path: root/arch/m68k
2009-08-05net: implement a SO_DOMAIN getsockoptionJan Engelhardt
This sockopt goes in line with SO_TYPE and SO_PROTOCOL. It makes it possible for userspace programs to pass around file descriptors — I am referring to arguments-to-functions, but it may even work for the fd passing over UNIX sockets — without needing to also pass the auxiliary information (PF_INET6/IPPROTO_TCP). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05net: implement a SO_PROTOCOL getsockoptionJan Engelhardt
Similar to SO_TYPE returning the socket type, SO_PROTOCOL allows to retrieve the protocol used with a given socket. I am not quite sure why we have that-many copies of socket.h, and why the values are not the same on all arches either, but for where hex numbers dominate, I use 0x1029 for SO_PROTOCOL as that seems to be the next free unused number across a bunch of operating systems, or so Google results make me want to believe. SO_PROTOCOL for others just uses the next free Linux number, 38. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-21Move FAULT_FLAG_xyz into handle_mm_fault() callersLinus Torvalds
This allows the callers to now pass down the full set of FAULT_FLAG_xyz flags to handle_mm_fault(). All callers have been (mechanically) converted to the new calling convention, there's almost certainly room for architectures to clean up their code and then add FAULT_FLAG_RETRY when that support is added. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ptrace: remove PT_DTRACE from m68k, m68knommuOleg Nesterov
m68k sets PT_DTRACE in trap_c() but never uses it. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer <gerg@snapgear.com> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16kmap_types: make most arches use generic header fileRandy Dunlap
Convert most arches to use asm-generic/kmap_types.h. Move the KM_FENCE_ macro additions into asm-generic/kmap_types.h, controlled by __WITH_KM_FENCE from each arch's kmap_types.h file. Would be nice to be able to add custom KM_types per arch, but I don't yet see a nice, clean way to do that. Built on x86_64, i386, mips, sparc, alpha(tonyb), powerpc(tonyb), and 68k(tonyb). Note: avr32 should be able to remove KM_PTE2 (since it's not used) and then just use the generic kmap_types.h file. Get avr32 maintainer approval. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Bryan Wu <cooloney@kernel.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "Luck Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: consolidate init_mm definitionAlexey Dobriyan
* create mm/init-mm.c, move init_mm there * remove INIT_MM, initialize init_mm with C99 initializer * unexport init_mm on all arches: init_mm is already unexported on x86. One strange place is some OMAP driver (drivers/video/omap/) which won't build modular, but it's already wants get_vm_area() export. Somebody should look there. [akpm@linux-foundation.org: add missing #includes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: add generic lib/checksum.c asm-generic: add a generic uaccess.h asm-generic: add generic NOMMU versions of some headers asm-generic: add generic atomic.h and io.h asm-generic: add legacy I/O header files asm-generic: add generic versions of common headers asm-generic: make bitops.h usable asm-generic: make pci.h usable directly asm-generic: make get_rtc_time overridable asm-generic: rename page.h and uaccess.h asm-generic: rename atomic.h to atomic-long.h asm-generic: add a generic unistd.h asm-generic: add generic ABI headers asm-generic: add generic sysv ipc headers asm-generic: introduce asm/bitsperlong.h asm-generic: rename termios.h, signal.h and mman.h
2009-06-12PM: Remove unused asm/suspend.hMagnus Damm
This patch removes unused asm/suspend.h files for the following architectures: alpha, arm, ia64, m68k, mips, s390, um Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12module: cleanup FIXME comments about trimming exception table entries.Rusty Russell
Everyone cut and paste this comment from my original one. We now do it generically, so cut the comments. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Amerigo Wang <amwang@redhat.com>
2009-06-12asm-generic: merge branch 'master' of torvalds/linux-2.6Arnd Bergmann
Fixes a merge conflict against the x86 tree caused by a fix to atomic.h which I renamed to atomic_long.h. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename page.h and uaccess.hArnd Bergmann
The current asm-generic/page.h only contains the get_order function, and asm-generic/uaccess.h only implements unaligned accesses. This renames the file to getorder.h and uaccess-unaligned.h to make room for new page.h and uaccess.h file that will be usable by all simple (e.g. nommu) architectures. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename atomic.h to atomic-long.hArnd Bergmann
The existing asm-generic/atomic.h only defines the atomic_long type. This renames it to atomic-long.h so we have a place to add a truly generic atomic.h that can be used on all non-SMP systems. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-06-11asm-generic: introduce asm/bitsperlong.hArnd Bergmann
This provides a reliable way for asm-generic/types.h and other files to find out if it is running on a 32 or 64 bit platform. We cannot use CONFIG_64BIT for this in headers that are included from user space because CONFIG symbols are not available there. We also cannot do it inside of asm/types.h because some headers need the word size but cannot include types.h. The solution is to introduce a new header <asm/bitsperlong.h> that defines both __BITS_PER_LONG for user space and BITS_PER_LONG for usage in the kernel. The asm-generic version falls back to 32 bit unless the architecture overrides it, which I did for all 64 bit platforms. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename termios.h, signal.h and mman.hArnd Bergmann
