path: root/arch/ia64
2012-10-18UAPI: Make arch/ia64/include/asm/kvm_para.h genericDavid Howells
Make arch/ia64/include/asm/kvm_para.h generic since it's the same as the asm-generic version. This deals with the problem when ia64 is compiled with allmodconfig you get: In file included from include/uapi/linux/kvm_para.h:26:0, from include/linux/kvm_para.h:4, from kernel/watchdog.c:28: arch/ia64/include/asm/kvm_para.h:24:28: error: redefinition of 'kvm_arch_para_features' include/asm-generic/kvm_para.h:16:28: note: previous definition of 'kvm_arch_para_features' was here arch/ia64/include/asm/kvm_para.h:29:20: error: redefinition of 'kvm_check_and_clear_guest_paused' include/asm-generic/kvm_para.h:11:20: note: previous definition of 'kvm_check_and_clear_guest_paused' was here This does not happen for ia64 defconfig. Reported-by: Yuanhan Liu <yuanhan.liu@intel.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Yuanhan Liu <yuanhan.liu@intel.com> cc: fengguang.wu@intel.com Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-10-17UAPI: Put a comment into uapi/asm-generic/kvm_para.h and use it from archesDavid Howells
Make uapi/asm-generic/kvm_para.h non-empty by addition of a comment to stop the patch program from deleting it when it creates it. Then delete empty arch-specific uapi/asm/kvm_para.h files and tell the Kbuild files to use the generic instead. Should this perhaps instead be a #warning or #error that the facility is unsupported on this arch? Signed-off-by: David Howells <dhowells@redhat.com> cc: Arnd Bergmann <arnd@arndb.de> cc: Avi Kivity <avi@redhat.com> cc: Marcelo Tosatti <mtosatti@redhat.com> cc: kvm@vger.kernel.org
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-13Merge tag 'please-pull-dhowells-uapi' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull ia64 UAPI changes from Tony Luck: "ia64 pieces of David Howells great UAPI include file move" * tag 'please-pull-dhowells-uapi' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: UAPI: (Scripted) Disintegrate arch/ia64/include/asm
2012-10-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull third pile of VFS updates from Al Viro: "Stuff from Jeff Layton, mostly. Sanitizing interplay between audit and namei, removing a lot of insanity from audit_inode() mess and getting things ready for his ESTALE patchset." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: procfs: don't need a PATH_MAX allocation to hold a string representation of an int vfs: embed struct filename inside of names_cache allocation if possible audit: make audit_inode take struct filename vfs: make path_openat take a struct filename pointer vfs: turn do_path_lookup into wrapper around struct filename variant audit: allow audit code to satisfy getname requests from its names_list vfs: define struct filename and have getname() return it vfs: unexport getname and putname symbols acct: constify the name arg to acct_on vfs: allocate page instead of names_cache buffer in mount_block_root audit: overhaul __audit_inode_child to accomodate retrying audit: optimize audit_compare_dname_path audit: make audit_compare_dname_path use parent_len helper audit: remove dirlen argument to audit_compare_dname_path audit: set the name_len in audit_inode for parent lookups audit: add a new "type" field to audit_names struct audit: reverse arguments to audit_inode_child audit: no need to walk list in audit_inode if name is NULL audit: pass in dentry to audit_copy_inode wherever possible audit: remove unnecessary NULL ptr checks from do_path_lookup
2012-10-12vfs: define struct filename and have getname() return itJeff Layton
getname() is intended to copy pathname strings from userspace into a kernel buffer. The result is just a string in kernel space. It would however be quite helpful to be able to attach some ancillary info to the string. For instance, we could attach some audit-related info to reduce the amount of audit-related processing needed. When auditing is enabled, we could also call getname() on the string more than once and not need to recopy it from userspace. This patchset converts the getname()/putname() interfaces to return a struct instead of a string. For now, the struct just tracks the string in kernel space and the original userland pointer for it. Later, we'll add other information to the struct as it becomes convenient. