path: root/arch/ia64/kvm
2012-07-30Merge tag 'please-pull-ia64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull misc ia64 build fixes from Tony Luck. * tag 'please-pull-ia64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: [IA64] Redefine ATOMIC_INIT and ATOMIC64_INIT to drop the casts [IA64] Rename platform_name to ia64_platform_name [IA64] Mark PARAVIRT and KVM as broken
2012-07-25[IA64] Mark PARAVIRT and KVM as brokenFengguang Wu
Well, this at least makes allmodconfig happy. Proposed-by: David Howells <dhowells@redhat.com> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-07-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Trivial updates all over the place as usual." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (29 commits) Fix typo in include/linux/clk.h . pci: hotplug: Fix typo in pci iommu: Fix typo in iommu video: Fix typo in drivers/video Documentation: Add newline at end-of-file to files lacking one arm,unicore32: Remove obsolete "select MISC_DEVICES" module.c: spelling s/postition/position/g cpufreq: Fix typo in cpufreq driver trivial: typo in comment in mksysmap mach-omap2: Fix typo in debug message and comment scsi: aha152x: Fix sparse warning and make printing pointer address more portable. Change email address for Steve Glendinning Btrfs: fix typo in convert_extent_bit via: Remove bogus if check netprio_cgroup.c: fix comment typo backlight: fix memory leak on obscure error path Documentation: asus-laptop.txt references an obsolete Kconfig item Documentation: ManagementStyle: fixed typo mm/vmscan: cleanup comment error in balance_pgdat mm: cleanup on the comments of zone_reclaim_stat ...
2012-06-28treewide: Put a space between #include and FILEPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-06-05KVM: ia64: Mark ia64 KVM as BROKENAvi Kivity
Practically all patches to ia64 KVM are build fixes; numerous warnings remain; the last patch from the maintainer was committed more than three years ago. It is clear that no one is using this thing. Mark as BROKEN to ensure people don't get hit by pointless build problems. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-04-19KVM: ia64: fix build due to typoAvi Kivity
s/kcm/kvm/. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-04-19KVM: Fix page-crossing MMIOAvi Kivity
MMIO that are split across a page boundary are currently broken - the code does not expect to be aborted by the exit to userspace for the first MMIO fragment. This patch fixes the problem by generalizing the current code for handling 16-byte MMIOs to handle a number of "fragments", and changes the MMIO code to create those fragments. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-04-08KVM: Factor out kvm_vcpu_kick to arch-generic codeChristoffer Dall
The kvm_vcpu_kick function performs roughly the same funcitonality on most all architectures, so we shouldn't have separate copies. PowerPC keeps a pointer to interchanging waitqueues on the vcpu_arch structure and to accomodate this special need a __KVM_HAVE_ARCH_VCPU_GET_WQ define and accompanying function kvm_arch_vcpu_wq have been defined. For all other architectures this is a generic inline that just returns &vcpu->wq; Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-08KVM: Ensure all vcpus are consistent with in-kernel irqchip settingsAvi Kivity
If some vcpus are created before KVM_CREATE_IRQCHIP, then irqchip_in_kernel() and vcpu->arch.apic will be inconsistent, leading to potential NULL pointer dereferences. Fix by: - ensuring that no vcpus are installed when KVM_CREATE_IRQCHIP is called - ensuring that a vcpu has an apic if it is installed after KVM_CREATE_IRQCHIP This is somewhat long winded because vcpu->arch.apic is created without kvm->lock held. Based on earlier patch by Michael Ellerman. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-08KVM: Introduce kvm_memory_slot::arch and move lpage_info into itTakuya Yoshikawa
Some members of kvm_memory_slot are not used by every architecture. This patch is the first step to make this difference clear by introducing kvm_memory_slot::arch; lpage_info is moved into it. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: ucontrol: export SIE control block to userCarsten Otte
This patch exports the s390 SIE hardware control block to userspace via the mapping of the vcpu file descriptor. In order to do so, a new arch callback named kvm_arch_vcpu_fault is introduced for all architectures. It allows to map architecture specific pages. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: add parameter for KVM_CREATE_VMCarsten Otte
