path: root/arch/microblaze
2012-05-15microblaze/PCI: fix "io_offset undeclared" errorBjorn Helgaas
There is a compile error for microblaze pci because io_offset is not declared. This patch adds declaration of io_offset. [bhelgaas: I introduced this problem with 58de74b8053] Signed-off-by: Hiroo MATSUMOTO <matsumoto.hiroo@jp.fujitsu.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-04-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull DMA mapping branch from Marek Szyprowski: "Short summary for the whole series: A few limitations have been identified in the current dma-mapping design and its implementations for various architectures. There exist more than one function for allocating and freeing the buffers: currently these 3 are used dma_{alloc, free}_coherent, dma_{alloc,free}_writecombine, dma_{alloc,free}_noncoherent. For most of the systems these calls are almost equivalent and can be interchanged. For others, especially the truly non-coherent ones (like ARM), the difference can be easily noticed in overall driver performance. Sadly not all architectures provide implementations for all of them, so the drivers might need to be adapted and cannot be easily shared between different architectures. The provided patches unify all these functions and hide the differences under the already existing dma attributes concept. The thread with more references is available here: http://www.spinics.net/lists/linux-sh/msg09777.html These patches are also a prerequisite for unifying DMA-mapping implementation on ARM architecture with the common one provided by dma_map_ops structure and extending it with IOMMU support. More information is available in the following thread: http://thread.gmane.org/gmane.linux.kernel.cross-arch/12819 More works on dma-mapping framework are planned, especially in the area of buffer sharing and managing the shared mappings (together with the recently introduced dma_buf interface: commit d15bd7ee445d "dma-buf: Introduce dma buffer sharing mechanism"). The patches in the current set introduce a new alloc/free methods (with support for memory attributes) in dma_map_ops structure, which will later replace dma_alloc_coherent and dma_alloc_writecombine functions." People finally started piping up with support for merging this, so I'm merging it as the last of the pending stuff from the merge window. Looks like pohmelfs is going to wait for 3.5 and more external support for merging. * 'for-linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: common: DMA-mapping: add NON-CONSISTENT attribute common: DMA-mapping: add WRITE_COMBINE attribute common: dma-mapping: introduce mmap method common: dma-mapping: remove old alloc_coherent and free_coherent methods Hexagon: adapt for dma_map_ops changes Unicore32: adapt for dma_map_ops changes Microblaze: adapt for dma_map_ops changes SH: adapt for dma_map_ops changes Alpha: adapt for dma_map_ops changes SPARC: adapt for dma_map_ops changes PowerPC: adapt for dma_map_ops changes MIPS: adapt for dma_map_ops changes X86 & IA64: adapt for dma_map_ops changes common: dma-mapping: introduce generic alloc() and free() methods
2012-04-03Merge branch 'next' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
Pull arch/microblaze fixes from Michal Simek. * 'next' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: Fix ret_from_fork declaration microblaze: Do not use tlb_skip in early_printk microblaze: Add missing headers caused by disintegration asm/system.h microblaze: Fix stack usage in PAGE_SIZE copy_tofrom_user microblaze: Fix tlb_skip variable on noMMU system microblaze: Fix __futex_atomic_op macro register usage
2012-04-02microblaze: Fix ret_from_fork declarationMichal Simek
ret_from_fork is used by noMMU system too. It should be the part of patch "Disintegrate asm/system.h for Microblaze" (sha1: c40d04df152a1111c5bbcb632278394dabd2b73d) Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-04-02microblaze: Do not use tlb_skip in early_printkMichal Simek
tlb_skip is valid only for MMU system. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-30Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - Unification of cmd_uimage among archs that use it - make headers_check tries harder before reporting a missing <linux/types.h> include - kbuild portability fix for shells that do not support echo -e - make clean descends into samples/ - setlocalversion grep fix - modpost typo fix - dtc warnings fix * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: setlocalversion: Use "grep -q" instead of piping output to "read dummy" modpost: fix ALL_INIT_DATA_SECTIONS Kbuild: centralize MKIMAGE and cmd_uimage definitions headers_check: recursively search for linux/types.h inclusion scripts/Kbuild.include: Fix portability problem of "echo -e" scripts: dtc: fix compile warnings kbuild: clean up samples directory kbuild: disable -Wmissing-field-initializers for W=1
