path: root/arch/hexagon
2015-07-17mm: clean up per architecture MM hook header filesLaurent Dufour
Commit 2ae416b142b6 ("mm: new mm hook framework") introduced an empty header file (mm-arch-hooks.h) for every architecture, even those which doesn't need to define mm hooks. As suggested by Geert Uytterhoeven, this could be cleaned through the use of a generic header file included via each per architecture asm/include/Kbuild file. The PowerPC architecture is not impacted here since this architecture has to defined the arch_remap MM hook. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Vineet Gupta <vgupta@synopsys.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25Merge branch 'for-4.2/sg' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull asm/scatterlist.h removal from Jens Axboe: "We don't have any specific arch scatterlist anymore, since parisc finally switched over. Kill the include" * 'for-4.2/sg' of git://git.kernel.dk/linux-block: remove scatterlist.h generation from arch Kbuild files remove <asm/scatterlist.h>
2015-06-24mm: new mm hook frameworkLaurent Dufour
CRIU is recreating the process memory layout by remapping the checkpointee memory area on top of the current process (criu). This includes remapping the vDSO to the place it has at checkpoint time. However some architectures like powerpc are keeping a reference to the vDSO base address to build the signal return stack frame by calling the vDSO sigreturn service. So once the vDSO has been moved, this reference is no more valid and the signal frame built later are not usable. This patch serie is introducing a new mm hook framework, and a new arch_remap hook which is called when mremap is done and the mm lock still hold. The next patch is adding the vDSO remap and unmap tracking to the powerpc architecture. This patch (of 3): This patch introduces a new set of header file to manage mm hooks: - per architecture empty header file (arch/x/include/asm/mm-arch-hooks.h) - a generic header (include/linux/mm-arch-hooks.h) The architecture which need to overwrite a hook as to redefine it in its header file, while architecture which doesn't need have nothing to do. The default hooks are defined in the generic header and are used in the case the architecture is not defining it. In a next step, mm hooks defined in include/asm-generic/mm_hooks.h should be moved here. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-22Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes are: - lockless wakeup support for futexes and IPC message queues (Davidlohr Bueso, Peter Zijlstra) - Replace spinlocks with atomics in thread_group_cputimer(), to improve scalability (Jason Low) - NUMA balancing improvements (Rik van Riel) - SCHED_DEADLINE improvements (Wanpeng Li) - clean up and reorganize preemption helpers (Frederic Weisbecker) - decouple page fault disabling machinery from the preemption counter, to improve debuggability and robustness (David Hildenbrand) - SCHED_DEADLINE documentation updates (Luca Abeni) - topology CPU masks cleanups (Bartosz Golaszewski) - /proc/sched_debug improvements (Srikar Dronamraju)" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits) sched/deadline: Remove needless parameter in dl_runtime_exceeded() sched: Remove superfluous resetting of the p->dl_throttled flag sched/deadline: Drop duplicate init_sched_dl_class() declaration sched/deadline: Reduce rq lock contention by eliminating locking of non-feasible target sched/deadline: Make init_sched_dl_class() __init sched/deadline: Optimize pull_dl_task() sched/preempt: Add static_key() to preempt_notifiers sched/preempt: Fix preempt notifiers documentation about hlist_del() within unsafe iteration sched/stop_machine: Fix deadlock between multiple stop_two_cpus() sched/debug: Add sum_sleep_runtime to /proc/<pid>/sched sched/debug: Replace vruntime with wait_sum in /proc/sched_debug sched/debug: Properly format runnable tasks in /proc/sched_debug sched/numa: Only consider less busy nodes as numa balancing destinations Revert 095bebf61a46 ("sched/numa: Do not move past the balance point if unbalanced") sched/fair: Prevent throttling in early pick_next_task_fair() preempt: Reorganize the notrace definitions a bit preempt: Use preempt_schedule_context() as the official tracing preemption point sched: Make preempt_schedule_context() function-tracing safe x86: Remove cpu_sibling_mask() and cpu_core_mask() x86: Replace cpu_**_mask() with topology_**_cpumask() ...
