path: root/arch/m68knommu/platform/5307
2011-03-25m68k: merge m68k and m68knommu arch directoriesGreg Ungerer
There is a lot of common code that could be shared between the m68k and m68knommu arch branches. It makes sense to merge the two branches into a single directory structure so that we can more easily share that common code. This is a brute force merge, based on a script from Stephen King <sfking@fdwdc.com>, which was originally written by Arnd Bergmann <arnd@arndb.de>. > The script was inspired by the script Sam Ravnborg used to merge the > includes from m68knommu. For those files common to both arches but > differing in content, the m68k version of the file is renamed to > <file>_mm.<ext> and the m68knommu version of the file is moved into the > corresponding m68k directory and renamed <file>_no.<ext> and a small > wrapper file <file>.<ext> is used to select between the two version. Files > that are common to both but don't differ are removed from the m68knommu > tree and files and directories that are unique to the m68knommu tree are > moved to the m68k tree. Finally, the arch/m68knommu tree is removed. > > To select between the the versions of the files, the wrapper uses > > #ifdef CONFIG_MMU > #include <file>_mm.<ext> > #else > #include <file>_no.<ext> > #endif On top of this file merge I have done a simplistic merge of m68k and m68knommu Kconfig, which primarily attempts to keep existing options and menus in place. Other than a handful of options being moved it produces identical .config outputs on m68k and m68knommu targets I tested it on. With this in place there is now quite a bit of scope for merge cleanups in future patches. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-03-15m68knommu: fix gpio warnings for ColdFire 5307 targetsGreg Ungerer
Fix these compiler warnings: arch/m68knommu/platform/5307/gpio.c:35:3: warning: initialisation makes pointer from integer without a cast arch/m68knommu/platform/5307/gpio.c:36:3: warning: initialisation makes pointer from integer without a cast arch/m68knommu/platform/5307/gpio.c:37:3: warning: initialisation makes pointer from integer without a cast Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2010-10-21m68knommu: change to new flag variablesmatt mooney
Replace EXTRA_CFLAGS with ccflags-y and EXTRA_AFLAGS with asflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2010-05-24m68knommu: add smc91x support for ColdFire NETtel boardsGreg Ungerer
The ColdFire based NETtel boards use the SMC9196 ethernet devices. Switch to using a platform setup for these parts using the smc91x driver. The init code is taken strait out of arch/m68k/include/asm/mcfsmc.h, just cleaned up a bit. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: map ColdFire interrupts to correct masking bitsGreg Ungerer
The older simple ColdFire interrupt controller has no one-to-one mapping of interrupt numbers to bits in the interrupt mask register. Create a mapping array that each ColdFire CPU type can populate with its available interrupts and the bits that each use in the interrupt mask register. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: simplify ColdFire "timers" clock initializationGreg Ungerer
The ColdFire "timers" clock setup can be simplified. There is really no need for the flexible per-platform setup code. The clock interrupt can be hard defined per CPU platform (in CPU include files). This makes the actual timer code simpler. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: merge old ColdFire interrupt controller masking macrosGreg Ungerer
Currently the code that supports setting the old style ColdFire interrupt controller mask registers is macros in the include files of each of the CPU types. Merge all these into a set of real masking functions in the old Coldfire interrupt controller code proper. All the macros are basically the same (excepting a register size difference on really early parts). Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: remove duplicate ColdFire mcf_autovector() codeGreg Ungerer
Each of the ColdFire CPU platform code that used the old style interrupt controller had its own copy of the mcf_autovector() function. They are all the same, remove them all and create a single function in the common coldfire/intc.c code. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-10generic GPIO support for the Freescale Coldfire 5307.sfking@fdwdc.com
Add support for the 5307. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-06-11m68knommu: add CPU reset code for the 5307 ColdFireGreg Ungerer
2009-03-24m68knommu: fix 5307 ColdFire UART vector setupGreg Ungerer
There is a couple of problems with the UART vector setup for the 5307 ColdFire UART. The ICR register access should be 8bit, not 32bit. The address of the UIVR register is wrong, it needs to be offset into the MBAR register region. Fix these. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-01-27m68knommu: remove obsolete and unused eLIA boardAdrian Bunk
Greg Ungerer said about this board: Only ever a handful where made, and that was in 1999. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2008-05-01m68knommu: remove unused CONFIG_DISKtelGreg Ungerer
Remove unused CONFIG_DISKtel support. Missing config definition pointed out by Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14m68knommu: use asflags instead of EXTRA_AFLAGSGreg Ungerer
Modify the extra asm flags for debugger capabilities, use asflags instead for EXTRA_AFLAGS. Suggestion from Sam Ravnborg. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: remove dead timer int pending codeGreg Ungerer