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-12Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer core update from Thomas Gleixner: - Bug fixes (one for a longstanding dead loop issue) - Rework of time related vsyscalls - Alarm timer updates - Jiffies updates to remove compile time dependencies * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: timekeeping: Cast raw_interval to u64 to avoid shift overflow timers: Fix endless looping between cascade() and internal_add_timer() time/jiffies: bring back unconditional LATCH definition time: Convert x86_64 to using new update_vsyscall time: Only do nanosecond rounding on GENERIC_TIME_VSYSCALL_OLD systems time: Introduce new GENERIC_TIME_VSYSCALL time: Convert CONFIG_GENERIC_TIME_VSYSCALL to CONFIG_GENERIC_TIME_VSYSCALL_OLD time: Move update_vsyscall definitions to timekeeper_internal.h time: Move timekeeper structure to timekeeper_internal.h for vsyscall changes jiffies: Remove compile time assumptions about CLOCK_TICK_RATE jiffies: Kill unused TICK_USEC_TO_NSEC alarmtimer: Rename alarmtimer_remove to alarmtimer_dequeue alarmtimer: Remove unused helpers & defines alarmtimer: Use hrtimer per-alarm instead of per-base alarmtimer: Implement minimum alarm interval for allowing suspend
2012-10-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull pile 2 of execve and kernel_thread unification work from Al Viro: "Stuff in there: kernel_thread/kernel_execve/sys_execve conversions for several more architectures plus assorted signal fixes and cleanups. There'll be more (in particular, real fixes for the alpha do_notify_resume() irq mess)..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (43 commits) alpha: don't open-code trace_report_syscall_{enter,exit} Uninclude linux/freezer.h m32r: trim masks avr32: trim masks tile: don't bother with SIGTRAP in setup_frame microblaze: don't bother with SIGTRAP in setup_rt_frame() mn10300: don't bother with SIGTRAP in setup_frame() frv: no need to raise SIGTRAP in setup_frame() x86: get rid of duplicate code in case of CONFIG_VM86 unicore32: remove pointless test h8300: trim _TIF_WORK_MASK parisc: decide whether to go to slow path (tracesys) based on thread flags parisc: don't bother looping in do_signal() parisc: fix double restarts bury the rest of TIF_IRET sanitize tsk_is_polling() bury _TIF_RESTORE_SIGMASK unicore32: unobfuscate _TIF_WORK_MASK mips: NOTIFY_RESUME is not needed in TIF masks mips: merge the identical "return from syscall" per-ABI code ... Conflicts: arch/arm/include/asm/thread_info.h
2012-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull generic execve() changes from Al Viro: "This introduces the generic kernel_thread() and kernel_execve() functions, and switches x86, arm, alpha, um and s390 over to them." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits) s390: convert to generic kernel_execve() s390: switch to generic kernel_thread() s390: fold kernel_thread_helper() into ret_from_fork() s390: fold execve_tail() into start_thread(), convert to generic sys_execve() um: switch to generic kernel_thread() x86, um/x86: switch to generic sys_execve and kernel_execve x86: split ret_from_fork alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve() alpha: switch to generic kernel_thread() alpha: switch to generic sys_execve() arm: get rid of execve wrapper, switch to generic execve() implementation arm: optimized current_pt_regs() arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve() arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk] generic sys_execve() generic kernel_execve() new helper: current_pt_regs() preparation for generic kernel_thread() um: kill thread->forking um: let signal_delivered() do SIGTRAP on singlestepping into handler ...
2012-10-09UAPI: (Scripted) Disintegrate arch/ia64/include/asmDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-09Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge patches from Andrew Morton: "A few misc things and very nearly all of the MM tree. A tremendous amount of stuff (again), including a significant rbtree library rework." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (160 commits) sparc64: Support transparent huge pages. mm: thp: Use more portable PMD clearing sequenece in zap_huge_pmd(). mm: Add and use update_mmu_cache_pmd() in transparent huge page code. sparc64: Document PGD and PMD layout. sparc64: Eliminate PTE table memory wastage. sparc64: Halve the size of PTE tables sparc64: Only support 4MB huge pages and 8KB base pages. memory-hotplug: suppress "Trying to free nonexistent resource <XXXXXXXXXXXXXXXX-YYYYYYYYYYYYYYYY>" warning mm: memcg: clean up mm_match_cgroup() signature mm: document PageHuge somewhat mm: use %pK for /proc/vmallocinfo mm, thp: fix mlock statistics mm, thp: fix mapped pages avoiding unevictable list on mlock memory-hotplug: update memory block's state and notify userspace memory-hotplug: preparation to notify memory block's state at memory hot remove mm: avoid section mismatch warning for memblock_type_name make GFP_NOTRACK definition unconditional cma: decrease cc.nr_migratepages after reclaiming pagelist CMA: migrate mlocked pages kpageflags: fix wrong KPF_THP on non-huge compound pages ...
