path: root/arch/metag
2013-07-14metag: delete __cpuinit usage from all metag filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. Note that some harmless section mismatch warnings may result, since notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c) are flagged as __cpuinit -- so if we remove the __cpuinit from arch specific callers, we will also get section mismatch warnings. As an intermediate step, we intend to turn the linux/init.h cpuinit content into no-ops as early as possible, since that will get rid of these warnings. In any case, they are temporary and harmless. This removes all the arch/metag uses of the __cpuinit macros from all C files. Currently metag does not have any __CPUINIT used in assembly files. [1] https://lkml.org/lkml/2013/5/20/589 Cc: James Hogan <james.hogan@imgtec.com> Acked-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-07-10Merge tag 'metag-fixes-for-v3.11-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull arch/metag fixes from James Hogan: "This is just a single fix to fix bad UDP checksums sometimes being generated to IP addresses *.*.255.255" * tag 'metag-fixes-for-v3.11-1' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: metag: checksum.h: fix carry in csum_tcpudp_nofold
2013-07-09mm: invoke oom-killer from remaining unconverted page fault handlersJohannes Weiner
A few remaining architectures directly kill the page faulting task in an out of memory situation. This is usually not a good idea since that task might not even use a significant amount of memory and so may not be the optimal victim to resolve the situation. Since 2.6.29's 1c0fe6e ("mm: invoke oom-killer from page fault") there is a hook that architecture page fault handlers are supposed to call to invoke the OOM killer and let it pick the right task to kill. Convert the remaining architectures over to this hook. To have the previous behavior of simply taking out the faulting task the vm.oom_kill_allocating_task sysctl can be set to 1. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc bits] Cc: James Hogan <james.hogan@imgtec.com> Cc: David Howells <dhowells@redhat.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09metag: checksum.h: fix carry in csum_tcpudp_nofoldJames Hogan
In csum_tcpudp_nofold, add 1 if the carry bit is set after adding the destination IP address (32 bits) to the checksum (16 bits). The lack of carry handling for this particular addition meant that a destination address of *.*.255.255 (e.g. certain broadcasts) sometimes resulted in an incorrect checksum. This bug has been present in the Meta port since the code was written in the 2.4 days. Reported-by: Marcin Nowakowski <Marcin.Nowakowski@pure.com> Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-07-06Merge tag 'metag-for-v3.11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull Metag architecture changes from James Hogan: - Infrastructure and DT files for TZ1090 SoC (pin control drivers already merged via pinctrl tree). - Panic on boot instead of just warning if cache aliasing possible. - Various SMP/hotplug fixes. - Various other randconfig/sparse fixes. * tag 'metag-for-v3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: (24 commits) metag: move EXPORT_SYMBOL(csum_partial) to metag_ksyms.c metag: cpu hotplug: route_irq: preserve irq mask metag: kick: add missing irq_enter/exit to kick_handler() metag: smp: don't spin waiting for CPU to start metag: smp: enable irqs after set_cpu_online metag: use clear_tasks_mm_cpumask() metag: tz1090: select and instantiate pinctrl-tz1090-pdc metag: tz1090: select and instantiate pinctrl-tz1090 metag: don't check for cache aliasing on smp cpu boot metag: panic if cache aliasing possible metag: *.dts: include using preprocessor metag: add <dt-bindings/> symlink metag/.gitignore: Extend the *.dtb pattern to match the dtb.S files metag/traps: include setup.h for the per_cpu_trap_init declaration metag/traps: Mark die() as __noreturn to match the declaration. metag/processor.h: Add missing cpuinfo_op declaration. metag/setup: Restrict scope for the capabilities variable metag/mm/cache: Restrict scope for metag_lnkget_probe metag/asm/irq.h: Declare init_IRQ metag/kernel/irq.c: Declare root_domain as static ...