Remove all the dead timer interrupt checking functions for the ColdFire CPU "timers" hardware that are not used after switching to GENERIC_TIME. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: modify Makefiles to support common coldfire directoryGreg Ungerer
Modify Makefiles to support separate coldfire platform directory. Currently the common ColdFire CPU family code sits in the arch/m68knommu/platform/5307 directory. This is confusing, the files containing this common code are in no way specific to the 5307 ColdFire. Create an arch/m68knommu/platform/coldfire directory to contain this common code. Other m68knommu CPU varients do not need use this code though, so it doesn't make sense to move it to arch/m68knommu/kernel. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: move ColdFire vectors.c to its own coldfire directoryGreg Ungerer
Move common ColdFire CPU vectors.c to common coldfire platform directory. Currently the common ColdFire CPU family code sits in the arch/m68knommu/platform/5307 directory. This is confusing, the files containing this common code are in no way specific to the 5307 ColdFire. Create an arch/m68knommu/platform/coldfire directory to contain this common code. Other m68knommu CPU varients do not need use this code though, so it doesn't make sense to move it to arch/m68knommu/kernel. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: move ColdFire timers.c to its own coldfire directoryGreg Ungerer
Move common ColdFire CPU timers.c to common coldfire platform directory. Currently the common ColdFire CPU family code sits in the arch/m68knommu/platform/5307 directory. This is confusing, the files containing this common code are in no way specific to the 5307 ColdFire. Create an arch/m68knommu/platform/coldfire directory to contain this common code. Other m68knommu CPU varients do not need use this code though, so it doesn't make sense to move it to arch/m68knommu/kernel. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: move ColdFire pit.c to its own coldfire directoryGreg Ungerer
Move common ColdFire CPU pit.c to common coldfire platform directory. Currently the common ColdFire CPU family code sits in the arch/m68knommu/platform/5307 directory. This is confusing, the files containing this common code are in no way specific to the 5307 ColdFire. Create an arch/m68knommu/platform/coldfire directory to contain this common code. Other m68knommu CPU varients do not need use this code though, so it doesn't make sense to move it to arch/m68knommu/kernel. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: move ColdFire head.S to its own coldfire directoryGreg Ungerer
Move common ColdFire CPU head.S to common coldfire platform directory. Currently the common ColdFire CPU family code sits in the arch/m68knommu/platform/5307 directory. This is confusing, the files containing this common code are in no way specific to the 5307 ColdFire. Create an arch/m68knommu/platform/coldfire directory to contain this common code. Other m68knommu CPU varients do not need use this code though, so it doesn't make sense to move it to arch/m68knommu/kernel. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: move ColdFire entry.S to its own coldfire directoryGreg Ungerer
Move common ColdFire CPU entry.S to common coldfire platform directory. Currently the common ColdFire CPU family code sits in the arch/m68knommu/platform/5307 directory. This is confusing, the files containing this common code are in no way specific to the 5307 ColdFire. Create an arch/m68knommu/platform/coldfire directory to contain this common code. Other m68knommu CPU varients do not need use this code though, so it doesn't make sense to move it to arch/m68knommu/kernel. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01m68knommu: platform setup for 5307 ColdFire partsGreg Ungerer
Switch to platform style configuration for 5307 ColdFire parts. Initial support is for the UARTs. DMA support moved to common code for all ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23m68knommu: cleanup m68knommu timer codeGreg Ungerer
Reduce the function pointer mess of the m68knommu timer code by calling directly to the local hardware's timer setup, and expose the local common timer interrupt handler to the lower level hardware timer. Ultimately this will save definitions of all these functions across all the platform code to setup the function pointers (which for any given m68knommu CPU family member can be only one set of hardware timer functions). Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23m68knommu: fix syscall tracingMatt Waddel
Fix the system call code for handling syscall tracing, so strace and gdbserver work properly. This fix originally developed by Philippe De Muyter and Stuart Hughes. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-15kbuild: fix AFLAGS use in h8300 and m68knommuSam Ravnborg
In most cases when AFALGS is manipuled direct this is a bug and EXTRA_AFLAGS should have been used. Fix the obvious candidates. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
2007-07-26m68knommu: use setup_irq() in ColdFire PIT timerGreg Ungerer
Use setup_irq() instead of request_irq() to set up system timer in ColdFire PIT timer code. With the old m68knommu irq code this was safe, but it is not now within the generic irq framework. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26m68knommu: use setup_irq() in ColdFire simple timerGreg Ungerer
