path: root/arch/h8300
2009-02-15net: new user space API for time stamping of incoming and outgoing packetsPatrick Ohly
User space can request hardware and/or software time stamping. Reporting of the result(s) via a new control message is enabled separately for each field in the message because some of the fields may require additional computation and thus cause overhead. User space can tell the different kinds of time stamps apart and choose what suits its needs. When a TX timestamp operation is requested, the TX skb will be cloned and the clone will be time stamped (in hardware or software) and added to the socket error queue of the skb, if the skb has a socket associated with it. The actual TX timestamp will reach userspace as a RX timestamp on the cloned packet. If timestamping is requested and no timestamping is done in the device driver (potentially this may use hardware timestamping), it will be done in software after the device's start_hard_xmit routine. Signed-off-by: Patrick Ohly <patrick.ohly@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-14Merge branch 'syscalls' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'syscalls' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (44 commits) [CVE-2009-0029] s390 specific system call wrappers [CVE-2009-0029] System call wrappers part 33 [CVE-2009-0029] System call wrappers part 32 [CVE-2009-0029] System call wrappers part 31 [CVE-2009-0029] System call wrappers part 30 [CVE-2009-0029] System call wrappers part 29 [CVE-2009-0029] System call wrappers part 28 [CVE-2009-0029] System call wrappers part 27 [CVE-2009-0029] System call wrappers part 26 [CVE-2009-0029] System call wrappers part 25 [CVE-2009-0029] System call wrappers part 24 [CVE-2009-0029] System call wrappers part 23 [CVE-2009-0029] System call wrappers part 22 [CVE-2009-0029] System call wrappers part 21 [CVE-2009-0029] System call wrappers part 20 [CVE-2009-0029] System call wrappers part 19 [CVE-2009-0029] System call wrappers part 18 [CVE-2009-0029] System call wrappers part 17 [CVE-2009-0029] System call wrappers part 16 [CVE-2009-0029] System call wrappers part 15 ...
2009-01-14byteorder: make swab.h include asm/swab.h like a regular headerHarvey Harrison
Add swab.h to kbuild.asm and remove the individual entries from each arch, mark as unifdef as some arches have some kernel-only bits inside. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] Rename old_readdir to sys_old_readdirHeiko Carstens
This way it matches the generic system call name convention. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-08NOMMU: Make VMAs per MM as for MMU-mode linuxDavid Howells
Make VMAs per mm_struct as for MMU-mode linux. This solves two problems: (1) In SYSV SHM where nattch for a segment does not reflect the number of shmat's (and forks) done. (2) In mmap() where the VMA's vm_mm is set to point to the parent mm by an exec'ing process when VM_EXECUTABLE is specified, regardless of the fact that a VMA might be shared and already have its vm_mm assigned to another process or a dead process. A new struct (vm_region) is introduced to track a mapped region and to remember the circumstances under which it may be shared and the vm_list_struct structure is discarded as it's no longer required. This patch makes the following additional changes: (1) Regions are now allocated with alloc_pages() rather than kmalloc() and with no recourse to __GFP_COMP, so the pages are not composite. Instead, each page has a reference on it held by the region. Anything else that is interested in such a page will have to get a reference on it to retain it. When the pages are released due to unmapping, each page is passed to put_page() and will be freed when the page usage count reaches zero. (2) Excess pages are trimmed after an allocation as the allocation must be made as a power-of-2 quantity of pages. (3) VMAs are added to the parent MM's R/B tree and mmap lists. As an MM may end up with overlapping VMAs within the tree, the VMA struct address is appended to the sort key. (4) Non-anonymous VMAs are now added to the backing inode's prio list. (5) Holes may be punched in anonymous VMAs with munmap(), releasing parts of the backing region. The VMA and region structs will be split if necessary. (6) sys_shmdt() only releases one attachment to a SYSV IPC shared memory segment instead of all the attachments at that addresss. Multiple shmat()'s return the same address under NOMMU-mode instead of different virtual addresses as under MMU-mode. (7) Core dumping for ELF-FDPIC requires fewer exceptions for NOMMU-mode. (8) /proc/maps is now the global list of mapped regions, and may list bits that aren't actually mapped anywhere. (9) /proc/meminfo gains a line (tagged "MmapCopy") that indicates the amount of RAM currently allocated by mmap to hold mappable regions that can't be mapped directly. These are copies of the backing device or file if not anonymous. These changes make NOMMU mode more similar to MMU mode. The downside is that NOMMU mode requires some extra memory to track things over NOMMU without this patch (VMAs are no longer shared, and there are now region structs). Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org>
