Fold all the mmu_gather rework patches into one for submission
Reported-by: Hugh Dickins <hughd@google.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
The old anon_vma code can lead to scalability issues with heavily forking
workloads. Specifically, each anon_vma will be shared between the parent
process and all its child processes.
In a workload with 1000 child processes and a VMA with 1000 anonymous
pages per process that get COWed, this leads to a system with a million
anonymous pages in the same anon_vma, each of which is mapped in just one
of the 1000 processes. However, the current rmap code needs to walk them
all, leading to O(N) scanning complexity for each page.
This can result in systems where one CPU is walking the page tables of
1000 processes in page_referenced_one, while all other CPUs are stuck on
the anon_vma lock. This leads to catastrophic failure for a benchmark
like AIM7, where the total number of processes can reach in the tens of
thousands. Real workloads are still a factor 10 less process intensive
than AIM7, but they are catching up.
This patch changes the way anon_vmas and VMAs are linked, which allows us
to associate multiple anon_vmas with a VMA. At fork time, each child
process gets its own anon_vmas, in which its COWed pages will be
instantiated. The parents' anon_vma is also linked to the VMA, because
non-COWed pages could be present in any of the children.
This reduces rmap scanning complexity to O(1) for the pages of the 1000
child processes, with O(N) complexity for at most 1/N pages in the system.
This reduces the average scanning cost in heavily forking workloads from
O(N) to 2.
The only real complexity in this patch stems from the fact that linking a
VMA to anon_vmas now involves memory allocations. This means vma_adjust
can fail, if it needs to attach a VMA to anon_vma structures. This in
turn means error handling needs to be added to the calling functions.
A second source of complexity is that, because there can be multiple
anon_vmas, the anon_vma linking in vma_adjust can no longer be done under
"the" anon_vma lock. To prevent the rmap code from walking up an
incomplete VMA, this patch introduces the VM_LOCK_RMAP VMA flag. This bit
flag uses the same slot as the NOMMU VM_MAPPED_COPY, with an ifdef in mm.h
to make sure it is impossible to compile a kernel that needs both symbolic
values for the same bitflag.
Some test results:
Without the anon_vma changes, when AIM7 hits around 9.7k users (on a test
box with 16GB RAM and not quite enough IO), the system ends up running
>99% in system time, with every CPU on the same anon_vma lock in the
pageout code.
With these changes, AIM7 hits the cross-over point around 29.7k users.
This happens with ~99% IO wait time, there never seems to be any spike in
system time. The anon_vma lock contention appears to be resolved.
[akpm@linux-foundation.org: cleanups]
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
This has been broken since May 2008 when Al Viro killed altroot support.
Since nobody has complained, it would appear that there are no users of
this code (A plausible theory since the main OSVs that support ia64 prefer
to use the IA32-EL software emulation).
Signed-off-by: Tony Luck <tony.luck@intel.com>
Make sure compiler won't do weird things with limits. E.g. fetching
them twice may return 2 different values after writable limits are
implemented.
I.e. either use rlimit helpers added in
3e10e716abf3c71bdb5d86b8f507f9e72236c9cd
or ACCESS_ONCE if not applicable.
If CONFIG_VIRTUAL_MEM_MAP is enabled, ia64 defines macro VMALLOC_END
as unsigned long variable vmalloc_end which is adjusted to prepare
room for vmemmap. This becomes probnlematic if a local variables
vmalloc_end is defined in some function (not very unlikely) and
VMALLOC_END is used in the function - the function thinks its
referencing the global VMALLOC_END value but would be referencing its
own local vmalloc_end variable.
There's no reason VMALLOC_END should be a macro. Just define it as an
unsigned long variable if CONFIG_VIRTUAL_MEM_MAP is set to avoid nasty
surprises.
Acked-by: Tony Luck <tony.luck@intel.com>
Cc: linux-ia64 <linux-ia64@vger.kernel.org>
For /proc/kcore, each arch registers its memory range by kclist_add().
