2016-07-03 | m68k: Assorted spelling fixes | Andrea Gelmini | |
- s/acccess/access/ - s/accoding/according/ - s/addad/added/ - s/addreess/address/ - s/allocatiom/allocation/ - s/Assember/Assembler/ - s/compactnes/compactness/ - s/conneced/connected/ - s/decending/descending/ - s/diectly/directly/ - s/diplacement/displacement/ Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> [geert: Squashed, fix arch/m68k/ifpsp060/src/pfpsp.S] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> | |||
2011-03-31 | Fix common misspellings | Lucas De Marchi | |
Fixes generated by 'codespell' and manually reviewed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> | |||
2009-12-04 | tree-wide: fix assorted typos all over the place | André Goddard Rosa | |
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> | |||
2007-10-19 | Convert files to UTF-8 and some cleanups | Jan Engelhardt | |
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org> | |||
2005-04-16 | Linux-2.6.12-rc2v2.6.12-rc2 | Linus Torvalds | |
Initial git repository build. I'm not bothering with the full history, even though we have it. We can create a separate "historical" git archive of that later if we want to, and in the meantime it's about 3.2GB when imported into git - space that would just make the early git days unnecessarily complicated, when we don't have a lot of good infrastructure for it. Let it rip! |
