path: root/arch/m68k/kernel/vmlinux-sun3.lds
2008-01-28all archs: consolidate init and exit sections in vmlinux.lds.hSam Ravnborg
This patch consolidate all definitions of .init.text, .init.data and .exit.text, .exit.data section definitions in the generic vmlinux.lds.h. This is a preparational patch - alone it does not buy us much good. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-20m68k: use .text.headAl Viro
i.e. tell modpost that entry point code (that has to be outside of .init.text for external reasons) is OK to refer to .init.* Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-31m68k: runtime patching infrastructureRoman Zippel
Add the basic infrastructure to allow runtime patching of kernel and modules to optimize a few functions with parameters, which are only calculated once during bootup and are otherwise constant. Use this for the conversion between virtual and physical addresses. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-19all-archs: consolidate .data section definition in asm-genericSam Ravnborg
With this consolidation we can now modify the .data section definition in one spot for all archs. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-19all-archs: consolidate .text section definition in asm-genericSam Ravnborg
Move definition of .text section to asm-generic. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-02-11[PATCH] disable init/initramfs.c: architecturesJean-Paul Saman
Update all arch/*/kernel/vmlinux.lds.S to not include space for initramfs when CONFIG_BLK_DEV_INITRAMFS is not selected. This saves another 4 kbytes on most platfoms (some reserve PAGE_SIZE for initramfs). Signed-off-by: Jean-Paul Saman <jean-paul.saman@nxp.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-09[PATCH] Sun3: General updatesSam Creasey
General compile fixes for 2.6.16 for sun3, and some updates to make the new bootloader work correctly. Tested on 3/50, 3/60, 3/80. Signed-off-by: Sam Creasey <sammy@sammy.net> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-29[PATCH] m68k: consolidate initcall sectionsGeert Uytterhoeven
Commit 61ce1efe6e40233663d27ab8ac9ba9710eebcaad missed the m68k initcall sections. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] m68k: fix reference to init_task in vmlinux-sun3.ldsAl Viro
it's *(.data.init_task), not init_task... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] m68k: compile fix - updated vmlinux.lds to include LOCK_TEXTAl Viro
