path: root/arch/ia64
2011-05-26arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,BIT_LE,LAST_BIT}Akinobu Mita
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT, CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used to test for existence of find bitops anymore. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26Merge branches 'core-fixes-for-linus' and 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: seqlock: Get rid of SEQLOCK_UNLOCKED * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: irq: Remove smp_affinity_list when unregister irq proc
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25ia64: mmu_gather reworkPeter Zijlstra
Fix up the ia64 mmu_gather code to conform to the new API. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Tony Luck <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25arch, mm: filter disallowed nodes from arch specific show_mem functionsDavid Rientjes
Architectures that implement their own show_mem() function did not pass the filter argument to show_free_areas() to appropriately avoid emitting the state of nodes that are disallowed in the current context. This patch now passes the filter argument to show_free_areas() so those nodes are now avoided. This patch also removes the show_free_areas() wrapper around __show_free_areas() and converts existing callers to pass an empty filter. ia64 emits additional information for each node, so skip_free_areas_zone() must be made global to filter disallowed nodes and it is converted to use a nid argument rather than a zone for this use case. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: James Bottomley <jejb@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24seqlock: Get rid of SEQLOCK_UNLOCKEDEric Dumazet
All static seqlock should be initialized with the lockdep friendly __SEQLOCK_UNLOCKED() macro. Remove legacy SEQLOCK_UNLOCKED() macro. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: David Miller <davem@davemloft.net> Link: http://lkml.kernel.org/r/%3C1306238888.3026.31.camel%40edumazet-laptop%3E Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-23Merge branch 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (131 commits) KVM: MMU: Use ptep_user for cmpxchg_gpte() KVM: Fix kvm mmu_notifier initialization order KVM: Add documentation for KVM_CAP_NR_VCPUS KVM: make guest mode entry to be rcu quiescent state KVM: x86 emulator: Make jmp far emulation into a separate function KVM: x86 emulator: Rename emulate_grpX() to em_grpX() KVM: x86 emulator: Remove unused arg from emulate_pop() KVM: x86 emulator: Remove unused arg from writeback() KVM: x86 emulator: Remove unused arg from read_descriptor() KVM: x86 emulator: Remove unused arg from seg_override() KVM: Validate userspace_addr of memslot when registered KVM: MMU: Clean up gpte reading with copy_from_user() KVM: PPC: booke: add sregs support KVM: PPC: booke: save/restore VRSAVE (a.k.a. USPRG0) KVM: PPC: use ticks, not usecs, for exit timing KVM: PPC: fix exit accounting for SPRs, tlbwe, tlbsx KVM: PPC: e500: emulate SVR KVM: VMX: Cache vmcs segment fields KVM: x86 emulator: consolidate segment accessors KVM: VMX: Avoid reading %rip unnecessarily when handling exceptions ...
2011-05-22KVM: ia64: fix sparse warningsJeff Mahoney
This patch fixes some sparse warning about "dubious one-bit signed bitfield." Signed-off-by: Jeff Mahoney <jeffm@suse.com> Originally-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-20Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] define "_sdata" symbol pstore: Fix Kconfig dependencies for apei->pstore pstore: fix potential logic issue in pstore read interface pstore: fix pstore filesystem mount/remount issue pstore: fix one type of return value in pstore [IA64] fix build warning in arch/ia64/oprofile/backtrace.c
2011-05-20sanitize <linux/prefetch.h> usageLinus Torvalds
Commit e66eed651fd1 ("list: remove prefetching from regular list iterators") removed the include of prefetch.h from list.h, which uncovered several cases that had apparently relied on that rather obscure header file dependency. So this fixes things up a bit, using grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]') grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]') to guide us in finding files that either need <linux/prefetch.h> inclusion, or have it despite not needing it. There are more of them around (mostly network drivers), but this gets many core ones. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-20[IA64] define "_sdata" symbolTony Luck
core_kernel_data() wants to know if an address looks like kernel data. IA64 has had _edata forever, but never needed _sdata until now. Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-05-20Pull misc-2.6.40 into release branchTony Luck
