path: root/arch/ia64/pci
2012-09-24Merge branch 'pci/yinghai-misc' into nextBjorn Helgaas
2012-09-21ia64/PCI: Clear host bridge aperture struct resourceYinghai Lu
Use kzalloc() so the struct resource doesn't contain garbage in fields we don't initialize. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: linux-ia64@vger.kernel.org
2012-09-18PCI: Provide a default pcibios_update_irq()Thierry Reding
Most architectures implement this in exactly the same way. Instead of having each architecture duplicate this function, provide a single implementation in the core and make it a weak symbol so that it can be overridden on architectures where it is required. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-09-18PCI: Discard __init annotations for pci_fixup_irqs() and related functionsThierry Reding
Remove the __init annotations in order to keep pci_fixup_irqs() around after init (e.g. for hotplug). This requires the same change for the implementation of pcibios_update_irq() on all architectures. While at it, all __devinit annotations are removed as well, since they will be useless now that HOTPLUG is always on. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-30Merge tag 'please-pull-ia64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull misc ia64 build fixes from Tony Luck. * tag 'please-pull-ia64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: [IA64] Redefine ATOMIC_INIT and ATOMIC64_INIT to drop the casts [IA64] Rename platform_name to ia64_platform_name [IA64] Mark PARAVIRT and KVM as broken
2012-07-25[IA64] Rename platform_name to ia64_platform_nameFengguang Wu
The macro name is too generic and conflicts with snd_soc_dai_link.platform_name, which triggers lots of build errors. Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-07-05Merge branch 'pci/myron-pcibios_setup' into nextBjorn Helgaas
* pci/myron-pcibios_setup: xtensa/PCI: factor out pcibios_setup() x86/PCI: adjust section annotations for pcibios_setup() unicore32/PCI: adjust section annotations for pcibios_setup() tile/PCI: factor out pcibios_setup() sparc/PCI: factor out pcibios_setup() sh/PCI: adjust section annotations for pcibios_setup() sh/PCI: factor out pcibios_setup() powerpc/PCI: factor out pcibios_setup() parisc/PCI: factor out pcibios_setup() MIPS/PCI: adjust section annotations for pcibios_setup() MIPS/PCI: factor out pcibios_setup() microblaze/PCI: factor out pcibios_setup() ia64/PCI: factor out pcibios_setup() cris/PCI: factor out pcibios_setup() alpha/PCI: factor out pcibios_setup() PCI: pull pcibios_setup() up into core
2012-07-05ia64/PCI: factor out pcibios_setup()Myron Stowe
The PCI core provides a generic pcibios_setup() routine. Drop this architecture-specific version in favor of that. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-13ia64/PCI: register busn_res for root busesYinghai Lu
Add the host bridge bus number aperture from _CRS to the resource list. Like the MMIO and I/O port apertures, this is used when assigning resources to hot-added devices or in the case of conflicts. [bhelgaas: changelog] CC: Tony Luck <tony.luck@intel.com> CC: Fenghua Yu <fenghua.yu@intel.com> CC: linux-ia64@vger.kernel.org Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-13PCI: replace struct pci_bus secondary/subordinate with busn_resYinghai Lu
Replace the struct pci_bus secondary/subordinate members with the struct resource busn_res. Later we'll build a resource tree of these bus numbers. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Disintegrate asm/system.h for IA64David Howells
Disintegrate asm/system.h for IA64. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Tony Luck <tony.luck@intel.com> cc: linux-ia64@vger.kernel.org
2012-02-23ia64/PCI: get rid of device resource fixupsBjorn Helgaas
Tell the PCI core about host bridge address translation so it can take care of bus-to-resource conversion for us. CC: Tony Luck <tony.luck@intel.com> CC: Jack Steiner <steiner@sgi.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-01-06ia64/PCI: convert to pci_create_root_bus() for correct root bus resourcesBjorn Helgaas
Convert from pci_create_bus() to pci_create_root_bus(). This way the root bus resources are correct immediately. This fixes the problem of "early" and "header" quirks seeing incorrect root bus resources. We can't use pci_scan_root_bus() because, like x86, ACPI hotplug currently requires pci_bus_add_devices() in a separate host bridge .start() method. v2: fix compile error by using window resource pointer instead CC: Tony Luck <tony.luck@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-06ia64/PCI: use pci_create_bus() instead of pci_scan_bus_parented()Bjorn Helgaas
This doesn't change any functionality, but it makes a subsequent patch slightly simpler. CC: Tony Luck <tony.luck@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-06PCI: IA64: convert pcibios_set_master() to a non-inlined functionMyron Stowe
This patch converts IA64's architecture-specific 'pcibios_set_master()' routine to a non-inlined function. This will allow follow on patches to create a generic 'pcibios_set_master()' function using the '__weak' attribute which can be used by all architectures as a default which, if necessary, can then be over-ridden by architecture- specific code. Converting 'pci_bios_set_master()' to a non-inlined function will allow IA64's 'pcibios_set_master()' implementation to remain architecture- specific after the generic version is introduced and thus, not change current behavior. No functional change. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-10-31ia64: Add export.h to arch/ia64 specific files as requiredPaul Gortmaker
