path: root/arch/m32r/lib
2016-07-26m32r: add __ucmpdi2 to fix build failureSudip Mukherjee
We are having build failure with m32r and the error message being: ERROR: "__ucmpdi2" [lib/842/842_decompress.ko] undefined! ERROR: "__ucmpdi2" [fs/btrfs/btrfs.ko] undefined! ERROR: "__ucmpdi2" [drivers/scsi/sd_mod.ko] undefined! ERROR: "__ucmpdi2" [drivers/media/i2c/adv7842.ko] undefined! ERROR: "__ucmpdi2" [drivers/md/bcache/bcache.ko] undefined! ERROR: "__ucmpdi2" [drivers/iio/imu/inv_mpu6050/inv-mpu6050.ko] undefined! __ucmpdi2 is introduced to m32r architecture taking example from other architectures like h8300, microblaze, mips. Link: http://lkml.kernel.org/r/1465509213-4280-1-git-send-email-sudipm.mukherjee@gmail.com Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-04m32r: export delay loop symbolsHirokazu Takata
- Move EXPORT_SYMBOL lines of delay loop functions from arch/m32r/kernel/m32r_ksyms.c to arch/m32r/lib/delay.c. - Export __ndelay. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2008-09-27m32r: export __ndelayAdrian Bunk
ERROR: "__ndelay" [drivers/spi/spi_bitbang.ko] undefined! Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-02-17Various typo fixes.Robert P. J. Day
Correct mis-spellings of "algorithm", "appear", "consistent" and (shame, shame) "kernel". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-11[PATCH] m32r: cosmetic updates and trivial fixesHirokazu Takata
Cosmetic updates and trivial fixes of m32r arch-dependent files. - Remove RCS ID strings and trailing white lines - Other misc. cosmetic updates Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-02[NET]: M32R checksum annotations and cleanups.Al Viro
* sanitize prototypes, annotate * ntohs -> shift in checksum calculations in l-e case * kill shift-by-16 in checksum calculations Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11[PATCH] m32r: security fix of {get,put}_user macrosHirokazu Takata
Update {get,put}_user macros for m32r kernel. - Modify get_user to use __get_user_asm macro, instead of __get_user_x macro. - Remove arch/m32r/lib/{get,put}user.S. - Some cosmetic updates. I would like to thank NIIBE Yutaka for his reporting about the m32r kernel's security problem in {get,put}_user macros. There were no address checking for user space access in {get,put}_user macros. ;-) Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: NIIBE Yutaka <gniibe@fsij.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] m32r: fix and update for gcc-4.0Hirokazu Takata
Fix and update for gcc-4.0. - arch/m32r/kernel/signal.c: Change type of the 8th parameter of sys_rt_sigsuspend() from 'struct pt_regs' to 'struct pt_regs *'. This functions make use of the 'regs' parameter to return status value, but gcc-4.0 optimizes and removes it as a dead code. Functions, sys_sigaltstack() and sys_rt_sigreturn(), have also modified. - arch/m32r/lib/usercopy.c, include/asm-m32r/uaccess.h: Add early-clobber constraints('&') to output values of asm statements; these constraints seems to be required for gcc-4.0 register assignment. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-26[PATCH] m32r: more basic __user annotationsAl Viro
2005-08-23[PATCH] missing exports on m32rAl Viro
missing exports on m32r Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
