Commit 4b59e6c47309 ("mm, show_mem: suppress page counts in
non-blockable contexts") introduced SHOW_MEM_FILTER_PAGE_COUNT to
suppress PFN walks on large memory machines. Commit c78e93630d15 ("mm:
do not walk all of system memory during show_mem") avoided a PFN walk in
the generic show_mem helper which removes the requirement for
SHOW_MEM_FILTER_PAGE_COUNT in that case.
This patch removes PFN walkers from the arch-specific implementations
that report on a per-node or per-zone granularity. ARM and unicore32
still do a PFN walk as they report memory usage on each bank which is a
much finer granularity where the debugging information may still be of
use. As the remaining arches doing PFN walks have relatively small
amounts of memory, this patch simply removes SHOW_MEM_FILTER_PAGE_COUNT.
[akpm@linux-foundation.org: fix parisc]
Acked-by: David Rientjes <rientjes@google.com>
Cc: James Bottomley <jejb@parisc-linux.org>
Merge first patch-bomb from Andrew Morton:
- various misc bits
- I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been
distracted. There has been quite a bit of activity.
- About half the MM queue
- Some backlight bits
- Various lib/ updates
- checkpatch updates
- zillions more little rtc patches
- ptrace
- signals
- exec
- procfs
- rapidio
- nbd
- aoe
- pps
- memstick
- tools/testing/selftests updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits)
tools/testing/selftests: don't assume the x bit is set on scripts
selftests: add .gitignore for kcmp
selftests: fix clean target in kcmp Makefile
selftests: add .gitignore for vm
selftests: add hugetlbfstest
self-test: fix make clean
selftests: exit 1 on failure
kernel/resource.c: remove the unneeded assignment in function __find_resource
aio: fix wrong comment in aio_complete()
drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode
drivers/memstick/host/r592.c: convert to module_pci_driver
drivers/memstick/host/jmb38x_ms: convert to module_pci_driver
pps-gpio: add device-tree binding and support
drivers/pps/clients/pps-gpio.c: convert to module_platform_driver
drivers/pps/clients/pps-gpio.c: convert to devm_* helpers
drivers/parport/share.c: use kzalloc
Documentation/accounting/getdelays.c: avoid strncpy in accounting tool
aoe: update internal version number to v83
aoe: update copyright date
aoe: perform I/O completions in parallel
Prepare for removing num_physpages and simplify mem_init().
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
This removes all the ia64 uses of the __cpuinit macros.
[1] https://lkml.org/lkml/2013/5/20/589
Signed-off-by: Tony Luck <tony.luck@intel.com>
On large systems with a lot of memory, walking all RAM to determine page
types may take a half second or even more.
In non-blockable contexts, the page allocator will emit a page allocation
failure warning unless __GFP_NOWARN is specified. In such contexts, irqs
are typically disabled and such a lengthy delay may even result in NMI
watchdog timeouts.
To fix this, suppress the page walk in such contexts when printing the
page allocation failure warning.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Now the function nr_free_buffer_pages returns unsigned long, so use %ld
to print its return value.
Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
ia64 used early_node_map[] just to prime free_area_init_nodes(). Now
memblock can be used for the same purpose and early_node_map[] is
scheduled to be dropped. Use memblock instead.
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: linux-ia64@vger.kernel.org
Architectures that implement their own show_mem() function did not pass
the filter argument to show_free_areas() to appropriately avoid emitting
the state of nodes that are disallowed in the current context. This patch
now passes the filter argument to show_free_areas() so those nodes are now
avoided.
This patch also removes the show_free_areas() wrapper around
__show_free_areas() and converts existing callers to pass an empty filter.
ia64 emits additional information for each node, so skip_free_areas_zone()
must be made global to filter disallowed nodes and it is converted to use
a nid argument rather than a zone for this use case.
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Helge Deller <deller@gmx.de>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from
meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which
resulted in build warnings on all architectures that implement their own
versions of show_mem():
lib/lib.a(show_mem.o): In function `show_mem':
show_mem.c:(.text+0x1f4): multiple definition of `show_mem'
arch/sparc/mm/built-in.o:(.text+0xd70): first defined here
The fix is to remove __show_mem() and add its argument to show_mem() in
all implementations to prevent this breakage.
