__get_cpu_var() is used for multiple purposes in the kernel source. One of
them is address calculation via the form &__get_cpu_var(x). This calculates
the address for the instance of the percpu variable of the current processor
based on an offset.
Other use cases are for storing and retrieving data from the current
processors percpu area. __get_cpu_var() can be used as an lvalue when
writing data or on the right side of an assignment.
__get_cpu_var() is defined as :
#define __get_cpu_var(var) (*this_cpu_ptr(&(var)))
__get_cpu_var() always only does an address determination. However, store
and retrieve operations could use a segment prefix (or global register on
other platforms) to avoid the address calculation.
this_cpu_write() and this_cpu_read() can directly take an offset into a
percpu area and use optimized assembly code to read and write per cpu
variables.
This patch converts __get_cpu_var into either an explicit address
calculation using this_cpu_ptr() or into a use of this_cpu operations that
use the offset. Thereby address calculations are avoided and less registers
are used when code is generated.
At the end of the patch set all uses of __get_cpu_var have been removed so
the macro is removed too.
The patch set includes passes over all arches as well. Once these operations
are used throughout then specialized macros can be defined in non -x86
arches as well in order to optimize per cpu access by f.e. using a global
register that may be set to the per cpu base.
Transformations done to __get_cpu_var()
1. Determine the address of the percpu instance of the current processor.
DEFINE_PER_CPU(int, y);
int *x = &__get_cpu_var(y);
Converts to
int *x = this_cpu_ptr(&y);
2. Same as #1 but this time an array structure is involved.
DEFINE_PER_CPU(int, y[20]);
int *x = __get_cpu_var(y);
Converts to
int *x = this_cpu_ptr(y);
3. Retrieve the content of the current processors instance of a per cpu
variable.
int x = __get_cpu_var(y)
Converts to
int x = __this_cpu_read(y);
4. Retrieve the content of a percpu struct
DEFINE_PER_CPU(struct mystruct, y);
struct mystruct x = __get_cpu_var(y);
Converts to
memcpy(&x, this_cpu_ptr(&y), sizeof(x));
5. Assignment to a per cpu variable
__get_cpu_var(y) = x;
Converts to
__this_cpu_write(y, x);
6. Increment/Decrement etc of a per cpu variable
__get_cpu_var(y)++
Converts to
__this_cpu_inc(y)
Cc: linux-ia64@vger.kernel.org
Signed-off-by: Christoph Lameter <cl@linux.com>
Back 2010 during a revamp of the irq code some initializations
were moved from ia64_mca_init() to ia64_mca_late_init() in
commit c75f2aa13f5b268aba369b5dc566088b5194377c
Cannot use register_percpu_irq() from ia64_mca_init()
But this was hideously wrong. First of all these initializations
are now down far too late. Specifically after all the other cpus
have been brought up and initialized their own CMC vectors from
smp_callin(). Also ia64_mca_late_init() may be called from any cpu
so the line:
ia64_mca_cmc_vector_setup(); /* Setup vector on BSP */
is generally not executed on the BSP, and so the CMC vector isn't
setup at all on that processor.
Make use of the arch_early_irq_init() hook to get this code executed
at just the right moment: not too early, not too late.
Reported-by: Fred Hartnett <fred.hartnett@hp.com>
Tested-by: Fred Hartnett <fred.hartnett@hp.com>
Cc: stable@kernel.org # v2.6.37+
Signed-off-by: Tony Luck <tony.luck@intel.com>
Remove the last open coded access to irq_desc.
Use the proper accessor functions instead of open coded irq_desc access.
Convert locks which cannot be sleeping locks in preempt-rt to
raw_spinlocks.
Acked-by: Peter Zijlstra <peterz@infradead.org>
The defines and typedefs (hw_interrupt_type, no_irq_type, irq_desc_t) have
been kept around for migration reasons. After more than two years it's
time to remove them finally.
This patch cleans up one of the remaining users. When all such patches
hit mainline we can remove the defines and typedefs finally.
Impact: cleanup
Convert the last remaining users and remove the typedef.
arch/parisc/kernel/irq.c
arch/x86/include/asm/fixmap_64.h
arch/x86/include/asm/setup.h
kernel/irq/handle.c
Semantic merge:
arch/x86/include/asm/fixmap.h
Impact: cleanup, update to new cpumask API
Irq_desc.affinity and irq_desc.pending_mask are now cpumask_var_t's
so access to them should be using the new cpumask API.
Signed-off-by: Mike Travis <travis@sgi.com>
Impact: build fix
Ingo Molnar wrote:
> tip/arch/blackfin/kernel/irqchip.c: In function 'show_interrupts':
> tip/arch/blackfin/kernel/irqchip.c:85: error: 'struct kernel_stat' has no member named 'irqs'
> make[2]: *** [arch/blackfin/kernel/irqchip.o] Error 1
> make[2]: *** Waiting for unfinished jobs....
