path: root/arch/m68k/lib
2013-06-24m68k/uaccess: Fix asm constraints for userspace accessGeert Uytterhoeven
When compiling a MMU kernel with CPU_HAS_ADDRESS_SPACES=n (e.g. "MMU=y allnoconfig": "echo CONFIG_MMU=y > allno.config && make KCONFIG_ALLCONFIG=1 allnoconfig"), we use plain "move" instead of "moves", and I got: CC arch/m68k/lib/uaccess.o {standard input}: Assembler messages: {standard input}:47: Error: operands mismatch -- statement `move.b %a0,(%a1)' ignored This happens because plain "move" doesn't support byte transfers between memory and address registers, while "moves" does. Fix the asm constraints for __generic_copy_from_user(), __generic_copy_to_user(), and __clear_user() to only use data registers when accessing userspace. Also, relax the asm constraints for 16-bit userspace accesses in __put_user() and __get_user(), as both "move" and "moves" do support such transfers between memory and address registers. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-06-24m68k: Remove inline strcpy() and strcat() implementationsGeert Uytterhoeven
Gcc may replace calls to standard string functions by open code and/or calls to other standard string functions. If the replacement function is not available out-of-line, link errors will happen. To avoid this, the out-of-line versions were provided by arch/m68k/lib/string.c, but they were usually not linked in anymore as typically none of its symbols are referenced by built-in code. However, if any module would need them, they would not be available. Hence remove the inline strcpy() and strcat() implementations, remove arch/m68k/lib/string.c, and let the generic string library code handle it. Impact on a typical kernel build seems minimal or nonexistent: - .text : 0x00001000 - 0x002aac74 (2728 KiB) - .data : 0x002ada48 - 0x00392148 ( 914 KiB) + .text : 0x00001000 - 0x002aacf4 (2728 KiB) + .data : 0x002adac8 - 0x00392148 ( 914 KiB) See also commit e00c73ee05dc38ecaccced55d4f5fc58b0b769f7 ("m68k: Remove inline strlen() implementation"). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-04-16m68k: Remove inline strlen() implementationMichal Marek
GCC can replace a strncat() call with constant second argument into a strlen + store, which results in a link error: ERROR: "strlen" [net/ipv4/ip_tunnel.ko] undefined! The inline function is a simple for loop in C. Other architectures either use an asm optimized variant, or use the generic function from lib/string.c. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2012-12-05m68k: fix unused variable warning in mempcy.cGreg Ungerer
When compiling for original 68000 or ColdFire targets you will get the following warning when compiling arch/m68k/lib/memcpy.c: CC arch/m68k/lib/memcpy.o arch/m68k/lib/memcpy.c: In function ‘__builtin_memcpy’: arch/m68k/lib/memcpy.c:13:15: warning: unused variable ‘temp1’ This is easily fixed by moving the definition of temp1 into the code block where it is used. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-06-10m68k: delay, muldi3 - Use CONFIG_CPU_HAS_NO_MULDIV64Geert Uytterhoeven
instead of open coding CONFIG_M68000 || CONFIG_COLDFIRE Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer<gerg@uclinux.org>
2012-06-06m68k: Use generic strncpy_from_user(), strlen_user(), and strnlen_user()Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer <gerg@uclinux.org>
2011-12-30m68k: modify user space access functions to support ColdFire CPUsGreg Ungerer
Modify the user space access functions to support the ColdFire V4e cores running with MMU enabled. The ColdFire processors do not support the "moves" instruction used by the traditional 680x0 processors for moving data into and out of another address space. They only support the notion of a single address space, and you use the usual "move" instruction to access that. Create a new config symbol (CONFIG_CPU_HAS_ADDRESS_SPACES) to mark the CPU types that support separate address spaces, and thus also support the sfc/dfc registers and the "moves" instruction that go along with that. The code is almost identical for user space access, so lets just use a define to choose either the "move" or "moves" in the assembler code. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Matt Waddel <mwaddel@yahoo.com> Acked-by: Kurt Mahan <kmahan@xmission.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-12-24m68k: handle presence of 64bit mul/div instructions cleanlyGreg Ungerer
The traditional 68000 processors and the newer reduced instruction set ColdFire processors do not support the 32*32->64 multiply or the 64/32->32 divide instructions. This is not a difference based on the presence of a hardware MMU or not. Create a new config symbol to mark that a CPU type doesn't support the longer multiply/divide instructions. Use this then as a basis for using the fast 64bit based divide (in div64.h) and for linking in the extra libgcc functions that may be required (mulsi3, divsi3, etc). Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-12-24m68k: simpler m68k and ColdFire CPU's can use generic csum codeGreg Ungerer