2015-05-19remove scatterlist.h generation from arch Kbuild filesChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-19mm/uaccess, mm/fault: Clarify that uaccess may only sleep if pagefaults are ↵David Hildenbrand
enabled In general, non-atomic variants of user access functions must not sleep if pagefaults are disabled. Let's update all relevant comments in uaccess code. This also reflects the might_sleep() checks in might_fault(). Reviewed-and-tested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: David.Laight@ACULAB.COM Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: airlied@linux.ie Cc: akpm@linux-foundation.org Cc: benh@kernel.crashing.org Cc: bigeasy@linutronix.de Cc: borntraeger@de.ibm.com Cc: daniel.vetter@intel.com Cc: heiko.carstens@de.ibm.com Cc: herbert@gondor.apana.org.au Cc: hocko@suse.cz Cc: hughd@google.com Cc: mst@redhat.com Cc: paulus@samba.org Cc: ralf@linux-mips.org Cc: schwidefsky@de.ibm.com Cc: yang.shi@windriver.com Link: http://lkml.kernel.org/r/1431359540-32227-4-git-send-email-dahi@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-13arch: Remove __ARCH_HAVE_CMPXCHGThomas Gleixner
We removed the only user of this define in the rtmutex code. Get rid of it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
2015-04-15Merge branch 'exec_domain_rip_v2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc Pull exec domain removal from Richard Weinberger: "This series removes execution domain support from Linux. The idea behind exec domains was to support different ABIs. The feature was never complete nor stable. Let's rip it out and make the kernel signal handling code less complicated" * 'exec_domain_rip_v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (27 commits) arm64: Removed unused variable sparc: Fix execution domain removal Remove rest of exec domains. arch: Remove exec_domain from remaining archs arc: Remove signal translation and exec_domain xtensa: Remove signal translation and exec_domain xtensa: Autogenerate offsets in struct thread_info x86: Remove signal translation and exec_domain unicore32: Remove signal translation and exec_domain um: Remove signal translation and exec_domain tile: Remove signal translation and exec_domain sparc: Remove signal translation and exec_domain sh: Remove signal translation and exec_domain s390: Remove signal translation and exec_domain mn10300: Remove signal translation and exec_domain microblaze: Remove signal translation and exec_domain m68k: Remove signal translation and exec_domain m32r: Remove signal translation and exec_domain m32r: Autogenerate offsets in struct thread_info frv: Remove signal translation and exec_domain ...
2015-04-12arch: Remove exec_domain from remaining archsRichard Weinberger
Signed-off-by: Richard Weinberger <richard@nod.at>
2015-04-11whack-a-mole: no need to set_fs(USER_DS) in {start,flush}_thread()Al Viro
flush_old_exec() has already done that. Back on 2011 a bunch of instances like that had been kicked out, but that hadn't taken care of then-out-of-tree architectures, obviously, and they served as reinfection vector... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-12all arches, signal: move restart_block to struct task_structAndy Lutomirski
If an attacker can cause a controlled kernel stack overflow, overwriting the restart block is a very juicy exploit target. This is because the restart_block is held in the same memory allocation as the kernel stack. Moving the restart block to struct task_struct prevents this exploit by making the restart_block harder to locate. Note that there are other fields in thread_info that are also easy targets, at least on some architectures. It's also a decent simplification, since the restart code is more or less identical on all architectures. [james.hogan@imgtec.com: metag: align thread_info::supervisor_stack] Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Kees Cook <keescook@chromium.org> Cc: David Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Steven Miao <realmz6@gmail.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11mm: make FIRST_USER_ADDRESS unsigned long on all archsKirill A. Shutemov
LKP has triggered a compiler warning after my recent patch "mm: account pmd page tables to the process": mm/mmap.c: In function 'exit_mmap': >> mm/mmap.c:2857:2: warning: right shift count >= width of type [enabled by default] The code: > 2857 WARN_ON(mm_nr_pmds(mm) > 2858 round_up(FIRST_USER_ADDRESS, PUD_SIZE) >> PUD_SHIFT); In this, on tile, we have FIRST_USER_ADDRESS defined as 0. round_up() has the same type -- int. PUD_SHIFT. I think the best way to fix it is to define FIRST_USER_ADDRESS as unsigned long. On every arch for consistency. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-10hexagon: drop _PAGE_FILE and pte_file()-related helpersKirill A. Shutemov