2013-07-04Merge branch 'kconfig-diet' from Dave HansenLinus Torvalds
Merge Kconfig menu diet patches from Dave Hansen: "I think the "Kernel Hacking" menu has gotten a bit out of hand. It is over 120 lines long on my system with everything enabled and options are scattered around it haphazardly. http://sr71.net/~dave/linux/kconfig-horror.png Let's try to introduce some sanity. This set takes that 120 lines down to 55 and makes it vastly easier to find some things. It's a start. This set stands on its own, but there is plenty of room for follow-up patches. The arch-specific debug options still end up getting stuck in the top-level "kernel hacking" menu. OPTIMIZE_INLINING, for instance, could obviously go in to the "compiler options" menu, but the fact that it is defined in arch/ in a separate Kconfig file keeps it on its own for the moment. The Signed-off-by's in here look funky. I changed employers while working on this set, so I have signoffs from both email addresses" * emailed patches from Dave Hansen <dave@sr71.net>: hang and lockup detection menu kconfig: consolidate printk options group locking debugging options consolidate compilation option configs consolidate runtime testing configs order memory debugging Kconfig options consolidate per-arch stack overflow debugging options
2013-07-04consolidate per-arch stack overflow debugging optionsDave Hansen
Original posting: http://lkml.kernel.org/r/20121214184202.F54094D9@kernel.stglabs.ibm.com Several architectures have similar stack debugging config options. They all pretty much do the same thing, some with slightly differing help text. This patch changes the architectures to instead enable a Kconfig boolean, and then use that boolean in the generic Kconfig.debug to present the actual menu option. This removes a bunch of duplication and adds consistency across arches. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [for tile] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-04metag: move EXPORT_SYMBOL(csum_partial) to metag_ksyms.cJames Hogan
Move EXPORT_SYMBOL(csum_partial) from lib/checksum.c into metag_ksyms.c so that it doesn't get omitted by the static linker if it's not used by any other statically linked code, which can result in undefined symbols when building modules. For example a randconfig caused the following error: ERROR: "csum_partial" [fs/reiserfs/reiserfs.ko] undefined! Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-07-03mm/metag: prepare for killing free_all_bootmem_node()Jiang Liu
Prepare for killing free_all_bootmem_node() by using free_all_bootmem(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: James Hogan <james.hogan@imgtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm/metag: prepare for removing num_physpages and simplify mem_init()Jiang Liu
Prepare for removing num_physpages and simplify mem_init(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: concentrate modification of totalram_pages into the mm coreJiang Liu
Concentrate code to modify totalram_pages into the mm core, so the arch memory initialized code doesn't need to take care of it. With these changes applied, only following functions from mm core modify global variable totalram_pages: free_bootmem_late(), free_all_bootmem(), free_all_bootmem_node(), adjust_managed_page_count(). With this patch applied, it will be much more easier for us to keep totalram_pages and zone->managed_pages in consistence. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: David Howells <dhowells@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: accurately calculate zone->managed_pages for highmem zonesJiang Liu
Commit "mm: introduce new field 'managed_pages' to struct zone" assumes that all highmem pages will be freed into the buddy system by function mem_init(). But that's not always true, some architectures may reserve some highmem pages during boot. For example PPC may allocate highmem pages for giagant HugeTLB pages, and several architectures have code to check PageReserved flag to exclude highmem pages allocated during boot when freeing highmem pages into the buddy system. So treat highmem pages in the same way as normal pages, that is to: 1) reset zone->managed_pages to zero in mem_init(). 2) recalculate managed_pages when freeing pages into the buddy system. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Tejun Heo <tj@kernel.org> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan@kernel.org> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: change signature of free_reserved_area() to fix building warningsJiang Liu