Architectures that implement their own show_mem() actually don't do
anything with the argument yet, but they could be made to filter nodes
that aren't allowed in the current context in the future just like the
generic implementation.
Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Unlike other archs, ia64 reserves space for percpu areas during early
memory initialization. These areas occupy a contiguous region indexed
by cpu number on contiguous memory model or are grouped by node on
discontiguous memory model.
As allocation and initialization are done by the arch code, all that
setup_per_cpu_areas() needs to do is communicating the determined
layout to the percpu allocator. This patch implements
setup_per_cpu_areas() for both contig and discontig memory models and
drops HAVE_LEGACY_PER_CPU_AREA.
Please note that for contig model, the allocation itself is modified
only to allocate for possible cpus instead of NR_CPUS. As dynamic
percpu allocator can handle non-direct mapping, there's no reason to
allocate memory for cpus which aren't possible.
Acked-by: Tony Luck <tony.luck@intel.com>
Cc: linux-ia64 <linux-ia64@vger.kernel.org>
cpu0 used special percpu area reserved by the linker, __cpu0_per_cpu,
which is set up early in boot by head.S. However, this doesn't
guarantee that the area will be on the same node as cpu0 and the
percpu area for cpu0 ends up very far away from percpu areas for other
cpus which cause problems for congruent percpu allocator.
This patch makes percpu area initialization allocate percpu area for
cpu0 like any other cpus and copy it from __cpu0_per_cpu which now
resides in the __init area. This means that for cpu0, percpu area is
first setup at __cpu0_per_cpu early by head.S and then moved to an
area in the linear mapping during memory initialization and it's not
allowed to take a pointer to percpu variables between head.S and
If CONFIG_VIRTUAL_MEM_MAP is enabled, ia64 defines macro VMALLOC_END
as unsigned long variable vmalloc_end which is adjusted to prepare
room for vmemmap. This becomes probnlematic if a local variables
vmalloc_end is defined in some function (not very unlikely) and
VMALLOC_END is used in the function - the function thinks its
referencing the global VMALLOC_END value but would be referencing its
own local vmalloc_end variable.
There's no reason VMALLOC_END should be a macro. Just define it as an
unsigned long variable if CONFIG_VIRTUAL_MEM_MAP is set to avoid nasty
surprises.
It is generally agreed that it would be beneficial for u64 to be an
unsigned long long on all architectures. ia64 (in common with several
other 64-bit architectures) currently uses unsigned long. Migrating
piecemeal is too painful; this giant patch fixes all compilation warnings
and errors that come as a result of switching to use int-ll64.h.
Note that userspace will still see __u64 defined as unsigned long. This
is important as it affects C++ name mangling.
[Updated by Tony Luck to change efi.h:efi_freemem_callback_t to use
u64 for start/end rather than unsigned long]
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Initial fix for making sure that we can access percpu variables
in all C code (commit: 10617bbe84628eb18ab5f723d3ba35005adde143)
inadvertantly allocated the memory in the "percpu" section of
the vmlinux ELF executable. This confused kexec/dump.
ia64 handles per-cpu variables a litle differently from other architectures
in that it maps the physical memory allocated for each cpu at a constant
virtual address (0xffffffffffff0000). This mapping is not enabled until
the architecture specific cpu_init() function is run, which causes problems
since some generic code is run before this point. In particular when
CONFIG_PRINTK_TIME is enabled, the boot cpu will trap on the access to
per-cpu memory at the first printk() call so the boot will fail without
the kernel printing anything to the console.
Fix this by allocating percpu memory for cpu0 in the kernel data section
and doing all initialization to enable percpu access in head.S before
calling any generic code.