We've replaced remap_file_pages(2) implementation with emulation. Nobody creates non-linear mapping anymore. This patch also increase number of bits availble for swap offset. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Richard Kuo <rkuo@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel Pull arch/hexagon updates from Richard Kuo: "Build cleanup and a few misc fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel: Hexagon: fix signal delivery for debug traps Hexagon: set ARCH_DMA_MINALIGN Hexagon: fix alignment of init_task in RW_DATA_SECTION hexagon: Fix build failures in linux-next
2014-12-16Hexagon: fix signal delivery for debug trapsRichard Kuo
Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2014-12-16Hexagon: set ARCH_DMA_MINALIGNRichard Kuo
2014-12-16Hexagon: fix alignment of init_task in RW_DATA_SECTIONRichard Kuo
2014-12-16hexagon: Fix build failures in linux-nextGuenter Roeck
hexagon:defconfig fails to build in linux-next since commit 332fd7c4fef5 ("genirq: Generic chip: Change irq_reg_{readl,writel} arguments"). The primary build failure is arch/hexagon/include/asm/cacheflush.h: In function 'copy_to_user_page': arch/hexagon/include/asm/cacheflush.h:89:22: error: 'VM_EXEC' undeclared This is the result of including of <linux/io.h> from <linux/irq.h>, which is now necessary due to the use of readl and writel from irq.h. This causes recursive inclusions in hexagon code; cacheflush.h is included from mm.h prior to the definition of VM_EXEC. Fix the problem by moving copy_to_user_page from the hexagon include file to arch/hexagon/mm/cache.c, similar to other architectures. After this change, several redefinitions of readl and writel are reported. Those are caused by recursive inclusions of io.h and asm/cacheflush.h. Fix those problems by reducing the number of files included from those files. Also, it was necessary to stop including asm-generic/cacheflush.h from asm/cacheflush.h. Instead, functionality originally provided by asm-generic/cacheflush.h is now coded in asm/cacheflush.h directly. Cc: Kevin Cernekee <cernekee@gmail.com> Cc: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2014-12-10net, lib: kill arch_fast_hash library bitsDaniel Borkmann
As there are now no remaining users of arch_fast_hash(), lets kill it entirely. This basically reverts commit 71ae8aac3e19 ("lib: introduce arch optimized hash library") and follow-up work, that is f.e., commit 237217546d44 ("lib: hash: follow-up fixups for arch hash"), commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for asm-generic/hash.h") and last but not least commit 6a02652df511 ("perf tools: Fix include for non x86 architectures"). Cc: Francesco Fusco <fusco@ntop.org> Cc: Thomas Graf <tgraf@suug.ch> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-13Merge branch 'locking-arch-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull arch atomic cleanups from Ingo Molnar: "This is a series kept separate from the main locking tree, which cleans up and improves various details in the atomics type handling: - Remove the unused atomic_or_long() method - Consolidate and compress atomic ops implementations between architectures, to reduce linecount and to make it easier to add new ops. - Rewrite generic atomic support to only require cmpxchg() from an architecture - generate all other methods from that" * 'locking-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits) locking,arch: Use ACCESS_ONCE() instead of cast to volatile in atomic_read() locking, mips: Fix atomics locking, sparc64: Fix atomics locking,arch: Rewrite generic atomic support locking,arch,xtensa: Fold atomic_ops locking,arch,sparc: Fold atomic_ops locking,arch,sh: Fold atomic_ops locking,arch,powerpc: Fold atomic_ops locking,arch,parisc: Fold atomic_ops locking,arch,mn10300: Fold atomic_ops locking,arch,mips: Fold atomic_ops locking,arch,metag: Fold atomic_ops locking,arch,m68k: Fold atomic_ops locking,arch,m32r: Fold atomic_ops locking,arch,ia64: Fold atomic_ops locking,arch,hexagon: Fold atomic_ops locking,arch,cris: Fold atomic_ops locking,arch,avr32: Fold atomic_ops locking,arch,arm64: Fold atomic_ops locking,arch,arm: Fold atomic_ops ...