Change signature of free_reserved_area() according to Russell King's suggestion to fix following build warnings: arch/arm/mm/init.c: In function 'mem_init': arch/arm/mm/init.c:603:2: warning: passing argument 1 of 'free_reserved_area' makes integer from pointer without a cast [enabled by default] free_reserved_area(__va(PHYS_PFN_OFFSET), swapper_pg_dir, 0, NULL); ^ In file included from include/linux/mman.h:4:0, from arch/arm/mm/init.c:15: include/linux/mm.h:1301:22: note: expected 'long unsigned int' but argument is of type 'void *' extern unsigned long free_reserved_area(unsigned long start, unsigned long end, mm/page_alloc.c: In function 'free_reserved_area': >> mm/page_alloc.c:5134:3: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast [enabled by default] In file included from arch/mips/include/asm/page.h:49:0, from include/linux/mmzone.h:20, from include/linux/gfp.h:4, from include/linux/mm.h:8, from mm/page_alloc.c:18: arch/mips/include/asm/io.h:119:29: note: expected 'const volatile void *' but argument is of type 'long unsigned int' mm/page_alloc.c: In function 'free_area_init_nodes': mm/page_alloc.c:5030:34: warning: array subscript is below array bounds [-Warray-bounds] Also address some minor code review comments. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reported-by: Arnd Bergmann <arnd@arndb.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-02Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Kernel improvements: - watchdog driver improvements by Li Zefan - Power7 CPI stack events related improvements by Sukadev Bhattiprolu - event multiplexing via hrtimers and other improvements by Stephane Eranian - kernel stack use optimization by Andrew Hunter - AMD IOMMU uncore PMU support by Suravee Suthikulpanit - NMI handling rate-limits by Dave Hansen - various hw_breakpoint fixes by Oleg Nesterov - hw_breakpoint overflow period sampling and related signal handling fixes by Jiri Olsa - Intel Haswell PMU support by Andi Kleen Tooling improvements: - Reset SIGTERM handler in workload child process, fix from David Ahern. - Makefile reorganization, prep work for Kconfig patches, from Jiri Olsa. - Add automated make test suite, from Jiri Olsa. - Add --percent-limit option to 'top' and 'report', from Namhyung Kim. - Sorting improvements, from Namhyung Kim. - Expand definition of sysfs format attribute, from Michael Ellerman. Tooling fixes: - 'perf tests' fixes from Jiri Olsa. - Make Power7 CPI stack events available in sysfs, from Sukadev Bhattiprolu. - Handle death by SIGTERM in 'perf record', fix from David Ahern. - Fix printing of perf_event_paranoid message, from David Ahern. - Handle realloc failures in 'perf kvm', from David Ahern. - Fix divide by 0 in variance, from David Ahern. - Save parent pid in thread struct, from David Ahern. - Handle JITed code in shared memory, from Andi Kleen. - Fixes for 'perf diff', from Jiri Olsa. - Remove some unused struct members, from Jiri Olsa. - Add missing liblk.a dependency for python/perf.so, fix from Jiri Olsa. - Respect CROSS_COMPILE in liblk.a, from Rabin Vincent. - No need to do locking when adding hists in perf report, only 'top' needs that, from Namhyung Kim. - Fix alignment of symbol column in in the hists browser (top, report) when -v is given, from NAmhyung Kim. - Fix 'perf top' -E option behavior, from Namhyung Kim. - Fix bug in isupper() and islower(), from Sukadev Bhattiprolu. - Fix compile errors in bp_signal 'perf test', from Sukadev Bhattiprolu. ... and more things" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (102 commits) perf/x86: Disable PEBS-LL in intel_pmu_pebs_disable() perf/x86: Fix shared register mutual exclusion enforcement perf/x86/intel: Support full width counting x86: Add NMI duration tracepoints perf: Drop sample rate when sampling is too slow x86: Warn when NMI handlers take large amounts of time hw_breakpoint: Introduce "struct bp_cpuinfo" hw_breakpoint: Simplify *register_wide_hw_breakpoint() hw_breakpoint: Introduce cpumask_of_bp() hw_breakpoint: Simplify the "weight" usage in toggle_bp_slot() paths hw_breakpoint: Simplify list/idx mess in toggle_bp_slot() paths perf/x86/intel: Add mem-loads/stores support for Haswell perf/x86/intel: Support Haswell/v4 LBR format perf/x86/intel: Move NMI clearing to end of PMI handler perf/x86/intel: Add Haswell PEBS support perf/x86/intel: Add simple Haswell PMU support perf/x86/intel: Add Haswell PEBS record support perf/x86/intel: Fix sparse warning perf/x86/amd: AMD IOMMU Performance Counter PERF uncore PMU implementation perf/x86/amd: Add IOMMU Performance Counter resource management ...