2012-03-30microblaze: Add missing headers caused by disintegration asm/system.hMichal Simek
2012-03-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into nextMichal Simek
2012-03-30microblaze: Fix stack usage in PAGE_SIZE copy_tofrom_userMichal Simek
If access to user space failed we need to reconstruct stack pointer and restore all register. This patch fixed problem introduces by: "microblaze: Add loop unrolling for PAGE in copy_tofrom_user" (sha1: ebe211254bfa6295f4ab0b33c7c881bdfabbab60) Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Delete all instances of asm/system.hDavid Howells
Delete all instances of asm/system.h as they should be redundant by this point. Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-28Move all declarations of free_initmem() to linux/mm.hDavid Howells
Move all declarations of free_initmem() to linux/mm.h so that there's only one and it's used by everything. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-c6x-dev@linux-c6x.org cc: microblaze-uclinux@itee.uq.edu.au cc: linux-sh@vger.kernel.org cc: sparclinux@vger.kernel.org cc: x86@kernel.org cc: linux-mm@kvack.org
2012-03-28Disintegrate asm/system.h for MicroblazeDavid Howells
Disintegrate asm/system.h for Microblaze. Not compiled. Signed-off-by: David Howells <dhowells@redhat.com> cc: microblaze-uclinux@itee.uq.edu.au
2012-03-28Microblaze: adapt for dma_map_ops changesAndrzej Pietrasiewicz
Adapt core Microblaze architecture code for dma_map_ops changes: replace alloc/free_coherent with generic alloc/free methods. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> [fixed coding style issues] Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2012-03-28microblaze: Fix tlb_skip variable on noMMU systemMichal Simek
TLBs are available only for MMU systems. Error log: arch/microblaze/kernel/setup.c: In function 'debugfs_tlb': arch/microblaze/kernel/setup.c:217: error: 'tlb_skip' undeclared (first use in this function) arch/microblaze/kernel/setup.c:217: error: (Each undeclared identifier is reported only once arch/microblaze/kernel/setup.c:217: error: for each function it appears in.) make[1]: *** [arch/microblaze/kernel/setup.o] Error 1 Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-28microblaze: Fix __futex_atomic_op macro register usageMichal Simek
Old Microblaze toolchain supported "b" contstrains for all register but it always points to general purpose reg. New Microblaze toolchain is more strict in this and general purpose register should be used there "r". Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-27Merge branch 'next' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
Pull arch/microblaze fixes from Michal Simek * 'next' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: Handle TLB skip size dynamically microblaze: Introduce TLB skip size microblaze: Improve TLB calculation for small systems microblaze: Extend space for compiled-in FDT to 32kB microblaze: Clear all MSR flags on the first kernel instruction microblaze: Use node name instead of compatible string microblaze: Fix mapin_ram function microblaze: Highmem support microblaze: Use active regions microblaze: Show more detailed information about memory microblaze: Introduce fixmap microblaze: mm: Fix lowmem max memory size limits microblaze: mm: Use ZONE_DMA instead of ZONE_NORMAL microblaze: trivial: Fix typo fault in timer.c microblaze: Use vsprintf extention %pf with builtin_return_address microblaze: Add PVR version string for MB 8.20.b and 8.30.a microblaze: Fix makefile to work with latest toolchain microblaze: Fix typo in early_printk.c
2012-03-26Kbuild: centralize MKIMAGE and cmd_uimage definitionsStephen Warren