2012-10-09mm: fix-up zone present pagesJianguo Wu
I think zone->present_pages indicates pages that buddy system can management, it should be: zone->present_pages = spanned pages - absent pages - bootmem pages, but is now: zone->present_pages = spanned pages - absent pages - memmap pages. spanned pages: total size, including holes. absent pages: holes. bootmem pages: pages used in system boot, managed by bootmem allocator. memmap pages: pages used by page structs. This may cause zone->present_pages less than it should be. For example, numa node 1 has ZONE_NORMAL and ZONE_MOVABLE, it's memmap and other bootmem will be allocated from ZONE_MOVABLE, so ZONE_NORMAL's present_pages should be spanned pages - absent pages, but now it also minus memmap pages(free_area_init_core), which are actually allocated from ZONE_MOVABLE. When offlining all memory of a zone, this will cause zone->present_pages less than 0, because present_pages is unsigned long type, it is actually a very large integer, it indirectly caused zone->watermark[WMARK_MIN] becomes a large integer(setup_per_zone_wmarks()), than cause totalreserve_pages become a large integer(calculate_totalreserve_pages()), and finally cause memory allocating failure when fork process(__vm_enough_memory()). [root@localhost ~]# dmesg -bash: fork: Cannot allocate memory I think the bug described in http://marc.info/?l=linux-mm&m=134502182714186&w=2 is also caused by wrong zone present pages. This patch intends to fix-up zone->present_pages when memory are freed to buddy system on x86_64 and IA64 platforms. Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reported-by: Petr Tesarik <ptesarik@suse.cz> Tested-by: Petr Tesarik <ptesarik@suse.cz> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09readahead: fault retry breaks mmap file read random detectionShaohua Li
.fault now can retry. The retry can break state machine of .fault. In filemap_fault, if page is miss, ra->mmap_miss is increased. In the second try, since the page is in page cache now, ra->mmap_miss is decreased. And these are done in one fault, so we can't detect random mmap file access. Add a new flag to indicate .fault is tried once. In the second try, skip ra->mmap_miss decreasing. The filemap_fault state machine is ok with it. I only tested x86, didn't test other archs, but looks the change for other archs is obvious, but who knows :) Signed-off-by: Shaohua Li <shaohua.li@fusionio.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: hugetlb: add arch hook for clearing page flags before entering poolWill Deacon
The core page allocator ensures that page flags are zeroed when freeing pages via free_pages_check. A number of architectures (ARM, PPC, MIPS) rely on this property to treat new pages as dirty with respect to the data cache and perform the appropriate flushing before mapping the pages into userspace. This can lead to cache synchronisation problems when using hugepages, since the allocator keeps its own pool of pages above the usual page allocator and does not reset the page flags when freeing a page into the pool. This patch adds a new architecture hook, arch_clear_hugepage_flags, so that architectures which rely on the page flags being in a particular state for fresh allocations can adjust the flags accordingly when a page is freed into the pool. Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Michal Hocko <mhocko@suse.cz> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: kill vma flag VM_RESERVED and mm->reserved_vm counterKonstantin Khlebnikov
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA, currently it lost original meaning but still has some effects: | effect | alternative flags -+------------------------+--------------------------------------------- 1| account as reserved_vm | VM_IO 2| skip in core dump | VM_IO, VM_DONTDUMP 3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP 4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP This patch removes reserved_vm counter from mm_struct. Seems like nobody cares about it, it does not exported into userspace directly, it only reduces total_vm showed in proc. Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP. remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP. remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP. [akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Merge tag 'asm-generic' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic updates from Arnd Bergmann: "This has three changes for asm-generic that did not really fit into any other branch as normal asm-generic changes do. One is a fix for a build warning, the other two are more interesting: * A patch from Mark Brown to allow using the common clock infrastructure on all architectures, so we can use the clock API in architecture independent device drivers. * The UAPI split patches from David Howells for the asm-generic files. There are other architecture specific series that are going through the arch maintainer tree and that depend on this one. There may be a few small merge conflicts between Mark's patch and the following arch header file split patches. In each case the solution will be to keep the new "generic-y += clkdev.h" line, even if it ends up being the only line in the Kbuild file." * tag 'asm-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: UAPI: (Scripted) Disintegrate include/asm-generic asm-generic: Add default clkdev.h asm-generic: xor: mark static functions as __maybe_unused