We have two implementations of the IP checksuming code for the m68k arch. One uses the more advanced instructions available in 68020 and above processors, the other uses the simpler instructions available on the original 68000 processors and the modern ColdFire processors. This simpler code is pretty much the same as the generic lib implementation of the IP csum functions. So lets just switch over to using that. That means we can completely remove the checksum_no.c file, and only have the local fast code used for the more complex 68k CPU family members. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-10-18m68k: fix memcpy to unmatched/unaligned source and dest on 68000Greg Ungerer
The original 68000 processors cannot copy 16bit or larger quantities from odd addresses. All newer members of the 68k family (including ColdFire) can do this. In the current memcpy implementation after trying to align the destination address to a 16bit boundary if we end up with an odd source address we go off and try to copy multi-byte quantities from it. This will trap on the 68000. The only solution if we end with an odd source address is to byte wise copy the whole memcpy region. We only need to do this if we are supporting original 68000 processors. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68k: merge and clean up delay.h filesGreg Ungerer
The real difference between the mmu and non-mmu varients of the delay.h files has nothing to do with having an mmu or not. It is processor family differences that means slightly different code. Merge the delay_mm.h and delay_no.h files back into a single file. The primarly difference we need to deal with is whether the processor supports a 32bit * 32bit -> 64bit multiply. Without it we need to do some shift scaling as well as use a 32bit * 32bit -> 32bit multiply. If building for a multi-CPU type kernel then we must use the simpler mult/shift scaling. This version of delay code allows the CPU32 family to use a 64bit mul, since it supports this instruction, the old code did not. The changes use macros where appropriate to try and optimize constant sized udelay times. And it removes the use of a fixed lib function for the non-mmu case. Code size on typical kernel configurations is similar, or only larger by a few tens of bytes. Also removed the unused muldiv() code from delay_mm.h. Build and run tested on ColdFire and ARAnyM. Build tested only on 68328 and 68360 (CPU32). Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-06-14m68k: use kernel processor defines for conditional optimizationsGreg Ungerer
Older m68k-linux compilers will include pre-defined symbols that confuse what processor it is being targeted for. For example gcc-4.1.2 will pre-define __mc68020__ even if you specify the target processor as -m68000 on the gcc command line. Newer versions of gcc have this corrected. In a few places the m68k code uses defined(__mc68020__) for optimizations that include instructions that are specific to the CPU 68020 and above. When compiling with older compilers this will be true even when we have selected to compile for the older 68000 processors. Switch to using the kernel processor defines, CONFIG_M68020 and friends. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68knommu: move EXPORT of local checksumming functions to definitionsGreg Ungerer
The EXPORT_SYMBOL() of the local lib checksum functions belongs with the definitions, not in some other random code file. So move then there. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68k: let Makefile sort out compiling mmu and non-mmu lib/checksum.cGreg Ungerer
We don't need an arch/m68k/lib/checksum.c wrapper to include the correct mmu or non-mmu version of the checksum code. Let the Makefile just build the appropriate one. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68k: remove duplicate memcpy() implementationGreg Ungerer
Merging the mmu and non-mmu directories we ended up with duplicate implementations of memcpy(). One is a little more optimized for the >= 68020 case, but that can easily be inserted into a single implementation of memcpy(). Clean up the exporting of this symbol too, otherwise we end up exporting it twice on a no-mmu build. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-24m68k: remove duplicate memset() implementationGreg Ungerer
Merging the mmu and non-mmu directories we ended up with duplicate implementations of memset(). One is a little more optimized for the >= 68020 case, but that can easily be inserted into a single implementation of memset(). Clean up the exporting of this symbol too, otherwise we end up exporting it twice on a no-mmu build. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-24m68k: remove duplicate memmove() implementationGreg Ungerer
Merging the mmu and non-mmu directories we ended up with duplicate (and identical) implementations of memmove(). Remove one of them. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-24m68k: merge mmu and non-mmu versions of lib/MakefileGreg Ungerer
We can easily support the slight differences in libs needed by the mmu and non-mmu builds in a single Makefile, so merge them back into a single file again. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-24m68k: merge mmu and non-mmu versions of muldi3Greg Ungerer