All ARCHs have the same definition of MKIMAGE. Move it to Makefile.lib to avoid duplication. All ARCHs have similar definitions of cmd_uimage. Place a sufficiently parameterized version in Makefile.lib to avoid duplication. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Nicolas Pitre <nico@linaro.org> Tested-by: Mike Frysinger <vapier@gentoo.org> [Blackfin] Tested-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Guan Xuetao <gxt@mprc.pku.edu.cn> [unicore32] Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-23Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge second batch of patches from Andrew Morton: - various misc things - core kernel changes to prctl, exit, exec, init, etc. - kernel/watchdog.c updates - get_maintainer - MAINTAINERS - the backlight driver queue - core bitops code cleanups - the led driver queue - some core prio_tree work - checkpatch udpates - largeish crc32 update - a new poll() feature for the v4l guys - the rtc driver queue - fatfs - ptrace - signals - kmod/usermodehelper updates - coredump - procfs updates * emailed from Andrew Morton <akpm@linux-foundation.org>: (141 commits) seq_file: add seq_set_overflow(), seq_overflow() proc-ns: use d_set_d_op() API to set dentry ops in proc_ns_instantiate(). procfs: speed up /proc/pid/stat, statm procfs: add num_to_str() to speed up /proc/stat proc: speed up /proc/stat handling fs/proc/kcore.c: make get_sparsemem_vmemmap_info() static coredump: add VM_NODUMP, MADV_NODUMP, MADV_CLEAR_NODUMP coredump: remove VM_ALWAYSDUMP flag kmod: make __request_module() killable kmod: introduce call_modprobe() helper usermodehelper: ____call_usermodehelper() doesn't need do_exit() usermodehelper: kill umh_wait, renumber UMH_* constants usermodehelper: implement UMH_KILLABLE usermodehelper: introduce umh_complete(sub_info) usermodehelper: use UMH_WAIT_PROC consistently signal: zap_pid_ns_processes: s/SEND_SIG_NOINFO/SEND_SIG_FORCED/ signal: oom_kill_task: use SEND_SIG_FORCED instead of force_sig() signal: cosmetic, s/from_ancestor_ns/force/ in prepare_signal() paths signal: give SEND_SIG_FORCED more power to beat SIGNAL_UNKILLABLE Hexagon: use set_current_blocked() and block_sigmask() ...
2012-03-23Remove remaining bits of io_remap_page_range()Javi Merino
Commit 33bf56106d9b ("feature removal of io_remap_page_range()") removed io_remap_page_range(), but it is still included in some arch header files. It has no in-tree users. Signed-off-by: Javi Merino <javi.merino@arm.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci Pull PCI changes (including maintainer change) from Jesse Barnes: "This pull has some good cleanups from Bjorn and Yinghai, as well as some more code from Yinghai to better handle resource re-allocation when enabled. There's also a new initcall_debug feature from Arjan which will print out quirk timing information to help identify slow quirks for fixing or refinement (Yinghai sent in a few patches to do just that once the new debug code landed). Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas. He's been a core PCI and Linux contributor for some time now, and has kindly volunteered to take over. I just don't feel I have the time for PCI review and work that it deserves lately (I've taken on some other projects), and haven't been as responsive lately as I'd like, so I approached Bjorn asking if he'd like to manage things. He's going to give it a try, and I'm confident he'll do at least as well as I have in keeping the tree managed, patches flowing, and keeping things stable." Fix up some fairly trivial conflicts due to other cleanups (mips device resource fixup cleanups clashing with list handling cleanup, ppc iseries removal clashing with pci_probe_only cleanup etc) * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits) PCI: Bjorn gets PCI hotplug too PCI: hand PCI maintenance over to Bjorn Helgaas unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h sparc/PCI: convert devtree and arch-probed bus addresses to resource powerpc/PCI: allow reallocation on PA Semi powerpc/PCI: convert devtree bus addresses to resource powerpc/PCI: compute I/O space bus-to-resource offset consistently arm/PCI: don't export pci_flags PCI: fix bridge I/O window bus-to-resource conversion x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()' PCI / PCIe: Introduce command line option to disable ARI PCI: make acpihp use __pci_remove_bus_device instead PCI: export __pci_remove_bus_device PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device PCI: print out PCI device info along with duration PCI: Move "pci reassigndev resource alignment" out of quirks.c PCI: Use class for quirk for usb host controller fixup PCI: Use class for quirk for ti816x class fixup PCI: Use class for quirk for intel e100 interrupt fixup ...