2012-10-07Merge tag 'stable/for-linus-3.7-arm-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull ADM Xen support from Konrad Rzeszutek Wilk: Features: * Allow a Linux guest to boot as initial domain and as normal guests on Xen on ARM (specifically ARMv7 with virtualized extensions). PV console, block and network frontend/backends are working. Bug-fixes: * Fix compile linux-next fallout. * Fix PVHVM bootup crashing. The Xen-unstable hypervisor (so will be 4.3 in a ~6 months), supports ARMv7 platforms. The goal in implementing this architecture is to exploit the hardware as much as possible. That means use as little as possible of PV operations (so no PV MMU) - and use existing PV drivers for I/Os (network, block, console, etc). This is similar to how PVHVM guests operate in X86 platform nowadays - except that on ARM there is no need for QEMU. The end result is that we share a lot of the generic Xen drivers and infrastructure. Details on how to compile/boot/etc are available at this Wiki: http://wiki.xen.org/wiki/Xen_ARMv7_with_Virtualization_Extensions and this blog has links to a technical discussion/presentations on the overall architecture: http://blog.xen.org/index.php/2012/09/21/xensummit-sessions-new-pvh-virtualisation-mode-for-arm-cortex-a15arm-servers-and-x86/ * tag 'stable/for-linus-3.7-arm-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (21 commits) xen/xen_initial_domain: check that xen_start_info is initialized xen: mark xen_init_IRQ __init xen/Makefile: fix dom-y build arm: introduce a DTS for Xen unprivileged virtual machines MAINTAINERS: add myself as Xen ARM maintainer xen/arm: compile netback xen/arm: compile blkfront and blkback xen/arm: implement alloc/free_xenballooned_pages with alloc_pages/kfree xen/arm: receive Xen events on ARM xen/arm: initialize grant_table on ARM xen/arm: get privilege status xen/arm: introduce CONFIG_XEN on ARM xen: do not compile manage, balloon, pci, acpi, pcpu and cpu_hotplug on ARM xen/arm: Introduce xen_ulong_t for unsigned long xen/arm: Xen detection and shared_info page mapping docs: Xen ARM DT bindings xen/arm: empty implementation of grant_table arch specific functions xen/arm: sync_bitops xen/arm: page.h definitions xen/arm: hypercalls ...
2012-10-06sections: fix section conflicts in arch/ia64Andi Kleen
Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-04Merge branch 'disintegrate-asm-generic' of ↵Arnd Bergmann
git://git.infradead.org/users/dhowells/linux-headers into asm-generic Patches from David Howells <dhowells@redhat.com>: This is to complete part of the UAPI disintegration for which the preparatory patches were pulled recently. Note that there are some fixup patches which are at the base of the branch aimed at you, plus all arches get the asm-generic branch merged in too. * 'disintegrate-asm-generic' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: (Scripted) Disintegrate include/asm-generic UAPI: Fix conditional header installation handling (notably kvm_para.h on m68k) c6x: remove c6x signal.h UAPI: Split compound conditionals containing __KERNEL__ in Arm64 UAPI: Fix the guards on various asm/unistd.h files Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-04Merge tag 'kvm-3.7-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Avi Kivity: "Highlights of the changes for this release include support for vfio level triggered interrupts, improved big real mode support on older Intels, a streamlines guest page table walker, guest APIC speedups, PIO optimizations, better overcommit handling, and read-only memory." * tag 'kvm-3.7-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (138 commits) KVM: s390: Fix vcpu_load handling in interrupt code KVM: x86: Fix guest debug across vcpu INIT reset KVM: Add resampling irqfds for level triggered interrupts KVM: optimize apic interrupt delivery KVM: MMU: Eliminate pointless temporary 'ac' KVM: MMU: Avoid access/dirty update loop if all is well KVM: MMU: Eliminate eperm temporary KVM: MMU: Optimize is_last_gpte() KVM: MMU: Simplify walk_addr_generic() loop KVM: MMU: Optimize pte permission checks KVM: MMU: Update accessed and dirty bits after guest pagetable walk KVM: MMU: Move gpte_access() out of paging_tmpl.h KVM: MMU: Optimize gpte_access() slightly KVM: MMU: Push clean gpte write protection out of gpte_access() KVM: clarify kvmclock documentation KVM: make processes waiting on vcpu mutex killable KVM: SVM: Make use of asm.h KVM: VMX: Make use of asm.h KVM: VMX: Make lto-friendly KVM: x86: lapic: Clean up find_highest_vector() and count_vectors() ... Conflicts: arch/s390/include/asm/processor.h arch/x86/kvm/i8259.c
