path: root/arch/frv
2014-08-19frv: Define cpu_relax_lowlatency()Davidlohr Bueso
3a6bfbc91df0 "(arch,locking: Ciao arch_mutex_cpu_relax()") broke building the frv arch. Fixes errors such as: kernel/locking/mcs_spinlock.h:87:2: error: implicit declaration of function 'cpu_relax_lowlatency' Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Compile-tested-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-09Merge branch 'signal-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc Pull arch signal handling cleanup from Richard Weinberger: "This patch series moves all remaining archs to the get_signal(), signal_setup_done() and sigsp() functions. Currently these archs use open coded variants of the said functions. Further, unused parameters get removed from get_signal_to_deliver(), tracehook_signal_handler() and signal_delivered(). At the end of the day we save around 500 lines of code." * 'signal-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (43 commits) powerpc: Use sigsp() openrisc: Use sigsp() mn10300: Use sigsp() mips: Use sigsp() microblaze: Use sigsp() metag: Use sigsp() m68k: Use sigsp() m32r: Use sigsp() hexagon: Use sigsp() frv: Use sigsp() cris: Use sigsp() c6x: Use sigsp() blackfin: Use sigsp() avr32: Use sigsp() arm64: Use sigsp() arc: Use sigsp() sas_ss_flags: Remove nested ternary if Rip out get_signal_to_deliver() Clean up signal_delivered() tracehook_signal_handler: Remove sig, info, ka and regs ...
2014-08-08lib/scatterlist: clean up useless architecture versions of scatterlist.hLaura Abbott
There's no need to have an architecture version of scatterlist.h if the only thing the file does is include asm-generic/scatterlist.h. Switch to the asm-generic versions directly. Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chen Liqin <liqin.linux@gmail.com>, Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06frv: Use sigsp()Richard Weinberger
Use sigsp() instead of the open coded variant. Signed-off-by: Richard Weinberger <richard@nod.at>
2014-08-06frv: Use get_signal() signal_setup_done()Richard Weinberger
Use the more generic functions get_signal() signal_setup_done() for signal delivery. Signed-off-by: Richard Weinberger <richard@nod.at>
2014-06-04sys_sgetmask/sys_ssetmask: add CONFIG_SGETMASK_SYSCALLFabian Frederick
sys_sgetmask and sys_ssetmask are obsolete system calls no longer supported in libc. This patch replaces architecture related __ARCH_WANT_SYS_SGETMAX by expert mode configuration.That option is enabled by default for those architectures. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Steven Miao <realmz6@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull core locking updates from Ingo Molnar: "The main changes in this cycle were: - reduced/streamlined smp_mb__*() interface that allows more usecases and makes the existing ones less buggy, especially in rarer architectures - add rwsem implementation comments - bump up lockdep limits" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits) rwsem: Add comments to explain the meaning of the rwsem's count field lockdep: Increase static allocations arch: Mass conversion of smp_mb__*() arch,doc: Convert smp_mb__*() arch,xtensa: Convert smp_mb__*() arch,x86: Convert smp_mb__*() arch,tile: Convert smp_mb__*() arch,sparc: Convert smp_mb__*() arch,sh: Convert smp_mb__*() arch,score: Convert smp_mb__*() arch,s390: Convert smp_mb__*() arch,powerpc: Convert smp_mb__*() arch,parisc: Convert smp_mb__*() arch,openrisc: Convert smp_mb__*() arch,mn10300: Convert smp_mb__*() arch,mips: Convert smp_mb__*() arch,metag: Convert smp_mb__*() arch,m68k: Convert smp_mb__*() arch,m32r: Convert smp_mb__*() arch,ia64: Convert smp_mb__*() ...