Other cpus must take care not to access per-cpu variables too early, but
their code path from start_secondary() to cpu_init() is all in arch/ia64
There is a NUMA memory configuration issue in 2.6.24:
A 2-node machine of ours has got the following memory layout:
Node 0: 0 - 2 Gbytes
Node 0: 4 - 8 Gbytes
Node 1: 8 - 16 Gbytes
Node 0: 16 - 18 Gbytes
"efi_memmap_init()" merges the three last ranges into one.
"register_active_ranges()" is called as follows:
efi_memmap_walk(register_active_ranges, NULL);
i.e. once for the 4 - 18 Gbytes range. It picks up the node
number from the start address, and registers all the memory for
the node #0.
"register_active_ranges()" should be called as follows to
make sure there is no merged address range at its entry:
efi_memmap_walk(filter_memory, register_active_ranges);
"filter_memory()" is similar to "filter_rsvd_memory()",
but the reserved memory ranges are not filtered out.
Signed-off-by: Zoltan Menyhart <Zoltan.Menyhart@bull.net>
show_mem() has no need to print the amount of free swap space manually because
show_free_areas() does this already and is called by the former.
The two outputs only differ in text formatting:
printk("Free swap = %lukB\n", ...);
printk("Free swap: %6ldkB\n", ...);
Signed-off-by: Johannes Weiner <hannes@saeurebad.de>
This patchset adds a flags variable to reserve_bootmem() and uses the
BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions
between crashkernel area and already used memory.
This patch:
Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE.
If that flag is set, the function returns with -EBUSY if the memory already
has been reserved in the past. This is to avoid conflicts.
Because that code runs before SMP initialisation, there's no race condition
inside reserve_bootmem_core().
[akpm@linux-foundation.org: fix powerpc build]
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: <linux-arch@vger.kernel.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
There is a section mismatch when building CONFIG_FLATMEM=y kernels
that also have CONFIG_HOTPLUG_CPU=y
WARNING: vmlinux.o(.text+0x5a902): Section mismatch: reference to \
.init.text:__alloc_bootmem (between 'per_cpu_init' and 'count_pages')
The issue occurs because per_cpu_init() in mm/contig.c is
marked __cpuinit (which is #define'd to nothing on a hot
plug cpu configuration) call __alloc_bootmem() (which is
an __init function). The usage is actually safe because
the __alloc_bootmem() is inside an "if (first_time)" test
so that the call is only made while it is still legal to
do so.
But the warning is irritating. Move the allocation to
find_memory().
When dumping memory via sysrq-m it is possible to take a bogus NMI watchdog
or softlockup watchdog because the dump can take a long time on big memory
systems.
Occasionally tickle the watchdog when doing the dump.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
IA64 is the origin of the quicklist implementation. So cut out the pieces
that are now in core code and modify the functions called.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
We have seen bad_pte_print when testing crashdump on an SN machine in
recent 2.6.20 kernel. There are tons of bad pte print (pfn < max_low_pfn)
reports when the crash kernel boots up, all those reported bad pages
are inside initmem range; That is because if the crash kernel code and
data happens to be at the beginning of the 1st node. build_node_maps in
discontig.c will bypass reserved regions with filter_rsvd_memory. Since
min_low_pfn is calculated in build_node_map, so in this case, min_low_pfn
will be greater than kernel code and data.
Because pages inside initmem are freed and reused later, we saw
pfn_valid check fail on those pages.
I think this theoretically happen on a normal kernel. When I check
min_low_pfn and max_low_pfn calculation in contig.c and discontig.c.
I found more issues than this.
1. min_low_pfn and max_low_pfn calculation is inconsistent between
contig.c and discontig.c,
min_low_pfn is calculated as the first page number of boot memmap in
contig.c (Why? Though this may work at the most of the time, I don't
think it is the right logic). It is calculated as the lowest physical
memory page number bypass reserved regions in discontig.c.
max_low_pfn is calculated include reserved regions in contig.c. It is
calculated exclude reserved regions in discontig.c.
2. If kernel code and data region is happen to be at the begin or the
end of physical memory, when min_low_pfn and max_low_pfn calculation is
bypassed kernel code and data, pages in initmem will report bad.
