git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull big execve/kernel_thread/fork unification series from Al Viro:
"All architectures are converted to new model. Quite a bit of that
stuff is actually shared with architecture trees; in such cases it's
literally shared branch pulled by both, not a cherry-pick.
A lot of ugliness and black magic is gone (-3KLoC total in this one):
- kernel_thread()/kernel_execve()/sys_execve() redesign.
We don't do syscalls from kernel anymore for either kernel_thread()
or kernel_execve():
kernel_thread() is essentially clone(2) with callback run before we
return to userland, the callbacks either never return or do
successful do_execve() before returning.
kernel_execve() is a wrapper for do_execve() - it doesn't need to
do transition to user mode anymore.
As a result kernel_thread() and kernel_execve() are
arch-independent now - they live in kernel/fork.c and fs/exec.c
resp. sys_execve() is also in fs/exec.c and it's completely
architecture-independent.
- daemonize() is gone, along with its parts in fs/*.c
- struct pt_regs * is no longer passed to do_fork/copy_process/
copy_thread/do_execve/search_binary_handler/->load_binary/do_coredump.
- sys_fork()/sys_vfork()/sys_clone() unified; some architectures
still need wrappers (ones with callee-saved registers not saved in
pt_regs on syscall entry), but the main part of those suckers is in
kernel/fork.c now."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (113 commits)
do_coredump(): get rid of pt_regs argument
print_fatal_signal(): get rid of pt_regs argument
ptrace_signal(): get rid of unused arguments
get rid of ptrace_signal_deliver() arguments
new helper: signal_pt_regs()
unify default ptrace_signal_deliver
flagday: kill pt_regs argument of do_fork()
death to idle_regs()
don't pass regs to copy_process()
flagday: don't pass regs to copy_thread()
bfin: switch to generic vfork, get rid of pointless wrappers
xtensa: switch to generic clone()
openrisc: switch to use of generic fork and clone
unicore32: switch to generic clone(2)
score: switch to generic fork/vfork/clone
c6x: sanitize copy_thread(), get rid of clone(2) wrapper, switch to generic clone()
take sys_fork/sys_vfork/sys_clone prototypes to linux/syscalls.h
mn10300: switch to generic fork/vfork/clone
h8300: switch to generic fork/vfork/clone
tile: switch to generic clone()
arch/microblaze/include/asm/Kbuild
now it can be done...
In order to promote interoperability between userspace tracers and ftrace,
add a trace_clock that reports raw TSC values which will then be recorded
in the ring buffer. Userspace tracers that also record TSCs are then on
exactly the same time base as the kernel and events can be unambiguously
interlaced.
Tested: Enabled a tracepoint and the "tsc" trace_clock and saw very large
timestamp values.
v2:
Move arch-specific bits out of generic code.
v3:
Rename "x86-tsc", cleanups
v7:
Generic arch bits in Kbuild.
Google-Bug-Id: 6980623
Link: http://lkml.kernel.org/r/1352837903-32191-1-git-send-email-dhsharp@google.com
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: "H. Peter Anvin" <hpa@linux.intel.com>
Signed-off-by: David Sharp <dhsharp@google.com>
introduce sane current_pt_regs(), use it in syscalls where needed.
Code Aurora Forum (CAF) is becoming a part of Linux Foundation Labs.
Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
Pull pile 2 of execve and kernel_thread unification work from Al Viro:
"Stuff in there: kernel_thread/kernel_execve/sys_execve conversions for
several more architectures plus assorted signal fixes and cleanups.
There'll be more (in particular, real fixes for the alpha
do_notify_resume() irq mess)..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (43 commits)
alpha: don't open-code trace_report_syscall_{enter,exit}
Uninclude linux/freezer.h
m32r: trim masks
avr32: trim masks
tile: don't bother with SIGTRAP in setup_frame
microblaze: don't bother with SIGTRAP in setup_rt_frame()
mn10300: don't bother with SIGTRAP in setup_frame()
frv: no need to raise SIGTRAP in setup_frame()
x86: get rid of duplicate code in case of CONFIG_VM86
unicore32: remove pointless test
h8300: trim _TIF_WORK_MASK
parisc: decide whether to go to slow path (tracesys) based on thread flags
parisc: don't bother looping in do_signal()
parisc: fix double restarts
bury the rest of TIF_IRET
sanitize tsk_is_polling()
bury _TIF_RESTORE_SIGMASK
unicore32: unobfuscate _TIF_WORK_MASK
mips: NOTIFY_RESUME is not needed in TIF masks
mips: merge the identical "return from syscall" per-ABI code
arch/arm/include/asm/thread_info.h
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull asm-generic updates from Arnd Bergmann:
"This has three changes for asm-generic that did not really fit into
any other branch as normal asm-generic changes do. One is a fix for a
build warning, the other two are more interesting:
* A patch from Mark Brown to allow using the common clock
infrastructure on all architectures, so we can use the clock API in
architecture independent device drivers.