The existing asm-generic versions are incomplete and included by some architectures. New architectures should be able to use a generic version, so rename the existing files and change all users, which lets us add the new files. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11m68knommu: enumerate INIT_THREAD fields properlyGreg Ungerer
Use proper field value setting init INIT_THREAD macro. Fixes this: arch/m68knommu/kernel/init_task.c:27: warning: excess elements in array initializer arch/m68knommu/kernel/init_task.c:27: warning: (near initialization for ‘init_task.thread.fpstate’) Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-06-11headers_check fix: m68k, swab.hJaswinder Singh Rajput
fix the following 'make headers_check' warnings: usr/include/asm-m68k/swab.h:4: include of <linux/types.h> is preferred over <asm/types.h> usr/include/asm-m68k/swab.h:10: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-06-11m68knommu: remove obsolete reset codeGreg Ungerer
All ColdFire and non-MMU 68k code has custom reset routines. Remove the obsolete and now un-used reset macros. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-06-11m68knommu: move CPU reset code for the 528x ColdFire into its platform codeGreg Ungerer
2009-06-11m68knommu: move CPU reset code for the 527x ColdFire into its platform codeGreg Ungerer
2009-06-11m68knommu: move CPU reset code for the 523x ColdFire into its platform codeGreg Ungerer
2009-06-11m68knommu: move CPU reset code for the 520x ColdFire into its platform codeGreg Ungerer
2009-06-11m68knommu: add CPU reset code for the 532x ColdFireGreg Ungerer
2009-06-11m68knommu: merge system reset for code ColdFire 523x familyGreg Ungerer
The sofwtare reset control code for the 523x ColdFire family uses the same Reset unit hardware as the 527x and 528x ColdFire parts. So they should all use the same code. Merge them. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-06-11m68knommu: fix system reset for ColdFire 527x familyGreg Ungerer
The sofwtare reset control for the 527x ColdFire family is based on the same Reset Control Unit as the 528x ColdFire family. So use the same reset code for both. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-05-29flat: fix data sections alignmentOskar Schirmer
The flat loader uses an architecture's flat_stack_align() to align the stack but assumes word-alignment is enough for the data sections. However, on the Xtensa S6000 we have registers up to 128bit width which can be used from userspace and therefor need userspace stack and data-section alignment of at least this size. This patch drops flat_stack_align() and uses the same alignment that is required for slab caches, ARCH_SLAB_MINALIGN, or wordsize if it's not defined by the architecture. It also fixes m32r which was obviously kaput, aligning an uninitialized stack entry instead of the stack pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Oskar Schirmer <os@emlix.com> Cc: David Howells <dhowells@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <cooloney@kernel.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Johannes Weiner <jw@emlix.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-28m68k: arch/m68k/kernel/sun3-head.S needs <linux/init.h>Geert Uytterhoeven
Fix this: arch/m68k/kernel/sun3-head.S: Assembler messages: arch/m68k/kernel/sun3-head.S:32: Error: Unknown operator -- statement `__head' ignored Introduced by commit 6f335cab0431d5df4995bcd4fd952d4c746d5a86 ("m68k: convert to use __HEAD and HEAD_TEXT macros."), which started using __HEAD without adding the appropriate include. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-26m68k: convert to use __HEAD and HEAD_TEXT macros.Tim Abbott
This has the consequence of changing the section name use for head code from ".text.head" to ".head.text". Since this commit changes all users in the architecture, this change should be harmless. Signed-off-by: Tim Abbott <tabbott@mit.edu> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-22m68k: Update defconfigs for 2.6.30-rc3Geert Uytterhoeven
2009-04-22m68k,m68knommu: Wire up preadv and pwritevGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer <gerg@uclinux.org>
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-04-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/rtc-pariscLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/rtc-parisc: powerpc/ps3: Add rtc-ps3 powerpc: Hook up rtc-generic, and kill rtc-ppc m68k: Hook up rtc-generic parisc: rtc: Rename rtc-parisc to rtc-generic parisc: rtc: Add missing module alias parisc: rtc: platform_driver_probe() fixups parisc: rtc: get_rtc_time() returns unsigned int
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: (41 commits) m68knommu: improve compile arch switch settings m68knommu: fix 5407 ColdFire UART vector setup m68knommu: fix 5307 ColdFire UART vector setup m68knommu: fix 5249 ColdFire UART vector setup m68knommu: fix 5249 ColdFire UART setup m68knommu: fix end of uart table marker m68knommu: switch to using generic_handle_irq() m68k: merge the mmu and non-mmu versions of tlbflush.h m68knommu: introduce basic clk infrastructure m68k: merge the mmu and non-mmu versions of module.h m68knommu: add missing interrupt line definition for UART 2 m68k: merge the mmu and non-mmu versions of mmu_context.h m68k: merge the mmu and non-mmu versions of current.h m68k: merge the mmu and non-mmu versions of div64.h m68k: merge the mmu and non-mmu versions of bugs.h m68k: merge the mmu and non-mmu versions of bug.h m68k: use the mmu version of cache.h for m68knommu as well m68k: use the mmu version of bootinfo.h for m68knommu as well m68k: merge the mmu and non-mmu versions of fb.h m68k: merge the mmu and non-mmu versions of segment.h ...