3. initrd is also in reserved regions, if it is at the begin or at the
end of physical memory, kernel will refuse to reuse the memory. Because
the virt_addr_valid check in free_initrd_mem.
So it is better to fix and clean up those issues.
Calculate min_low_pfn and max_low_pfn in a consistent way.
Signed-off-by: Zou Nan hai <nanhai.zou@intel.com>
Acked-by: Jay Lan <jlan@sgi.com>
Make saved_max_pfn point to max_pfn of entire system.
Without this patch is so that vmcore is zero length on ia64. This is
because saved_max_pfn was wrongly being set to the max_pfn of the crash
kernel's address space, rather than the max_pfg on the physical memory of
the machine - the whole purpose of vmcore is to access physical memory that
is not part of the crash kernel's addresss space.
Signed-off-by: Simon Horman <horms@verge.net.au>
Sort-Of-Acked-By: Jay Lan <jlan@sgi.com>
ZONE_DMA less operation for IA64 SGI platform
Disable ZONE_DMA for SGI SN2. All memory is addressable by all devices and we
do not need any special memory pool.
Cc: "Luck, Tony" <tony.luck@intel.com>
On the ia64 architecture only this patch upgrades show_mem() for sparse
memory to be the same as it was for discontig memory. It has been shown to
work on NUMA and flatmem architectures.
Signed-off-by: George Beshers <gbeshers@sgi.com>
Fix a typo in the saved_max_pfn description in contig.c
This warning only shows up with CONFIG_VIRTUAL_MEM_MAP=y and
CONFIG_FLATMEM=y.
There is only one caller left for register_active_ranges() from the
contig.c code ... so it doesn't need to pick up the node number, the
node number is always zero.
Actually, on reflection I think that there is a good case for
keeping the options separate. I am thinking particularly of people
who want a very small crashdump kernel and thus don't want to compile
in kexec.
The patch below should fix things up so that all valid combinations of
KEXEC, CRASH_DUMP and VMCORE compile cleanly - VMCORE depends on
CRASH_DUMP which is why I said valid combinations. In a nutshell
it just untangles unrelated code and switches around a few defines.
Please note that it creats a new file, arch/ia64/kernel/crash_dump.c
This is in keeping with the i386 implementation.
Arch-independent zone-sizing is using indices instead of symbolic names to
offset within an array related to zones (max_zone_pfns). The unintended
impact is that ZONE_DMA and ZONE_NORMAL is initialised on powerpc instead
of ZONE_DMA and ZONE_HIGHMEM when CONFIG_HIGHMEM is set. As a result, the
the machine fails to boot but will boot with CONFIG_HIGHMEM turned off.
The following patch properly initialises the max_zone_pfns[] array and uses
symbolic names instead of indices in each architecture using
arch-independent zone-sizing. Two users have successfully booted their
powerpcs with it (one an ibook G4). It has also been boot tested on x86,
x86_64, ppc64 and ia64. Please merge for 2.6.19-rc2.
Credit to Benjamin Herrenschmidt for identifying the bug and rolling the
first fix. Additional credit to Johannes Berg and Andreas Schwab for
reporting the problem and testing on powerpc.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] minor reformatting to vmlinux.lds.S
[IA64] CMC/CPE: Reverse the order of fetching log and checking poll threshold
[IA64] PAL calls need physical mode, stacked
[IA64] ar.fpsr not set on MCA/INIT kernel entry
[IA64] printing support for MCA/INIT
[IA64] trim output of show_mem()
[IA64] show_mem() printk levels
[IA64] Make gp value point to Region 5 in mca handler
Revert "[IA64] Unwire set/get_robust_list"
[IA64] Implement futex primitives
[IA64-SGI] Do not request DMA memory for BTE
[IA64] Move perfmon tables from thread_struct to pfm_context
[IA64] Add interface so modules can discover whether multithreading is on.
[IA64] kprobes: fixup the pagefault exception caused by probehandlers
[IA64] kprobe opcode 16 bytes alignment on IA64
[IA64] esi-support
[IA64] Add "model name" to /proc/cpuinfo
Size zones and holes in an architecture independent manner for ia64.