2009-01-06h8300: introduce asm/swab.hHarvey Harrison
2009-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (237 commits) Staging: android: binder: fix build errors Staging: android: add lowmemorykiller driver Staging: android: remove dummy android.c driver Staging: android: timed_gpio: Rename android_timed_gpio to timed_gpio Staging: android: add timed_gpio driver Staging: android: add ram_console driver Staging: android: add logging driver staging: android: binder: Fix use of euid Staging: android: binder: Fix gcc warnings about improper format specifiers for size_t in printk Staging: android: add binder driver Staging: add android framework Staging: epl: fix netdev->priv b0rkage Staging: epl: hr timers all run in hard irq context now Staging: epl: run Lindent on *.c files Staging: epl: run Lindent on *.h files Staging: epl: run Lindent on all user/*.h files Staging: epl: run Lindent on all kernel/*.h files Staging: add epl stack Staging: frontier: fix compiler warnings Staging: frontier: remove unused alphatrack_sysfs.c file ...
2009-01-06atomic_t: unify all arch definitionsMatthew Wilcox
The atomic_t type cannot currently be used in some header files because it would create an include loop with asm/atomic.h. Move the type definition to linux/types.h to break the loop. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06Staging: Kconfig for ARCH=arm,8300, crisF. Duncan M. Haldane
The new Kconfig option to build "staging" drivers (code in drivers/staging/) is seen in all except three architectures (arm, h8300, cris), because in these cases arch/$ARCH/Kconfig does NOT source drivers/Kconfig. This patch adds the source "drivers/staging/Kconfig" to arch/$ARCH/Kconfig for these three exceptional cases. Signed-off-by: Duncan Haldane <duncan_h@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-03Merge branch 'cpus4096-for-linus-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (77 commits) x86: setup_per_cpu_areas() cleanup cpumask: fix compile error when CONFIG_NR_CPUS is not defined cpumask: use alloc_cpumask_var_node where appropriate cpumask: convert shared_cpu_map in acpi_processor* structs to cpumask_var_t x86: use cpumask_var_t in acpi/boot.c x86: cleanup some remaining usages of NR_CPUS where s/b nr_cpu_ids sched: put back some stack hog changes that were undone in kernel/sched.c x86: enable cpus display of kernel_max and offlined cpus ia64: cpumask fix for is_affinity_mask_valid() cpumask: convert RCU implementations, fix xtensa: define __fls mn10300: define __fls m32r: define __fls h8300: define __fls frv: define __fls cris: define __fls cpumask: CONFIG_DISABLE_OBSOLETE_CPUMASK_FUNCTIONS cpumask: zero extra bits in alloc_cpumask_var_node cpumask: replace for_each_cpu_mask_nr with for_each_cpu in kernel/time/ cpumask: convert mm/ ...
2009-01-03h8300: define __flsRusty Russell
Like fls, but can't be handed 0 and returns the bit number. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-12-31take init_fs to saner placeAl Viro
2008-10-23Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: (47 commits) uwb: wrong sizeof argument in mac address compare uwb: don't use printk_ratelimit() so often uwb: use kcalloc where appropriate uwb: use time_after() when purging stale beacons uwb: add credits for the original developers of the UWB/WUSB/WLP subsystems uwb: add entries in the MAINTAINERS file uwb: depend on EXPERIMENTAL wusb: wusb-cbaf (CBA driver) sysfs ABI simplification uwb: document UWB and WUSB sysfs files uwb: add symlinks in sysfs between radio controllers and PALs uwb: dont tranmit identification IEs uwb: i1480/GUWA100U: fix firmware download issues uwb: i1480: remove MAC/PHY information checking function uwb: add Intel i1480 HWA to the UWB RC quirk table uwb: disable command/event filtering for D-Link DUB-1210 uwb: initialize the debug sub-system uwb: Fix handling IEs with empty IE data in uwb_est_get_size() wusb: fix bmRequestType for Abort RPipe request wusb: fix error path for wusb_set_dev_addr() wusb: add HWA host controller driver ...
