path: root/arch/ia64/sn
2012-04-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull DMA mapping branch from Marek Szyprowski: "Short summary for the whole series: A few limitations have been identified in the current dma-mapping design and its implementations for various architectures. There exist more than one function for allocating and freeing the buffers: currently these 3 are used dma_{alloc, free}_coherent, dma_{alloc,free}_writecombine, dma_{alloc,free}_noncoherent. For most of the systems these calls are almost equivalent and can be interchanged. For others, especially the truly non-coherent ones (like ARM), the difference can be easily noticed in overall driver performance. Sadly not all architectures provide implementations for all of them, so the drivers might need to be adapted and cannot be easily shared between different architectures. The provided patches unify all these functions and hide the differences under the already existing dma attributes concept. The thread with more references is available here: http://www.spinics.net/lists/linux-sh/msg09777.html These patches are also a prerequisite for unifying DMA-mapping implementation on ARM architecture with the common one provided by dma_map_ops structure and extending it with IOMMU support. More information is available in the following thread: http://thread.gmane.org/gmane.linux.kernel.cross-arch/12819 More works on dma-mapping framework are planned, especially in the area of buffer sharing and managing the shared mappings (together with the recently introduced dma_buf interface: commit d15bd7ee445d "dma-buf: Introduce dma buffer sharing mechanism"). The patches in the current set introduce a new alloc/free methods (with support for memory attributes) in dma_map_ops structure, which will later replace dma_alloc_coherent and dma_alloc_writecombine functions." People finally started piping up with support for merging this, so I'm merging it as the last of the pending stuff from the merge window. Looks like pohmelfs is going to wait for 3.5 and more external support for merging. * 'for-linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: common: DMA-mapping: add NON-CONSISTENT attribute common: DMA-mapping: add WRITE_COMBINE attribute common: dma-mapping: introduce mmap method common: dma-mapping: remove old alloc_coherent and free_coherent methods Hexagon: adapt for dma_map_ops changes Unicore32: adapt for dma_map_ops changes Microblaze: adapt for dma_map_ops changes SH: adapt for dma_map_ops changes Alpha: adapt for dma_map_ops changes SPARC: adapt for dma_map_ops changes PowerPC: adapt for dma_map_ops changes MIPS: adapt for dma_map_ops changes X86 & IA64: adapt for dma_map_ops changes common: dma-mapping: introduce generic alloc() and free() methods
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Disintegrate asm/system.h for IA64David Howells
Disintegrate asm/system.h for IA64. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Tony Luck <tony.luck@intel.com> cc: linux-ia64@vger.kernel.org
2012-03-28X86 & IA64: adapt for dma_map_ops changesAndrzej Pietrasiewicz
Adapt core x86 and IA64 architecture code for dma_map_ops changes: replace alloc/free_coherent with generic alloc/free methods. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> [removed swiotlb related changes and replaced it with wrappers, merged with IA64 patch to avoid inter-patch dependences in intel-iommu code] Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Tony Luck <tony.luck@intel.com>
2012-03-23Merge tag 'ia64-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull miscellaneous Itanium patches from Tony Luck. The conflicts in arch/ia64/hp/sim/simserial.c were due to patches to simserial that had alredy been included (with lots of further cleanups) in the serial tree. * tag 'ia64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: Documentation/kernel-parameters: remove inttest parameter [IA64] Fix ISA IRQ trigger model and polarity setting [IA64] Fix a couple of warnings for EXPORT_SYMBOL [IA64] Check return from device_register() in cx_device_register() [IA64] Fix warning from machine_kexec.c [IA64] simserial, bail out when request_irq fails [IA64] hpsim, initialize chip for assigned irqs [IA64] simserial, include some headers [IA64] hpsim, fix SAL handling in fw-emu [IA64] genirq fixup for SGI/SN [IA64] disable interrupts when exiting from ia64_mca_cmc_int_handler()
2012-02-27[IA64] Fix a couple of warnings for EXPORT_SYMBOLPaul Gortmaker
To get rid of things like: arch/ia64/sn/kernel/sn2/sn_hwperf.c:1002:1: warning: data definition has no type or storage class arch/ia64/sn/kernel/sn2/sn_hwperf.c:1002:1: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' arch/ia64/sn/kernel/sn2/sn_hwperf.c:1002:1: warning: parameter names (without types) in function declaration Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-02-27[IA64] Check return from device_register() in cx_device_register()Paul Gortmaker
The device_register() is declared with must_check, causing this: arch/ia64/sn/kernel/tiocx.c: In function 'cx_device_register': arch/ia64/sn/kernel/tiocx.c:210:17: warning: ignoring return value of 'device_register', declared with attribute warn_unused_result Check the return value, and free resources if it fails. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-02-23ia64/PCI: get rid of device resource fixupsBjorn Helgaas