2012-03-23microblaze: Handle TLB skip size dynamicallyMichal Simek
This patch fix the problem with rootfs on JFFS2 with early printk console turned on. The origin version used TLB63 for temporary early printk mapping. The code expect that kernel is not able to use all 64 TLB entries till early printk console is remapped by ioremap. After that temporary mapping on TLB63 is silently lost. This expectation give the opportunity to have early console pretty early. Microblaze systems with JFFS2 rootfs with early printk console turned on used more than 64 TLB entries before kernel can remap early console. Based on that kernel does access to bad area because early printk mapping is rewritten. This patch introduces tlb_skip variable which dynamically stores number of skipped TLB entries from the TLB0. skip_tlb=2 means that TLB0 and TLB1 should be skipped. MICROBLAZE_TLB_SKIP defines how many TLB is skipped at the kernel start. They can be used for user purpose. TLB 63 is used for temporary LMB mapping (MICROBLAZE_LMB_TLB_ID). Also clean TLBLO when kernel starts. For specific kernel sizes kernel can use just one TLB. Detect this case and use the second TLB for general purpose. Change _tlbia function to flush TLB entries from tlb_skip to TLB_SIZE. Export tlb_skip size through debugfs. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-23microblaze: Introduce TLB skip sizeMichal Simek
TLB skip size direct how many TLBs is skipped. Currently TLB0 and TLB1 are used for Linux kernel mapping that's why their are skipped. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-23microblaze: Improve TLB calculation for small systemsMichal Simek
Systems with small amount of memory need to be handled differently. Linux can't allocate the whole 32MB with two TLBs because then there is no MMU protection. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-23microblaze: Extend space for compiled-in FDT to 32kBMichal Simek
2012-03-23microblaze: Clear all MSR flags on the first kernel instructionMichal Simek
The main reason is bug because of dynamic TLB allocation. U-BOOT didn't disable dcache and then writing to physical address from ASM wan't visible for reading through MMU. Disabling caches and clearing all flags from previous code is good to do so. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-23microblaze: Use node name instead of compatible stringMichal Simek
Change report in bootlog: Origin: xlnx,xps-intc-1.00.a #0 at 0xc8000000, num_irq=6, edge=0x4 xlnx,xps-timer-1.00.a #0 at 0xc8004000, irq=2 New: interrupt-controller #0 at 0xc8000000, num_irq=6, edge=0x4 system-timer #0 at 0xc8004000, irq=2 Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-23microblaze: Fix mapin_ram functionMichal Simek
Fix how many pages are allocated in mapin_ram. It is lowmem_size not setup CONFIG_LOWMEM_SIZE because it is the same for all systems. Which means that wrong pages are allocated if memory size is smaller than CONFIG_LOWMEM_SIZE. It has dramatic impact on bootup time. On sp605 MMU full hw design is 7s. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-23microblaze: Highmem supportMichal Simek
The first highmem implementation. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-23microblaze: Use active regionsMichal Simek
Register lowmem active regions. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-23microblaze: Show more detailed information about memoryMichal Simek
Microblaze MMU is similar to ppc that's why ppc layout was reused. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-23microblaze: Introduce fixmapMichal Simek
Fixmap will be used for highmem support. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-23microblaze: mm: Fix lowmem max memory size limitsMichal Simek
Use CONFIG_LOWMEM_SIZE if system has larger ram size. For system with larger ram size, enable HIGMEM support. Also setup limitation for memblock and use memblock allocation in lowmem region. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-23microblaze: mm: Use ZONE_DMA instead of ZONE_NORMALMichal Simek