So could move kstat_irqs array to irq_desc struct.
(s390, m68k, sparc) are not touched yet, because they don't support genirq
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Impact: cleanup
The function prototype should use 'struct cpumask *' to declare
cpumask arguments (instead of cpumask_var_t).
Note: arch/ia64/kernel/irq.c still had the following "old cpumask_t" usages:
105: cpumask_t mask = CPU_MASK_NONE;
107: cpu_set(cpu_logical_id(hwid), mask);
110: irq_desc[irq].affinity = mask;
... replaced with a simple "cpumask_of(cpu_logical_id(hwid))".
161: new_cpu = any_online_cpu(cpu_online_map);
194: time_keeper_id = first_cpu(cpu_online_map);
... replaced with cpu_online_mask refs.
Impact: build fix on ia64
ia64's default_affinity_write() still had old cpumask_t usage:
/home/mingo/tip/kernel/irq/proc.c: In function `default_affinity_write':
/home/mingo/tip/kernel/irq/proc.c:114: error: incompatible type for argument 1 of `is_affinity_mask_valid'
make[3]: *** [kernel/irq/proc.o] Error 1
make[3]: *** Waiting for unfinished jobs....
update it to cpumask_var_t.
Impact: change existing irq_chip API
Not much point with gentle transition here: the struct irq_chip's
setaffinity method signature needs to change.
Fortunately, not widely used code, but hits a few architectures.
Note: In irq_select_affinity() I save a temporary in by mangling
irq_desc[irq].affinity directly. Ingo, does this break anything?
(Folded in fix from KOSAKI Motohiro)
Reviewed-by: Grant Grundler <grundler@parisc-linux.org>
Acked-by: Ingo Molnar <mingo@redhat.com>
Cc: ralf@linux-mips.org
Cc: grundler@parisc-linux.org
Cc: jeremy@xensource.com
This patch shuts up the following:
WARNING: vmlinux.o(.text+0x7102): Section mismatch in
reference from the function fixup_irqs() to the function
.devinit.text:ia64_disable_timer()
Removing ia64_disable_timer() is safe because there are no functions
calling it other than the fixup_irqs(),
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Clean up /proc/interrupts output on the system that has 10 or more
CPUs.
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Add base support for implementing platform_irq_to_vector(), and
then use it on SN2.
Acked-by: John Keller <jpk@sgi.com>
Add mapping tables between irqs and vectors, and its management code.
This is necessary for supporting multiple vector domain because 1:1
mapping between irq and vector will be changed to n:1.
The irq == vector relationship between irqs and vectors is explicitly
remained for percpu interrupts, platform interrupts, isa IRQs and
vectors assigned using assign_irq_vector() because some programs might
depend on it.
And I should consider the following problem.
When pci drivers enabled/disabled devices dynamically, its irq number
is changed to the different one. Therefore, suspend/resume code may
happen problem.
To fix this problem, I bound gsi to irq.
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Spelling and apostrophe fixes in arch/ia64/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
On SN, only allow one bit to be set in the smp_affinty mask when
redirecting an interrupt. Currently setting multiple bits is allowed, but
only the first bit is used in determining the CPU to redirect to. This has
caused confusion among some customers.
[akpm@linux-foundation.org: fixes]
Signed-off-by: John Keller <jpk@sgi.com>
This patch fixes up ia64 kexec support for HP rx2620 hardware. It does
this by skipping migration of already disabled irqs. This is most likely a
problem on other ia64 platforms as well, but I've only been able to
reproduce it on one machine so far.
The full story is that handle_bad_irq() gets invoked before starting the
new kernel without this patch. This seems to happen when fixup_irqs()
calls generic_handle_irq() on already migrated (and disabled) irqs. So by
avoiding migration of disabled irqs we stay away of handle_bad_irq().
The code has been tested on three different ia64 machines, all with good
results. It is possible to trigger the same bug by offlining a processor
using echo 0 > /sys/devices/system/cpu/cpuX/online.
More detailed information is available in the following mail thread:
http://lists.osdl.org/pipermail/fastboot/2007-January/thread.html#5774
Signed-off-by: Magnus Damm <magnus@valinux.co.jp>
Acked-by: Simon Horman <horms@verge.net.au>
Acked-by: Zou, Nanhai <nanhai.zou@intel.com>
Acked-by: Jay Lan <jlan@sgi.com>
Acked-by: "Luck, Tony" <tony.luck@intel.com>
Use generic_handle_irq() to handle mixed-type irq handling.