Tell the PCI core about host bridge address translation so it can take care of bus-to-resource conversion for us. CC: Tony Luck <tony.luck@intel.com> CC: Jack Steiner <steiner@sgi.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-02-23ia64/PCI: SN: convert to pci_scan_root_bus() for correct root bus resourcesBjorn Helgaas
Convert from pci_scan_bus() to pci_scan_root_bus(). Supply the root bus resources from bussoft. When we move the resource adjustment from pcibios_fixup_resources() to the PCI core, it will be important to have the root bus resources correct from the beginning. CC: Tony Luck <tony.luck@intel.com> CC: Jack Steiner <steiner@sgi.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-02-22[IA64] genirq fixup for SGI/SNDimitri Sivanich
This patch allows the system to boot and enables the console and at least some hardware drivers, as well as some platform error handling. Tested on a variety of SGI Altix system without issues. Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> Tested-by: Raymund Will <rw@suse.de> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-12-09ia64: pcibr: Use kmemdup rather than duplicating its implementationThomas Meyer
The semantic patch that makes this change is available in scripts/coccinelle/api/memdup.cocci. Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-12-09ia64: sn: Use kmemdup rather than duplicating its implementationThomas Meyer
2011-12-09ia64: tioca: Use kmemdup rather than duplicating its implementationThomas Meyer
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-10-31ia64: Add export.h to arch/ia64 specific files as requiredPaul Gortmaker
2011-08-11[IA64] sn2: add missing put_cpu()Tony Luck
sn_hwperf_op_cpu() uses get_cpu() but is missing a corresponding put_cpu(). Reported-by: Thomas Meyer <thomas@m3y3r.de> Acked-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-07-22Merge branch 'x86-vdso-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-64, vdso: Do not allocate memory for the vDSO clocksource: Change __ARCH_HAS_CLOCKSOURCE_DATA to a CONFIG option x86, vdso: Drop now wrong comment Document the vDSO and add a reference parser ia64: Replace clocksource.fsys_mmio with generic arch data x86-64: Move vread_tsc and vread_hpet into the vDSO clocksource: Replace vread with generic arch data x86-64: Add --no-undefined to vDSO build x86-64: Allow alternative patching in the vDSO x86: Make alternative instruction pointers relative x86-64: Improve vsyscall emulation CS and RIP handling x86-64: Emulate legacy vsyscalls x86-64: Fill unused parts of the vsyscall page with 0xcc x86-64: Remove vsyscall number 3 (venosys) x86-64: Map the HPET NX x86-64: Remove kernel.vsyscall64 sysctl x86-64: Give vvars their own page x86-64: Document some of entry_64.S x86-64: Fix alignment of jiffies variable
2011-07-20ia64,rcu: Convert call_rcu(sn_irq_info_free) to kfree_rcu()Lai Jiangshan
The rcu callback sn_irq_info_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(sn_irq_info_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-07-14ia64: Replace clocksource.fsys_mmio with generic arch dataAndy Lutomirski
Now that clocksource.archdata is available, use it for ia64-specific code. Cc: Clemens Ladisch <clemens@ladisch.de> Cc: linux-ia64@vger.kernel.org Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andy Lutomirski <luto@mit.edu> Link: http://lkml.kernel.org/r/d31de0ee0842a0e322fb6441571c2b0adb323fa2.1310563276.git.luto@mit.edu Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-05-14Merge branch 'consolidate-clksrc-i8253' of ↵Thomas Gleixner
master.kernel.org:~rmk/linux-2.6-arm into timers/clocksource Conflicts: arch/ia64/kernel/cyclone.c arch/mips/kernel/i8253.c arch/x86/kernel/i8253.c Reason: Resolve conflicts so further cleanups do not conflict further Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-01[IA64] fix build warning: argument 1 of 'irqd_irq_disabled'Tony Luck
In commit f5e5bf088bd3d30990efb7429aaf9f1e5134ffd6 ia64: Use irqd_irq_disabled() instead of desc->status access Thomas forgot to convert from irq to *irq_data. Add a call to irq_get_irq_data() to fix that. Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-03-29[IA64] Fix build breakage - sn_force_interrupt_flag: undefinedTony Luck
Latest irq changes removed the need for this forcing flag, and the definition - but missed the code that allowed it to be tweaked via /proc. Delete accessor functions too. Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-03-29ia64: Convert to the new irq_* function namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: Use irqd_irq_disabled() instead of desc->status accessThomas Gleixner
Remove the last open coded access to irq_desc. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: sn: Use irqd_mark_affinity_set() helperThomas Gleixner
irq_desc->status is going to be restricted. Provide a helper to set that information in irq_data, where it belongs. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: sn: Use irq_move_irq()Thomas Gleixner