2009-04-02Simplify copy_thread()Alexey Dobriyan
First argument unused since 2.3.11. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02m68k: Hook up rtc-genericGeert Uytterhoeven
m68k has been a long time user of the generic RTC abstraction, so hook up rtc-generic: - Create the "rtc-generic" platform device if mach_hwclk is set, - Add checks for mach_hwclk, in anticipation of RTC chip drivers being moved to drivers/rtc/. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-03-27ide: cleanup <asm-m68k/ide.h>Bartlomiej Zolnierkiewicz
* Remove superfluous <asm/macints.h> include. * No need to re-define in/out*() macros as they are no longer used by m68k host drivers. * readl() and writel() are not used by core IDE code. * Use raw_*_swapw() directly in {falcon,q40}ide.c and remove {in,out}sw_swapw() macros. Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michael Schmitz <schmitz@debian.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: remove IDE_ARCH_LOCK (v2)Bartlomiej Zolnierkiewicz
* Add ->{get,release}_lock methods to struct ide_port_info and struct ide_host. * Convert core IDE code, m68k IDE code and falconide support to use ->{get,release}_lock methods instead of ide_{get,release}_lock(). * Remove IDE_ARCH_LOCK. v2: * Build fix from Geert updating ide_{get,release}_lock() callers in falconide.c. Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michael Schmitz <schmitz@debian.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: remove IDE_ARCH_INTR (v2)Bartlomiej Zolnierkiewicz
This micro-optimization is not worth it. Just always check for existence of ->ack_intr method in ide_intr() and ide_timer_expiry(). v2: Fix brown-paper-bag bug spotted by David D. Kilzer. Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michael Schmitz <schmitz@debian.org> Cc: "David D. Kilzer" <ddkilzer@kilzer.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k: irq_node.handler() should return irqreturn_t m68k: section mismatch fixes: Atari SCSI m68k: section mismatch fixes: DMAsound for Atari MAINTAINERS: Replace dead link to m68k CVS repository by link to new git repository m68k: mac - Add SWIM floppy support m68k: mac - Add a new entry in mac_model to identify the floppy controller type. m68k: Add install target
2009-03-26Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/wimax/i2400m/usb-notif.c
2009-03-26m68k: irq_node.handler() should return irqreturn_tGeert Uytterhoeven
commit b5dc7840b3ebe9c7967dd8ba73db957767009ff9 ("m68k: introduce irq controller") reverted the return type of struct irq_node.handler() from irqreturn_t to int. Change it back to irqreturn_t, else it will give a compiler warning when irqreturn_t is turned into an enum in the near future: | arch/m68k/kernel/ints.c:231: warning: assignment from incompatible pointer type Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-03-26m68k: mac - Add SWIM floppy supportLaurent Vivier
It allows to read data from a floppy, but not to write to, and to eject the floppy (useful on our Mac without eject button). Signed-off-by: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-03-26m68k: mac - Add a new entry in mac_model to identify the floppy controller type.Laurent Vivier
This patch adds a field "floppy_type" which can take the following values: MAC_FLOPPY_IWM for an IWM based mac MAC_FLOPPY_SWIM_ADDR1 for a SWIM based mac with controller at VIA1 + 0x1E000 MAC_FLOPPY_SWIM_ADDR2 for a SWIM based mac with controller at VIA1 + 0x16000 MAC_FLOPPY_IOP for an IOP based mac MAC_FLOPPY_AV for an AV based mac Signed-off-by: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-03-26m68k: Add install targetLaurent Vivier
This patch enables the use of "make install" on m68k architecture to copy kernel to /boot. Signed-off-by: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-03-24m68k: merge the mmu and non-mmu versions of tlbflush.hGreg Ungerer
Simple merge of the mmu and non-mmu versions of tlbflush.h Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-03-24m68k: merge the mmu and non-mmu versions of module.hGreg Ungerer
Simple merge of the mmu and non-mmu versions of module.h Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-03-24m68knommu: add missing interrupt line definition for UART 2Greg Ungerer
Signed-off-by: David Wu <david.wu@arcturusnetworks.com> Acked-by: Michael Durrant <mdurrant@arcturusnetworks.com> Acked-by: Oleksandr Zhadan <oleks@arcturusnetworks.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-03-24m68k: merge the mmu and non-mmu versions of mmu_context.hGreg Ungerer
Simple merge of the mmu and non-mmu versions of mmu_context.h Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-03-24m68k: merge the mmu and non-mmu versions of current.hGreg Ungerer
Trivial merge of the mmu and non-mmu versions of current.h Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-03-24m68k: merge the mmu and non-mmu versions of div64.hGreg Ungerer
Trivial merge of the mmu and non-mmu versions of div64.h Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