2014-05-27PCI: Turn pcibios_penalize_isa_irq() into a weak functionHanjun Guo
pcibios_penalize_isa_irq() is only implemented by x86 now, and legacy ISA is not used by some architectures. Make pcibios_penalize_isa_irq() a __weak function to simplify the code. This removes the need for new platforms to add stub implementations of pcibios_penalize_isa_irq(). [bhelgaas: changelog, comments] Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-04-18arch,frv: Convert smp_mb__*()Peter Zijlstra
Because: arch/frv/include/asm/smp.h:#error SMP not supported smp_mb() is barrier() and we can use the default implementation that uses smp_mb(). Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/n/tip-n296g51yzdu5ru1vp7mccxmf@git.kernel.org Cc: David Howells <dhowells@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-01Merge tag 'pci-v3.15-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: "Enumeration - Increment max correctly in pci_scan_bridge() (Andreas Noever) - Clarify the "scan anyway" comment in pci_scan_bridge() (Andreas Noever) - Assign CardBus bus number only during the second pass (Andreas Noever) - Use request_resource_conflict() instead of insert_ for bus numbers (Andreas Noever) - Make sure bus number resources stay within their parents bounds (Andreas Noever) - Remove pci_fixup_parent_subordinate_busnr() (Andreas Noever) - Check for child busses which use more bus numbers than allocated (Andreas Noever) - Don't scan random busses in pci_scan_bridge() (Andreas Noever) - x86: Drop pcibios_scan_root() check for bus already scanned (Bjorn Helgaas) - x86: Use pcibios_scan_root() instead of pci_scan_bus_with_sysdata() (Bjorn Helgaas) - x86: Use pcibios_scan_root() instead of pci_scan_bus_on_node() (Bjorn Helgaas) - x86: Merge pci_scan_bus_on_node() into pcibios_scan_root() (Bjorn Helgaas) - x86: Drop return value of pcibios_scan_root() (Bjorn Helgaas) NUMA - x86: Add x86_pci_root_bus_node() to look up NUMA node from PCI bus (Bjorn Helgaas) - x86: Use x86_pci_root_bus_node() instead of get_mp_bus_to_node() (Bjorn Helgaas) - x86: Remove mp_bus_to_node[], set_mp_bus_to_node(), get_mp_bus_to_node() (Bjorn Helgaas) - x86: Use NUMA_NO_NODE, not -1, for unknown node (Bjorn Helgaas) - x86: Remove acpi_get_pxm() usage (Bjorn Helgaas) - ia64: Use NUMA_NO_NODE, not MAX_NUMNODES, for unknown node (Bjorn Helgaas) - ia64: Remove acpi_get_pxm() usage (Bjorn Helgaas) - ACPI: Fix acpi_get_node() prototype (Bjorn Helgaas) Resource management - i2o: Fix and refactor PCI space allocation (Bjorn Helgaas) - Add resource_contains() (Bjorn Helgaas) - Add %pR support for IORESOURCE_UNSET (Bjorn Helgaas) - Mark resources as IORESOURCE_UNSET if we can't assign them (Bjorn Helgaas) - Don't clear IORESOURCE_UNSET when updating BAR (Bjorn Helgaas) - Check IORESOURCE_UNSET before updating BAR (Bjorn Helgaas) - Don't try to claim IORESOURCE_UNSET resources (Bjorn Helgaas) - Mark 64-bit resource as IORESOURCE_UNSET if we only support 32-bit (Bjorn Helgaas) - Don't enable decoding if BAR hasn't been assigned an address (Bjorn Helgaas) - Add "weak" generic pcibios_enable_device() implementation (Bjorn Helgaas) - alpha, microblaze, sh, sparc, tile: Use default pcibios_enable_device() (Bjorn Helgaas) - s390: Use generic pci_enable_resources() (Bjorn Helgaas) - Don't check resource_size() in pci_bus_alloc_resource() (Bjorn Helgaas) - Set type in __request_region() (Bjorn Helgaas) - Check all IORESOURCE_TYPE_BITS in pci_bus_alloc_from_region() (Bjorn Helgaas) - Change pci_bus_alloc_resource() type_mask to unsigned long (Bjorn Helgaas) - Log IDE resource quirk in dmesg (Bjorn Helgaas) - Revert "[PATCH] Insert GART region into resource map" (Bjorn Helgaas) PCI device hotplug - Make check_link_active() non-static (Rajat Jain) - Use link change notifications for hot-plug and removal (Rajat Jain) - Enable link state change notifications (Rajat Jain) - Don't disable the link permanently during removal (Rajat Jain) - Don't check adapter or latch status while disabling (Rajat Jain) - Disable link notification across slot reset (Rajat Jain) - Ensure very fast hotplug events are also processed (Rajat Jain) - Add hotplug_lock to serialize hotplug events (Rajat Jain) - Remove a non-existent card, regardless of "surprise" capability (Rajat Jain) - Don't turn slot off when hot-added device already exists (Yijing Wang) MSI - Keep pci_enable_msi() documentation (Alexander Gordeev) - ahci: Fix broken single MSI fallback (Alexander Gordeev) - ahci, vfio: