path: root/arch/m32r/Makefile
2012-05-05m32r: Use generic init_taskThomas Gleixner
Same code. Use the generic version. The special Makefile treatment is pointless anyway as init_task.o contains only data which is handled by the linker script. So no point on being treated like head text. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Link: http://lkml.kernel.org/r/20120503085034.756332161@linutronix.de
2010-08-03kbuild: allow assignment to {A,C}FLAGS_KERNEL on the command lineSam Ravnborg
It is now possible to assign options to AS and CC on the command line - which is only used for built-in code. {A,C}FLAGS_KERNEL was used both in the top-level Makefile in the arch makefiles, thus users had no way to specify additional options to AS, CC without overriding the original value. Introduce a new set of variables KBUILD_{A,C}FLAGS_KERNEL that is used by arch specific files and free up {A,C}FLAGS_KERNEL so they can be assigned on the command line. All arch Makefiles that used the old variables has been updated. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-03kbuild: allow assignment to {A,C,LD}FLAGS_MODULE on the command lineSam Ravnborg
It is now possible to assign options to AS, CC and LD on the command line - which is only used when building modules. {A,C,LD}FLAGS_MODULE was all used both in the top-level Makefile in the arch makefiles, thus users had no way to specify additional options to AS, CC, LD when building modules without overriding the original value. Introduce a new set of variables KBUILD_{A,C,LD}FLAGS_MODULE that is used by arch specific files and free up {A,C,LD}FLAGS_MODULE so they can be assigned on the command line. All arch Makefiles that used the old variables has been updated. Note: Previously we had a MODFLAGS variable for both AS and CC. But in favour of consistency this was dropped. So in some cases arch Makefile has one assignmnet replaced by two assignmnets. Note2: MODFLAGS was not documented and is dropped without any notice. I do not expect much/any breakage from this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin] Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [avr32] Signed-off-by: Michal Marek <mmarek@suse.cz>
2008-04-29m32r: use KBUILD_DEFCONFIGAdrian Bunk
With using KBUILD_DEFCONFIG we don't have to ship a second copy of m32700ut.smp_defconfig Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Hirokazu Takata <takata@linux-m32r.org>
2007-10-15kbuild: enable 'make AFLAGS=...' to add additional options to ASSam Ravnborg
The variable AFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of AFLAGS with KBUILD_AFLAGS all over the tree. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-14kbuild: enable 'make CFLAGS=...' to add additional options to CCSam Ravnborg
The variable CFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of CFLAGS with KBUILD_CFLAGS all over the tree and enabling one to use: make CFLAGS=... to specify additional gcc commandline options. One usecase is when trying to find gcc bugs but other use cases has been requested too. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k Test was simple to do a defconfig build, apply the patch and check that nothing got rebuild. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-09-03m32r: Rearrange platform-dependent codesHirokazu Takata
Rearrange platform-dependent codes from arch/m32r/kernel/*.c to arch/m32r/platforms/{platform}/. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-02-11[PATCH] m32r: fix kernel entry address of vmlinuxHirokazu Takata
This patch fixes the kernel entry point address of vmlinux. The m32r kernel entry address is 0x08002000 (physical). But, so far, the ENTRY point written in vmlinux.lds.S was not point the correct kernel entry address. (before fix) $ objdump -x vmlinux vmlinux: file format elf32-m32r-linux vmlinux architecture: m32r2, flags 0x00000112: EXEC_P, HAS_SYMS, D_PAGED start address 0x88002090 /* NG */ : Sections: Idx Name Size VMA LMA File off Algn 0 .empty_zero_page 00001000 88001000 88001000 00001000 2**12 CONTENTS, ALLOC, LOAD, DATA 1 .boot 0000008c 88002000 88002000 00002000 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 2 .text 001ab694 88002090 88002090 00002090 2**4 CONTENTS, ALLOC, LOAD, READONLY, CODE : (after fix) $ objdump -x vmlinux vmlinux: file format elf32-m32r-linux vmlinux architecture: m32r2, flags 0x00000112: EXEC_P, HAS_SYMS, D_PAGED start address 0x08002000 /* OK */ : This fix also remedies the following GDB error message (of gdb-6.4 or after) at the first operation of kernel debugging: "Previous frame identical to this frame (corrupt stack?)". Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-25Merge master.kernel.org:/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/sam/kbuild: (46 commits) kbuild: remove obsoleted scripts/reference_* files kbuild: fix make help & make *pkg kconfig: fix time ordering of writes to .kconfig.d and include/linux/autoconf.h Kconfig: remove the CONFIG_CC_ALIGN_* options kbuild: add -fverbose-asm to i386 Makefile kbuild: clean-up genksyms kbuild: Lindent genksyms.c kbuild: fix genksyms build error kbuild: in makefile.txt note that Makefile is preferred name for kbuild files kbuild: replace PHONY with FORCE kbuild: Fix bug in crc symbol generating of kernel and modules kbuild: change kbuild to not rely on incorrect GNU make behavior kbuild: when warning symbols exported twice now tell user this is the problem kbuild: fix make dir/file.xx when asm symlink is missing kbuild: in the section mismatch check try harder to find symbols kbuild: fix section mismatch check for unwind on IA64 kbuild: kill false positives from section mismatch warnings for powerpc kbuild: kill trailing whitespace in modpost & friends kbuild: small update of allnoconfig description kbuild: make namespace.pl CROSS_COMPILE happy ... Trivial conflict in arch/ppc/boot/Makefile manually fixed up
2006-03-06kbuild: change kbuild to not rely on incorrect GNU make behaviorPaul Smith
The kbuild system takes advantage of an incorrect behavior in GNU make. Once this behavior is fixed, all files in the kernel rebuild every time, even if nothing has changed. This patch ensures kbuild works with both the incorrect and correct behaviors of GNU make. For more details on the incorrect behavior, see: http://lists.gnu.org/archive/html/bug-make/2006-03/msg00003.html Changes in this patch: - Keep all targets that are to be marked .PHONY in a variable, PHONY. - Add .PHONY: $(PHONY) to mark them properly. - Remove any $(PHONY) files from the $? list when determining whether targets are up-to-date or not. Signed-off-by: Paul Smith <psmith@gnu.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-02-24[PATCH] m32r: enable asm code optimizationHirokazu Takata
Add -O2 option to AFLAGS to enable asm code optimization for m32r. On m32r gas, "-m32r2 -O" option enables assembler's parallel code generation optimization for M32R2 ISA as a default. So, "-no-parallel" option is required explicitly for a cpu core with single instuction issuing, for example, VDEC2. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-26[PATCH] m32r: set CHECKFLAGS properlyAl Viro
We do _not_ need "sparse" in sparse arguments ;-) What we do need is __BIG_ENDIAN__; right now unconditional, when m32r starts using CPU_LITTLE_ENDIAN, we'll need to adjust. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