2013-07-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS patches (part 1) from Al Viro: "The major change in this pile is ->readdir() replacement with ->iterate(), dealing with ->f_pos races in ->readdir() instances for good. There's a lot more, but I'd prefer to split the pull request into several stages and this is the first obvious cutoff point." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (67 commits) [readdir] constify ->actor [readdir] ->readdir() is gone [readdir] convert ecryptfs [readdir] convert coda [readdir] convert ocfs2 [readdir] convert fatfs [readdir] convert xfs [readdir] convert btrfs [readdir] convert hostfs [readdir] convert afs [readdir] convert ncpfs [readdir] convert hfsplus [readdir] convert hfs [readdir] convert befs [readdir] convert cifs [readdir] convert freevxfs [readdir] convert fuse [readdir] convert hpfs reiserfs: switch reiserfs_readdir_dentry to inode reiserfs: is_privroot_deh() needs only directory inode, actually ...
2013-07-02metag: cpu hotplug: route_irq: preserve irq maskJames Hogan
The route_irq() function needs to preserve the irq mask by using the _irqsave/irqrestore variants of raw spin lock functions instead of the _irq variants. This is because it is called from __cpu_disable() (via migrate_irqs()), which is called with IRQs disabled, so using the _irq variants re-enables IRQs. This appears to have been causing occasional hits of the BUG_ON(!irqs_disabled()) in __irq_work_run() during CPU hotplug soak testing: BUG: failure at kernel/irq_work.c:122/__irq_work_run()! Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
2013-07-02metag: kick: add missing irq_enter/exit to kick_handler()James Hogan
kick_handler() doesn't have an irq_enter/exit pair, but it's used for handling SMP IPIs which require work to be done in softirqs, which are invoked from irq_exit() when the hard irq nest count reaches 0. The scheduler_ipi() callback in the IPI handler calls irq_enter/exit itself, but this is inside kick_handler()'s spin lock critical section, so if an invoked softirq issues an IPI the kick_handler() will be re-entered on the same CPU and will deadlock. This is easily fixed by adding the missing irq_enter/exit to kick_handler() so that the hard irq nest count doesn't reach 0 until after the spin lock has been released. Ideally the spin lock protected handler list will also be replaced by a lockless RCU protected list since it is certainly mostly read. That can be done in a later change though. Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2013-07-02metag: smp: don't spin waiting for CPU to startJames Hogan
Use a completion to block until a secondary CPU has started up, like ARM do, instead of a loop of udelays. On Meta, SMP is really SMT, with each "CPU" being a different hardware thread on the same Meta processor core, so as well as being more efficient and latency friendly, using a completion prevents the bogomips of the secondary CPU from being drastically skewed every time by the execution of the tight in-cache udelay loop on the other CPU. Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
2013-07-02metag: smp: enable irqs after set_cpu_onlineJames Hogan
In secondary_start_kernel() interrupts should be enabled with local_irq_enable() after the cpu is marked as online with set_cpu_online(). Otherwise it's possible for a timer interrupt to trigger a softirq, which if the cpu is marked as offline may have it's affinity altered. Reported-by: Kirill Tkhai <tkhai@yandex.ru> Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com> Cc: Kirill Tkhai <tkhai@yandex.ru>
2013-07-02metag: use clear_tasks_mm_cpumask()James Hogan
Checking for process->mm is not enough because process' main thread may exit or detach its mm via use_mm(), but other threads may still have a valid mm. To fix this we would need to use find_lock_task_mm(), which would walk up all threads and returns an appropriate task (with task lock held). clear_tasks_mm_cpumask() was introduced in v3.5-rc1 to fix this issue, so let's use it for metag too. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Anton Vorontsov <anton.vorontsov@linaro.org>
2013-06-29consolidate io_remap_pfn_range definitionsAl Viro
2013-06-27metag: tz1090: select and instantiate pinctrl-tz1090-pdcJames Hogan