Use pci_enable_msi_range() (Alexander Gordeev) - Check kmalloc() return value, fix leak of name (Greg Kroah-Hartman) - Fix leak of msi_attrs (Greg Kroah-Hartman) - Fix pci_msix_vec_count() htmldocs failure (Masanari Iida) Virtualization - Device-specific ACS support (Alex Williamson) Freescale i.MX6 - Wait for retraining (Marek Vasut) Marvell MVEBU - Use Device ID and revision from underlying endpoint (Andrew Lunn) - Fix incorrect size for PCI aperture resources (Jason Gunthorpe) - Call request_resource() on the apertures (Jason Gunthorpe) - Fix potential issue in range parsing (Jean-Jacques Hiblot) Renesas R-Car - Check platform_get_irq() return code (Ben Dooks) - Add error interrupt handling (Ben Dooks) - Fix bridge logic configuration accesses (Ben Dooks) - Register each instance independently (Magnus Damm) - Break out window size handling (Magnus Damm) - Make the Kconfig dependencies more generic (Magnus Damm) Synopsys DesignWare - Fix RC BAR to be single 64-bit non-prefetchable memory (Mohit Kumar) Miscellaneous - Remove unused SR-IOV VF Migration support (Bjorn Helgaas) - Enable INTx if BIOS left them disabled (Bjorn Helgaas) - Fix hex vs decimal typo in cpqhpc_probe() (Dan Carpenter) - Clean up par-arch object file list (Liviu Dudau) - Set IORESOURCE_ROM_SHADOW only for the default VGA device (Sander Eikelenboom) - ACPI, ARM, drm, powerpc, pcmcia, PCI: Use list_for_each_entry() for bus traversal (Yijing Wang) - Fix pci_bus_b() build failure (Paul Gortmaker)" * tag 'pci-v3.15-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (108 commits) Revert "[PATCH] Insert GART region into resource map" PCI: Log IDE resource quirk in dmesg PCI: Change pci_bus_alloc_resource() type_mask to unsigned long PCI: Check all IORESOURCE_TYPE_BITS in pci_bus_alloc_from_region() resources: Set type in __request_region() PCI: Don't check resource_size() in pci_bus_alloc_resource() s390/PCI: Use generic pci_enable_resources() tile PCI RC: Use default pcibios_enable_device() sparc/PCI: Use default pcibios_enable_device() (Leon only) sh/PCI: Use default pcibios_enable_device() microblaze/PCI: Use default pcibios_enable_device() alpha/PCI: Use default pcibios_enable_device() PCI: Add "weak" generic pcibios_enable_device() implementation PCI: Don't enable decoding if BAR hasn't been assigned an address PCI: Enable INTx in pci_reenable_device() only when MSI/MSI-X not enabled PCI: Mark 64-bit resource as IORESOURCE_UNSET if we only support 32-bit PCI: Don't try to claim IORESOURCE_UNSET resources PCI: Check IORESOURCE_UNSET before updating BAR PCI: Don't clear IORESOURCE_UNSET when updating BAR PCI: Mark resources as IORESOURCE_UNSET if we can't assign them ... Conflicts: arch/x86/include/asm/topology.h drivers/ata/ahci.c
2014-03-13arch: Remove stub cputime.h headersFrederic Weisbecker
Many architectures have a stub cputime.h that only include the default cputime.h Lets remove the useless headers, we only need to mention that we want the default headers on the Kbuild files. Cc: Archs <linux-arch@vger.kernel.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2014-02-20PCI: frv: replace now removed pci_bus_b() causing build failurePaul Gortmaker
In commit 94e6a9b93064 ("PCI: Remove pci_bus_b() and use list_for_each_entry() directly") the function pci_bus_b() was removed, but one instance of its usage was missed. Replace it in the same fashion that the original commit did. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Cc: Yijing Wang <wangyijing@huawei.com>
2014-02-09locking/mcs: Allow architecture specific asm files to be used for contended caseTim Chen
This patch allows each architecture to add its specific assembly optimized arch_mcs_spin_lock_contended and arch_mcs_spinlock_uncontended for MCS lock and unlock functions. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Cc: Scott J Norton <scott.norton@hp.com> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: AswinChandramouleeswaran <aswin@hp.com> Cc: George Spelvin <linux@horizon.com> Cc: Rik vanRiel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: MichelLespinasse <walken@google.com> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alex Shi <alex.shi@linaro.org> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: "Figo.zhang" <figo1802@gmail.com> Cc: "Paul E.McKenney" <paulmck@linux.vnet.ibm.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Will Deacon <will.deacon@arm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matthew R Wilcox <matthew.r.wilcox@intel.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1390347382.3138.67.camel@schen9-DESK Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-02-09locking/mcs: Order the header files in Kbuild of each architecture in ↵Tim Chen