2011-05-19Merge branch 'timers-clocksource-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clocksource: convert mips to generic i8253 clocksource clocksource: convert x86 to generic i8253 clocksource clocksource: convert footbridge to generic i8253 clocksource clocksource: add common i8253 PIT clocksource blackfin: convert to clocksource_register_hz mips: convert to clocksource_register_hz/khz sparc: convert to clocksource_register_hz/khz alpha: convert to clocksource_register_hz microblaze: convert to clocksource_register_hz/khz ia64: convert to clocksource_register_hz/khz x86: Convert remaining x86 clocksources to clocksource_register_hz/khz Make clocksource name const
2011-05-19Merge branches 'sched-core-for-linus' and 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (60 commits) sched: Fix and optimise calculation of the weight-inverse sched: Avoid going ahead if ->cpus_allowed is not changed sched, rt: Update rq clock when unthrottling of an otherwise idle CPU sched: Remove unused parameters from sched_fork() and wake_up_new_task() sched: Shorten the construction of the span cpu mask of sched domain sched: Wrap the 'cfs_rq->nr_spread_over' field with CONFIG_SCHED_DEBUG sched: Remove unused 'this_best_prio arg' from balance_tasks() sched: Remove noop in alloc_rt_sched_group() sched: Get rid of lock_depth sched: Remove obsolete comment from scheduler_tick() sched: Fix sched_domain iterations vs. RCU sched: Next buddy hint on sleep and preempt path sched: Make set_*_buddy() work on non-task entities sched: Remove need_migrate_task() sched: Move the second half of ttwu() to the remote cpu sched: Restructure ttwu() some more sched: Rename ttwu_post_activation() to ttwu_do_wakeup() sched: Remove rq argument from ttwu_stat() sched: Remove rq->lock from the first half of ttwu() sched: Drop rq->lock from sched_exec() ... * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Fix rt_rq runtime leakage bug
2011-05-14Merge branch 'consolidate-clksrc-i8253' of ↵Thomas Gleixner
master.kernel.org:~rmk/linux-2.6-arm into timers/clocksource Conflicts: arch/ia64/kernel/cyclone.c arch/mips/kernel/i8253.c arch/x86/kernel/i8253.c Reason: Resolve conflicts so further cleanups do not conflict further Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-04[CPUFREQ] use dynamic debug instead of custom infrastructureDominik Brodowski
With dynamic debug having gained the capability to report debug messages also during the boot process, it offers a far superior interface for debug messages than the custom cpufreq infrastructure. As a first step, remove the old cpufreq_debug_printk() function and replace it with a call to the generic pr_debug() function. How can dynamic debug be used on cpufreq? You need a kernel which has CONFIG_DYNAMIC_DEBUG enabled. To enabled debugging during runtime, mount debugfs and $ echo -n 'module cpufreq +p' > /sys/kernel/debug/dynamic_debug/control for debugging the complete "cpufreq" module. To achieve the same goal during boot, append ddebug_query="module cpufreq +p" as a boot parameter to the kernel of your choice. For more detailled instructions, please see Documentation/dynamic-debug-howto.txt Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Dave Jones <davej@redhat.com>
2011-04-14sched: Provide scheduler_ipi() callback in response to smp_send_reschedule()Peter Zijlstra
For future rework of try_to_wake_up() we'd like to push part of that function onto the CPU the task is actually going to run on. In order to do so we need a generic callback from the existing scheduler IPI. This patch introduces such a generic callback: scheduler_ipi() and implements it as a NOP. BenH notes: PowerPC might use this IPI on offline CPUs under rare conditions! Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110405152728.744338123@chello.nl
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-07[IA64] fix build warning in arch/ia64/oprofile/backtrace.cTony Luck
arch/ia64/oprofile/backtrace.c:63: warning: comparison of distinct pointer types lacks a cast Comparing a "u64 *" with an "unsigned long *". Make them match. Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-04-01[IA64] fix build warning: argument 1 of 'irqd_irq_disabled'Tony Luck
In commit f5e5bf088bd3d30990efb7429aaf9f1e5134ffd6 ia64: Use irqd_irq_disabled() instead of desc->status access Thomas forgot to convert from irq to *irq_data. Add a call to irq_get_irq_data() to fix that. Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-03-29[IA64] Fix build breakage - sn_force_interrupt_flag: undefinedTony Luck
Latest irq changes removed the need for this forcing flag, and the definition - but missed the code that allowed it to be tweaked via /proc. Delete accessor functions too. Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-03-29ia64: Remove redundant declaration of irq_desc[]Thomas Gleixner