2012-10-03Merge tag 'uapi-prep-20121002' of ↵Linus Torvalds
git://git.infradead.org/users/dhowells/linux-headers Pull preparatory patches for user API disintegration from David Howells: "The patches herein prepare for the extraction of the Userspace API bits from the various header files named in the Kbuild files. New subdirectories are created under either include/uapi/ or arch/x/include/uapi/ that correspond to the subdirectory containing that file under include/ or arch/x/include/. The new subdirs under the uapi/ directory are populated with Kbuild files that mostly do nothing at this time. Further patches will disintegrate the headers in each original directory and fill in the Kbuild files as they do it. These patches also: (1) fix up #inclusions of "foo.h" rather than <foo.h>. (2) Remove some redundant #includes from the DRM code. (3) Make the kernel build infrastructure handle Kbuild files both in the old places and the new UAPI place that both specify headers to be exported. (4) Fix some kernel tools that #include kernel headers during their build. I have compile tested this with allyesconfig against x86_64, allmodconfig against i386 and a scattering of additional defconfigs of other arches. Prepared for main script Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com>" * tag 'uapi-prep-20121002' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: Plumb the UAPI Kbuilds into the user header installation and checking UAPI: x86: Differentiate the generated UAPI and internal headers UAPI: Remove the objhdr-y export list UAPI: Move linux/version.h UAPI: Set up uapi/asm/Kbuild.asm UAPI: x86: Fix insn_sanity build failure after UAPI split UAPI: x86: Fix the test_get_len tool UAPI: (Scripted) Set up UAPI Kbuild files UAPI: Partition the header include path sets and add uapi/ header directories UAPI: (Scripted) Convert #include "..." to #include <path/...> in kernel system headers UAPI: (Scripted) Convert #include "..." to #include <path/...> in drivers/gpu/ UAPI: (Scripted) Remove redundant DRM UAPI header #inclusions from drivers/gpu/. UAPI: Refer to the DRM UAPI headers with <...> and from certain headers only
2012-10-03asm-generic: Add default clkdev.hMark Brown
Ease the deployment of clkdev by providing a default asm/clkdev.h for use if the arch does not have an include/asm/clkdev.h. Due to limitations in Kbuild we manually add clkdev.h to all architectures that don't have one rather than having the header appear by default. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-02Merge tag 'stable/for-linus-3.7-x86-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen update from Konrad Rzeszutek Wilk: "Features: - When hotplugging PCI devices in a PV guest we can allocate Xen-SWIOTLB later. - Cleanup Xen SWIOTLB. - Support pages out grants from HVM domains in the backends. - Support wild cards in xen-pciback.hide=(BDF) arguments. - Update grant status updates with upstream hypervisor. - Boot PV guests with more than 128GB. - Cleanup Xen MMU code/add comments. - Obtain XENVERS using a preferred method. - Lay out generic changes to support Xen ARM. - Allow privcmd ioctl for HVM (used to do only PV). - Do v2 of mmap_batch for privcmd ioctls. - If hypervisor saves the LED keyboard light - we will now instruct the kernel about its state. Fixes: - More fixes to Xen PCI backend for various calls/FLR/etc. - With more than 4GB in a 64-bit PV guest disable native SWIOTLB. - Fix up smatch warnings. - Fix up various return values in privmcmd and mm." * tag 'stable/for-linus-3.7-x86-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (48 commits) xen/pciback: Restore the PCI config space after an FLR. xen-pciback: properly clean up after calling pcistub_device_find() xen/vga: add the xen EFI video mode support xen/x86: retrieve keyboard shift status flags from hypervisor. xen/gndev: Xen backend support for paged out grant targets V4. xen-pciback: support wild cards in slot specifications xen/swiotlb: Fix compile warnings when using plain integer instead of NULL pointer. xen/swiotlb: Remove functions not needed anymore. xen/pcifront: Use Xen-SWIOTLB when initting if required. xen/swiotlb: For early initialization, return zero on success. xen/swiotlb: Use the swiotlb_late_init_with_tbl to init Xen-SWIOTLB late when PV PCI is used. xen/swiotlb: Move the error strings to its own function. xen/swiotlb: Move the nr_tbl determination in its own function. xen/arm: compile and run xenbus xen: resynchronise grant table status codes with upstream xen/privcmd: return -EFAULT on error xen/privcmd: Fix mmap batch ioctl error status copy back. xen/privcmd: add PRIVCMD_MMAPBATCH_V2 ioctl xen/mm: return more precise error from xen_remap_domain_range() xen/mmu: If the revector fails, don't attempt to revector anything else. ...