2014-09-13irq_work: Introduce arch_irq_work_has_interrupt()Peter Zijlstra
The nohz full code needs irq work to trigger its own interrupt so that the subsystem can work even when the tick is stopped. Lets introduce arch_irq_work_has_interrupt() that archs can override to tell about their support for this ability. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2014-08-29flush_icache_range: export symbol to fix build errorsPranith Kumar
Fix building errors occuring due to a missing export of flush_icache_range() in kisskb.ellerman.id.au/kisskb/buildresult/11677809/ ERROR: "flush_icache_range" [drivers/misc/lkdtm.ko] undefined! Signed-off-by: Pranith Kumar <bobby.prani@gmail.com> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon] Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Chris Zankel <chris@zankel.net> Acked-by: Max Filippov <jcmvbkbc@gmail.com> [xtensa] Cc: Noam Camus <noamc@ezchip.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Zhigang Lu <zlu@tilera.com> [tile] Cc: Kirill Tkhai <tkhai@yandex.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-14locking,arch,hexagon: Fold atomic_opsPeter Zijlstra
OK, no LoC saved in this case because the !return variants were defined in terms of the return ops. Still do it because this also prepares for easy addition of new ops. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Richard Kuo <rkuo@codeaurora.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: linux-hexagon@vger.kernel.org Link: http://lkml.kernel.org/r/20140508135852.171567636@infradead.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-08-09Merge branch 'signal-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc Pull arch signal handling cleanup from Richard Weinberger: "This patch series moves all remaining archs to the get_signal(), signal_setup_done() and sigsp() functions. Currently these archs use open coded variants of the said functions. Further, unused parameters get removed from get_signal_to_deliver(), tracehook_signal_handler() and signal_delivered(). At the end of the day we save around 500 lines of code." * 'signal-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (43 commits) powerpc: Use sigsp() openrisc: Use sigsp() mn10300: Use sigsp() mips: Use sigsp() microblaze: Use sigsp() metag: Use sigsp() m68k: Use sigsp() m32r: Use sigsp() hexagon: Use sigsp() frv: Use sigsp() cris: Use sigsp() c6x: Use sigsp() blackfin: Use sigsp() avr32: Use sigsp() arm64: Use sigsp() arc: Use sigsp() sas_ss_flags: Remove nested ternary if Rip out get_signal_to_deliver() Clean up signal_delivered() tracehook_signal_handler: Remove sig, info, ka and regs ...
2014-08-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree changes from Jiri Kosina: "Summer edition of trivial tree updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits) doc: fix two typos in watchdog-api.txt irq-gic: remove file name from heading comment MAINTAINERS: Add miscdevice.h to file list for char/misc drivers. scsi: mvsas: mv_sas.c: Fix for possible null pointer dereference doc: replace "practise" with "practice" in Documentation befs: remove check for CONFIG_BEFS_RW scsi: doc: fix 'SCSI_NCR_SETUP_MASTER_PARITY' drivers/usb/phy/phy.c: remove a leading space mfd: fix comment cpuidle: fix comment doc: hpfall.c: fix missing null-terminate after strncpy call usb: doc: hotplug.txt code typos kbuild: fix comment in Makefile.modinst SH: add proper prompt to SH_MAGIC_PANEL_R2_VERSION ARM: msm: Remove MSM_SCM crypto: Remove MPILIB_EXTRA doc: CN: remove dead link, kerneltrap.org no longer works media: update reference, kerneltrap.org no longer works hexagon: update reference, kerneltrap.org no longer works doc: LSM: update reference, kerneltrap.org no longer works ...
2014-08-06hexagon: Use sigsp()Richard Weinberger
Use sigsp() instead of the open coded variant. Signed-off-by: Richard Weinberger <richard@nod.at>
2014-08-06hexagon: Use get_signal() signal_setup_done()Richard Weinberger
Use the more generic functions get_signal() signal_setup_done() for signal delivery. Acked-by: Richard Kuo <rkuo@codeaurora.org> Signed-off-by: Richard Weinberger <richard@nod.at>
2014-08-05Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer and time updates from Thomas Gleixner: "A rather large update of timers, timekeeping & co - Core timekeeping code is year-2038 safe now for 32bit machines. Now we just need to fix all in kernel users and the gazillion of user space interfaces which rely on timespec/timeval :) - Better cache layout for the timekeeping internal data structures. - Proper nanosecond based interfaces for in kernel users. - Tree wide cleanup of code which wants nanoseconds but does hoops and loops to convert back and forth from timespecs. Some of it definitely belongs into the ugly code museum. - Consolidation of the timekeeping interface zoo. - A fast NMI safe accessor to clock monotonic for tracing. This is a long standing request to support correlated user/kernel space traces. With proper NTP frequency correction it's also suitable for correlation of traces accross separate machines. - Checkpoint/restart support for timerfd. - A few NOHZ[_FULL] improvements in the [hr]timer code. - Code move from kernel to kernel/time of all time* related code. - New clocksource/event drivers from the ARM universe. I'm really impressed that despite an architected timer in the newer chips SoC manufacturers insist on inventing new and differently broken SoC specific timers. [ Ed. "Impressed"? I don't think that word means what you think it means ] - Another round of code move from arch to drivers. Looks like most of the legacy mess in ARM regarding timers is sorted out except for a few obnoxious strongholds. - The usual updates and fixlets all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (114 commits) timekeeping: Fixup typo in update_vsyscall_old definition clocksource: document some basic timekeeping concepts timekeeping: Use cached ntp_tick_length when accumulating error timekeeping: Rework frequency adjustments to work better w/ nohz timekeeping: Minor fixup for timespec64->timespec assignment ftrace: Provide trace clocks monotonic timekeeping: Provide fast and NMI safe access to CLOCK_MONOTONIC seqcount: Add raw_write_seqcount_latch() seqcount: Provide raw_read_seqcount() timekeeping: Use tk_read_base as argument for timekeeping_get_ns() timekeeping: Create struct tk_read_base and use it in struct timekeeper timekeeping: Restructure the timekeeper some more clocksource: Get rid of cycle_last clocksource: Move cycle_last validation to core code clocksource: Make delta calculation a function wireless: ath9k: Get rid of timespec conversions drm: vmwgfx: Use nsec based interfaces drm: i915: Use nsec based interfaces timekeeping: Provide ktime_get_raw() hangcheck-timer: Use ktime_get_ns() ...