2008-10-20container freezer: implement freezer cgroup subsystemMatt Helsley
This patch implements a new freezer subsystem in the control groups framework. It provides a way to stop and resume execution of all tasks in a cgroup by writing in the cgroup filesystem. The freezer subsystem in the container filesystem defines a file named freezer.state. Writing "FROZEN" to the state file will freeze all tasks in the cgroup. Subsequently writing "RUNNING" will unfreeze the tasks in the cgroup. Reading will return the current state. * Examples of usage : # mkdir /containers/freezer # mount -t cgroup -ofreezer freezer /containers # mkdir /containers/0 # echo $some_pid > /containers/0/tasks to get status of the freezer subsystem : # cat /containers/0/freezer.state RUNNING to freeze all tasks in the container : # echo FROZEN > /containers/0/freezer.state # cat /containers/0/freezer.state FREEZING # cat /containers/0/freezer.state FROZEN to unfreeze all tasks in the container : # echo RUNNING > /containers/0/freezer.state # cat /containers/0/freezer.state RUNNING This is the basic mechanism which should do the right thing for user space task in a simple scenario. It's important to note that freezing can be incomplete. In that case we return EBUSY. This means that some tasks in the cgroup are busy doing something that prevents us from completely freezing the cgroup at this time. After EBUSY, the cgroup will remain partially frozen -- reflected by freezer.state reporting "FREEZING" when read. The state will remain "FREEZING" until one of these things happens: 1) Userspace cancels the freezing operation by writing "RUNNING" to the freezer.state file 2) Userspace retries the freezing operation by writing "FROZEN" to the freezer.state file (writing "FREEZING" is not legal and returns EIO) 3) The tasks that blocked the cgroup from entering the "FROZEN" state disappear from the cgroup's set of tasks. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: export thaw_process] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Tested-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20container freezer: add TIF_FREEZE flag to all architecturesMatt Helsley
This patch series introduces a cgroup subsystem that utilizes the swsusp freezer to freeze a group of tasks. It's immediately useful for batch job management scripts. It should also be useful in the future for implementing container checkpoint/restart. The freezer subsystem in the container filesystem defines a cgroup file named freezer.state. Reading freezer.state will return the current state of the cgroup. Writing "FROZEN" to the state file will freeze all tasks in the cgroup. Subsequently writing "RUNNING" will unfreeze the tasks in the cgroup. * Examples of usage : # mkdir /containers/freezer # mount -t cgroup -ofreezer freezer /containers # mkdir /containers/0 # echo $some_pid > /containers/0/tasks to get status of the freezer subsystem : # cat /containers/0/freezer.state RUNNING to freeze all tasks in the container : # echo FROZEN > /containers/0/freezer.state # cat /containers/0/freezer.state FREEZING # cat /containers/0/freezer.state FROZEN to unfreeze all tasks in the container : # echo RUNNING > /containers/0/freezer.state # cat /containers/0/freezer.state RUNNING This patch: The first step in making the refrigerator() available to all architectures, even for those without power management. The purpose of such a change is to be able to use the refrigerator() in a new control group subsystem which will implement a control group freezer. [akpm@linux-foundation.org: fix sparc] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: Pavel Machek <pavel@suse.cz> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@tuxonice.net> Tested-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Merge branch 'master' into for-upstreamDavid Vrabel
Conflicts: Documentation/ABI/testing/sysfs-bus-usb drivers/Makefile
2008-10-16Merge branch 'personality' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'personality' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [PATCH] remove unused ibcs2/PER_SVR4 in SET_PERSONALITY
2008-10-16asm-h8300/md.h: remove CVS keywordAdrian Bunk
Remove a CVS keyword that wasn't updated for a long time from a comment. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16h8300: GENERIC_BUG supportYoshinori Sato
CONFIG_GENERIC_BUG support. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16h8300: update timer handler - misc updateYoshinori Sato
- Update selection - Update common timer handler - Add support functions Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16h8300: update timer handler - new filesYoshinori Sato