alphabetical order We perform a clean up of the Kbuid files in each architecture. We order the files in each Kbuild in alphabetical order by running the below script. for i in arch/*/include/asm/Kbuild do cat $i | gawk '/^generic-y/ { i = 3; do { for (; i <= NF; i++) { if ($i == "\\") { getline; i = 1; continue; } if ($i != "") hdr[$i] = $i; } break; } while (1); next; } // { print $0; } END { n = asort(hdr); for (i = 1; i <= n; i++) print "generic-y += " hdr[i]; }' > ${i}.sorted; mv ${i}.sorted $i; done Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Matthew R Wilcox <matthew.r.wilcox@intel.com> Cc: AswinChandramouleeswaran <aswin@hp.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: "Paul E.McKenney" <paulmck@linux.vnet.ibm.com> Cc: Scott J Norton <scott.norton@hp.com> Cc: Will Deacon <will.deacon@arm.com> Cc: "Figo.zhang" <figo1802@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rik van Riel <riel@redhat.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Alex Shi <alex.shi@linaro.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: George Spelvin <linux@horizon.com> Cc: MichelLespinasse <walken@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> [ Fixed build bug. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-30Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - fix make -s detection with make-4.0 - fix for scripts/setlocalversion when the kernel repository is a submodule - do not hardcode ';' in macros that expand to assembler code, as some architectures' assemblers use a different character for newline - Fix passing --gdwarf-2 to the assembler * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: frv: Remove redundant debugging info flag mn10300: Remove redundant debugging info flag kbuild: Fix debugging info generation for .S files arch: use ASM_NL instead of ';' for assembler new line character in the macro kbuild: Fix silent builds with make-4 Fix detectition of kernel git repository in setlocalversion script [take #2]
2014-01-28frv: Remove redundant debugging info flagGeoff Levand
The generic makefile now sets '-Wa,--gdwarf2' in KBUILD_AFLAGS, so this setting is no longer needed in arch makefiles. Also remove a commented out addition of a -O1 to KBUILD_CFLAGS, and comment text relating to these removed lines. Cc: David Howells <dhowells@redhat.com> Signed-off-by: Geoff Levand <geoff@infradead.org> for Huawei, Linaro Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-18net: introduce SO_BPF_EXTENSIONSMichal Sekletar
For user space packet capturing libraries such as libpcap, there's currently only one way to check which BPF extensions are supported by the kernel, that is, commit aa1113d9f85d ("net: filter: return -EINVAL if BPF_S_ANC* operation is not supported"). For querying all extensions at once this might be rather inconvenient. Therefore, this patch introduces a new option which can be used as an argument for getsockopt(), and allows one to obtain information about which BPF extensions are supported by the current kernel. As David Miller suggests, we do not need to define any bits right now and status quo can just return 0 in order to state that this versions supports SKF_AD_PROTOCOL up to SKF_AD_PAY_OFFSET. Later additions to BPF extensions need to add their bits to the bpf_tell_extensions() function, as documented in the comment. Signed-off-by: Michal Sekletar <msekleta@redhat.com> Cc: David Miller <davem@davemloft.net> Reviewed-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-12arch: Clean up asm/barrier.h implementations using asm-generic/barrier.hPeter Zijlstra
We're going to be adding a few new barrier primitives, and in order to avoid endless duplication make more agressive use of asm-generic/barrier.h. Change the asm-generic/barrier.h such that it allows partial barrier definitions and fills out the rest with defaults. There are a few architectures (m32r, m68k) that could probably do away with their barrier.h file entirely but are kept for now due to their unconventional nop() implementation. Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org> Reviewed-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Michael Neuling <mikey@neuling.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Victor Kaplansky <VICTORK@il.ibm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20131213150640.846368594@infradead.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-12-17lib: Add missing arch generic-y entries for asm-generic/hash.hDavid S. Miller