Select PINCTRL_TZ1090_PDC from SOC_TZ1090 to enable the PDC pin controller driver once it is merged, and instantiate it from tz1090.dtsi. Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Grant Likely <grant.likely@linaro.org>
2013-06-27metag: tz1090: select and instantiate pinctrl-tz1090James Hogan
Select PINCTRL and PINCTRL_TZ1090 from SOC_TZ1090 to enable the main pin controller driver once it is merged, and instantiate it from tz1090.dtsi. Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Grant Likely <grant.likely@linaro.org>
2013-06-27metag: don't check for cache aliasing on smp cpu bootJames Hogan
The cache configuration of the boot cpu is now duplicated to secondary cpus, so there's no need to check for cache aliasing again when a secondary cpu is booted. Therefore remove the check from secondary_start_kernel(). Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-06-27metag: panic if cache aliasing possibleJames Hogan
If the cache and page size configuration allows for cache aliasing to occur we warn on boot, but the log messages are easy to miss and will result is random crashes occuring in userland. Let's panic too in this case so that the user immediately knows they need to fix the cache configuration or configured page size. Also fix the warning messages which display the cache and page sizes to include newlines, and add the word "Potential" since an actual cache alias hasn't been detected. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-06-27metag: *.dts: include using preprocessorJames Hogan
Include *.dtsi files from *.dts using the preprocessor to set a good example for future device tree files. Files included in the old way don't get pre-processed. Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Grant Likely <grant.likely@linaro.org> Cc: devicetree-discuss@lists.ozlabs.org
2013-06-27metag: add <dt-bindings/> symlinkJames Hogan
Add symlink to include/dt-bindings from arch/metag/boot/dts/include/ to match the one in arch/arm/... (see the commit below) so that preprocessed device tree files can include various useful constant definitions. Commit c58299aa87544a590c62bda0bf52b69fa56cb8d5 ("kbuild: create an "include chroot" for DT bindings") merged in v3.10-rc1. Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Grant Likely <grant.likely@linaro.org> Reviewed-by: Stephen Warren <swarren@nvidia.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: linux-kbuild@vger.kernel.org Cc: devicetree-discuss@lists.ozlabs.org
2013-06-19metag: fix mm/hugetlb.c build breakageJames Hogan
Commit 106c992a5ebe ("mm/hugetlb: add more arch-defined huge_pte functions") added an include of <asm-generic/hugetlb.h> to each architecture's <asm/hugetlb.h> (except s390). Unfortunately metag was missed which resulted in build errors when hugetlbfs is enabled (see below). Add the include for metag too to fix the build errors: mm/hugetlb.c In function 'make_huge_pte': mm/hugetlb.c +2250 : error: implicit declaration of function 'huge_pte_mkwrite' mm/hugetlb.c +2250 : error: implicit declaration of function 'huge_pte_mkdirty' ... Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-19perf: Add const qualifier to perf_pmu_register's 'name' argMischa Jonker
This allows us to use pdev->name for registering a PMU device. IMO the name is not supposed to be changed anyway. Signed-off-by: Mischa Jonker <mjonker@synopsys.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1370339148-5566-1-git-send-email-mjonker@synopsys.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-13metag/.gitignore: Extend the *.dtb pattern to match the dtb.S filesMarkos Chandras
The .SECONDARY rule for generating the *.dtb.S files added in 0b4184c26b18ecbc0ec0657f514b087c3a6216fb "metag: avoid unnecessary builtin dtb rebuilds" Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-06-13metag/traps: include setup.h for the per_cpu_trap_init declarationMarkos Chandras
2013-06-13metag/traps: Mark die() as __noreturn to match the declaration.Markos Chandras
2013-06-13metag/processor.h: Add missing cpuinfo_op declaration.Markos Chandras
2013-06-13metag/setup: Restrict scope for the capabilities variableMarkos Chandras
2013-06-13metag/mm/cache: Restrict scope for metag_lnkget_probeMarkos Chandras
Hide symbol since it's only used within the cache.c file Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-06-13metag/asm/irq.h: Declare init_IRQMarkos Chandras