2014-07-23ktime: Kill non-scalar ktime_t implementation for 2038John Stultz
The non-scalar ktime_t implementation is basically a timespec which has to be changed to support dates past 2038 on 32bit systems. This patch removes the non-scalar ktime_t implementation, forcing the scalar s64 nanosecond version on all architectures. This may have additional performance overhead on some 32bit systems when converting between ktime_t and timespec structures, however the majority of 32bit systems (arm and i386) were already using scalar ktime_t, so no performance regressions will be seen on those platforms. On affected platforms, I'm open to finding optimizations, including avoiding converting to timespecs where possible. [ tglx: We can now cleanup the ktime_t.tv64 mess, but thats a different issue and we can throw a coccinelle script at it ] Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2014-07-17arch, locking: Ciao arch_mutex_cpu_relax()Davidlohr Bueso
The arch_mutex_cpu_relax() function, introduced by 34b133f, is hacky and ugly. It was added a few years ago to address the fact that common cpu_relax() calls include yielding on s390, and thus impact the optimistic spinning functionality of mutexes. Nowadays we use this function well beyond mutexes: rwsem, qrwlock, mcs and lockref. Since the macro that defines the call is in the mutex header, any users must include mutex.h and the naming is misleading as well. This patch (i) renames the call to cpu_relax_lowlatency ("relax, but only if you can do it with very low latency") and (ii) defines it in each arch's asm/processor.h local header, just like for regular cpu_relax functions. On all archs, except s390, cpu_relax_lowlatency is simply cpu_relax, and thus we can take it out of mutex.h. While this can seem redundant, I believe it is a good choice as it allows us to move out arch specific logic from generic locking primitives and enables future(?) archs to transparently define it, similarly to System Z. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Anton Blanchard <anton@samba.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Bharat Bhushan <r65777@freescale.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Howells <dhowells@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Deepthi Dharwar <deepthi@linux.vnet.ibm.com> Cc: Dominik Dingel <dingel@linux.vnet.ibm.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jason Wang <jasowang@redhat.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Joe Perches <joe@perches.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Joseph Myers <joseph@codesourcery.com> Cc: Kees Cook <keescook@chromium.org> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michael Neuling <mikey@neuling.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Mikael Starvik <starvik@axis.com> Cc: Nicolas Pitre <nico@linaro.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Qais Yousef <qais.yousef@imgtec.com> Cc: Qiaowei Ren <qiaowei.ren@intel.com> Cc: Rafael Wysocki <rafael.j.wysocki@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Steven Miao <realmz6@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: Stratos Karafotis <stratosk@semaphore.gr> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Vasily Kulikov <segoon@openwall.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: Waiman Long <Waiman.Long@hp.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Wolfram Sang <wsa@the-dreams.de> Cc: adi-buildroot-devel@lists.sourceforge.net Cc: linux390@de.ibm.com Cc: linux-alpha@vger.kernel.org Cc: linux-am33-list@redhat.com Cc: linux-arm-kernel@lists.infradead.org Cc: linux-c6x-dev@linux-c6x.org Cc: linux-cris-kernel@axis.com Cc: linux-hexagon@vger.kernel.org Cc: linux-ia64@vger.kernel.org Cc: linux@lists.openrisc.net Cc: linux-m32r-ja@ml.linux-m32r.org Cc: linux-m32r@ml.linux-m32r.org Cc: linux-m68k@lists.linux-m68k.org Cc: linux-metag@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-parisc@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-s390@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-xtensa@linux-xtensa.org Cc: sparclinux@vger.kernel.org Link: http://lkml.kernel.org/r/1404079773.2619.4.camel@buesod1.americas.hpqcorp.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-19hexagon: update reference, kerneltrap.org no longer worksPranith Kumar