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq cleanups from Ingo Molnar: "This is a multi-arch cleanup series from Thomas Gleixner, which we kept to near the end of the merge window, to not interfere with architecture updates. This series (motivated by the -rt kernel) unifies more aspects of IRQ handling and generalizes PREEMPT_ACTIVE" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: preempt: Make PREEMPT_ACTIVE generic sparc: Use preempt_schedule_irq ia64: Use preempt_schedule_irq m32r: Use preempt_schedule_irq hardirq: Make hardirq bits generic m68k: Simplify low level interrupt handling code genirq: Prevent spurious detection for unconditionally polled interrupts
2013-11-15frv: handle pgtable_page_ctor() failKirill A. Shutemov
Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-14Merge tag 'pci-v3.13-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: "Resource management - Fix host bridge window coalescing (Alexey Neyman) - Pass type, width, and prefetchability for window alignment (Wei Yang) PCI device hotplug - Convert acpiphp, acpiphp_ibm to dynamic debug (Lan Tianyu) Power management - Remove pci_pm_complete() (Liu Chuansheng) MSI - Fail initialization if device is not in PCI_D0 (Yijing Wang) MPS (Max Payload Size) - Use pcie_get_mps() and pcie_set_mps() to simplify code (Yijing Wang) - Use pcie_set_readrq() to simplify code (Yijing Wang) - Use cached pci_dev->pcie_mpss to simplify code (Yijing Wang) SR-IOV - Enable upstream bridges even for VFs on virtual buses (Bjorn Helgaas) - Use pci_is_root_bus() to avoid catching virtual buses (Wei Yang) Virtualization - Add x86 MSI masking ops (Konrad Rzeszutek Wilk) Freescale i.MX6 - Support i.MX6 PCIe controller (Sean Cross) - Increase link startup timeout (Marek Vasut) - Probe PCIe in fs_initcall() (Marek Vasut) - Fix imprecise abort handler (Tim Harvey) - Remove redundant of_match_ptr (Sachin Kamat) Renesas R-Car - Support Gen2 internal PCIe controller (Valentine Barshak) Samsung Exynos - Add MSI support (Jingoo Han) - Turn off power when link fails (Jingoo Han) - Add Jingoo Han as maintainer (Jingoo Han) - Add clk_disable_unprepare() on error path (Wei Yongjun) - Remove redundant of_match_ptr (Sachin Kamat) Synopsys DesignWare - Add irq_create_mapping() (Pratyush Anand) - Add header guards (Seungwon Jeon) Miscellaneous - Enable native PCIe services by default on non-ACPI (Andrew Murray) - Cleanup _OSC usage and messages (Bjorn Helgaas) - Remove pcibios_last_bus boot option on non-x86 (Bjorn Helgaas) - Convert bus code to use bus_, drv_, and dev_groups (Greg Kroah-Hartman) - Remove unused pci_mem_start (Myron Stowe) - Make sysfs functions static (Sachin Kamat) - Warn on invalid return from driver probe (Stephen M. Cameron) - Remove Intel Haswell D3 delays (Todd E Brandt) - Call pci_set_master() in core if driver doesn't do it (Yinghai Lu) - Use pci_is_pcie() to simplify code (Yijing Wang) - Use PCIe capability accessors to simplify code (Yijing Wang) - Use cached pci_dev->pcie_cap to simplify code (Yijing Wang) - Removed unused "is_pcie" from struct pci_dev (Yijing Wang) - Simplify sysfs CPU affinity implementation (Yijing Wang)" * tag 'pci-v3.13-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (79 commits) PCI: Enable upstream bridges even for VFs on virtual buses PCI: Add pci_upstream_bridge() PCI: Add x86_msi.msi_mask_irq() and msix_mask_irq() PCI: Warn on driver probe return value greater than zero PCI: Drop warning about drivers that don't use pci_set_master() PCI: Workaround missing pci_set_master in pci drivers powerpc/pci: Use pci_is_pcie() to simplify code [fix] PCI: Update pcie_ports 'auto' behavior for non-ACPI platforms PCI: imx6: Probe the PCIe in fs_initcall() PCI: Add R-Car Gen2 internal PCI support PCI: imx6: Remove redundant of_match_ptr PCI: Report pci_pme_active() kmalloc failure mn10300/PCI: Remove useless pcibios_last_bus frv/PCI: Remove pcibios_last_bus PCI: imx6: Increase link startup timeout PCI: exynos: Remove redundant of_match_ptr PCI: imx6: Fix imprecise abort handler PCI: Fail MSI/MSI-X initialization if device is not in PCI_D0 PCI: imx6: Remove redundant dev_err() in imx6_pcie_probe() x86/PCI: Coalesce multiple overlapping host bridge windows ...
