Add a very basic mmu-less support for coldfire m548x family. This is perhaps
also valid for m547x family. The port comprises the serial, tick timer and
reboot support. The gpio part compiles but is empty. This gives a functional
albeit limited linux for the m548x coldfire family. This has been tested
on a Freescale M548xEVB Lite board with a M5484 processor and the default
dbug monitor.
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
Signed-off-by: Philip Nye <philipn@engarts.com>
Modern versions of gcc have a better range of ColdFire optimization
switches for the vairous ColdFire family members. Use these when we can.
Greg Ungerer said about this board:
Only ever a handful where made, and that was in 1999.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
the ff1 and bitrev opcode appears in ISA C and ISA A+ what isn't
supported by all plattforms. The assembly optimization is automaticly
enabled if the compiler understand the required cpu keyword.
My m5235 seems to boot and run fine so far.
Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de>
Modify Makefiles to support separate coldfire platform directory.
Currently the common ColdFire CPU family code sits in the
arch/m68knommu/platform/5307 directory. This is confusing, the files
containing this common code are in no way specific to the 5307 ColdFire.
Create an arch/m68knommu/platform/coldfire directory to contain this
common code. Other m68knommu CPU varients do not need use this code
though, so it doesn't make sense to move it to arch/m68knommu/kernel.
Remove build reference to arch/m68knommu/boot directory, it doesn't
exist.
Add make support for the Savant/Rosie1 board.
The variable AFLAGS is a wellknown variable and the usage by
kbuild may result in unexpected behaviour.
On top of that several people over time has asked for a way to
pass in additional flags to gcc.
This patch replace use of AFLAGS with KBUILD_AFLAGS all over
the tree.
Patch was tested on following architectures:
alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
The variable CFLAGS is a wellknown variable and the usage by
This patch replace use of CFLAGS with KBUILD_CFLAGS all over the
tree and enabling one to use:
make CFLAGS=...
to specify additional gcc commandline options.
One usecase is when trying to find gcc bugs but other
use cases has been requested too.
Test was simple to do a defconfig build, apply the patch and check
that nothing got rebuild.
Add build support for the new Arcturus boards.
Add build support for the M523x ColdFire CPU family.
Add support for the Avnet/5282 board.
Here is a small patch that made my kernel .text segment shrink by 8k IIRC
on my 5272-based board, by removing `-Wa,-S' from CFLAGS.
The `-Wa,-S' option prevents `gas' from using short forms of jsr.
Without it, `gas' replaces `jsr xxx.l' (6 bytes) by `jsr xxx@pc'
(4 bytes) when possible. On 5272, both forms are equally fast.
The `-Wa,-m5307' option is useless, because gcc already gives it
to `gas' from the `-m5307' option.
Don't specify compiler optimization flags in the m68knommu Makefile.
Let the top level Makefile/config set it.
Add build support for the new Freescale 5208 ColdFire processor,
and its M5208EVB eval board. Patch originally from Matt Waddel.
Signed-off-by: Greg Ungerer <gerg@uclinux.com>
h8300, m68knommu, sh and sh64 all used the name asm-offsets.h so minimal
changes required.
Add support for the 523x ColdFire family of processors
There was only two users left of descend. Fix them so they
use $(clean)= and $(build)=.
Drop definition of descend.
infrastructure for it.
Let it rip!