New timer handler files. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16h8300: update timer handler - delete filesYoshinori Sato
Delete old timer handler. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16[PATCH] remove unused ibcs2/PER_SVR4 in SET_PERSONALITYMartin Schwidefsky
The SET_PERSONALITY macro is always called with a second argument of 0. Remove the ibcs argument and the various tests to set the PER_SVR4 personality. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-09-17uwb: add the UWB stack (build system)Greg Kroah-Hartman
The Kbuild and Kconfig files. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-09-06Remove asm/a.out.h files for all architectures without a.out support.Adrian Bunk
This patch also includes the required removal of (unused) inclusion of <asm/a.out.h> <linux/a.out.h>'s in the arch/ code for these architectures. [dwmw2: updated for 2.6.27-rc] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-09-06Remove redundant CONFIG_ARCH_SUPPORTS_AOUTDavid Woodhouse
We don't need this any more; arguably we never really did. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-13[h8300] move include/asm-h8300 to arch/h8300/include/asmLinus Torvalds
Done as a script (well, a single "git mv" actually) on request from Yoshinori Sato as a way to avoid a huge diff. Requested-by: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12h8300: fix section mismatchesYoshinori Sato
WARNING: vmlinux.o(.text+0x2fdf): Section mismatch in reference from the variable .LM3 to the variable .init.text:___alloc_bootmem The function .LM3() references the variable __init ___alloc_bootmem. This is often because .LM3 lacks a __init annotation or the annotation of ___alloc_bootmem is wrong. WARNING: vmlinux.o(.text+0x2ff5): Section mismatch in reference from the variable .LM4 to the variable .init.text:___alloc_bootmem The function .LM4() references the variable __init ___alloc_bootmem. This is often because .LM4 lacks a __init annotation or the annotation of ___alloc_bootmem is wrong. WARNING: vmlinux.o(.text+0x300b): Section mismatch in reference from the variable .LM5 to the variable .init.text:___alloc_bootmem The function .LM5() references the variable __init ___alloc_bootmem. This is often because .LM5 lacks a __init annotation or the annotation of ___alloc_bootmem is wrong. WARNING: vmlinux.o(.text+0x304b): Section mismatch in reference from the variable .LM10 to the variable .init.text:_free_area_init The function .LM10() references the variable __init _free_area_init. This is often because .LM10 lacks a __init annotation or the annotation of _free_area_init is wrong. WARNING: vmlinux.o(.text+0x30a3): Section mismatch in reference from the variable .LM17 to the variable .init.text:_free_all_bootmem The function .LM17() references the variable __init _free_all_bootmem. This is often because .LM17 lacks a __init annotation or the annotation of _free_all_bootmem is wrong. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26h8300: use generic show_mem()Johannes Weiner
Remove arch-specific show_mem() in favor of the generic version. This also removes the following redundant information display: - free pages, printed by show_free_areas() - pages in swapcache, printed by show_swap_cache_info() where show_mem() calls show_free_areas(), which calls show_swap_cache_info(). Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25pty: remove unused UNIX98_PTY_COUNT optionsAdrian Bunk
The h8300 and sparc options somehow survived when the code stopped using CONFIG_UNIX98_PTY_COUNT. Reviewed-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25inflate: refactor inflate malloc codeThomas Petazzoni
Inflate requires some dynamic memory allocation very early in the boot process and this is provided with a set of four functions: malloc/free/gzip_mark/gzip_release. The old inflate code used a mark/release strategy rather than implement free. This new version instead keeps a count on the number of outstanding allocations and when it hits zero, it resets the malloc arena. This allows removing all the mark and release implementations and unifying all the malloc/free implementations. The architecture-dependent code must define two addresses: - free_mem_ptr, the address of the beginning of the area in which allocations should be made - free_mem_end_ptr, the address of the end of the area in which allocations should be made. If set to 0, then no check is made on the number of allocations, it just grows as much as needed The architecture-dependent code can also provide an arch_decomp_wdog() function call. This function will be called several times during the decompression process, and allow to notify the watchdog that the system is still running. If an architecture provides such a call, then it must define ARCH_HAS_DECOMP_WDOG so that the generic inflate code calls arch_decomp_wdog(). Work initially done by Matt Mackall, updated to a recent version of the kernel and improved by me. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <mikael.starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24PAGE_ALIGN(): correctly handle 64-bit values on 32-bit architecturesAndrea Righi