We should use ZONE_DMA because all address space is dma-able. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-21Merge tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull irq_domain support for all architectures from Grant Likely: "Generialize powerpc's irq_host as irq_domain This branch takes the PowerPC irq_host infrastructure (reverse mapping from Linux IRQ numbers to hardware irq numbering), generalizes it, renames it to irq_domain, and makes it available to all architectures. Originally the plan has been to create an all-new irq_domain implementation which addresses some of the powerpc shortcomings such as not handling 1:1 mappings well, but doing that proved to be far more difficult and invasive than generalizing the working code and refactoring it in-place. So, this branch rips out the 'new' irq_domain and replaces it with the modified powerpc version (in a fully bisectable way of course). It converts all users over to the new API and makes irq_domain selectable on any architecture. No architecture is forced to enable irq_domain, but the infrastructure is required for doing OpenFirmware style irq translations. It will even work on SPARC even though SPARC has it's own mechanism for translating irqs at boot time. MIPS, microblaze, embedded x86 and c6x are converted too. The resulting irq_domain code is probably still too verbose and can be optimized more, but that can be done incrementally and is a task for follow-on patches." * tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6: (31 commits) dt: fix twl4030 for non-dt compile on x86 mfd: twl-core: Add IRQ_DOMAIN dependency devicetree: Add empty of_platform_populate() for !CONFIG_OF_ADDRESS (sparc) irq_domain: Centralize definition of irq_dispose_mapping() irq_domain/mips: Allow irq_domain on MIPS irq_domain/x86: Convert x86 (embedded) to use common irq_domain ppc-6xx: fix build failure in flipper-pic.c and hlwd-pic.c irq_domain/microblaze: Convert microblaze to use irq_domains irq_domain/powerpc: Replace custom xlate functions with library functions irq_domain/powerpc: constify irq_domain_ops irq_domain/c6x: Use library of xlate functions irq_domain/c6x: constify irq_domain structures irq_domain/c6x: Convert c6x to use generic irq_domain support. irq_domain: constify irq_domain_ops irq_domain: Create common xlate functions that device drivers can use irq_domain: Remove irq_domain_add_simple() irq_domain: Remove 'new' irq_domain in favour of the ppc one mfd: twl-core.c: Fix the number of interrupts managed by twl4030 of/address: add empty static inlines for !CONFIG_OF irq_domain: Add support for base irq and hwirq in legacy mappings ...
2012-03-19microblaze: trivial: Fix typo fault in timer.cMichal Simek
2012-03-19microblaze: Use vsprintf extention %pf with builtin_return_addressJoe Perches
Emit the function name not the address when possible. builtin_return_address() gives an address. When building a kernel with CONFIG_KALLSYMS, emit the actual function name not the address. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-19microblaze: Add PVR version string for MB 8.20.b and 8.30.aMichal Simek
Just extend PVR reg decoding. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-19microblaze: Fix makefile to work with latest toolchainMichal Simek
When building with latest binutils, vmlinux includes some sections which need to be stripped out when building the binary image. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-19microblaze: Fix typo in early_printk.cMasanari Iida
Correct spelling "remaping" to "remapping" in arch/microblaze/kernel/early_printk.c Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-03-01sched/rt: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-23PCI: collapse pcibios_resource_to_busBjorn Helgaas
Everybody uses the generic pcibios_resource_to_bus() supplied by the core now, so remove the ARCH_HAS_GENERIC_PCI_OFFSETS used during conversion. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-02-23microblaze/PCI: get rid of device resource fixupsBjorn Helgaas
Tell the PCI core about host bridge address translation so it can take care of bus-to-resource conversion for us. CC: Michal Simek <monstr@monstr.eu> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-02-23microblaze/PCI: remove unused pci_flagsBjorn Helgaas
pci_flags is initialized to zero and never modified (I think this was just copied from powerpc). Therefore, "(pci_flags & XX)" is always false and "!(pci_flags & XX)" is always true, and we can remove all references to pci_flags. CC: Michal Simek <monstr@monstr.eu> CC: microblaze-uclinux@itee.uq.edu.au Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-02-16irq_domain/microblaze: Convert microblaze to use irq_domainsGrant Likely