2010-04-04ACPI: pci_root: pass acpi_pci_root to arch-specific scanBjorn Helgaas
The acpi_pci_root structure contains all the individual items (acpi_device, domain, bus number) we pass to pci_acpi_scan_root(), so just pass the single acpi_pci_root pointer directly. This will make it easier to add _CBA support later. For _CBA, we need the entire downstream bus range, not just the base bus number. We have that in the acpi_pci_root structure, so passing the pointer makes it available to the arch-specific code. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-02-23PCI: augment bus resource table with a listBjorn Helgaas
Previously we used a table of size PCI_BUS_NUM_RESOURCES (16) for resources forwarded to a bus by its upstream bridge. We've increased this size several times when the table overflowed. But there's no good limit on the number of resources because host bridges and subtractive decode bridges can forward any number of ranges to their secondary buses. This patch reduces the table to only PCI_BRIDGE_RESOURCE_NUM (4) entries, which corresponds to the number of windows a PCI-to-PCI (3) or CardBus (4) bridge can positively decode. Any additional resources, e.g., PCI host bridge windows or subtractively-decoded regions, are kept in a list. I'd prefer a single list rather than this split table/list approach, but that requires simultaneous changes to every architecture. This approach only requires immediate changes where we set up (a) host bridges with more than four windows and (b) subtractive-decode P2P bridges, and we can incrementally change other architectures to use the list. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-23PCI: add pci_bus_for_each_resource(), remove direct bus->resource[] refsBjorn Helgaas
No functional change; this converts loops that iterate from 0 to PCI_BUS_NUM_RESOURCES through pci_bus resource[] table to use the pci_bus_for_each_resource() iterator instead. This doesn't change the way resources are stored; it merely removes dependencies on the fact that they're in a table. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22resource/PCI: mark struct resource as constDominik Brodowski
Now that we return the new resource start position, there is no need to update "struct resource" inside the align function. Therefore, mark the struct resource as const. Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22resource/PCI: align functions now return start of resourceDominik Brodowski
As suggested by Linus, align functions should return the start of a resource, not void. An update of "res->start" is no longer necessary. Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04vsprintf: use %pR, %pr instead of %pRt, %pRfBjorn Helgaas
Jesse accidentally applied v1 [1] of the patchset instead of v2 [2]. This is the diff between v1 and v2. The changes in this patch are: - tidied vsprintf stack buffer to shrink and compute size more accurately - use %pR for decoding and %pr for "raw" (with type and flags) instead of adding %pRt and %pRf [1] http://lkml.org/lkml/2009/10/6/491 [2] http://lkml.org/lkml/2009/10/13/441 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04ia64/PCI: print resources consistently with %pRtBjorn Helgaas
This uses %pRt to print additional resource information (type, size, prefetchability, etc.) consistently. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: determine CLS more intelligentlyJesse Barnes
Till now, CLS has been determined either by arch code or as L1_CACHE_BYTES. Only x86 and ia64 set CLS explicitly and x86 doesn't always get it right. On most configurations, the chance is that firmware configures the correct value during boot. This patch makes pci_init() determine CLS by looking at what firmware has configured. It scans all devices and if all non-zero values agree, the value is used. If none is configured or there is a disagreement, pci_dfl_cache_line_size is used. arch can set the dfl value (via PCI_CACHE_LINE_BYTES or pci_dfl_cache_line_size) or override the actual one. ia64, x86 and sparc64 updated to set the default cls instead of the actual one. While at it, declare pci_cache_line_size and pci_dfl_cache_line_size in pci.h and drop private declarations from arch code. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David Miller <davem@davemloft.net> Acked-by: Greg KH <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-10-13[IA64] Require SAL 3.2 in order to do extended config space opsMatthew Wilcox
We had assumed that SAL firmware would return an error if it didn't understand extended config space. Unfortunately, the SAL on the SGI 750 doesn't do that, it panics the machine. So, condition the extended PCI config space accesses on SAL revision 3.2. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Tested-by: Brad Spengler <spender@grsecurity.net> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-06-30ia64/PCI: adjust section annotation for pcibios_setup()Ingo Molnar