kerneltrap.org no longer works, update to a working reference Signed-off-by: Pranith Kumar <bobby.prani@gmail.com> Acked-by: Richard Kuo <rkuo@codeaurora.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-04-18arch,hexagon: Convert smp_mb__*()Peter Zijlstra
Hexagon uses asm-gemeric/barrier.h and its smp_mb() is barrier(). Therefore we can use the default implementation that uses smp_mb(). Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/n/tip-87irqrrbgizeojjfdqhypud3@git.kernel.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: linux-hexagon@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-18arc,hexagon: Delete asm/barrier.hPeter Zijlstra
Both already use asm-generic/barrier.h as per their include/asm/Kbuild. Remove the stale files. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/n/tip-c7vlkshl3tblim0o8z2p70kt@git.kernel.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: linux-hexagon@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-07Kconfig: rename HAS_IOPORT to HAS_IOPORT_MAPUwe Kleine-König
If the renamed symbol is defined lib/iomap.c implements ioport_map and ioport_unmap and currently (nearly) all platforms define the port accessor functions outb/inb and friend unconditionally. So HAS_IOPORT_MAP is the better name for this. Consequently NO_IOPORT is renamed to NO_IOPORT_MAP. The motivation for this change is to reintroduce a symbol HAS_IOPORT that signals if outb/int et al are available. I will address that at least one merge window later though to keep surprises to a minimum and catch new introductions of (HAS|NO)_IOPORT. The changes in this commit were done using: $ git grep -l -E '(NO|HAS)_IOPORT' | xargs perl -p -i -e 's/\b((?:CONFIG_)?(?:NO|HAS)_IOPORT)\b/$1_MAP/' Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel Pull Hexagon updates from Richard Kuo: "Mostly cleanups for compilation with allmodconfig and some other miscellaneous fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel: Hexagon: update CR year for elf.h Hexagon: remove SP macro Hexagon: set ELF_EXEC_PAGESIZE to PAGE_SIZE Hexagon: set the e_flags in user regset view for core dumps Hexagon: fix atomic_set Hexagon: add screen_info for VGA_CONSOLE hexagon: correct type on pgd copy smp, hexagon: kill SMP single function call interrupt arch: hexagon: include: asm: add generic macro 'mmiowb' in "io.h" arch: hexagon: kernel: hexagon_ksyms.c: export related symbols which various modules need arch: hexagon: kernel: reset.c: use function pointer instead of function for pm_power_off and export it arch: hexagon: include: asm: add "vga.h" in Kbuild arch: hexagon: include: asm: Kbuild: add generic "serial.h" in Kbuild arch: hexagon: include: uapi: asm: setup.h add swith macro __KERNEL__ arch: hexagon: include: asm: add prefix "hvm[ci]_" for all enum members in "hexagon_vm.h" arch: hexagon: Kconfig: add HAVE_DMA_ATTR in Kconfig and remove "linux/dma-mapping.h" from "asm/dma-mapping.h" arch: hexagon: kernel: add export symbol function __delay() hexagon: include: asm: kgdb: extend DBG_MAX_REG_NUM for "cs0/1" hexagon: kernel: kgdb: include related header for pass compiling. hexagon: kernel: remove useless variables 'dn', 'r' and 'err' in time_init_deferred() in "time.c"
2014-04-04Hexagon: update CR year for elf.hRichard Kuo
2014-04-04Hexagon: remove SP macroRichard Kuo
The SP/r29 macro wasn't used anywhere else and was causing conflicts with another module, so just remove it. Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2014-04-04Hexagon: set ELF_EXEC_PAGESIZE to PAGE_SIZERichard Kuo
2014-04-04Hexagon: set the e_flags in user regset view for core dumpsRichard Kuo
2014-04-04Hexagon: fix atomic_setRichard Kuo
Normal writes in our our architecture don't invalidate lock reservations. Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2014-04-04Hexagon: add screen_info for VGA_CONSOLERichard Kuo
2014-04-04hexagon: correct type on pgd copyIlia Mirkin
swapper_pg_dir is an array of pgd_t, not pgd_t*. This has no actual effect since sizeof(pgd_t) == sizeof(pgd_t*), but unconfuses tools that check types. Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu> Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2014-04-04smp, hexagon: kill SMP single function call interruptJiang Liu