In usual,
- range of physical memory
- range of vmalloc area
- text, etc...
are registered but "range of physical memory" has some troubles. It
doesn't updated at memory hotplug and it tend to include unnecessary
memory holes. Now, /proc/iomem (kernel/resource.c) includes required
physical memory range information and it's properly updated at memory
hotplug. Then, it's good to avoid using its own code(duplicating
information) and to rebuild kclist for physical memory based on
/proc/iomem.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Some 64bit arch has special segment for mapping kernel text. It should be
entried to /proc/kcore in addtion to direct-linear-map, vmalloc area.
This patch unifies KCORE_TEXT entry scattered under x86 and ia64.
I'm not familiar with other archs (mips has its own even after this patch)
but range of [_stext ..._end) is a valid area of text and it's not in
direct-map area, defining CONFIG_ARCH_PROC_KCORE_TEXT is only a necessary
thing to do.
Note: I left mips as it is now.
For /proc/kcore, vmalloc areas are registered per arch. But, all of them
registers same range of [VMALLOC_START...VMALLOC_END) This patch unifies
them. By this. archs which have no kclist_add() hooks can see vmalloc
area correctly.
Presently, kclist_add() only eats start address and size as its arguments.
Considering to make kclist dynamically reconfigulable, it's necessary to
know which kclists are for System RAM and which are not.
This patch add kclist types as
KCORE_RAM
KCORE_VMALLOC
KCORE_TEXT
KCORE_OTHER
This "type" is used in a patch following this for detecting KCORE_RAM.
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()")
modified nr_free_pages() to return 'unsigned long' instead of 'unsigned
int'. This made the casts to 'unsigned long' in most callers superfluous,
so remove them.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Chris Zankel <zankel@tensilica.com>
It is generally agreed that it would be beneficial for u64 to be an
unsigned long long on all architectures. ia64 (in common with several
other 64-bit architectures) currently uses unsigned long. Migrating
piecemeal is too painful; this giant patch fixes all compilation warnings
and errors that come as a result of switching to use int-ll64.h.
Note that userspace will still see __u64 defined as unsigned long. This
is important as it affects C++ name mangling.
[Updated by Tony Luck to change efi.h:efi_freemem_callback_t to use
u64 for start/end rather than unsigned long]
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Replace:
if (test)
BUG();
with
BUG_ON(test);
Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com>
paravirtualize gate page by allowing each pv_ops instances
to define its own gate page.
Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp>
Add two hooks, paravirt_get_fsyscall_table() and
paravirt_get_fsys_bubble_doen() to paravirtualize fsyscall implementation.
This patch just add the hooks fsyscall and don't paravirtualize it.
Show node to memory section relationship with symlinks in sysfs
Add /sys/devices/system/node/nodeX/memoryY symlinks for all
the memory sections located on nodeX. For example:
/sys/devices/system/node/node1/memory135 -> ../../memory/memory135
indicates that memory section 135 resides on node1.
Also revises documentation to cover this change as well as updating
Documentation/ABI/testing/sysfs-devices-memory to include descriptions
of memory hotremove files 'phys_device', 'phys_index', and 'state'
that were previously not described there.
In addition to it always being a good policy to provide users with
the maximum possible amount of physical location information for
resources that can be hot-added and/or hot-removed, the following
are some (but likely not all) of the user benefits provided by
this change.
Immediate:
- Provides information needed to determine the specific node
on which a defective DIMM is located. This will reduce system
downtime when the node or defective DIMM is swapped out.
- Prevents unintended onlining of a memory section that was
previously offlined due to a defective DIMM. This could happen
during node hot-add when the user or node hot-add assist script
onlines _all_ offlined sections due to user or script inability
to identify the specific memory sections located on the hot-added
node. The consequences of reintroducing the defective memory
could be ugly.
- Provides information needed to vary the amount and distribution
of memory on specific nodes for testing or debugging purposes.
Future:
- Will provide information needed to identify the memory
sections that need to be offlined prior to physical removal
of a specific node.