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-10-02UAPI: (Scripted) Set up UAPI Kbuild filesDavid Howells
Set up empty UAPI Kbuild files to be populated by the header splitter. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-01Merge tag 'please-pull-ia64-for-3.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull ia64 update from Tony Luck: "Usual mish-mash of ia64 fixes for next merge window" * tag 'please-pull-ia64-for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: [IA64] xen: Fix return value check in xencomm_vtop() [IA64] Must enable interrupts in do_notify_resume_user before calling tracehook_notify_resume() [IA64] kexec: Move the dereference below the NULL test [IA64] Fix a node distance bug
2012-10-01Merge tag 'tty-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/ttyLinus Torvalds
Pull TTY changes from Greg Kroah-Hartman: "As we skipped the merge window for 3.6-rc1 for the tty tree, everything is now settled down and working properly, so we are ready for 3.7-rc1. Here's the patchset, it's big, but the large changes are removing a firmware file and adding a staging tty driver (it depended on the tty core changes, so it's going through this tree instead of the staging tree.) All of these patches have been in the linux-next tree for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up more-or-less trivial conflicts in - drivers/char/pcmcia/synclink_cs.c: tty NULL dereference fix vs tty_port_cts_enabled() helper function - drivers/staging/{Kconfig,Makefile}: add-add conflict (dgrp driver added close to other staging drivers) - drivers/staging/ipack/devices/ipoctal.c: "split ipoctal_channel from iopctal" vs "TTY: use tty_port_register_device" * tag 'tty-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (235 commits) tty/serial: Add kgdb_nmi driver tty/serial/amba-pl011: Quiesce interrupts in poll_get_char tty/serial/amba-pl011: Implement poll_init callback tty/serial/core: Introduce poll_init callback kdb: Turn KGDB_KDB=n stubs into static inlines kdb: Implement disable_nmi command kernel/debug: Mask KGDB NMI upon entry serial: pl011: handle corruption at high clock speeds serial: sccnxp: Make 'default' choice in switch last serial: sccnxp: Remove mask termios caps for SW flow control serial: sccnxp: Report actual baudrate back to core serial: samsung: Add poll_get_char & poll_put_char Powerpc 8xx CPM_UART setting MAXIDL register proportionaly to baud rate Powerpc 8xx CPM_UART maxidl should not depend on fifo size Powerpc 8xx CPM_UART too many interrupts Powerpc 8xx CPM_UART desynchronisation serial: set correct baud_base for EXSYS EX-41092 Dual 16950 serial: omap: fix the reciever line error case 8250: blacklist Winbond CIR port 8250_pnp: do pnp probe before legacy probe ...
2012-10-01Merge tag 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pciLinus Torvalds
Pull PCI changes from Bjorn Helgaas: "Host bridge hotplug - Protect acpi_pci_drivers and acpi_pci_roots (Taku Izumi) - Clear host bridge resource info to avoid issue when releasing (Yinghai Lu) - Notify acpi_pci_drivers when hot-plugging host bridges (Jiang Liu) - Use standard list ops for acpi_pci_drivers (Jiang Liu) Device hotplug - Use pci_get_domain_bus_and_slot() to close hotplug races (Jiang Liu) - Remove fakephp driver (Bjorn Helgaas) - Fix VGA ref count in hotplug remove path (Yinghai Lu) - Allow acpiphp to handle PCIe ports without native hotplug (Jiang Liu) - Implement resume regardless of pciehp_force param (Oliver Neukum) - Make pci_fixup_irqs() work after init (Thierry Reding) Miscellaneous - Add pci_pcie_type(dev) and remove pci_dev.pcie_type (Yijing Wang) - Factor out PCI Express Capability accessors (Jiang Liu) - Add pcibios_window_alignment() so powerpc EEH can use generic resource assignment (Gavin Shan) - Make pci_error_handlers const (Stephen Hemminger) - Cleanup drivers/pci/remove.c (Bjorn Helgaas) - Improve Vendor-Specific Extended Capability support (Bjorn Helgaas) - Use standard list ops for bus->devices (Bjorn Helgaas) - Avoid kmalloc in pci_get_subsys() and pci_get_class() (Feng Tang) - Reassign invalid bus number ranges (Intel DP43BF workaround) (Yinghai Lu)" * tag 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (102 commits) PCI: acpiphp: Handle PCIe ports without native hotplug capability PCI/ACPI: Use acpi_driver_data() rather than searching acpi_pci_roots PCI/ACPI: Protect acpi_pci_roots list with mutex PCI/ACPI: Use acpi_pci_root info rather than looking it up again PCI/ACPI: Pass acpi_pci_root to acpi_pci_drivers' add/remove interface PCI/ACPI: Protect acpi_pci_drivers list with mutex PCI/ACPI: Notify acpi_pci_drivers when hot-plugging PCI root bridges PCI/ACPI: Use normal list for struct acpi_pci_driver PCI/ACPI: Use DEVICE_ACPI_HANDLE rather than searching acpi_pci_roots PCI: Fix default vga ref_count ia64/PCI: Clear host bridge aperture struct resource x86/PCI: Clear host bridge aperture struct resource PCI: Stop all children first, before removing all children Revert "PCI: Use hotplug-safe pci_get_domain_bus_and_slot()" PCI: Provide a default pcibios_update_irq() PCI: Discard __init annotations for pci_fixup_irqs() and related functions PCI: Use correct type when freeing bus resource list PCI: Check P2P bridge for invalid secondary/subordinate range PCI: Convert "new_id"/"remove_id" into generic pci_bus driver attributes xen-pcifront: Use hotplug-safe pci_get_domain_bus_and_slot() ...