The implementation of gcc's muldi3 support function differs only in the use of the machine's 64 bit sized mul or not. (It isn't based on using an MMU or not). Merge the current mmu and non-mmu versions of arc/m68k/lib/muldi3 and use the appropriate pre-processor conditionals to get the right version for all m68k processor types. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-03-25m68k: merge m68k and m68knommu arch directoriesGreg Ungerer
There is a lot of common code that could be shared between the m68k and m68knommu arch branches. It makes sense to merge the two branches into a single directory structure so that we can more easily share that common code. This is a brute force merge, based on a script from Stephen King <sfking@fdwdc.com>, which was originally written by Arnd Bergmann <arnd@arndb.de>. > The script was inspired by the script Sam Ravnborg used to merge the > includes from m68knommu. For those files common to both arches but > differing in content, the m68k version of the file is renamed to > <file>_mm.<ext> and the m68knommu version of the file is moved into the > corresponding m68k directory and renamed <file>_no.<ext> and a small > wrapper file <file>.<ext> is used to select between the two version. Files > that are common to both but don't differ are removed from the m68knommu > tree and files and directories that are unique to the m68knommu tree are > moved to the m68k tree. Finally, the arch/m68knommu tree is removed. > > To select between the the versions of the files, the wrapper uses > > #ifdef CONFIG_MMU > #include <file>_mm.<ext> > #else > #include <file>_no.<ext> > #endif On top of this file merge I have done a simplistic merge of m68k and m68knommu Kconfig, which primarily attempts to keep existing options and menus in place. Other than a handful of options being moved it produces identical .config outputs on m68k and m68knommu targets I tested it on. With this in place there is now quite a bit of scope for merge cleanups in future patches. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-02-16m68k: remove arch specific non-optimized memcmp()Greg Ungerer
The m68k arch implements its own memcmp() function. It is not optimized in any way (it is the most strait forward coding of memcmp you can get). Remove it and use the kernels standard memcmp() implementation. This also goes part of the way to fixing a regression caused by commit ea61bc461d09e8d331a307916530aaae808c72a2 ("m68k/m68knommu: merge MMU and non-MMU string.h"), which breaks non-coldfire non-mmu builds (which is the 68x328 and 68360 families). They currently have no memcmp() function defined, since there is none in the m68knommu/lib functions. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-07-20Stringify support commasMathieu Desnoyers
> This is a no-no for those archs that still use -traditional. > > I dunno if this is a problem for you at the moment and the > > right fix is anyway to nuke -traditional. > > > > Sam Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-21provide out-of-line strcat() for m68kAl Viro
Whether we sidestep it in init/main.c or not, such situations will arise again; compiler does generate calls of strcat() on optimizations, so we really ought to have an out-of-line version... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2007-07-17missing exports of csum_...Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15m68k: implement __clear_user()Geert Uytterhoeven
m68k: implement __clear_user(), which is needed by fs/signalfd.c Since we always let the MMU do all checking, clear_user() and __clear_user() are identical. The old clear_user() is renamed to __clear_user() for consistency. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: export csum_partial_copy_from_userGeert Uytterhoeven
net/rxrpc/af-rxrpc.ko needs csum_partial_copy_from_user Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-02[NET]: M68K checksum annotations and cleanups.Al Viro
* sanitize prototypes, annotate Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-06[PATCH] m68k: fix typo in __generic_copy_to_userRoman Zippel
Jump to the correct exit label after exception Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-06[PATCH] m68k: cleanup string functionsRoman Zippel
- cleanup asm of string functions - deinline strncat()/strncmp() - provide non-inlined strcpy() Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] m68k: clean up uaccess.hRoman Zippel
This uninlines a few large functions in uaccess.h and cleans up the rest. It includes a (hopefully temporary) workaround for the broken typeof of gcc-4.1. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] m68k: checksum __user annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] m68k: cleanup inline mem functionsRoman Zippel
Use the builtin functions for memset/memclr/memcpy, special optimizations for page operations have dedicated functions now. Uninline memmove/memchr and move all functions into a single file and clean it up a little. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