Symlink creation during boot was tested on 2-node x86_64, 2-node
ppc64, and 2-node ia64 systems. Symlink creation during physical
memory hot-add tested on a 2-node x86_64 system.
Signed-off-by: Gary Hade <garyhade@us.ibm.com>
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
There is nothing architecture specific about remove_memory().
remove_memory() function is common for all architectures which support
hotplug memory remove. Instead of duplicating it in every architecture,
collapse them into arch neutral function.
[akpm@linux-foundation.org: fix the export]
Cc: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Gary Hade <garyhade@us.ibm.com>
This patch also includes the required removal of (unused) inclusion of
<asm/a.out.h> <linux/a.out.h>'s in the arch/ code for these
architectures.
[dwmw2: updated for 2.6.27-rc]
Signed-off-by: Adrian Bunk <bunk@kernel.org>
The patch aims to fix a performance issue for the syscall
personality(PER_LINUX32).
On IA-64 box, the syscall personality (PER_LINUX32) has poor performance
because it failed to find the Linux/x86 execution domain. Then it tried
to load the kernel module however it failed always and it used the default
execution domain PER_LINUX instead. Requesting kernel modules is very
expensive. It caused the performance issue. (see the function
lookup_exec_domain in kernel/exec_domain.c).
To resolve the issue, execution domain Linux/x86 is always registered in
initialization time for IA-64 architecture.
Signed-off-by: Xiaolan Huang <xiaolan.huang@intel.com>
All architectures use an effectively identical definition of online_page(), so
just make it common code. x86-64, ia64, powerpc and sh are actually
identical; x86-32 is slightly different.
x86-32's differences arise because it puts its hotplug pages in the highmem
zone. We can handle this in the generic code by inspecting the page to see if
its in highmem, and update the totalhigh_pages count appropriately. This
leaves init_32.c:free_new_highpage with a single caller, so I folded it into
add_one_highpage_init.
I also removed an incorrect comment referring to the NUMA case; any NUMA
details have already been dealt with by the time online_page() is called.
[akpm@linux-foundation.org: fix indenting]
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Acked-by: Dave Hansen <dave@linux.vnet.ibm.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamez.hiroyu@jp.fujitsu.com>
Tested-by: KAMEZAWA Hiroyuki <kamez.hiroyu@jp.fujitsu.com>
Cc: Christoph Lameter <clameter@sgi.com>
Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com>
There is a NUMA memory configuration issue in 2.6.24:
A 2-node machine of ours has got the following memory layout:
Node 0: 0 - 2 Gbytes
Node 0: 4 - 8 Gbytes
Node 1: 8 - 16 Gbytes
Node 0: 16 - 18 Gbytes
"efi_memmap_init()" merges the three last ranges into one.
"register_active_ranges()" is called as follows:
efi_memmap_walk(register_active_ranges, NULL);
i.e. once for the 4 - 18 Gbytes range. It picks up the node
number from the start address, and registers all the memory for
the node #0.
"register_active_ranges()" should be called as follows to
make sure there is no merged address range at its entry:
efi_memmap_walk(filter_memory, register_active_ranges);
"filter_memory()" is similar to "filter_rsvd_memory()",
but the reserved memory ranges are not filtered out.
Signed-off-by: Zoltan Menyhart <Zoltan.Menyhart@bull.net>
Untangle the chaos of page size determination in this function by
simply using PAGE_SIZE << compound_order().
Signed-off-by: Christoph Lameter <clameter@sgi.com>
__FUNCTION__ is gcc-specific, use __func__
Long lines have been kept where they exist, some small spacing changes
have been done.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This patch fixes the following section mismatches:
<-- snip -->
WARNING: vmlinux.o(.text+0x5b5c2): Section mismatch: reference to .init.text:memmap_init_zone (between 'memmap_init' and 'virtual_memmap_init')
WARNING: vmlinux.o(.text+0x5b842): Section mismatch: reference to .init.text:memmap_init_zone (between 'virtual_memmap_init' and 'ia64_mmu_init')
<-- snip -->
This patch uses vm_get_page_prot() to setup vma->vm_page_prot.