Use setup_irq() instead of request_irq() to set up system timer in ColdFire simple timer code. With the old m68knommu irq code this was safe, but it is not now within the generic irq framework. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26m68knommu: remove use of colfire_trap_initGreg Ungerer
The switch to using the generic irq framework removed the coldfire_trap_init() code, so remove all references to it. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-25m68knommu: make BOOTPARAM setup commonGreg Ungerer
Currently most of the m68knommu cpu/board setup files are handling the setup of fixed boot parameters (via CONFIG_BOOTPARAM) themselves. Move all this into the common setup code. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-25m68knommu: simplify ColdFire resume codeGreg Ungerer
It is useless to preserve THREAD_SR in `resume'. The real user's sr is actually in the stack. We also don't need to disable interrupts : we'll never be in an invalid state, the sp switch is atomic. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19m68knommu: generic irq handlingGreg Ungerer
Change the m68knommu irq handling to use the generic irq framework. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08m68knommu: fix ColdFire timer off by 1Greg Ungerer
The coldfire timer runs from 0 to TRR included, then 0 again and so on. It counts thus actually TRR + 1 steps for 1 tick, not TRR. Fix that. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-06[PATCH] m68knommu: remove local_bh_countGreg Ungerer
Remove un-used/un-referenced local_bh_count. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-19[PATCH] Declare init_irq_proc before we use it.Andrew Morton
powerpc gets: init/main.c: In function `do_basic_setup': init/main.c:714: warning: implicit declaration of function `init_irq_proc' but we cannot include linux/irq.h in generic code. Fix it by moving the declaration into linux/interrupt.h instead. And make sure all code that defines init_irq_proc() is including linux/interrupt.h. And nuke an ifdef-in-C Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-17Various typo fixes.Robert P. J. Day
Correct mis-spellings of "algorithm", "appear", "consistent" and (shame, shame) "kernel". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-09[PATCH] m68knommu: use irq_handler_t for passing handler typesGreg Ungerer
Use irq_handler_t for passing clock handler routine around. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[PATCH] m68knommu: use irq_handler_t passing handler to clock initGreg Ungerer
Use irq_handler_t for passing interrupt handler around. Fix optional profiler handler to return a irq_return_t type. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[PATCH] m68knommu: use irq_handler_t passing handler to PIT initGreg Ungerer
Use irq_handler_t type for passing timer handler to timer init code. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-06[PATCH] m68knommu: fix timer register access on 523x ColdFire platformsGreg Ungerer
The 523x timer TRR register is a full 32bits, the older register (on other ColdFire parts) was only 16 bits. Use the right type of __raw_read when accessing it. Problem found by Yaroslav Vinogradov <yaroslav.vinogradov@freescale.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] m68knommu: auto detect memory size on M5208EVB boardMichael Broughton
Here is a small patch to automatically detect the DRAM size on m520x. It was generated against 2.6.17-uc0, and tested on an Intec 5208 dev board. Signed-off-by: Michael Broughton <mbobowik@telusplanet.net> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-20[PATCH] m68knommu: fix up for the irq_handler_t changesGreg Ungerer
Switch to using irq_handler_t for interrupt function handler pointers. Change name of m68knommu's irq_hanlder_t data structure so it doesn't clash with the common type (include/linux/interrupt.h). Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: M68KNOMMU: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] m68knommu: use configurable RAM setup in start up codeGreg Ungerer
Change to using a configurable RAM setup in startup code. This cleans up the whole RAM base/sizing issue, and removes a lot of board specific code. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: improve syscall entry and fix stracePhilippe De Muyter
Here is a patch to the system call handling for 5307/5272/etc to: - fix the strace support (one tested the wrong bit) - make all system calls a little bit faster by inlining set_esp0 and supporting ENOSYS out of the critical path. - remove extraneous spaces Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: add ColdFire 532x timer build supportGreg Ungerer
Add build support for new Freescale M532x CPU family timer. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: read/write register access for PIT timerGreg Ungerer
Modify the m68knommu/ColdFire PIT timer code to use register offsets with raw_read/raw_write access, instead of a mapped struct. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: read/write register access for ColdFire core timerGreg Ungerer
Modify the m68knommu/ColdFire core timer code to use register offsets with raw_read/raw_write access, instead of a mapped struct. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] m68knommu: move some platform irq support out of irq.hGreg Ungerer
Move some of the m68knommu platform specific irq core support to its own header, irqnode.h. Having it in asm-m68knommu/irq.h causes some build pain, since it is included in a number of common code places (and not all the required definitions will be included at these places). Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
