nice cleanup as we move the information out where it is used. Notes for the different architectures touched: arm - we use an already exported symbol cris - we use a config symbol aleady available [Not build tested] mips - the jiffies complexity has moved to vmlinux.lds.S where we need it. Added a few variables to CPPFLAGS - they are only used by the linker script. [Not build tested] powerpc - removed assignment that is not needed [not build tested] sparc - simplified it using $(BITS) um - introduced a few new exported variables to deal with this xtensa - added options to CPP invocation [not build tested] Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-17MIPS: BCM63xx: Add support for the Broadcom BCM63xx family of SOCs.Maxime Bizon
Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: Add GCC 4.4 support for Loongson2EWu Zhangjin
Because only gcc >=4.4 have loongson-specific support, we need to choose the suitable -march argument for gcc <= 4.3 and gcc >= 4.4, and here, we use -march=loongson2e for loongson2e. Thanks goes to Arnaud Patard <apatard@mandriva.com> for suggestion of using cc-options(Documentation/kbuild/makefiles.txt). and thanks Zhang Le for introducing the new CPU_LOONGSON2E kernel option. NOTE: -mtune option is not need if -march and -mtune use the same value. Signed-off-by: Zhang Le <r0bertz@gentoo.org> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: Split common loongson source code outWu Zhangjin
To share common loongson source code between all of the loongson-based machines. there is a need to split it out of the fuloong-2e/ directory. at the same time, other according tuning is needed. the machine-specific parts are defined as macros in relative header file, pci.h, mem.h, machine.h. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