Should be __init. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-17ia64: Fix resource assignment for root bussesMatthew Wilcox
ia64 was assigning resources to root busses after allocations had been made for child busses. Calling pcibios_setup_root_windows() from pcibios_fixup_bus() solves this problem by assigning the resources to the root bus before child busses are scanned. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Tested-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-17[IA64] Convert ia64 to use int-ll64.hMatthew Wilcox
It is generally agreed that it would be beneficial for u64 to be an unsigned long long on all architectures. ia64 (in common with several other 64-bit architectures) currently uses unsigned long. Migrating piecemeal is too painful; this giant patch fixes all compilation warnings and errors that come as a result of switching to use int-ll64.h. Note that userspace will still see __u64 defined as unsigned long. This is important as it affects C++ name mangling. [Updated by Tony Luck to change efi.h:efi_freemem_callback_t to use u64 for start/end rather than unsigned long] Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-01-15[IA64] SN specific version of dma_get_required_mask()John Keller
Create a platform specific version of dma_get_required_mask() for ia64 SN Altix. All SN Altix platforms support 64 bit DMA addressing regardless of the size of system memory. Create an ia64 machvec for dma_get_required_mask, with the SN version unconditionally returning DMA_64BIT_MASK. Signed-off-by: John Keller <jpk@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-10-20PCI: Add ability to mmap legacy_io on some platformsBenjamin Herrenschmidt
This adds the ability to mmap legacy IO space to the legacy_io files in sysfs on platforms that support it. This will allow to clean up X to use this instead of /dev/mem for legacy IO accesses such as those performed by Int10. While at it I moved pci_create/remove_legacy_files() to pci-sysfs.c where I think they belong, thus making more things statis in there and cleaned up some spurrious prototypes in the ia64 pci.h file Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-08-18[IA64] pci_acpi_scan_root cleanupLuck, Tony
The code walks all the acpi _CRS methods to see how many windows to allocate. It then scans them all again to insert_resource() for each *even if the first scan found that there were none*. Move the second scan inside the "if (windows)" clause. Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-20PCI: ia64: use generic pci_enable_resources()Bjorn Helgaas
Use the generic pci_enable_resources() instead of the arch-specific code. Unlike this arch-specific code, the generic version: - does not check for a NULL dev pointer - skips resources that have neither IORESOURCE_IO nor IORESOURCE_MEM set Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-15acpi: unneccessary to scan the PCI bus already scannedyakui.zhao@intel.com
http://bugzilla.kernel.org/show_bug.cgi?id=10124 this change: commit 08f1c192c3c32797068bfe97738babb3295bbf42 Author: Muli Ben-Yehuda <muli@il.ibm.com> Date: Sun Jul 22 00:23:39 2007 +0300 x86-64: introduce struct pci_sysdata to facilitate sharing of ->sysdata This patch introduces struct pci_sysdata to x86 and x86-64, and converts the existing two users (NUMA, Calgary) to use it. This lays the groundwork for having other users of sysdata, such as the PCI domains work. The Calgary bits are tested, the NUMA bits just look ok. replaces pcibios_scan_root by pci_scan_bus_parented... but in pcibios_scan_root we have a check about scanned busses. Cc: <yakui.zhao@intel.com> Cc: Stian Jordet <stian@jordet.net> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Yinghai Lu" <yhlu.kernel@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-06[IA64] use dev_printk in video quirkBjorn Helgaas
Convert quirk printks to dev_printk(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-06[IA64] remove remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Long lines have been kept where they exist, some small spacing changes have been done. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-10Change pci_raw_ops to pci_raw_read/writeMatthew Wilcox
We want to allow different implementations of pci_raw_ops for standard and extended config space on x86. Rather than clutter generic code with knowledge of this, we make pci_raw_ops private to x86 and use it to implement the new raw interface -- raw_pci_read() and raw_pci_write(). Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-25[IA64] Nail two more simple section mismatch errorsTony Luck
pcibios_setup (between 'pci_setup' and 'quirk_mellanox_tavor') setup_profiling_timer (between 'write_profile' and 'delayed_put_task_struct') Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-11[IA64] prevent MCA when performing MMIO mmap to PCI config spaceAlex Chiang
Example memory map (HP rx7640 with 'default' acpiconfig setting, VGA disabled): 0x00000000 - 0x3FFFBFFF supports only WB (cacheable) access If a user attempts to perform an MMIO mmap (using the PCIIOC_MMAP_IS_MEM ioctl) to PCI config space (like mmap'ing and accessing memory at 0xA0000), we will MCA because the kernel will attempt to use a mapping with the UC attribute. So check the memory attribute in kern_mmap and the EFI memmap. If WC is requested, and WC or UC access is supported for the region, allow it. Otherwise, use the same attribute the kernel uses. Updates documentation and test cases as well. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-22[IA64] fix kmalloc(0) in arch/ia64/pci/pci.cKenji Kaneshige
