path: root/arch/h8300/kernel/process.c
2013-04-30dump_stack: unify debug information printed by show_regs()Tejun Heo
show_regs() is inherently arch-dependent but it does make sense to print generic debug information and some archs already do albeit in slightly different forms. This patch introduces a generic function to print debug information from show_regs() so that different archs print out the same information and it's much easier to modify what's printed. show_regs_print_info() prints out the same debug info as dump_stack() does plus task and thread_info pointers. * Archs which didn't print debug info now do. alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r, metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc, um, xtensa * Already prints debug info. Replaced with show_regs_print_info(). The printed information is superset of what used to be there. arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86 * s390 is special in that it used to print arch-specific information along with generic debug info. Heiko and Martin think that the arch-specific extra isn't worth keeping s390 specfic implementation. Converted to use the generic version. Note that now all archs print the debug info before actual register dumps. An example BUG() dump follows. kernel BUG at /work/os/work/kernel/workqueue.c:4841! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000 RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6 RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246 RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650 0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760 Call Trace: [<ffffffff81000312>] do_one_initcall+0x122/0x170 [<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8 [<ffffffff81c47760>] ? rest_init+0x140/0x140 [<ffffffff81c4776e>] kernel_init+0xe/0xf0 [<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0 [<ffffffff81c47760>] ? rest_init+0x140/0x140 ... v2: Typo fix in x86-32. v3: CPU number dropped from show_regs_print_info() as dump_stack_print_info() has been updated to print it. s390 specific implementation dropped as requested by s390 maintainers. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-08h8300: Use generic idle loopThomas Gleixner
Use the core idle poll function instead of the private one Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Link: http://lkml.kernel.org/r/20130321215234.277153345@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-11-28flagday: don't pass regs to copy_thread()Al Viro
2012-11-28h8300: switch to generic fork/vfork/cloneAl Viro
2012-10-14h8300: generic sys_execve()Al Viro
2012-10-14h8300: generic kernel_thread()Al Viro
2012-10-12vfs: define struct filename and have getname() return itJeff Layton
getname() is intended to copy pathname strings from userspace into a kernel buffer. The result is just a string in kernel space. It would however be quite helpful to be able to attach some ancillary info to the string. For instance, we could attach some audit-related info to reduce the amount of audit-related processing needed. When auditing is enabled, we could also call getname() on the string more than once and not need to recopy it from userspace. This patchset converts the getname()/putname() interfaces to return a struct instead of a string. For now, the struct just tracks the string in kernel space and the original userland pointer for it. Later, we'll add other information to the struct as it becomes convenient. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-23h8300: Add missing RCU idle APIs on idle loopFrederic Weisbecker
In the old times, the whole idle task was considered as an RCU quiescent state. But as RCU became more and more successful overtime, some RCU read side critical section have been added even in the code of some architectures idle tasks, for tracing for example. So nowadays, rcu_idle_enter() and rcu_idle_exit() must be called by the architecture to tell RCU about the part in the idle loop that doesn't make use of rcu read side critical sections, typically the part that puts the CPU in low power mode. This is necessary for RCU to find the quiescent states in idle in order to complete grace periods. Add this missing pair of calls in the h8300's idle loop. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: <stable@vger.kernel.org> # 3.3+ Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2012-03-28Disintegrate asm/system.h for H8300David Howells
Disintegrate asm/system.h for H8300. Signed-off-by: David Howells <dhowells@redhat.com> cc: Yoshinori Sato <ysato@users.sourceforge.jp>
2012-03-01sched/rt: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-17Make do_execve() take a const filename pointerDavid Howells
Make do_execve() take a const filename pointer so that kernel_execve() compiles correctly on ARM: arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type This also requires the argv and envp arguments to be consted twice, once for the pointer array and once for the strings the array points to. This is because do_execve() passes a pointer to the filename (now const) to copy_strings_kernel(). A simpler alternative would be to cast the filename pointer in do_execve() when it's passed to copy_strings_kernel(). do_execve() may not change any of the strings it is passed as part of the argv or envp lists as they are some of them in .rodata, so marking these strings as const should be fine. Further kernel_execve() and sys_execve() need to be changed to match. This has been test built on x86_64, frv, arm and mips. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-10-14h83000: Remove BKL from sys_execveJohn Kacur
This looks like a copy-and-paste job for code that no-longer needs the BKL Just remove it. Signed-off-by: John Kacur <jkacur@redhat.com> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> LKML-Reference: <alpine.LFD.2.00.0910130010000.3658@localhost.localdomain> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-04-02Simplify copy_thread()Alexey Dobriyan
First argument unused since 2.3.11. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-06Remove asm/a.out.h files for all architectures without a.out support.Adrian Bunk
This patch also includes the required removal of (unused) inclusion of <asm/a.out.h> <linux/a.out.h>'s in the arch/ code for these architectures. [dwmw2: updated for 2.6.27-rc] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2007-08-22h8300: missing includeYoshinori Sato
Build error fix. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-24[PATCH] kill include/linux/platform.h, default_idle() cleanupAdrian Bunk
include/linux/platform.h contained nothing that was actually used except the default_idle() prototype, and is therefore removed by this patch. This patch does the following with the platform specific default_idle() functions on different architectures: - remove the unused function: - parisc - sparc64 - make the needlessly global function static: - arm - h8300 - m68k - m68knommu - s390 - v850 - x86_64 - add a prototype in asm/system.h: - cris - i386 - ia64 Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Patrick Mochel <mochel@digitalimplant.org> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-06[PATCH] add missing pm_power_off'sAdrian Bunk
Add the missing pm_power_off's for the h8300, v850 and xtensa architectures. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] h8300: task_stack_page()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] dump_thread() cleanupakpm@osdl.org
) From: Adrian Bunk <bunk@stusta.de> - create one common dump_thread() prototype in kernel.h - dump_thread() is only used in fs/binfmt_aout.c and can therefore be removed on all architectures where CONFIG_BINFMT_AOUT is not available Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: disable preempt in idle tasksNick Piggin
Run idle threads with preempt disabled. Also corrected a bugs in arm26's cpu_idle (make it actually call schedule()). How did it ever work before? Might fix the CPU hotplugging hang which Nigel Cunningham noted. We think the bug hits if the idle thread is preempted after checking need_resched() and before going to sleep, then the CPU offlined. After calling stop_machine_run, the CPU eventually returns from preemption and into the idle thread and goes to sleep. The CPU will continue executing previous idle and have no chance to call play_dead. By disabling preemption until we are ready to explicitly schedule, this bug is fixed and the idle threads generally become more robust. From: alexs <ashepard@u.washington.edu> PPC build fix From: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> MIPS build fix Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Don't export machine_restart, machine_halt, or machine_power_off.Eric W. Biederman
machine_restart, machine_halt and machine_power_off are machine specific hooks deep into the reboot logic, that modules have no business messing with. Usually code should be calling kernel_restart, kernel_halt, kernel_power_off, or emergency_restart. So don't export machine_restart, machine_halt, and machine_power_off so we can catch buggy users. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-31[PATCH] h8300 sleep problemNick Piggin
h8300 appears to sleep (halt) when need_resched IS set. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