Though inside vm_get_page_prot() the protection flags is AND with
(VM_READ|VM_WRITE|VM_EXEC|VM_SHARED), it does not hurt correct code.
Signed-off-by: Coly Li <coyli@suse.de>
Cc: Hugh Dickins <hugh@veritas.com>
Now, arch dependent code around CONFIG_MEMORY_HOTREMOVE is a mess.
This patch cleans up them. This is against 2.6.23-rc6-mm1.
- fix compile failure on ia64/ CONFIG_MEMORY_HOTPLUG && !CONFIG_MEMORY_HOTREMOVE case.
- For !CONFIG_MEMORY_HOTREMOVE, add generic no-op remove_memory(),
which returns -EINVAL.
- removed remove_pages() only used in powerpc.
- removed no-op remove_memory() in i386, sh, sparc64, x86_64.
- only powerpc returns -ENOSYS at memory hot remove(no-op). changes it
to return -EINVAL.
Note:
Currently, only ia64 supports CONFIG_MEMORY_HOTREMOVE. I welcome other
archs if there are requirements and testers.
IA64 memory unplug interface.
Current ia64 kernel flushes icache by lazy_mmu_prot_update() *after*
set_pte(). This is too late. This patch removes lazy_mmu_prot_update and
add modfied set_pte() for flushing if necessary.
This patch flush icache of a page when
new pte has exec bit.
&& new pte has present bit
&& new pte is user's page.
&& (old *ptep is not present
|| new pte's pfn is not same to old *ptep's ptn)
&& new pte's page has no Pg_arch_1 bit.
Pg_arch_1 is set when a page is cache consistent.
I think this condition checks are much easier to understand than considering
"Where sync_icache_dcache() should be inserted ?".
pte_user() for ia64 was removed by http://lkml.org/lkml/2007/6/12/67 as
clean-up. So, I added it again.
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
IA64 is the origin of the quicklist implementation. So cut out the pieces
that are now in core code and modify the functions called.
* git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] update memory attribute aliasing documentation & test cases
[IA64] fail mmaps that span areas with incompatible attributes
[IA64] allow WB /sys/.../legacy_mem mmaps
[IA64] make ioremap avoid unsupported attributes
[IA64] rename ioremap variables to match i386
[IA64] relax per-cpu TLB requirement to DTC
[IA64] remove per-cpu ia64_phys_stacked_size_p8
[IA64] Fix example error injection program
[IA64] Itanium MC Error Injection Tool: pal_mc_error_inject() interface
[IA64] Itanium MC Error Injection Tool: Makefile changes
[IA64] Itanium MC Error Injection Tool: Driver sysfs interface
[IA64] Itanium MC Error Injection Tool: Doc and sample application
[IA64] Itanium MC Error Injection Tool: Kernel configuration
If we add a new flag so that we can distinguish between the first page and the
tail pages then we can avoid to use page->private in the first page.
page->private == page for the first page, so there is no real information in
there.
Freeing up page->private makes the use of compound pages more transparent.
They become more usable like real pages. Right now we have to be careful f.e.
if we are going beyond PAGE_SIZE allocations in the slab on i386 because we
can then no longer use the private field. This is one of the issues that
cause us not to support debugging for page size slabs in SLAB.
Having page->private available for SLUB would allow more meta information in
the page struct. I can probably avoid the 16 bit ints that I have in there
right now.
Also if page->private is available then a compound page may be equipped with
buffer heads. This may free up the way for filesystems to support larger
blocks than page size.
We add PageTail as an alias of PageReclaim. Compound pages cannot currently
be reclaimed. Because of the alias one needs to check PageCompound first.