This patch introduces a new config option for user controlled kernel virtual machines. It introduces a parameter to KVM_CREATE_VM that allows to set bits that alter the capabilities of the newly created virtual machine. The parameter is passed to kvm_arch_init_vm for all architectures. The only valid modifier bit for now is KVM_VM_S390_UCONTROL. This requires CAP_SYS_ADMIN privileges and creates a user controlled virtual machine on s390 architectures. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: IA64: fix struct redefinitionXiao Guangrong
There is the same struct definition in ia64 and kvm common code: arch/ia64/kvm//kvm-ia64.c: At top level: arch/ia64/kvm//kvm-ia64.c:777:8: error: redefinition of ‘struct kvm_io_range’ include/linux/kvm_host.h:62:8: note: originally defined here So, rename kvm_io_range to kvm_ia64_io_range in ia64 code Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: introduce id_to_memslot functionXiao Guangrong
Introduce id_to_memslot to get memslot by slot id Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: introduce kvm_for_each_memslot macroXiao Guangrong
Introduce kvm_for_each_memslot to walk all valid memslot Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-10-21iommu/core: Convert iommu_found to iommu_presentJoerg Roedel
With per-bus iommu_ops the iommu_found function needs to work on a bus_type too. This patch adds a bus_type parameter to that function and converts all call-places. The function is also renamed to iommu_present because the function now checks if an iommu is present for a given bus and does not check for a global iommu anymore. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-07-23virtio: expose for non-virtualization users tooOhad Ben-Cohen
virtio has been so far used only in the context of virtualization, and the virtio Kconfig was sourced directly by the relevant arch Kconfigs when VIRTUALIZATION was selected. Now that we start using virtio for inter-processor communications, we need to source the virtio Kconfig outside of the virtualization scope too. Moreover, some architectures might use virtio for both virtualization and inter-processor communications, so directly sourcing virtio might yield unexpected results due to conflicting selections. The simple solution offered by this patch is to always source virtio's Kconfig in drivers/Kconfig, and remove it from the appropriate arch Kconfigs. Additionally, a virtio menu entry has been added so virtio drivers don't show up in the general drivers menu. This way anyone can use virtio, though it's arguably less accessible (and neat!) for virtualization users now. Note: some architectures (mips and sh) seem to have a VIRTUALIZATION menu merely for sourcing virtio's Kconfig, so that menu is removed too. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-22KVM: ia64: fix sparse warningsJeff Mahoney
This patch fixes some sparse warning about "dubious one-bit signed bitfield." Signed-off-by: Jeff Mahoney <jeffm@suse.com> Originally-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-17KVM: Add "exiting guest mode" stateXiao Guangrong
Currently we keep track of only two states: guest mode and host mode. This patch adds an "exiting guest mode" state that tells us that an IPI will happen soon, so unless we need to wait for the IPI, we can avoid it completely. Also 1: No need atomically to read/write ->mode in vcpu's thread 2: reorganize struct kvm_vcpu to make ->mode and ->requests in the same cache line explicitly Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17ia64: change to new flag variablesmatt mooney
Replace EXTRA_CFLAGS with ccflags-y and EXTRA_AFLAGS with asflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-01-13Merge branch 'kvm-updates/2.6.38' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.38' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (142 commits) KVM: Initialize fpu state in preemptible context KVM: VMX: when entering real mode align segment base to 16 bytes KVM: MMU: handle 'map_writable' in set_spte() function KVM: MMU: audit: allow audit more guests at the same time KVM: Fetch guest cr3 from hardware on demand KVM: Replace reads of vcpu->arch.cr3 by an accessor KVM: MMU: only write protect mappings at pagetable level KVM: VMX: Correct asm constraint in vmcs_load()/vmcs_clear() KVM: MMU: Initialize base_role for tdp mmus KVM: VMX: Optimize atomic EFER load KVM: VMX: Add definitions for more vm entry/exit control bits KVM: SVM: copy instruction bytes from VMCB KVM: SVM: implement enhanced INVLPG intercept KVM: SVM: enhance mov DR intercept handler KVM: SVM: enhance MOV CR intercept handler KVM: SVM: add new SVM feature bit names KVM: cleanup emulate_instruction KVM: move complete_insn_gp() into x86.c KVM: x86: fix CR8 handling KVM guest: Fix kvm clock initialization when it's configured out ...