This replaces the old move_native_irq() function which is going away. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: Use accessor functions all over the placeThomas Gleixner
Use the proper accessor functions instead of open coded irq_desc access. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: sn: Drop unused functionThomas Gleixner
Leftover from the irq chip conversion. Reported-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29ia64: Convert sn to new irq_chip functionsThomas Gleixner
2011-03-29ia64: Convert msi_sn to new irq_chip functionsThomas Gleixner
2011-03-29ia64: Remove stale irq_chip.endThomas Gleixner
irq_chip.end got obsolete with the removal of __do_IRQ(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tony Luck <tony.luck@intel.com> LKML-Reference: <20110203004210.143127544@linutronix.de>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-17ia64: change to new flag variablesmatt mooney
Replace EXTRA_CFLAGS with ccflags-y and EXTRA_AFLAGS with asflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-02[IA64] tioca: Fix assignment from incompatible pointer warningsJeff Mahoney
The prototype for sn_pci_provider->{dma_map,dma_map_consistent} expects an unsigned long instead of a u64. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-03-02[IA64] setup.c Typo fix "Architechtuallly"Justin P. Mattock
s/Architechtuallly/Architecturally/ Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-02-21ia64: convert to clocksource_register_hz/khzJohn Stultz
This converts the ia64 clocksources to use clocksource_register_hz/khz CC: Tony Luck <tony.luck@intel.com> CC: Thomas Gleixner <tglx@linutronix.de> Tested-by: Tony Luck <tony.luck@intel.com> [clocksource_itc path] Signed-off-by: John Stultz <johnstul@us.ibm.com>
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-12pci: Convert msi to new irq_chip functionsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Tony Luck <tony.luck@intel.com> Cc: Russell King <linux@arm.linux.org.uk>
2010-08-06Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (30 commits) PCI: update for owner removal from struct device_attribute PCI: Fix warnings when CONFIG_DMI unset PCI: Do not run NVidia quirks related to MSI with MSI disabled x86/PCI: use for_each_pci_dev() PCI: use for_each_pci_dev() PCI: MSI: Restore read_msi_msg_desc(); add get_cached_msi_msg_desc() PCI: export SMBIOS provided firmware instance and label to sysfs PCI: Allow read/write access to sysfs I/O port resources x86/PCI: use host bridge _CRS info on ASRock ALiveSATA2-GLAN PCI: remove unused HAVE_ARCH_PCI_SET_DMA_MAX_SEGMENT_{SIZE|BOUNDARY} PCI: disable mmio during bar sizing PCI: MSI: Remove unsafe and unnecessary hardware access PCI: Default PCIe ASPM control to on and require !EMBEDDED to disable PCI: kernel oops on access to pci proc file while hot-removal PCI: pci-sysfs: remove casts from void* ACPI: Disable ASPM if the platform won't provide _OSC control for PCIe PCI hotplug: make sure child bridges are enabled at hotplug time PCI hotplug: shpchp: Removed check for hotplug of display devices PCI hotplug: pciehp: Fixed return value sign for pciehp_unconfigure_device PCI: Don't enable aspm before drivers have had a chance to veto it ...
2010-07-30PCI: MSI: Restore read_msi_msg_desc(); add get_cached_msi_msg_desc()Ben Hutchings
commit 2ca1af9aa3285c6a5f103ed31ad09f7399fc65d7 "PCI: MSI: Remove unsafe and unnecessary hardware access" changed read_msi_msg_desc() to return the last MSI message written instead of reading it from the device, since it may be called while the device is in a reduced power state. However, the pSeries platform code really does need to read messages from the device, since they are initially written by firmware. Therefore: - Restore the previous behaviour of read_msi_msg_desc() - Add new functions get_cached_msi_msg{,_desc}() which return the last MSI message written - Use the new functions where appropriate Acked-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-06-16Merge branch 'master' into for-nextJiri Kosina
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-24Merge branch 'bkl/ioctl' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing * 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing: uml: Pushdown the bkl from harddog_kern ioctl sunrpc: Pushdown the bkl from sunrpc cache ioctl sunrpc: Pushdown the bkl from ioctl autofs4: Pushdown the bkl from ioctl uml: Convert to unlocked_ioctls to remove implicit BKL ncpfs: BKL ioctl pushdown coda: Clean-up whitespace problems in pioctl.c coda: BKL ioctl pushdown drivers: Push down BKL into various drivers isdn: Push down BKL into ioctl functions scsi: Push down BKL into ioctl functions dvb: Push down BKL into ioctl functions smbfs: Push down BKL into ioctl function coda/psdev: Remove BKL from ioctl function um/mmapper: Remove BKL usage sn_hwperf: Kill BKL usage hfsplus: Push down BKL into ioctl function
2010-05-18[IA64] Use set_cpus_allowed_ptrJulia Lawall
Use set_cpus_allowed_ptr rather than set_cpus_allowed. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Tony Luck <tony.luck@intel.com>
2010-05-17sn_hwperf: Kill BKL usageArnd Bergmann
This driver always gave up the BKL in its ioctl function, so just convert it to unlocked_ioctl and remove the BKL here. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