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit boundary. For example: u64 val = PAGE_ALIGN(size); always returns a value < 4GB even if size is greater than 4GB. The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for example): #define PAGE_SHIFT 12 #define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT) #define PAGE_MASK (~(PAGE_SIZE-1)) ... #define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK) The "~" is performed on a 32-bit value, so everything in "and" with PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary. Using the ALIGN() macro seems to be the right way, because it uses typeof(addr) for the mask. Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in include/linux/mm.h. See also lkml discussion: http://lkml.org/lkml/2008/6/11/237 [akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c] [akpm@linux-foundation.org: fix v850] [akpm@linux-foundation.org: fix powerpc] [akpm@linux-foundation.org: fix arm] [akpm@linux-foundation.org: fix mips] [akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c] [akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c] [akpm@linux-foundation.org: fix powerpc] Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-16[PATCH] take init_files to fs/file.cAl Viro
2008-05-03unified (weak) sys_pipe implementationUlrich Drepper
This replaces the duplicated arch-specific versions of "sys_pipe()" with one unified implementation. This removes almost 250 lines of duplicated code. It's marked __weak, so that *if* an architecture wants to override the default implementation it can do so by simply having its own replacement version, since many architectures use alternate calling conventions for the 'pipe()' system call for legacy reasons (ie traditional UNIX implementations often return the two file descriptors in registers) I still haven't changed the cris version even though Linus says the BKL isn't needed. The arch maintainer can easily do it if there are really no obstacles. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29h8300: use kbuild.h instead of defining macros in asm-offsets.cChristoph Lameter
Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-02-23h8300: defconfig updateYoshinori Sato
defconfig update. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23h8300: IRQ handling updateYoshinori Sato
- add missing file and declare. - remove unused file and macros. - some cleanup. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23h8300: signal.c typo fixYoshinori Sato
typo fix. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-09ide: introduce HAVE_IDESam Ravnborg
To allow flexible configuration of IDE introduce HAVE_IDE. All archs except arm, um and s390 unconditionally select it. For arm the actual configuration determine if IDE is supported. This is a step towards introducing drivers/Kconfig for arm. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Russell King - ARM Linux <linux@arm.linux.org.uk> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-08avoid overflows in kernel/time.cH. Peter Anvin
When the conversion factor between jiffies and milli- or microseconds is not a single multiply or divide, as for the case of HZ == 300, we currently do a multiply followed by a divide. The intervening result, however, is subject to overflows, especially since the fraction is not simplified (for HZ == 300, we multiply by 300 and divide by 1000). This is exposed to the user when passing a large timeout to poll(), for example. This patch replaces the multiply-divide with a reciprocal multiplication on 32-bit platforms. When the input is an unsigned long, there is no portable way to do this on 64-bit platforms there is no portable way to do this since it requires a 128-bit intermediate result (which gcc does support on 64-bit platforms but may generate libgcc calls, e.g. on 64-bit s390), but since the output is a 32-bit integer in the cases affected, just simplify the multiply-divide (*3/10 instead of *300/1000). The reciprocal multiply used can have off-by-one errors in the upper half of the valid output range. This could be avoided at the expense of having to deal with a potential 65-bit intermediate result. Since the intent is to avoid overflow problems and most of the other time conversions are only semiexact, the