Fixes the following sparce warning: warning: symbol 'init_IRQ' was not declared. Should it be static? Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-06-13metag/kernel/irq.c: Declare root_domain as staticMarkos Chandras
It is only referenced within the irq.c file, so restrict it's scope as appropriate. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-06-13metag: log core and timer frequencies from arch codeJames Hogan
Log core clock and Meta timer frequencies during init in architecture generic code, removing the need for equivalent log messages in SoC specific code. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2013-06-13metag: init common clk and use "core" clkJames Hogan
If the common clock framework is enabled, call of_clk_init(NULL) in time_init() to register device tree clocks with the clock framework. After this time_init() calls a new function init_metag_clocks(), which looks for a clock named "core" in the node compatible with "img,meta" (usually the root node). If found the get_core_freq machine callback is overridden to obtain the core clock frequency using that clock. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Mike Turquette <mturquette@linaro.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: devicetree-discuss@lists.ozlabs.org
2013-06-13metag: minimal TZ1090 (Comet) SoC infrastructureJames Hogan
Add really minimal support for Toumaz Xenif TZ1090 SoC (A.K.A. Comet). This consists of minimal build infrastructure, device tree files, and a defconfig based on meta2_defconfig. This SoC contains a 2-threaded HTP (Meta 2) as the main application processor, and is found in a number of development boards and digital radios, such as the Minimorph Development Platform. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Rob Landley <rob@landley.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: linux-doc@vger.kernel.org Cc: devicetree-discuss@lists.ozlabs.org
2013-06-13metag: of_platform_populate from arch generic codeJames Hogan
If no init_machine callback is provided, call of_platform_populate() instead. This allows a board/SoC that only needs to call of_platform_populate to omit the callback altogether. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: devicetree-discuss@lists.ozlabs.org
2013-05-09Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull removal of GENERIC_GPIO from Grant Likely: "GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it is possible to do so which has been causing confusion and breakage. This branch does the work to completely eliminate GENERIC_GPIO." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux: gpio: update gpio Chinese documentation Remove GENERIC_GPIO config option Convert selectors of GENERIC_GPIO to GPIOLIB blackfin: force use of gpiolib m68k: coldfire: use gpiolib mips: pnx833x: remove requirement for GENERIC_GPIO openrisc: default GENERIC_GPIO to false avr32: default GENERIC_GPIO to false xtensa: remove explicit selection of GENERIC_GPIO sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB powerpc: remove redundant GENERIC_GPIO selection unicore32: default GENERIC_GPIO to false unicore32: remove unneeded select GENERIC_GPIO arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB arm: remove redundant GENERIC_GPIO selection mips: alchemy: require gpiolib mips: txx9: change GENERIC_GPIO to GPIOLIB mips: loongson: use GPIO driver on CONFIG_GPIOLIB mips: remove redundant GENERIC_GPIO select
2013-05-05Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull mudule updates from Rusty Russell: "We get rid of the general module prefix confusion with a binary config option, fix a remove/insert race which Never Happens, and (my favorite) handle the case when we have too many modules for a single commandline. Seriously, the kernel is full, please go away!" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modpost: fix unwanted VMLINUX_SYMBOL_STR expansion X.509: Support parse long form of length octets in Authority Key Identifier module: don't unlink the module until we've removed all exposure. kernel: kallsyms: memory override issue, need check destination buffer length MODSIGN: do not send garbage to stderr when enabling modules signature modpost: handle huge numbers of modules. modpost: add -T option to read module names from file/stdin. modpost: minor cleanup. genksyms: pass symbol-prefix instead of arch module: fix symbol versioning with symbol prefixes CONFIG_SYMBOL_PREFIX: cleanup.
