path: root/arch/m68knommu/kernel
2006-01-12[PATCH] m68knommu: task_stack_page()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] m68knommu: fix ram length of m5208evb boardGreg Ungerer
Adjust length of M5208EVB ram define. It should size up to 32MB after adding in the dBUG reserved 128k. Problem pointed out be Milton Miller <miltonm@bga.com>. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] m68knommu: fix a5 reg corruption in signal handlersGreg Ungerer
This is a patch adapted from a posting by Andrea Tarani which was pointed out to me by Bernardo Innocenti. Thanks to both of them for their help and patience. The original posting is here: http://mailman.uclinux.org/pipermail/uclinux-dev/2005-July/033543.html The problem first manifest itself as busybox ping terminating with an "Illegal instruction". I reduced this to a test case and found that variable size arrays allocated on the stack could lead to stacks not aligned on 32 bit boundaries. For the Coldfire this proved fatal. Having been pointed out this patch by Bernardo, I applied it and it fixed the first test case. I then went back to busybox's ping. This still failed with "Illegal instruction", but in a different way. Before it depended on the size allocated for the ping buffer, now it happened every time. I also found it depended on optimisation level (gcc-3.4.0) -Os was okay but not -O2. After a lot of looking, it turned out that register a5 was being corrupted by the signal handler (after applying the patch). I re-worked the patch a bit to save/restore a5 and now all seems well. Patch submitted by Stuart Hughs <stuarth@freescale.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] m68knommu: fix mangled 'truct' in ptrace.cGreg Ungerer
Fix broken "truct" -> "struct" in arch_ptrace() parameter list. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] dump_thread() cleanupakpm@osdl.org
) From: Adrian Bunk <bunk@stusta.de> - create one common dump_thread() prototype in kernel.h - dump_thread() is only used in fs/binfmt_aout.c and can therefore be removed on all architectures where CONFIG_BINFMT_AOUT is not available Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m68knommu: enable_irq/disable_irqChristoph Hellwig
mach_enable_irq/mach_disable_irq are never actually set, so let's remove them. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] m68knommu: move some platform irq support out of irq.hGreg Ungerer
Move some of the m68knommu platform specific irq core support to its own header, irqnode.h. Having it in asm-m68knommu/irq.h causes some build pain, since it is included in a number of common code places (and not all the required definitions will be included at these places). Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] m68knommu: align param section and add 5208EVB linker supportGreg Ungerer
Align the param section. It can end up starting on an unalingned boundary depending on the size of ksymtab_strings. If it is unaligned things like modules will fail to load with unaligned access traps. Add linker scipt support for the M5208EVB board. Patch originally from Matt Waddel. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] m68knommu: add ColdFire 5208 setup supportGreg Ungerer
Add setup support for the new Freescale 5208 ColdFire processor. (Also fixed a little typo in there, "UNKOWN" -> "UNKNOWN"). Patch originally from Matt Waddel (from code originally written by Mike Lavender). Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] consolidate sys_ptrace()Christoph Hellwig
The sys_ptrace boilerplate code (everything outside the big switch statement for the arch-specific requests) is shared by most architectures. This patch moves it to kernel/ptrace.c and leaves the arch-specific code as arch_ptrace. Some architectures have a too different ptrace so we have to exclude them. They continue to keep their implementations. For sh64 I had to add a sh64_ptrace wrapper because it does some initialization on the first call. For um I removed an ifdefed SUBARCH_PTRACE_SPECIAL block, but SUBARCH_PTRACE_SPECIAL isn't defined anywhere in the tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] jiffies_64 cleanupThomas Gleixner
Define jiffies_64 in kernel/timer.c rather than having 24 duplicated defines in each architecture. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] unify sys_ptrace prototypeChristoph Hellwig
Make sure we always return, as all syscalls should. Also move the common prototype to <linux/syscalls.h> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] NTP: ntp-helper functionsjohn stultz
This patch cleans up a commonly repeated set of changes to the NTP state variables by adding two helper inline functions: ntp_clear(): Clears the ntp state variables ntp_synced(): Returns 1 if the system is synced with a time server. This was compile tested for alpha, arm, i386, x86-64, ppc64, s390, sparc, sparc64. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-02[PATCH] m68knommu: new board support in linker scriptGreg Ungerer
. add support for the M5235EVB board . add support for the SOM5282 board . add support for the MOD5272 board . fix end of memory define for eLITE board Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-02[PATCH] m68knommu: cleanup showstack()Greg Ungerer
Make show_stack() consistent with other architectures. Put the vector string names in the .rodata section. Patch originally submitted by Philippe De Muyter <phdm@macqel.be>. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-02[PATCH] m68knommu: new family (523x) and board setupGreg Ungerer
. setup for the new 523x ColdFire family . break up of 527x to be 5271 and 5275 . some white space cleanup Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[PATCH] convert signal handling of NODEFER to act like other Unix boxes.Steven Rostedt
It has been reported that the way Linux handles NODEFER for signals is not consistent with the way other Unix boxes handle it. I've written a program to test the behavior of how this flag affects signals and had several reports from people who ran this on various Unix boxes, confirming that Linux seems to be unique on the way this is handled. The way NODEFER affects signals on other Unix boxes is as follows: 1) If NODEFER is set, other signals in sa_mask are still blocked. 2) If NODEFER is set and the signal is in sa_mask, then the signal is still blocked. (Note: this is the behavior of all tested but Linux _and_ NetBSD 2.0 *). The way NODEFER affects signals on Linux: 1) If NODEFER is set, other signals are _not_ blocked regardless of sa_mask (Even NetBSD doesn't do this). 2) If NODEFER is set and the signal is in sa_mask, then the signal being handled is not blocked. The patch converts signal handling in all current Linux architectures to the way most Unix boxes work. Unix boxes that were tested: DU4, AIX 5.2, Irix 6.5, NetBSD 2.0, SFU 3.5 on WinXP, AIX 5.3, Mac OSX, and of course Linux 2.6.13-rcX. * NetBSD was the only other Unix to behave like Linux on point #2. The main concern was brought up by point #1 which even NetBSD isn't like Linux. So with this patch, we leave NetBSD as the lonely one that behaves differently here with #2. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Don't export machine_restart, machine_halt, or machine_power_off.Eric W. Biederman
machine_restart, machine_halt and machine_power_off are machine specific hooks deep into the reboot logic, that modules have no business messing with. Usually code should be calling kernel_restart, kernel_halt, kernel_power_off, or emergency_restart. So don't export machine_restart, machine_halt, and machine_power_off so we can catch buggy users. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-03[PATCH] m68knommu: fix scheduling and race problems in idle loopGreg Ungerer
Re-work the m68knommu specific idle code according to suggestions from Nick Piggin <nickpiggin@yahoo.com.au>. A couple of rules that we need to follow: 1. Preempt should now disabled over idle routines. Should only be enabled to call schedule() then disabled again. 3. When cpu_idle finds (need_resched() == 'true'), it should call schedule(). It should not call schedule() otherwise. Also fix interrupt locking around the need_resched() and cpu stop state so that there is no race condition. Signed-off-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] convert that currently tests _NSIG directly to use valid_signal()Jesper Juhl
Convert most of the current code that uses _NSIG directly to instead use valid_signal(). This avoids gcc -W warnings and off-by-one errors. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