2011-01-12KVM: Take missing slots_lock for kvm_io_bus_unregister_dev()Takuya Yoshikawa
In KVM_CREATE_IRQCHIP, kvm_io_bus_unregister_dev() is called without taking slots_lock in the error handling path. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-01-12KVM: Clean up vm creation and releaseJan Kiszka
IA64 support forces us to abstract the allocation of the kvm structure. But instead of mixing this up with arch-specific initialization and doing the same on destruction, split both steps. This allows to move generic destruction calls into generic code. It also fixes error clean-up on failures of kvm_create_vm for IA64. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-24KVM: ia64: define kvm_lapic_enabled() to fix a compile errorTakuya Yoshikawa
The following patch commit 57ce1659316f4ca298919649f9b1b55862ac3826 KVM: x86: In DM_LOWEST, only deliver interrupts to vcpus with enabled LAPIC's ignored the fact that kvm_irq_delivery_to_apic() was also used by ia64. We define kvm_lapic_enabled() to fix a compile error caused by this. This will have the same effect as reverting the problematic patch for ia64. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-01KVM: ia64: cleanup kvm_ia64_sync_dirty_log()Takuya Yoshikawa
kvm_ia64_sync_dirty_log() is a helper function for kvm_vm_ioctl_get_dirty_log() which copies ia64's arch specific dirty bitmap to general one in memslot. So doing sanity checks in this function is unnatural. We move these checks outside of this and change the prototype appropriately. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: ia64: fix dirty_log_lock spin_lock section not to include get_dirty_log()Takuya Yoshikawa
kvm_get_dirty_log() calls copy_to_user(). So we need to narrow the dirty_log_lock spin_lock section not to include this. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: Remove memory alias supportAvi Kivity
As advertised in feature-removal-schedule.txt. Equivalent support is provided by overlapping memory regions. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: move vcpu locking to dispatcher for generic vcpu ioctlsAvi Kivity
All vcpu ioctls need to be locked, so instead of locking each one specifically we lock at the generic dispatcher. This patch only updates generic ioctls and leaves arch specific ioctls alone. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-06-16Merge branch 'master' into for-nextJiri Kosina
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
2010-06-09KVM: ia64: Add missing spin_unlock in kvm_arch_hardware_enable()Julia Lawall
Add a spin_unlock missing on the error path. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E1; @@ * spin_lock(E1,...); <+... when != E1 if (...) { ... when != E1 * return ...; } ...+> * spin_unlock(E1,...); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-06-01Merge branch 'for-35' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits) kbuild: Revert part of e8d400a to resolve a conflict kbuild: Fix checking of scm-identifier variable gconfig: add support to show hidden options that have prompts menuconfig: add support to show hidden options which have prompts gconfig: remove show_debug option gconfig: remove dbg_print_ptype() and dbg_print_stype() kconfig: fix zconfdump() kconfig: some small fixes add random binaries to .gitignore kbuild: Include gen_initramfs_list.sh and the file list in the .d file kconfig: recalc symbol value before showing search results .gitignore: ignore *.lzo files headerdep: perlcritic warning scripts/Makefile.lib: Align the output of LZO kbuild: Generate modules.builtin in make modules_install Revert "kbuild: specify absolute paths for cscope" kbuild: Do not unnecessarily regenerate modules.builtin headers_install: use local file handles headers_check: fix perl warnings export_report: fix perl warnings ...
2010-05-19KVM: Let vcpu structure alignment be determined at runtimeAvi Kivity
vmx and svm vcpus have different contents and therefore may have different alignmment requirements. Let each specify its required alignment. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: use the correct RCU API for PROVE_RCU=yLai Jiangshan
The RCU/SRCU API have already changed for proving RCU usage. I got the following dmesg when PROVE_RCU=y because we used incorrect API. This patch coverts rcu_deference() to srcu_dereference() or family API. =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- arch/x86/kvm/mmu.c:3020 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by qemu-system-x86/8550: #0: (&kvm->slots_lock){+.+.+.}, at: [<ffffffffa011a6ac>] kvm_set_memory_region+0x29/0x50 [kvm] #1: (&(&kvm->mmu_lock)->rlock){+.+...