2013-05-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc update from Benjamin Herrenschmidt: "The main highlights this time around are: - A pile of addition POWER8 bits and nits, such as updated performance counter support (Michael Ellerman), new branch history buffer support (Anshuman Khandual), base support for the new PCI host bridge when not using the hypervisor (Gavin Shan) and other random related bits and fixes from various contributors. - Some rework of our page table format by Aneesh Kumar which fixes a thing or two and paves the way for THP support. THP itself will not make it this time around however. - More Freescale updates, including Altivec support on the new e6500 cores, new PCI controller support, and a pile of new boards support and updates. - The usual batch of trivial cleanups & fixes" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits) powerpc: Fix build error for book3e powerpc: Context switch the new EBB SPRs powerpc: Turn on the EBB H/FSCR bits powerpc: Replace CPU_FTR_BCTAR with CPU_FTR_ARCH_207S powerpc: Setup BHRB instructions facility in HFSCR for POWER8 powerpc: Fix interrupt range check on debug exception powerpc: Update tlbie/tlbiel as per ISA doc powerpc: Print page size info during boot powerpc: print both base and actual page size on hash failure powerpc: Fix hpte_decode to use the correct decoding for page sizes powerpc: Decode the pte-lp-encoding bits correctly. powerpc: Use encode avpn where we need only avpn values powerpc: Reduce PTE table memory wastage powerpc: Move the pte free routines from common header powerpc: Reduce the PTE_INDEX_SIZE powerpc: Switch 16GB and 16MB explicit hugepages to a different page table format powerpc: New hugepage directory format powerpc: Don't truncate pgd_index wrongly powerpc: Don't hard code the size of pte page powerpc: Save DAR and DSISR in pt_regs on MCE ...
2013-04-30dump_stack: unify debug information printed by show_regs()Tejun Heo
show_regs() is inherently arch-dependent but it does make sense to print generic debug information and some archs already do albeit in slightly different forms. This patch introduces a generic function to print debug information from show_regs() so that different archs print out the same information and it's much easier to modify what's printed. show_regs_print_info() prints out the same debug info as dump_stack() does plus task and thread_info pointers. * Archs which didn't print debug info now do. alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r, metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc, um, xtensa * Already prints debug info. Replaced with show_regs_print_info(). The printed information is superset of what used to be there. arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86 * s390 is special in that it used to print arch-specific information along with generic debug info. Heiko and Martin think that the arch-specific extra isn't worth keeping s390 specfic implementation. Converted to use the generic version. Note that now all archs print the debug info before actual register dumps. An example BUG() dump follows. kernel BUG at /work/os/work/kernel/workqueue.c:4841! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000 RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6 RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246 RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650 0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760 Call Trace: [<ffffffff81000312>] do_one_initcall+0x122/0x170 [<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8 [<ffffffff81c47760>] ? rest_init+0x140/0x140 [<ffffffff81c4776e>] kernel_init+0xe/0xf0 [<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0 [<ffffffff81c47760>] ? rest_init+0x140/0x140 ... v2: Typo fix in x86-32. v3: CPU number dropped from show_regs_print_info() as dump_stack_print_info() has been updated to print it. s390 specific implementation dropped as requested by s390 maintainers. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30dump_stack: consolidate dump_stack() implementations and unify their behaviorsTejun Heo
Both dump_stack() and show_stack() are currently implemented by each architecture. show_stack(NULL, NULL) dumps the backtrace for the current task as does dump_stack(). On some archs, dump_stack() prints extra information - pid, utsname and so on - in addition to the backtrace while the two are identical on other archs. The usages in arch-independent code of the two functions indicate show_stack(NULL, NULL) should print out bare backtrace while dump_stack() is used for debugging purposes when something went wrong, so it does make sense to print additional information on the task which triggered dump_stack(). There's no reason to require archs to implement two separate but mostly identical functions. It leads to unnecessary subtle information. This patch expands the dummy fallback dump_stack() implementation in lib/dump_stack.c such that it prints out debug information (taken from x86) and invokes show_stack(NULL, NULL) and drops arch-specific dump_stack() implementations in all archs except blackfin. Blackfin's dump_stack() does something wonky that I don't understand. Debug information can be printed separately by calling dump_stack_print_info() so that arch-specific dump_stack() implementation can still emit the same debug information. This is used in blackfin. This