`typename' is going away and is usually uninitialised anwyay.
A few missed spots in ia64-land from this gigantic commit:
7d12e780e003f93433d49ce78cfedf4b4c52adc5
Cleanup: remove irq_descp() - explicit use of irq_desc[] is shorter and more
readable.
Consolidation: remove the irq_affinity[NR_IRQS] array and move it into the
irq_desc[NR_IRQS].affinity field.
[akpm@osdl.org: sparc64 build fix]
This patch-queue improves the generic IRQ layer to be truly generic, by adding
various abstractions and features to it, without impacting existing
functionality.
While the queue can be best described as "fix and improve everything in the
generic IRQ layer that we could think of", and thus it consists of many
smaller features and lots of cleanups, the one feature that stands out most is
the new 'irq chip' abstraction.
The irq-chip abstraction is about describing and coding and IRQ controller
driver by mapping its raw hardware capabilities [and quirks, if needed] in a
straightforward way, without having to think about "IRQ flow"
(level/edge/etc.) type of details.
This stands in contrast with the current 'irq-type' model of genirq
architectures, which 'mixes' raw hardware capabilities with 'flow' details.
The patchset supports both types of irq controller designs at once, and
converts i386 and x86_64 to the new irq-chip design.
As a bonus side-effect of the irq-chip approach, chained interrupt controllers
(master/slave PIC constructs, etc.) are now supported by design as well.
The end result of this patchset intends to be simpler architecture-level code
and more consolidation between architectures.
We reused many bits of code and many concepts from Russell King's ARM IRQ
layer, the merging of which was one of the motivations for this patchset.
This patch:
rename desc->handler to desc->chip.
Originally i did not want to do this, because it's a big patch. But having
both "desc->handler", "desc->handle_irq" and "action->handler" caused a
large degree of confusion and made the code appear alot less clean than it
truly is.
I have also attempted a dual approach as well by introducing a
desc->chip alias - but that just wasnt robust enough and broke
frequently.
So lets get over with this quickly. The conversion was done automatically
via scripts and converts all the code in the kernel.
This renaming patch is the first one amongst the patches, so that the
remaining patches can stay flexible and can be merged and split up
without having some big monolithic patch act as a merge barrier.
[akpm@osdl.org: build fix]
[akpm@osdl.org: another build fix]
Calls to set_irq_info in set_irq_affinity_info() is redundant because
irq_affinity mask was set just one line immediately above it. Remove
that duplicate call.
Signed-off-by: Ken Chen <kenneth.w.chen@intel.com>
here is the BSP removal support for IA64. Its pretty much the same thing that
was released a while back, but has your feedback incorporated.
- Removed CONFIG_BSP_REMOVE_WORKAROUND and associated cmdline param
- Fixed compile issue with sn2/zx1 due to a undefined fix_b0_for_bsp
- some formatting nits (whitespace etc)
This has been tested on tiger and long back by alex on hp systems as well.
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
In arch/ia64 change the explicit use of for-loops and NR_CPUS into the
general for_each_cpu() or for_each_online_cpu() constructs, as
appropriate. This widens the scope of potential future optimizations
of the general constructs, as well as takes advantage of the existing
optimizations of first_cpu() and next_cpu().
Signed-off-by: John Hawkes <hawkes@sgi.com>
When handling writes to /proc/irq, current code is re-programming rte
entries directly. This is not recommended and could potentially cause
chipset's to lockup, or cause missing interrupts.
CONFIG_IRQ_BALANCE does this correctly, where it re-programs only when the
interrupt is pending. The same needs to be done for /proc/irq handling as well.
Otherwise user space irq balancers are really not doing the right thing.
- Changed pending_irq_balance_cpumask to pending_irq_migrate_cpumask for
lack of a generic name.
- added move_irq out of IRQ_BALANCE, and added this same to X86_64
- Added new proc handler for write, so we can do deferred write at irq
handling time.
- Display of /proc/irq/XX/smp_affinity used to display CPU_MASKALL, instead
it now shows only active cpu masks, or exactly what was set.
- Provided a common move_irq implementation, instead of duplicating
when using generic irq framework.
Tested on i386/x86_64 and ia64 with CONFIG_PCI_MSI turned on and off.
Tested UP builds as well.
MSI testing: tbd: I have cards, need to look for a x-over cable, although I
did test an earlier version of this patch. Will test in a couple days.
Acked-by: Zwane Mwaikambo <zwane@holomorphy.com>
Grudgingly-acked-by: Andi Kleen <ak@muc.de>
Signed-off-by: Coywolf Qi Hunt <coywolf@lovecn.org>
infrastructure for it.
Let it rip!