2011-03-29ia64: Convert to the new irq_* function namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: Use generic show_interrupts()Thomas Gleixner
2011-03-29ia64: Use irqd_irq_disabled() instead of desc->status accessThomas Gleixner
Remove the last open coded access to irq_desc. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: sn: Use irqd_mark_affinity_set() helperThomas Gleixner
irq_desc->status is going to be restricted. Provide a helper to set that information in irq_data, where it belongs. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: msi: Use irq_move_irq()Thomas Gleixner
This replaces the old move_native_irq() function which is going away. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: sn: Use irq_move_irq()Thomas Gleixner
2011-03-29ia64: iosapic: Use new irq_move_* functionsThomas Gleixner
The current functions are going away. Also use the accessor for pending setaffinity in irq_data instead of the open coded irq_desc access. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: iosapic: Remove redundant mask from ack()Thomas Gleixner
The core code calls mask_ack() which calls irq_ack() and irq_mask() for the case where an interrupt is disabled and marked pending. That seems to be a leftover from the old __do_IRQ() mode. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: Use accessor functions all over the placeThomas Gleixner
Use the proper accessor functions instead of open coded irq_desc access. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: xen: Use irq accessor functionsThomas Gleixner
2011-03-29ia64: iosapic: Cleanup irq_desc accessThomas Gleixner
Use irq_to_desc() and use accessors for setting chip and handler. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: sn: Drop unused functionThomas Gleixner
Leftover from the irq chip conversion. Reported-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: Convert iosapic to new irq_chip functionsThomas Gleixner
2011-03-29ia64: Convert lsapic to new irq_chip functionsThomas Gleixner
2011-03-29ia64: Convert msi to new irq_chip functionsThomas Gleixner
2011-03-29ia64: Convert sn to new irq_chip functionsThomas Gleixner
2011-03-29ia64: Convert msi_sn to new irq_chip functionsThomas Gleixner
2011-03-29ia64: hp-sim: Cleanup direct access to irq_descThomas Gleixner
Use accessor functions instead of open coded access. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: Convert hp-sim to new irq_chip functionsThomas Gleixner
2011-03-29ia64: Remove stale irq_chip.endThomas Gleixner
irq_chip.end got obsolete with the removal of __do_IRQ(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tony Luck <tony.luck@intel.com> LKML-Reference: <20110203004210.143127544@linutronix.de>
2011-03-29ia64: Cleanup migrate_irqs()Thomas Gleixner
2011-03-29ia64: Convert migrate_platform_irqs() to new irq chip functionsThomas Gleixner
2011-03-24lib, arch: add filter argument to show_mem and fix private implementationsDavid Rientjes
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which resulted in build warnings on all architectures that implement their own versions of show_mem(): lib/lib.a(show_mem.o): In function `show_mem': show_mem.c:(.text+0x1f4): multiple definition of `show_mem' arch/sparc/mm/built-in.o:(.text+0xd70): first defined here The fix is to remove __show_mem() and add its argument to show_mem() in all implementations to prevent this breakage. Architectures that implement their own show_mem() actually don't do anything with the argument yet, but they could be made to filter nodes that aren't allowed in the current context in the future just like the generic implementation. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: pstore: cleanups to pstore_dump() [IA64] New syscalls for 2.6.39
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (42 commits) ACPI: minor printk format change in acpi_pad ACPI: make acpi_pad /sys output more readable ACPICA: Update version to 20110316 ACPICA: Header support for SLIC table ACPI: Make sure the FADT is at least rev 2 before using the reset register ACPI: Bug compatibility for Windows on the ACPI reboot vector ACPICA: Fix access width for reset vector ACPI battery: fribble sysfs files from a resume notifier ACPI button: remove unused procfs I/F ACPI, APEI, Add PCIe AER error information printing support PCIe, AER, use pre-generated prefix in error information printing ACPI, APEI, Add ERST record ID cache ACPI: Use syscore_ops instead of sysdev class and sysdev ACPI: Remove the unused EC sysdev class ACPI: use __cpuinit for the acpi_processor_set_pdc() call tree ACPI: use __init where possible in processor driver Thermal_Framework-Fix_crash_during_hwmon_unregister ACPICA: Update version to 20110211. ACPICA: Add mechanism to defer _REG methods for some installed handlers ACPICA: Add support for FunctionalFixedHW in acpi_ut_get_region_name ...