patch brings the following behavior changes. * On some archs, an extra level in backtrace for show_stack() could be printed. This is because the top frame was determined in dump_stack() on those archs while generic dump_stack() can't do that reliably. It can be compensated by inlining dump_stack() but not sure whether that'd be necessary. * Most archs didn't use to print debug info on dump_stack(). They do now. An example WARN dump follows. WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505() Hardware name: empty Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9 0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48 ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c 0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58 Call Trace: [<ffffffff81c614dc>] dump_stack+0x19/0x1b [<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20 [<ffffffff8234a071>] init_workqueues+0x35/0x505 ... v2: CPU number added to the generic debug info as requested by s390 folks and dropped the s390 specific dump_stack(). This loses %ksp from the debug message which the maintainers think isn't important enough to keep the s390-specific dump_stack() implementation. dump_stack_print_info() is moved to kernel/printk.c from lib/dump_stack.c. Because linkage is per objecct file, dump_stack_print_info() living in the same lib file as generic dump_stack() means that archs which implement custom dump_stack() - at this point, only blackfin - can't use dump_stack_print_info() as that will bring in the generic version of dump_stack() too. v1 The v1 patch broke build on blackfin due to this issue. The build breakage was reported by Fengguang Wu. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits] Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge tag 'metag-for-v3.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull arch/metag update from James Hogan: - Various fixes for the interrupting perf counter handling in metag's perf backend. - Add OProfile support based on perf. - Sets up cache partitions for SMP so bootloader doesn't have to. - Patch from Paul Bolle to remove ARCH_POPULATES_NODE_MAP again (touches microblaze too). - Add TLS pointer regset to metag ptrace api. - Add exported metag DSP extended context handling header <asm/ech.h>. - Increase defconfig log buffer size to 128KiB. - Various fixes, typos, missing exports. * tag 'metag-for-v3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: metag: defconfigs: increase log buffer 8KiB => 128KiB metag: avoid unnecessary builtin dtb rebuilds metag: add exported <asm/ech.h> for extended context handling metag: export _metag_da_present and cpu_2_hwthread_id metag: ptrace: Implement NT_METAG_TLS memblock: Kill ARCH_POPULATES_NODE_MAP once more metag: cachepart: fix get_global_dcache_size() typo metag: cachepart: take into account small cache bits metag: smp: copy cache partition and enable GCOn metag: OProfile support metag: perf: prepare for use by oprofile metag: perf: don't reset TXTACTCYC metag: perf: use hard_processor_id() to get thread metag: perf: fix frequency sampling (dynamic period) metag: perf: add missing prev_count updates metag: perf: fixes for interrupting perf counters metag: perf: fix wrap handling in delta calculation metag: perf: fix core internal / perf channel mux
2013-04-30Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull SMP/hotplug changes from Ingo Molnar: "This is a pretty large, multi-arch series unifying and generalizing the various disjunct pieces of idle routines that architectures have historically copied from each other and have grown in random, wildly inconsistent and sometimes buggy directions: 101 files changed, 455 insertions(+), 1328 deletions(-) this went through a number of review and test iterations before it was committed, it was tested on various architectures, was exposed to linux-next for quite some time - nevertheless it might cause problems on architectures that don't read the mailing lists and don't regularly test linux-next. This cat herding excercise was motivated by the -rt kernel, and was brought to you by Thomas "the Whip" Gleixner." * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) idle: Remove GENERIC_IDLE_LOOP config switch um: Use generic idle loop ia64: Make sure interrupts enabled when we "safe_halt()" sparc: Use generic idle loop idle: Remove unused ARCH_HAS_DEFAULT_IDLE bfin: Fix typo in arch_cpu_idle() xtensa: Use generic idle loop x86: Use generic idle loop unicore: Use generic idle loop tile: Use generic idle loop tile: Enter idle with preemption disabled sh: Use generic idle loop score: Use generic idle loop s390: Use generic idle loop powerpc: Use generic idle loop parisc: Use generic idle loop openrisc: Use generic idle loop mn10300: Use generic idle loop mips: Use generic idle loop microblaze: Use generic idle loop ...
2013-04-29mm/metag: use free_highmem_page() to free highmem pages into buddy systemJiang Liu
Use helper function free_highmem_page() to free highmem pages into the buddy system. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: James Hogan <james.hogan@imgtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm/metag: use common help functions to free reserved pagesJiang Liu
Use common help functions to free reserved pages. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: James Hogan <james.hogan@imgtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