* The UAPI split patches from David Howells for the asm-generic
files. There are other architecture specific series that are going
through the arch maintainer tree and that depend on this one.
There may be a few small merge conflicts between Mark's patch and the
following arch header file split patches. In each case the solution
will be to keep the new "generic-y += clkdev.h" line, even if it ends
up being the only line in the Kbuild file."
* tag 'asm-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
UAPI: (Scripted) Disintegrate include/asm-generic
asm-generic: Add default clkdev.h
asm-generic: xor: mark static functions as __maybe_unused
Pull UAPI disintegration fixes from David Howells:
"There are three main parts:
(1) I found I needed some more fixups in the wake of testing Arm64
(some asm/unistd.h files had weird guards that caused problems -
mostly in arches for which I don't have a compiler) and some
__KERNEL__ splitting needed to take place in Arm64.
(2) I found that c6x was missing some __KERNEL__ guards in its
asm/signal.h. Mark Salter pointed me at a tree with a patch to
remove that file entirely and use the asm-generic variant instead.
(3) Lastly, m68k turned out to have a header installation problem due
to it lacking a kvm_para.h file.
The conditional installation bits for linux/kvm_para.h, linux/kvm.h
and linux/a.out.h weren't very well specified - and didn't work if
an arch didn't have the asm/ version of that file, but there *was*
an asm-generic/ version.
It seems the "ifneq $((wildcard ...),)" for each of those three
headers in include/kernel/Kbuild is invoked twice during header
installation, and the second time it matches on the just installed
asm-generic/kvm_para.h file and thus incorrectly installs
linux/kvm_para.h as well.
Most arches actually have an asm/kvm_para.h, so this wasn't
detectable in those."
* 'uapi-prep' of git://git.infradead.org/users/dhowells/linux-headers:
UAPI: Fix conditional header installation handling (notably kvm_para.h on m68k)
c6x: remove c6x signal.h
UAPI: Split compound conditionals containing __KERNEL__ in Arm64
UAPI: Fix the guards on various asm/unistd.h files
c6x: make dsk6455 the default config
Historically, the top three bytes of personality have been used for
things such as ADDR_NO_RANDOMIZE, which made sense only for specific
architectures.
We now however have a flag there that is general no matter the
architecture (UNAME26); generally we have to be careful to preserve the
personality flags across exec().
This patch tries to fix all architectures that forcefully overwrite
personality flags during exec() (ppc32 and s390 have been fixed recently
by commits f9783ec862ea ("[S390] Do not clobber personality flags on
exec") and 59e4c3a2fe9c ("powerpc/32: Don't clobber personality flags on
exec") in a similar way already).
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Mark Salter <msalter@redhat.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Zankel <chris@zankel.net>
git://git.infradead.org/users/dhowells/linux-headers into asm-generic
Patches from David Howells <dhowells@redhat.com>:
This is to complete part of the UAPI disintegration for which the
preparatory patches were pulled recently.
Note that there are some fixup patches which are at the base of the
branch aimed at you, plus all arches get the asm-generic branch merged in too.
* 'disintegrate-asm-generic' of git://git.infradead.org/users/dhowells/linux-headers:
asm-generic/unistd.h and a number of asm/unistd.h files have been given
reinclusion guards that allow the guard to be overridden if __SYSCALL is
defined. Unfortunately, these files define __SYSCALL and don't undefine it
when they've finished with it, thus rendering the guard ineffective.
The reason for this override is to allow the file to be #included multiple
times with different settings on __SYSCALL for purposes like generating syscall
tables.
The following guards are problematic:
arch/arm64/include/asm/unistd.h:#if !defined(__ASM_UNISTD_H) || defined(__SYSCALL)
arch/arm64/include/asm/unistd32.h:#if !defined(__ASM_UNISTD32_H) || defined(__SYSCALL)
arch/c6x/include/asm/unistd.h:#if !defined(_ASM_C6X_UNISTD_H) || defined(__SYSCALL)
arch/hexagon/include/asm/unistd.h:#if !defined(_ASM_HEXAGON_UNISTD_H) || defined(__SYSCALL)
arch/openrisc/include/asm/unistd.h:#if !defined(__ASM_OPENRISC_UNISTD_H) || defined(__SYSCALL)
arch/score/include/asm/unistd.h:#if !defined(_ASM_SCORE_UNISTD_H) || defined(__SYSCALL)
arch/tile/include/asm/unistd.h:#if !defined(_ASM_TILE_UNISTD_H) || defined(__SYSCALL)
arch/unicore32/include/asm/unistd.h:#if !defined(__UNICORE_UNISTD_H__) || defined(__SYSCALL)
include/asm-generic/unistd.h:#if !defined(_ASM_GENERIC_UNISTD_H) || defined(__SYSCALL)
On the assumption that the guards' ineffectiveness has passed unnoticed, just
remove these guards entirely.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Ease the deployment of clkdev by providing a default asm/clkdev.h for
use if the arch does not have an include/asm/clkdev.h.
