path: root/arch/ia64/oprofile
2006-01-08[PATCH] remove gcc-2 checksAndrew Morton
Remove various things which were checking for gcc-1.x and gcc-2.x compilers. From: Adrian Bunk <bunk@stusta.de> Some documentation updates and removes some code paths for gcc < 3.2. Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Move Kprobes and Oprofile to "Instrumentation Support" menuPrasanna S Panchamukhi
Andrew Morton suggested to move kprobes from kernel hacking menu, since kernel hacking menu is in-appropriate for the Kprobes. This patch moves Kprobes and Oprofile under instrumentation menu. (akpm: it's not a natural fit, but things like djprobes and the s390 guys' statistics library need a home) Signed-of-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: John Levon <levon@movementarian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