}, at: [<ffffffffa012262d>] kvm_arch_commit_memory_region+0xa6/0xe2 [kvm] stack backtrace: Pid: 8550, comm: qemu-system-x86 Not tainted 2.6.34-rc4-tip-01028-g939eab1 #27 Call Trace: [<ffffffff8106c59e>] lockdep_rcu_dereference+0xaa/0xb3 [<ffffffffa012f6c1>] kvm_mmu_calculate_mmu_pages+0x44/0x7d [kvm] [<ffffffffa012263e>] kvm_arch_commit_memory_region+0xb7/0xe2 [kvm] [<ffffffffa011a5d7>] __kvm_set_memory_region+0x636/0x6e2 [kvm] [<ffffffffa011a6ba>] kvm_set_memory_region+0x37/0x50 [kvm] [<ffffffffa015e956>] vmx_set_tss_addr+0x46/0x5a [kvm_intel] [<ffffffffa0126592>] kvm_arch_vm_ioctl+0x17a/0xcf8 [kvm] [<ffffffff810a8692>] ? unlock_page+0x27/0x2c [<ffffffff810bf879>] ? __do_fault+0x3a9/0x3e1 [<ffffffffa011b12f>] kvm_vm_ioctl+0x364/0x38d [kvm] [<ffffffff81060cfa>] ? up_read+0x23/0x3d [<ffffffff810f3587>] vfs_ioctl+0x32/0xa6 [<ffffffff810f3b19>] do_vfs_ioctl+0x495/0x4db [<ffffffff810e6b2f>] ? fget_light+0xc2/0x241 [<ffffffff810e416c>] ? do_sys_open+0x104/0x116 [<ffffffff81382d6d>] ? retint_swapgs+0xe/0x13 [<ffffffff810f3ba6>] sys_ioctl+0x47/0x6a [<ffffffff810021db>] system_call_fastpath+0x16/0x1b Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: ia64: fix the error of ioctl KVM_IRQ_LINE if no irq chipWei Yongjun
If no irq chip in kernel, ioctl KVM_IRQ_LINE will return -EFAULT. But I see in other place such as KVM_[GET|SET]IRQCHIP, -ENXIO is return. So this patch used -ENXIO instead of -EFAULT. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-05-17KVM: ia64: fix the error code of ioctl KVM_IA64_VCPU_GET_STACK failureWei Yongjun
The ioctl KVM_IA64_VCPU_GET_STACK does not set the error code if copy_to_user() fail, and 0 will be return, we should use -EFAULT instead of 0 in this case, so this patch fixed it. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-04-20KVM: fix the handling of dirty bitmaps to avoid overflowsTakuya Yoshikawa
Int is not long enough to store the size of a dirty bitmap. This patch fixes this problem with the introduction of a wrapper function to calculate the sizes of dirty bitmaps. Note: in mark_page_dirty(), we have to consider the fact that __set_bit() takes the offset as int, not long. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-05Merge branch 'kvm-updates/2.6.34' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.34' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (145 commits) KVM: x86: Add KVM_CAP_X86_ROBUST_SINGLESTEP KVM: VMX: Update instruction length on intercepted BP KVM: Fix emulate_sys[call, enter, exit]()'s fault handling KVM: Fix segment descriptor loading KVM: Fix load_guest_segment_descriptor() to inject page fault KVM: x86 emulator: Forbid modifying CS segment register by mov instruction KVM: Convert kvm->requests_lock to raw_spinlock_t KVM: Convert i8254/i8259 locks to raw_spinlocks KVM: x86 emulator: disallow opcode 82 in 64-bit mode KVM: x86 emulator: code style cleanup KVM: Plan obsolescence of kernel allocated slots, paravirt mmu KVM: x86 emulator: Add LOCK prefix validity checking KVM: x86 emulator: Check CPL level during privilege instruction emulation KVM: x86 emulator: Fix popf emulation KVM: x86 emulator: Check IOPL level during io instruction emulation KVM: x86 emulator: fix memory access during x86 emulation KVM: x86 emulator: Add Virtual-8086 mode of emulation KVM: x86 emulator: Add group9 instruction decoding KVM: x86 emulator: Add group8 instruction decoding KVM: do not store wqh in irqfd ... Trivial conflicts in Documentation/feature-removal-schedule.txt
2010-03-03Rename .text.ivt to .text..ivt.Denys Vlasenko
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-03-01KVM: ia64: destroy ioapic device if fail to setup default irq routingWei Yongjun
If KVM_CREATE_IRQCHIP fail due to kvm_setup_default_irq_routing(), ioapic device is not destroyed and kvm->arch.vioapic is not set to NULL, this may cause KVM_GET_IRQCHIP and KVM_SET_IRQCHIP access to unexcepted memory. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: ia64: Fix string literal continuation linesJoe Perches
String constants that are continued on subsequent lines with \ are not good. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: fix cleanup_srcu_struct on vm destructionMarcelo Tosatti
cleanup_srcu_struct on VM destruction remains broken: BUG: unable to handle kernel paging request at ffffffffffffffff IP: [<ffffffff802533d2>] srcu_read_lock+0x16/0x21 RIP: 0010:[<ffffffff802533d2>] [<ffffffff802533d2>] srcu_read_lock+0x16/0x21 Call Trace: [<ffffffffa05354c4>] kvm_arch_vcpu_uninit+0x1b/0x48 [kvm] [<ffffffffa05339c6>] kvm_vcpu_uninit+0x9/0x15 [kvm] [<ffffffffa0569f7d>] vmx_free_vcpu+0x7f/0x8f [kvm_intel] [<ffffffffa05357b5>] kvm_arch_destroy_vm+0x78/0x111 [kvm] [<ffffffffa053315b>] kvm_put_kvm+0xd4/0xfe [kvm] Move it to kvm_arch_destroy_vm. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Reported-by: Jan Kiszka <jan.kiszka@siemens.com>
2010-03-01KVM: ia64: remove redundant kvm_get_exit_data() NULL testsRoel Kluin
kvm_get_exit_data() cannot return a NULL pointer. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: convert slots_lock to a mutexMarcelo Tosatti
2010-03-01KVM: switch vcpu context to use SRCUMarcelo Tosatti