Due to limitations in Kbuild we manually add clkdev.h to all
architectures that don't have one rather than having the header appear
by default.
Reviewed-by: Stephen Rothwell <sfr@canb.auug.org.au>
Some architectures had blindly copied it for no reason whatsoever.
Make default just return 0. The current default (checking
TIF_POLLING_NRFLAG) is taken to architectures that need it;
ones that don't do polling in their idle threads don't need
to defined TIF_POLLING_NRFLAG at all.
ia64 defined both TS_POLLING (used by its tsk_is_polling())
and TIF_POLLING_NRFLAG (not used at all). Killed the latter...
never used...
mn10300 has a header (in its include/asm directory) that is a thin
wrapper around asm-generic/ipc.h. This wrapper is useless, since that
header doesn't exist. It is also unused (no file includes asm/ipc.h).
hexagon and tile generate similar headers at build time (using a
generic-y entry in include/asm/Kbuild). These generated headers are
useless and unused too.
Remove this header and these generic-y entries.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Acked-by: Richard Kuo <rkuo@codeaurora.org>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: David Howells <dhowells@redhat.com> [MN10300]
frv and xtensa both have a header (in their include/asm directories)
that are thin wrappers around asm-generic/cpumask.h. These wrappers are
useless, since that header doesn't exist. They are also unused (all
files including asm/cpumask.h are x86 specific).
hexagon and openrisc generate similar headers at build time (using a
Remove these headers and generic-y entries.
Acked-by: David Howells <dhowells@redhat.com> [FRV]
Pull KVM changes from Avi Kivity:
"Changes include additional instruction emulation, page-crossing MMIO,
faster dirty logging, preventing the watchdog from killing a stopped
guest, module autoload, a new MSI ABI, and some minor optimizations
and fixes. Outside x86 we have a small s390 and a very large ppc
update.
Regarding the new (for kvm) rebaseless workflow, some of the patches
that were merged before we switch trees had to be rebased, while
others are true pulls. In either case the signoffs should be correct
now."
Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
arch/powerpc/kvm/book3s_segment.S and arch/x86/include/asm/kvm_para.h.
I suspect the kvm_para.h resolution ends up doing the "do I have cpuid"
check effectively twice (it was done differently in two different
commits), but better safe than sorry ;)
* 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (125 commits)
KVM: make asm-generic/kvm_para.h have an ifdef __KERNEL__ block
KVM: s390: onereg for timer related registers
KVM: s390: epoch difference and TOD programmable field
KVM: s390: KVM_GET/SET_ONEREG for s390
KVM: s390: add capability indicating COW support
KVM: Fix mmu_reload() clash with nested vmx event injection
KVM: MMU: Don't use RCU for lockless shadow walking
KVM: VMX: Optimize %ds, %es reload
KVM: VMX: Fix %ds/%es clobber
KVM: x86 emulator: convert bsf/bsr instructions to emulate_2op_SrcV_nobyte()
KVM: VMX: unlike vmcs on fail path
KVM: PPC: Emulator: clean up SPR reads and writes
KVM: PPC: Emulator: clean up instruction parsing
kvm/powerpc: Add new ioctl to retreive server MMU infos
kvm/book3s: Make kernel emulated H_PUT_TCE available for "PR" KVM
KVM: PPC: bookehv: Fix r8/r13 storing in level exception handler
KVM: PPC: Book3S: Enable IRQs during exit handling
KVM: PPC: Fix PR KVM on POWER7 bare metal
KVM: PPC: Fix stbux emulation
KVM: PPC: bookehv: Use lwz/stw instead of PPC_LL/PPC_STL for 32-bit fields
Pull fpu state cleanups from Ingo Molnar:
"This tree streamlines further aspects of FPU handling by eliminating
the prepare_to_copy() complication and moving that logic to
arch_dup_task_struct().
It also fixes the FPU dumps in threaded core dumps, removes and old
(and now invalid) assumption plus micro-optimizes the exit path by
avoiding an FPU save for dead tasks."
Fixed up trivial add-add conflict in arch/sh/kernel/process.c that came
in because we now do the FPU handling in arch_dup_task_struct() rather
than the legacy (and now gone) prepare_to_copy().