[bob.picco@hp.com: fix ia64 FLATMEM+VIRTUAL_MEM_MAP]
Signed-off-by: Bob Picco <bob.picco@hp.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Andy Whitcroft <apw@shadowen.org>
Cc: Andi Kleen <ak@muc.de>
Cc: "Keith Mannthey" <kmannth@gmail.com>
Cc: Yasunori Goto <y-goto@jp.fujitsu.com>
Use the default sysrq printk level for printing show_mem() output both
for disconfig and contig versions. This is consistent with the printk
level used on other architectures (well ia32 at least).
Signed-off-by: Jes Sorensen <jes@sgi.com>
contig.c (FLATMEM) requires the same optimization as in discontig.c for show_mem
when VIRTUAL_MEM_MAP is in use. Otherwise FLATMEM has softlockup timeouts.
This was boot tested for memory configuration: SPARSEMEM,
DISCONTIG+VIRTUAL_MEM_MAP, FLATMEM, FLATMEM+VIRTUAL_MEM_MAP and
FLATMEM+VIRTUAL_MEM_MAP with largest memory gap less than LARGE_GAP by
using boot parameter "mem=".
This was boot tested and "echo m >/proc/sysrq-trigger" output evaluated for
: FLATMEM, FLATMEM+VIRTUAL_MEM_MAP, DISCONTIGMEM+VIRTUAL_MEM_MAP and
SPARSEMEM.
Assure that vmem_map's high endpoint is MAX_ORDER aligned. Not doing so violates
the buddy allocator algorithm. Also anyone using mem=XXX on boot line and
not aligned to MAX_ORDER requires this patch in order to satisfy buddy
allocator. vmem_map always starts at pfn 0. The potentially large MAX_ORDER
on ia64 (due to hugetlbfs) requires that the end of vmem_map be aligned
to MAX_ORDER_NR_PAGES.
This was boot tested for: FLATMEM, FLATMEM+VIRTUAL_MEM_MAP,
DISCONTIGMEM+VIRTUAL_MEM_MAP and SPARSEMEM.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Add init declaration to variables/functions used for memory
initialization. I don't think they would clash with memory
hotplug. If they do, please yell.
Signed-off-by: Ken Chen <kenneth.w.chen@intel.com>
Add init declaration to cpu initialization functions.
here is the BSP removal support for IA64. Its pretty much the same thing that
was released a while back, but has your feedback incorporated.
- Removed CONFIG_BSP_REMOVE_WORKAROUND and associated cmdline param
- Fixed compile issue with sn2/zx1 due to a undefined fix_b0_for_bsp
- some formatting nits (whitespace etc)
This has been tested on tiger and long back by alex on hp systems as well.
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
For FLATMEM contig_page_data has been made transparent to the arch code.
This patch conforms to that change.
This patch introduces using the quicklists for pgd, pmd, and pte levels
by combining the alloc and free functions into a common set of routines.
This greatly simplifies the reading of this header file.
This patch is simple but necessary for large numa configurations.
It simply ensures that only pages from the local node are added to a
cpus quicklist. This prevents the trapping of pages on a remote nodes
quicklist by starting a process, touching a large number of pages to
fill pmd and pte entries, migrating to another node, and then unmapping
or exiting. With those conditions, the pages get trapped and if the
machine has more than 100 nodes of the same size, the calculation of
the pgtable high water mark will be larger than any single node so page
table cache flushing will never occur.
I ran lmbench lat_proc fork and lat_proc exec on a zx1 with and without
this patch and did not notice any change.
On an sn2 machine, there was a slight improvement which is possibly
due to pages from other nodes trapped on the test node before starting
the run. I did not investigate further.
This patch shrinks the quicklist based upon free memory on the node
instead of the high/low water marks. I have written it to enable
preemption periodically and recalculate the amount to shrink every time
we have freed enough pages that the quicklist size should have grown.
I rescan the nodes zones each pass because other processess may be
draining node memory at the same time as we are adding.
Signed-off-by: Robin Holt <holt@sgi.com>
infrastructure for it.
Let it rip!