This patch converts Microblaze to use the irq_domain remapper and get away from hard coding the offset between hwirq number and the linux irq number space. This also paves the way for multiple interrupt controllers. v2: Don't enable SPARSE_IRQ and keep NR_IRQS set to 33 Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Michal Simek <monstr@monstr.eu> Cc: Rob Herring <rob.herring@calxeda.com> Cc: John Williams <john.williams@petalogix.com> Cc: John Linn <john.linn@xilinx.com>
2012-02-14irq_domain: convert microblaze from irq_host to irq_domainGrant Likely
Trivial change, microblaze doesn't use irq remapping yet. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Michal Simek <monstr@monstr.eu> Cc: Thomas Gleixner <tglx@linutronix.de>
2012-01-31Revert "microblaze: Add topology init"Michal Simek
This reverts commit d761f0c521868e59cd0bc59159cbdb4686fe210d. Patch: "cpu: Register a generic CPU device on architectures that currently do not" (sha1: 9f13a1fd452f11c18004ba2422a6384b424ec8a9) selects GENERIC_CPU_DEVICES for Microblaze which register cpu. My patch was done in the same time that's why cpu was registered twice which caused this warning log: ------------[ cut here ]------------ WARNING: at fs/sysfs/dir.c:481 sysfs_add_one+0xb0/0xdc() sysfs: cannot create duplicate filename '/devices/system/cpu/cpu0' Modules linked in: ... Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-01-20microblaze: generic atomic64 supportDaniel Borkmann
This tiny patch adds generic atomic64 support for the Microblaze architecture. The patch is against the latest linux-2.6-microblaze tree. It also fixes the kernel build for microblaze: Error log: CC kernel/trace/trace_clock.o kernel/trace/trace_clock.c:117: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'trace_counter' kernel/trace/trace_clock.c: In function 'trace_clock_counter': kernel/trace/trace_clock.c:126: error: implicit declaration of function 'atomic64_add_return' kernel/trace/trace_clock.c:126: error: 'trace_counter' undeclared (first use in this function) kernel/trace/trace_clock.c:126: error: (Each undeclared identifier is reported only once kernel/trace/trace_clock.c:126: error: for each function it appears in.) make[2]: *** [kernel/trace/trace_clock.o] Error 1 make[1]: *** [kernel/trace] Error 2 make: *** [kernel] Error 2 Signed-off-by: Ariane Keller <ariane.keller@tik.ee.ethz.ch> Signed-off-by: Daniel Borkmann <daniel.borkmann@tik.ee.ethz.ch> Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-01-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit: (29 commits) audit: no leading space in audit_log_d_path prefix audit: treat s_id as an untrusted string audit: fix signedness bug in audit_log_execve_info() audit: comparison on interprocess fields audit: implement all object interfield comparisons audit: allow interfield comparison between gid and ogid audit: complex interfield comparison helper audit: allow interfield comparison in audit rules Kernel: Audit Support For The ARM Platform audit: do not call audit_getname on error audit: only allow tasks to set their loginuid if it is -1 audit: remove task argument to audit_set_loginuid audit: allow audit matching on inode gid audit: allow matching on obj_uid audit: remove audit_finish_fork as it can't be called audit: reject entry,always rules audit: inline audit_free to simplify the look of generic code audit: drop audit_set_macxattr as it doesn't do anything audit: inline checks for not needing to collect aux records audit: drop some potentially inadvisable likely notations ... Use evil merge to fix up grammar mistakes in Kconfig file. Bad speling and horrible grammar (and copious swearing) is to be expected, but let's keep it to commit messages and comments, rather than expose it to users in config help texts or printouts.
2012-01-17audit: inline audit_syscall_entry to reduce burden on archsEric Paris
Every arch calls: if (unlikely(current->audit_context)) audit_syscall_entry() which requires knowledge about audit (the existance of audit_context) in the arch code. Just do it all in static inline in audit.h so that arch's can remain blissfully ignorant. Signed-off-by: Eric Paris <eparis@redhat.com>