off-by-one errors were considered an acceptable tradeoff. At Ralf Baechle's suggestion, this version uses a Perl script to compute the necessary constants. We already have dependencies on Perl for kernel compiles. This does, however, require the Perl module Math::BigInt, which is included in the standard Perl distribution starting with version 5.8.0. In order to support older versions of Perl, include a table of canned constants in the script itself, and structure the script so that Math::BigInt isn't required if pulling values from said table. Running the script requires that the HZ value is available from the Makefile. Thus, this patch also adds the Kconfig variable CONFIG_HZ to the architectures which didn't already have it (alpha, cris, frv, h8300, m32r, m68k, m68knommu, sparc, v850, and xtensa.) It does *not* touch the sh or sh64 architectures, since Paul Mundt has dealt with those separately in the sh tree. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Ralf Baechle <ralf@linux-mips.org>, Cc: Sam Ravnborg <sam@ravnborg.org>, Cc: Paul Mundt <lethal@linux-sh.org>, Cc: Richard Henderson <rth@twiddle.net>, Cc: Michael Starvik <starvik@axis.com>, Cc: David Howells <dhowells@redhat.com>, Cc: Yoshinori Sato <ysato@users.sourceforge.jp>, Cc: Hirokazu Takata <takata@linux-m32r.org>, Cc: Geert Uytterhoeven <geert@linux-m68k.org>, Cc: Roman Zippel <zippel@linux-m68k.org>, Cc: William L. Irwin <sparclinux@vger.kernel.org>, Cc: Chris Zankel <chris@zankel.net>, Cc: H. Peter Anvin <hpa@zytor.com>, Cc: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08procfs: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: mark arches that support A.OUT formatDavid Howells
Mark arches that support A.OUT format by including the following in their master Kconfig files: config ARCH_SUPPORTS_AOUT def_bool y This should also be set if the arch provides compatibility A.OUT support for an older arch, for instance x86_64 for i386 or sparc64 for sparc. I've guessed at which arches don't, based on comments in the code, however I'm sure that some of the ones I've marked as 'yes' actually should be 'no'. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Introduce flags for reserve_bootmem()Bernhard Walle
This patchset adds a flags variable to reserve_bootmem() and uses the BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions between crashkernel area and already used memory. This patch: Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE. If that flag is set, the function returns with -EBUSY if the memory already has been reserved in the past. This is to avoid conflicts. Because that code runs before SMP initialisation, there's no race condition inside reserve_bootmem_core(). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06proper show_interrupts() prototypeAdrian Bunk
Add a proper prototype for show_interrupts() in include/linux/interrupt.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (79 commits) Jesper Juhl is the new trivial patches maintainer Documentation: mention email-clients.txt in SubmittingPatches fs/binfmt_elf.c: spello fix do_invalidatepage() comment typo fix Documentation/filesystems/porting fixes typo fixes in net/core/net_namespace.c typo fix in net/rfkill/rfkill.c typo fixes in net/sctp/sm_statefuns.c lib/: Spelling fixes kernel/: Spelling fixes include/scsi/: Spelling fixes include/linux/: Spelling fixes include/asm-m68knommu/: Spelling fixes include/asm-frv/: Spelling fixes fs/: Spelling fixes drivers/watchdog/: Spelling fixes drivers/video/: Spelling fixes drivers/ssb/: Spelling fixes drivers/serial/: Spelling fixes drivers/scsi/: Spelling fixes ...
2008-02-03arch/h8300/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03Move Kconfig.instrumentation to arch/Kconfig and init/KconfigMathieu Desnoyers
Move the instrumentation Kconfig to arch/Kconfig for architecture dependent options - oprofile - kprobes and init/Kconfig for architecture independent options - profiling - markers Remove the "Instrumentation Support" menu. Everything moves to "General setup". Delete the kernel/Kconfig.instrumentation file. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28all archs: consolidate init and exit sections in vmlinux.lds.hSam Ravnborg
This patch consolidate all definitions of .init.text, .init.data and .exit.text, .exit.data section definitions in the generic vmlinux.lds.h. This is a preparational patch - alone it does not buy us much good. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-30Kbuild/doc: fix links to Documentation filesDirk Hohndel
Fix links to files in Documentation/* in various Kconfig files Signed-off-by: Dirk Hohndel <hohndel@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