Hiroyuki Kamezawa reported the problem that pci_acpi_scan_root() of ia64 might call kmalloc_node() with zero size. Currently ia64's pci_acpi_scan_root() assumes that _CRS method of root bridge has at least one resource window. But, the root bridges that has no resource window must be taken into account. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-03-30[IA64] allow WB /sys/.../legacy_mem mmapsBjorn Helgaas
Allow cacheable mmaps of legacy_mem if WB access is supported for the region. The "legacy_mem" file often contains a shadow option ROM, and some versions of X depend on this. Tim Yamin <plasm@roo.me.uk> reported that this change fixes X on a Dell PowerEdge 3250. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-03-29[IA64] Fix arch/ia64/pci/pci.c:571: warning: `return' with a valueTony Luck
Typo/thinko in bba6f6fc68e74d4572028646f61dd3505a68747e Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-03-28[PATCH] MSI-X: fix resume crashEric W. Biederman
So I think the right solution is to simply make pci_enable_device just flip enable bits and move the rest of the work someplace else. However a thorough cleanup is a little extreme for this point in the release cycle, so I think a quick hack that makes the code not stomp the irq when msi irq's are enabled should be the first fix. Then we can later make the code not change the irqs at all. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[IA64] replace kmalloc+memset with kzallocYan Burman
Replace kmalloc+memset with kzalloc Signed-off-by: Yan Burman <burman.yan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-12-06[IA64] Fix pci.c kernel compilation breakage.Peter Chubb
The recent change to convert the is_enabled flag in the PCI device to an atomic count broke the IA64 compilation. As pcibios_disable_device is only ever called if the reference count is zero, convert the if to a BUG_ON. Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-12-01Altix: Add initial ACPI IO supportJohn Keller
First phase in introducing ACPI support to SN. In this phase, when running with an ACPI capable PROM, the DSDT will define the root busses and all SN nodes (SGIHUB, SGITIO). An ACPI bus driver will be registered for the node devices, with the acpi_pci_root_driver being used for the root busses. An ACPI vendor descriptor is now used to pass platform specific information for both nodes and busses, eliminating the need for the current SAL calls. Also, with ACPI support, SN fixup code is no longer needed to initiate the PCI bus scans, as the acpi_pci_root_driver does that. However, to maintain backward compatibility with non-ACPI capable PROMs, none of the current 'fixup' code can been deleted, though much restructuring has been done. For example, the bulk of the code in io_common.c is relocated code that is now common regardless of what PROM is running, while io_acpi_init.c and io_init.c contain routines specific to an ACPI or non ACPI capable PROM respectively. A new pci bus fixup platform vector has been created to provide a hook for invoking platform specific bus fixup from pcibios_fixup_bus(). The size of io_space[] has been increased to support systems with large IO configurations. Signed-off-by: John Keller <jpk@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01PCI: Use pci_generic_prep_mwi on ia64Matthew Wilcox
The pci_generic_prep_mwi() code does everything that pcibios_prep_mwi() does on ia64. All we need to do is be sure that pci_cache_line_size is set appropriately, and we can delete pcibios_prep_mwi(). Using SMP_CACHE_BYTES as the default was wrong on uniprocessor machines as it is only 8 bytes. The default in the generic code of L1_CACHE_BYTES is at least as good. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-27PCI: fix pci_fixup_video as it blows up on sparc64Eiichiro Oiwa
This reverts much of the original pci_fixup_video change and makes it work for all arches that need it. fixed, and tested on x86, x86_64 and IA64 dig. Signed-off-by: Eiichiro Oiwa <eiichiro.oiwa.nm@hitachi.com> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-04[PATCH] genirq: msi: simplify the msi irq limit policyEric W. Biederman
Currently we attempt to predict how many irqs we will be able to allocate with msi using pci_vector_resources and some complicated accounting, and then we only allow each device as many irqs as we think are available on average. Only the s2io driver even takes advantage of this feature all other drivers have a fixed number of irqs they need and bail if they can't get them. pci_vector_resources is inaccurate if anyone ever frees an irq. The whole implmentation is racy. The current irq limit policy does not appear to make sense with current drivers. So I have simplified things. We can revisit this we we need a more sophisticated policy. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rajesh Shah <rajesh.shah@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: "Protasevich, Natalie" <Natalie.Protasevich@UNISYS.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