The RFC for the this approach was discussed at
http://marc.info/?t=117574302800001&r=1&w=2
[nacc@us.ibm.com: fix hugetlbfs]
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
ia64 expects following vm layout:
== low memory
[register-stack grows up]
[memory-stack grows down]
== high memory
But the code assigns the base of the register stack at the
maximum stack size offset from the fixed address where the
stack *might* start. Stack randomization will result in the
memory stack starting at a lower address than this, and if the
user has set a low stack limit with "ulimit -s", then you can
end up with the register stack above the memory stack (or if
you were very unlucky right on top of it!).
Fix: Calculate the base address for the register stack starting
from the actual address of the memory stack.
We have seen bad_pte_print when testing crashdump on an SN machine in
recent 2.6.20 kernel. There are tons of bad pte print (pfn < max_low_pfn)
reports when the crash kernel boots up, all those reported bad pages
are inside initmem range; That is because if the crash kernel code and
data happens to be at the beginning of the 1st node. build_node_maps in
discontig.c will bypass reserved regions with filter_rsvd_memory. Since
min_low_pfn is calculated in build_node_map, so in this case, min_low_pfn
will be greater than kernel code and data.
Because pages inside initmem are freed and reused later, we saw
pfn_valid check fail on those pages.
I think this theoretically happen on a normal kernel. When I check
min_low_pfn and max_low_pfn calculation in contig.c and discontig.c.
I found more issues than this.
1. min_low_pfn and max_low_pfn calculation is inconsistent between
contig.c and discontig.c,
min_low_pfn is calculated as the first page number of boot memmap in
contig.c (Why? Though this may work at the most of the time, I don't
think it is the right logic). It is calculated as the lowest physical
memory page number bypass reserved regions in discontig.c.
max_low_pfn is calculated include reserved regions in contig.c. It is
calculated exclude reserved regions in discontig.c.
2. If kernel code and data region is happen to be at the begin or the
end of physical memory, when min_low_pfn and max_low_pfn calculation is
bypassed kernel code and data, pages in initmem will report bad.
3. initrd is also in reserved regions, if it is at the begin or at the
end of physical memory, kernel will refuse to reuse the memory. Because
the virt_addr_valid check in free_initrd_mem.
So it is better to fix and clean up those issues.
Calculate min_low_pfn and max_low_pfn in a consistent way.
Signed-off-by: Zou Nan hai <nanhai.zou@intel.com>
Acked-by: Jay Lan <jlan@sgi.com>
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the
corresponding "kmem_cache_zalloc()" call.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Roland McGrath <roland@redhat.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Greg KH <greg@kroah.com>
Acked-by: Joel Becker <Joel.Becker@oracle.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Jan Kara <jack@ucw.cz>
Cc: Michael Halcrow <mhalcrow@us.ibm.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Chris Wright <chrisw@sous-sol.org>
Function is unnecessary now. We can use the summing features of the ZVCs to
get the values we need.
Instead of pinning per-cpu TLB into a DTR, use DTC. This will free up
one TLB entry for application, or even kernel if access pattern to
per-cpu data area has high temporal locality.
Since per-cpu is mapped at the top of region 7 address, we just need to
add special case in alt_dtlb_miss. The physical address of per-cpu data
is already conveniently stored in IA64_KR(PER_CPU_DATA). Latency for
alt_dtlb_miss is not affected as we can hide all the latency. It was
measured that alt_dtlb_miss handler has 23 cycles latency before and
after the patch.
The performance effect is massive for applications that put lots of tlb
pressure on CPU. Workload environment like database online transaction
processing or application uses tera-byte of memory would benefit the most.
Measurement with industry standard database benchmark shown an upward
of 1.6% gain. While smaller workloads like cpu, java also showing small
improvement.
Signed-off-by: Ken Chen <kenneth.w.chen@intel.com>
This patch fixes
- marking I-cache clean of pages DMAed to now only done for IA64
- broken multiple inclusion in include/asm-x86_64/swiotlb.h
- missing call to mark_clean in swiotlb_sync_sg()
- a (perhaps only theoretical) issue in swiotlb_dma_supported() when
io_tlb_end is exactly at the end of memory
Signed-off-by: Jan Beulich <jbeulich@novell.com>
While pursuing and unrelated issue with 64Mb granules I noticed a problem
related to inconsistent use of add_active_range. There doesn't appear any
reason to me why FLATMEM versus DISCONTIG_MEM should register memory to
add_active_range with different code. So I've changed the code into a
common implementation.