2012-10-01Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "Continued quest to clean up and enhance the cputime code by Frederic Weisbecker, in preparation for future tickless kernel features. Other than that, smallish changes." Fix up trivial conflicts due to additions next to each other in arch/{x86/}Kconfig * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) cputime: Make finegrained irqtime accounting generally available cputime: Gather time/stats accounting config options into a single menu ia64: Reuse system and user vtime accounting functions on task switch ia64: Consolidate user vtime accounting vtime: Consolidate system/idle context detection cputime: Use a proper subsystem naming for vtime related APIs sched: cpu_power: enable ARCH_POWER sched/nohz: Clean up select_nohz_load_balancer() sched: Fix load avg vs. cpu-hotplug sched: Remove __ARCH_WANT_INTERRUPTS_ON_CTXSW sched: Fix nohz_idle_balance() sched: Remove useless code in yield_to() sched: Add time unit suffix to sched sysctl knobs sched/debug: Limit sd->*_idx range on sysctl sched: Remove AFFINE_WAKEUPS feature flag s390: Remove leftover account_tick_vtime() header cputime: Consolidate vtime handling on context switch sched: Move cputime code to its own file cputime: Generalize CONFIG_VIRT_CPU_ACCOUNTING tile: Remove SD_PREFER_LOCAL leftover ...
2012-10-01sanitize tsk_is_polling()Al Viro
Make default just return 0. The current default (checking TIF_POLLING_NRFLAG) is taken to architectures that need it; ones that don't do polling in their idle threads don't need to defined TIF_POLLING_NRFLAG at all. ia64 defined both TS_POLLING (used by its tsk_is_polling()) and TIF_POLLING_NRFLAG (not used at all). Killed the latter... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-01ia64: can't reach do_signal() when returning to kernel modeAl Viro
2012-09-28Make most arch asm/module.h files use asm-generic/module.hDavid Howells
Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela, ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version into asm-generic/module.h for all arches bar MIPS. Also, use the generic definition mod_arch_specific where possible. To this end, I've defined three new config bools: (*) HAVE_MOD_ARCH_SPECIFIC Arches define this if they don't want to use the empty generic mod_arch_specific struct. (*) MODULES_USE_ELF_RELA Arches define this if their modules can contain RELA records. This causes the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be defined by the arch rather than have the core emit an error message. (*) MODULES_USE_ELF_REL Arches define this if their modules can contain REL records. This causes the Elf_Rel mapping to be emitted and allows apply_relocate() to be defined by the arch rather than have the core emit an error message. Note that it is possible to allow both REL and RELA records: m68k and mips are two arches that do this. With this, some arch asm/module.h files can be deleted entirely and replaced with a generic-y marker in the arch Kbuild file. Additionally, I have removed the bits from m32r and score that handle the unsupported type of relocation record as that's now handled centrally. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-27[IA64] xen: Fix return value check in xencomm_vtop()Wei Yongjun
In case of error, the function follow_page() returns ERR_PTR() or NULL pointer. The NULL test in the error handling should be replaced with IS_ERR_OR_NULL(). dpatch engine is used to auto generated this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-09-26switch simple cases of fget_light to fdgetAl Viro
2012-09-26make get_file() return its argumentAl Viro
simplifies a bunch of callers... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-26switch itanic perfmonctl(2) to fget_light()Al Viro
2012-09-25ia64: Reuse system and user vtime accounting functions on task switchFrederic Weisbecker
To avoid code duplication. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-09-25ia64: Consolidate user vtime accountingFrederic Weisbecker
Factorize the code that accounts user time into a single function to avoid code duplication. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-09-25vtime: Consolidate system/idle context detectionFrederic Weisbecker