2013-11-13preempt: Make PREEMPT_ACTIVE genericThomas Gleixner
No point in having this bit defined by architecture. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20130917183629.090698799@linutronix.de
2013-11-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) The addition of nftables. No longer will we need protocol aware firewall filtering modules, it can all live in userspace. At the core of nftables is a, for lack of a better term, virtual machine that executes byte codes to inspect packet or metadata (arriving interface index, etc.) and make verdict decisions. Besides support for loading packet contents and comparing them, the interpreter supports lookups in various datastructures as fundamental operations. For example sets are supports, and therefore one could create a set of whitelist IP address entries which have ACCEPT verdicts attached to them, and use the appropriate byte codes to do such lookups. Since the interpreted code is composed in userspace, userspace can do things like optimize things before giving it to the kernel. Another major improvement is the capability of atomically updating portions of the ruleset. In the existing netfilter implementation, one has to update the entire rule set in order to make a change and this is very expensive. Userspace tools exist to create nftables rules using existing netfilter rule sets, but both kernel implementations will need to co-exist for quite some time as we transition from the old to the new stuff. Kudos to Patrick McHardy, Pablo Neira Ayuso, and others who have worked so hard on this. 2) Daniel Borkmann and Hannes Frederic Sowa made several improvements to our pseudo-random number generator, mostly used for things like UDP port randomization and netfitler, amongst other things. In particular the taus88 generater is updated to taus113, and test cases are added. 3) Support 64-bit rates in HTB and TBF schedulers, from Eric Dumazet and Yang Yingliang. 4) Add support for new 577xx tigon3 chips to tg3 driver, from Nithin Sujir. 5) Fix two fatal flaws in TCP dynamic right sizing, from Eric Dumazet, Neal Cardwell, and Yuchung Cheng. 6) Allow IP_TOS and IP_TTL to be specified in sendmsg() ancillary control message data, much like other socket option attributes. From Francesco Fusco. 7) Allow applications to specify a cap on the rate computed automatically by the kernel for pacing flows, via a new SO_MAX_PACING_RATE socket option. From Eric Dumazet. 8) Make the initial autotuned send buffer sizing in TCP more closely reflect actual needs, from Eric Dumazet. 9) Currently early socket demux only happens for TCP sockets, but we can do it for connected UDP sockets too. Implementation from Shawn Bohrer. 10) Refactor inet socket demux with the goal of improving hash demux performance for listening sockets. With the main goals being able to use RCU lookups on even request sockets, and eliminating the listening lock contention. From Eric Dumazet. 11) The bonding layer has many demuxes in it's fast path, and an RCU conversion was started back in 3.11, several changes here extend the RCU usage to even more locations. From Ding Tianhong and Wang Yufen, based upon suggestions by Nikolay Aleksandrov and Veaceslav Falico. 12) Allow stackability of segmentation offloads to, in particular, allow segmentation offloading over tunnels. From Eric Dumazet. 13) Significantly improve the handling of secret keys we input into the various hash functions in the inet hashtables, TCP fast open, as well as syncookies. From Hannes Frederic Sowa. The key fundamental operation is "net_get_random_once()" which uses static keys. Hannes even extended this to ipv4/ipv6 fragmentation handling and our generic flow dissector. 14) The generic driver layer takes care now to set the driver data to NULL on device removal, so it's no longer necessary for drivers to explicitly set it to NULL any more. Many drivers have been cleaned up in this way, from Jingoo Han. 15) Add a BPF based packet scheduler classifier, from Daniel Borkmann. 16) Improve CRC32 interfaces and generic SKB checksum iterators so that SCTP's checksumming can more cleanly be handled. Also from Daniel Borkmann. 