path: root/arch/h8300/kernel/time.c
2008-10-16h8300: update timer handler - misc updateYoshinori Sato
- Update selection - Update common timer handler - Add support functions Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20spelling fixes: arch/h8300/Simon Arlott
Spelling fixes in arch/h8300/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-05-07h8300 generic irqYoshinori Sato
h8300 using generic irq handler patch. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Convert h8/300 to generic timekeepingjohn stultz
Currently h8/300 does not implement sub-jiffy timekeeping, so there is no benefit to having arch specific timekeeping code. This patch simply removes those functions and enables the generic timekeeping code. Signed-off-by: John Stultz <johnstul@us.ibm.com> Acked-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Consolidate default sched_clock()Alexey Dobriyan
Use attribute(weak). Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-29[PATCH] simplify update_times (avoid jiffies/jiffies_64 aliasing problem)Atsushi Nemoto
Pass ticks to do_timer() and update_times(), and adjust x86_64 and s390 timer interrupt handler with this change. Currently update_times() calculates ticks by "jiffies - wall_jiffies", but callers of do_timer() should know how many ticks to update. Passing ticks get rid of this redundant calculation. Also there are another redundancy pointed out by Martin Schwidefsky. This cleanup make a barrier added by 5aee405c662ca644980c184774277fc6d0769a84 needless. So this patch removes it. As a bonus, this cleanup make wall_jiffies can be removed easily, since now wall_jiffies is always synced with jiffies. (This patch does not really remove wall_jiffies. It would be another cleanup patch) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] jiffies_64 cleanupThomas Gleixner
Define jiffies_64 in kernel/timer.c rather than having 24 duplicated defines in each architecture. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] NTP: ntp-helper functionsjohn stultz
This patch cleans up a commonly repeated set of changes to the NTP state variables by adding two helper inline functions: ntp_clear(): Clears the ntp state variables ntp_synced(): Returns 1 if the system is synced with a time server. This was compile tested for alpha, arm, i386, x86-64, ppc64, s390, sparc, sparc64. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