Commit 9a46ad6d6df3b54 "smp: make smp_call_function_many() use logic similar to smp_call_function_single()" has unified the way to handle single and multiple cross-CPU function calls. Now only one intterupt is needed for architecture specific code to support generic SMP function call interfaces, so kill the redundant single function call interrupt. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Shaohua Li <shli@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jiri Kosina <trivial@kernel.org> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: linux-hexagon@vger.kernel.org Signed-off-by: Jiang Liu <liuj97@gmail.com> Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2014-04-04arch: hexagon: include: asm: add generic macro 'mmiowb' in "io.h"Chen Gang
Need dumy mmiowb(), or can not pass compiling, the related error with allmodconfig: CC [M] drivers/mmc/host/sdhci.o drivers/mmc/host/sdhci.c: In function 'sdhci_request': drivers/mmc/host/sdhci.c:1409:2: error: implicit declaration of function 'mmiowb' [-Werror=implicit-function-declaration] Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2014-04-04arch: hexagon: kernel: hexagon_ksyms.c: export related symbols which various ↵Chen Gang
modules need Need export all related functions and symbols for various modules with allmodconfig. The related errors: MODPOST 2879 modules ERROR: "__vmyield" [sound/sound_firmware.ko] undefined! ERROR: "__phys_offset" [sound/drivers/snd-dummy.ko] undefined! ERROR: "ioremap_nocache" [drivers/char/ipmi/ipmi_si.ko] undefined! ERROR: "__iounmap" [drivers/char/ipmi/ipmi_si.ko] undefined! ... For including files, need "linux/*" first, then "asm/*". All related included files and symbols need be sorted by alphabetical order. Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2014-04-04arch: hexagon: kernel: reset.c: use function pointer instead of function for ↵Chen Gang
pm_power_off and export it 'pm_power_off' is a function pointer, not a function, so need change its type, and also need export it, or can not pass compiling with allmodconfig. The related error: MODPOST 2879 modules ERROR: "pm_power_off" [drivers/char/ipmi/ipmi_poweroff.ko] undefined! Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2014-04-04arch: hexagon: include: asm: add "vga.h" in KbuildChen Gang
Need include generic "vga.h", or can not pass compiling with allmodconfig, the related error: CC [M] drivers/gpu/drm/drm_irq.o In file included from include/linux/vgaarb.h:34:0, from drivers/gpu/drm/drm_irq.c:42: include/video/vga.h:22:21: fatal error: asm/vga.h: No such file or directory Also move "preempt.h" upper to match sort order. Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2014-04-04arch: hexagon: include: asm: Kbuild: add generic "serial.h" in KbuildChen Gang
Add "serial.h" in Kbuild, or can not pass compiling with allmodconfig, the related error: CC [M] drivers/staging/speakup/speakup_acntpc.o In file included from drivers/staging/speakup/speakup_acntpc.c:33:0: drivers/staging/speakup/serialio.h:7:24: fatal error: asm/serial.h: No such file or directory Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2014-04-04arch: hexagon: include: uapi: asm: setup.h add swith macro __KERNEL__Chen Gang
Define dummy '__init' instead of include "linux/init.h" if !__KERNEL__, or can not pass checking. The related error (with allmodconfig under hexagon): CHECK include/asm (34 files) usr/include/asm/setup.h:22: included file 'linux/init.h' is not exported Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
2014-04-04arch: hexagon: include: asm: add prefix "hvm[ci]_" for all enum members in ↵Chen Gang
"hexagon_vm.h" Append "hvmc_" or "hvmi_" to all related enum members (which are too common to make conflict with another sub-systems). The related error with allmodconfig: CC [M] drivers/md/raid1.o drivers/md/raid1.c:1440:13: error: 'status' redeclared as different kind of symbol arch/hexagon/include/asm/hexagon_vm.h:76:2: note: previous definition of 'status' was here Also use 'affinity' instead of 'locdis' for __vmintop_affinity(). Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