The other subtle issue fixed by this patch was calling add_active_range in
count_node_pages before granule aligning is performed. We were lucky with
16MB granules but not so with 64MB granules. count_node_pages has reserved
regions filtered out and as a consequence linked kernel text and data
aren't covered by calls to count_node_pages. So linked kernel regions
wasn't reported to add_active_regions. This resulted in free_initmem
causing numerous bad_page reports. This won't occur with this patch
because now all known memory regions are reported by
register_active_ranges.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Signed-off-by: Bob Picco <bob.picco@hp.com>
Acked-by: Simon Horman <horms@verge.net.au>
Fix an oops experienced on the Cell architecture when init-time functions,
early_*(), are called at runtime. It alters the call paths to make sure
that the callers explicitly say whether the call is being made on behalf of
a hotplug even, or happening at boot-time.
It has been compile tested on ppc64, ia64, s390, i386 and x86_64.
Acked-by: Arnd Bergmann <arndb@de.ibm.com>
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
Acked-by: Andy Whitcroft <apw@shadowen.org>
Cc: Christoph Lameter <clameter@engr.sgi.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
This warning only shows up with CONFIG_VIRTUAL_MEM_MAP=y and
CONFIG_FLATMEM=y.
There is only one caller left for register_active_ranges() from the
contig.c code ... so it doesn't need to pick up the node number, the
node number is always zero.
SLAB_KERNEL is an alias of GFP_KERNEL.
Size zones and holes in an architecture independent manner for ia64.
[bob.picco@hp.com: fix ia64 FLATMEM+VIRTUAL_MEM_MAP]
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Andy Whitcroft <apw@shadowen.org>
Cc: "Keith Mannthey" <kmannth@gmail.com>
contig.c (FLATMEM) requires the same optimization as in discontig.c for show_mem
when VIRTUAL_MEM_MAP is in use. Otherwise FLATMEM has softlockup timeouts.
This was boot tested for memory configuration: SPARSEMEM,
DISCONTIG+VIRTUAL_MEM_MAP, FLATMEM, FLATMEM+VIRTUAL_MEM_MAP and
FLATMEM+VIRTUAL_MEM_MAP with largest memory gap less than LARGE_GAP by
using boot parameter "mem=".
This was boot tested and "echo m >/proc/sysrq-trigger" output evaluated for
: FLATMEM, FLATMEM+VIRTUAL_MEM_MAP, DISCONTIGMEM+VIRTUAL_MEM_MAP and
SPARSEMEM.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Change the name of old add_memory() to arch_add_memory. And use node id to
get pgdat for the node at NODE_DATA().
Note: Powerpc's old add_memory() is defined as __devinit. However,
add_memory() is usually called only after bootup.
I suppose it may be redundant. But, I'm not well known about powerpc.
So, I keep it. (But, __meminit is better at least.)
Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: "Brown, Len" <len.brown@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] ioremap() should prefer WB over UC
[IA64] Add __mca_table to the DISCARD list in gate.lds
[IA64] Move __mca_table out of the __init section
[IA64] simplify some condition checks in iosapic_check_gsi_range
[IA64] correct some messages and fixes some minor things
[IA64-SGI] fix for-loop in sn_hwperf_geoid_to_cnode()
[IA64-SGI] sn_hwperf use of num_online_cpus()
[IA64] optimize flush_tlb_range on large numa box
[IA64] lazy_mmu_prot_update needs to be aware of huge pages
Function lazy_mmu_prot_update is also used on huge pages when it is called
by set_huge_ptep_writable, but it isn't aware of huge pages.
Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com>
Acked-by: Ken Chen <kenneth.w.chen@intel.com>
Replace for_each_pgdat() with for_each_online_pgdat().
Add __initdata to nolwsys.