* 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, fpu: drop the fpu state during thread exit
x86, xsave: remove thread_has_fpu() bug check in __sanitize_i387_state()
coredump: ensure the fpu state is flushed for proper multi-threaded core dump
fork: move the real prepare_to_copy() users to arch_dup_task_struct()
arch/hexagon/include/asm/spinlock_types.h
"make versioncheck" points out that arch/hexagon/include/asm/spinlock_types.h
does not need to include version.h .
A quick look at the file seems to confirm its findings, so here's a patch that
removes the include.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Historical prepare_to_copy() is mostly a no-op, duplicated for majority of
the architectures and the rest following the x86 model of flushing the extended
register state like fpu there.
Remove it and use the arch_dup_task_struct() instead.
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Link: http://lkml.kernel.org/r/1336692811-30576-1-git-send-email-suresh.b.siddha@intel.com
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
The core now has a threadinfo allocator which uses a kmemcache when
THREAD_SIZE < PAGE_SIZE.
Link: http://lkml.kernel.org/r/20120505150141.812612113@linutronix.de
When a host stops or suspends a VM it will set a flag to show this. The
watchdog will use these functions to determine if a softlockup is real, or the
result of a suspended VM.
Signed-off-by: Eric B Munson <emunson@mgebm.net>
asm-generic changes Acked-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
git://git.linaro.org/people/mszyprowski/linux-dma-mapping
Pull DMA mapping branch from Marek Szyprowski:
"Short summary for the whole series:
A few limitations have been identified in the current dma-mapping
design and its implementations for various architectures. There exist
more than one function for allocating and freeing the buffers:
currently these 3 are used dma_{alloc, free}_coherent,
dma_{alloc,free}_writecombine, dma_{alloc,free}_noncoherent.
For most of the systems these calls are almost equivalent and can be
interchanged. For others, especially the truly non-coherent ones
(like ARM), the difference can be easily noticed in overall driver
performance. Sadly not all architectures provide implementations for
all of them, so the drivers might need to be adapted and cannot be
easily shared between different architectures. The provided patches
unify all these functions and hide the differences under the already
existing dma attributes concept. The thread with more references is
available here:
http://www.spinics.net/lists/linux-sh/msg09777.html
These patches are also a prerequisite for unifying DMA-mapping
implementation on ARM architecture with the common one provided by
dma_map_ops structure and extending it with IOMMU support. More
information is available in the following thread:
http://thread.gmane.org/gmane.linux.kernel.cross-arch/12819
More works on dma-mapping framework are planned, especially in the
area of buffer sharing and managing the shared mappings (together with
the recently introduced dma_buf interface: commit d15bd7ee445d
"dma-buf: Introduce dma buffer sharing mechanism").
The patches in the current set introduce a new alloc/free methods
(with support for memory attributes) in dma_map_ops structure, which
will later replace dma_alloc_coherent and dma_alloc_writecombine
functions."
People finally started piping up with support for merging this, so I'm
merging it as the last of the pending stuff from the merge window.
Looks like pohmelfs is going to wait for 3.5 and more external support
for merging.
* 'for-linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping:
common: DMA-mapping: add NON-CONSISTENT attribute
common: DMA-mapping: add WRITE_COMBINE attribute
common: dma-mapping: introduce mmap method
common: dma-mapping: remove old alloc_coherent and free_coherent methods
Hexagon: adapt for dma_map_ops changes
Unicore32: adapt for dma_map_ops changes
Microblaze: adapt for dma_map_ops changes
SH: adapt for dma_map_ops changes
Alpha: adapt for dma_map_ops changes
SPARC: adapt for dma_map_ops changes
PowerPC: adapt for dma_map_ops changes
MIPS: adapt for dma_map_ops changes
X86 & IA64: adapt for dma_map_ops changes
common: dma-mapping: introduce generic alloc() and free() methods
Delete all instances of asm/system.h as they should be redundant by this
point.
Disintegrate asm/system.h for Hexagon. Not compiled.
cc: linux-hexagon@vger.kernel.org
Adapt core Hexagon architecture code for dma_map_ops changes: replace
alloc/free_coherent with generic alloc/free methods.
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Put the logic to compute the event index into a per pmu method. This
is required because the x86 rules are weird and wonderful and don't
match the capabilities of the current scheme.
AFAIK only powerpc actually has a usable userspace read of the PMCs
but I'm not at all sure anybody actually used that.
ARM is restored to the default since it currently does not support
userspace access at all. And all software events are provided with a
method that reports their index as 0 (disabled).
Cc: Michael Cree <mcree@orcon.net.nz>
Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Stephane Eranian <eranian@google.com>
Cc: Arun Sharma <asharma@fb.com>
Link: http://lkml.kernel.org/n/tip-dfydxodki16lylkt3gl2j7cw@git.kernel.org
Signed-off-by: Linas Vepstas <linas@codeaurora.org>
Mostly all stubs, as the TLB is managed by the hypervisor.