Move the code that finds out to which context we account the cputime into generic layer. Archs that consider the whole time spent in the idle task as idle time (ia64, powerpc) can rely on the generic vtime_account() and implement vtime_account_system() and vtime_account_idle(), letting the generic code to decide when to call which API. Archs that have their own meaning of idle time, such as s390 that only considers the time spent in CPU low power mode as idle time, can just override vtime_account(). Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-09-25cputime: Use a proper subsystem naming for vtime related APIsFrederic Weisbecker
Use a naming based on vtime as a prefix for virtual based cputime accounting APIs: - account_system_vtime() -> vtime_account() - account_switch_vtime() -> vtime_task_switch() It makes it easier to allow for further declension such as vtime_account_system(), vtime_account_idle(), ... if we want to find out the context we account to from generic code. This also make it better to know on which subsystem these APIs refer to. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-09-24Merge branch 'pci/yinghai-misc' into nextBjorn Helgaas
2012-09-24time: Convert CONFIG_GENERIC_TIME_VSYSCALL to CONFIG_GENERIC_TIME_VSYSCALL_OLDJohn Stultz
To help migrate archtectures over to the new update_vsyscall method, redfine CONFIG_GENERIC_TIME_VSYSCALL as CONFIG_GENERIC_TIME_VSYSCALL_OLD Cc: Tony Luck <tony.luck@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Turner <pjt@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2012-09-24time: Move update_vsyscall definitions to timekeeper_internal.hJohn Stultz
Since users will need to include timekeeper_internal.h, move update_vsyscall definitions to timekeeper_internal.h. Cc: Tony Luck <tony.luck@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Turner <pjt@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2012-09-23ia64: Add missing RCU idle APIs on idle loopPaul E. McKenney
Traditionally, the entire idle task served as an RCU quiescent state. But when RCU read side critical sections started appearing within the idle loop, this traditional strategy became untenable. The fix was to create new RCU APIs named rcu_idle_enter() and rcu_idle_exit(), which must be called by each architecture's idle loop so that RCU can tell when it is safe to ignore a given idle CPU. Unfortunately, this fix was never applied to ia64, a shortcoming remedied by this commit. Reported by: Tony Luck <tony.luck@intel.com> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Cc: <stable@vger.kernel.org> # 3.3+ Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested by: Tony Luck <tony.luck@intel.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2012-09-21ia64/PCI: Clear host bridge aperture struct resourceYinghai Lu
Use kzalloc() so the struct resource doesn't contain garbage in fields we don't initialize. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: linux-ia64@vger.kernel.org
2012-09-21userns: On ia64 deal with current_uid and current_gid being kuid and kgidEric W. Biederman
These ia64 uses of current_uid and current_gid slipped through the cracks when I was converting everything to kuids and kgids convert them now. Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-09-20[IA64] Must enable interrupts in do_notify_resume_user before calling ↵Tony Luck
tracehook_notify_resume() If we call with interrupts disabled, we'll be hit with: WARNING: at kernel/softirq.c:160 local_bh_enable_ip+0x150/0x180() and a stack trace like this: Call Trace: [<a000000100015480>] show_stack+0x80/0xa0 [<a000000100d9a520>] dump_stack+0x30/0x50 [<a000000100072fc0>] warn_slowpath_common+0xc0/0x100 [<a000000100073040>] warn_slowpath_null+0x40/0x60 [<a0000001000884d0>] local_bh_enable_ip+0x150/0x180 [<a000000100da2960>] _raw_write_unlock_bh+0x40/0x60 [<a000000100cf03c0>] unix_release_sock+0x120/0x5a0 [<a000000100cf0880>] unix_release+0x40/0x60 [<a000000100b84400>] sock_release+0x60/0x1a0 [<a000000100b84b70>] sock_close+0x30/0xa0 [<a0000001001d10f0>] __fput+0x190/0x500 [<a0000001001d1580>] ____fput+0x20/0x40 [<a0000001000b6570>] task_work_run+0x1b0/0x260 [<a000000100015190>] do_notify_resume_user+0x110/0x2a0 [<a00000010000c5a0>] notify_resume_user+0x40/0x60 [<a00000010000c4d0>] skip_rbs_switch+0xe0/0xf0 [<a000000000040720>] ia64_ivt+0xffffffff00040720/0x400 Fix-suggested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-09-20get rid of generic instances of asm/exec.hAl Viro
2012-09-19Merge branch 'pci/thierry-fixup-irqs' into nextBjorn Helgaas
* pci/thierry-fixup-irqs: PCI: Provide a default pcibios_update_irq() PCI: Discard __init annotations for pci_fixup_irqs() and related functions