17) Add a new PMTU discovery mode, IP_PMTUDISC_INTERFACE, which forces using the interface MTU value. This helps avoid PMTU attacks, particularly on DNS servers. From Hannes Frederic Sowa. 18) Use generic XPS for transmit queue steering rather than internal (re-)implementation in virtio-net. From Jason Wang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits) random32: add test cases for taus113 implementation random32: upgrade taus88 generator to taus113 from errata paper random32: move rnd_state to linux/random.h random32: add prandom_reseed_late() and call when nonblocking pool becomes initialized random32: add periodic reseeding random32: fix off-by-one in seeding requirement PHY: Add RTL8201CP phy_driver to realtek xtsonic: add missing platform_set_drvdata() in xtsonic_probe() macmace: add missing platform_set_drvdata() in mace_probe() ethernet/arc/arc_emac: add missing platform_set_drvdata() in arc_emac_probe() ipv6: protect for_each_sk_fl_rcu in mem_check with rcu_read_lock_bh vlan: Implement vlan_dev_get_egress_qos_mask as an inline. ixgbe: add warning when max_vfs is out of range. igb: Update link modes display in ethtool netfilter: push reasm skb through instead of original frag skbs ip6_output: fragment outgoing reassembled skb properly MAINTAINERS: mv643xx_eth: take over maintainership from Lennart net_sched: tbf: support of 64bit rates ixgbe: deleting dfwd stations out of order can cause null ptr deref ixgbe: fix build err, num_rx_queues is only available with CONFIG_RPS ...
2013-10-29frv/PCI: Remove pcibios_last_busBjorn Helgaas
pcibios_last_bus was apparently copied from x86. On FR-V, it is statically initialized to -1 and never changed unless the user boots with "pci=lastbus=<X>". I doubt that option is used on FR-V, so this patch removes all the code related to pcibios_last_bus. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-09-28net: introduce SO_MAX_PACING_RATEEric Dumazet
As mentioned in commit afe4fd062416b ("pkt_sched: fq: Fair Queue packet scheduler"), this patch adds a new socket option. SO_MAX_PACING_RATE offers the application the ability to cap the rate computed by transport layer. Value is in bytes per second. u32 val = 1000000; setsockopt(sockfd, SOL_SOCKET, SO_MAX_PACING_RATE, &val, sizeof(val)); To be effectively paced, a flow must use FQ packet scheduler. Note that a packet scheduler takes into account the headers for its computations. The effective payload rate depends on MSS and retransmits if any. I chose to make this pacing rate a SOL_SOCKET option instead of a TCP one because this can be used by other protocols. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Steinar H. Gunderson <sesse@google.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-25sched, arch: Create asm/preempt.hPeter Zijlstra
In order to prepare to per-arch implementations of preempt_count move the required bits into an asm-generic header and use this for all archs. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-h5j0c1r3e3fk015m30h8f1zx@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-09-12arch: mm: pass userspace fault flag to generic fault handlerJohannes Weiner
Unlike global OOM handling, memory cgroup code will invoke the OOM killer in any OOM situation because it has no way of telling faults occuring in kernel context - which could be handled more gracefully - from user-triggered faults. Pass a flag that identifies faults originating in user space from the architecture-specific fault handlers to generic code so that memcg OOM handling can be improved. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-25frv/PCI: Mark pcibios_fixup_bus() as non-initBjorn Helgaas
pcibios_fixup_bus() is called by pci_scan_child_bus(), which is not marked __init. Therefore, pcibios_fixup_bus() cannot be marked __init either. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-14frv: delete __cpuinit usage from all frv filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. Note that some harmless section mismatch warnings may result, since notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c) are flagged as __cpuinit -- so if we remove the __cpuinit from arch specific callers, we will also get section mismatch warnings. As an intermediate step, we intend to turn the linux/init.h cpuinit content into no-ops as early as possible, since that will get rid of these warnings. In any case, they are temporary and harmless. This removes all the arch/frv uses of the __cpuinit macros from all C files. Currently frv does not have any __CPUINIT used in assembly files. [1] https://lkml.org/lkml/2013/5/20/589 Cc: David Howells <dhowells@redhat.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-07-10net: rename busy poll socket op and globalsEliezer Tamir
Rename LL_SO to BUSY_POLL_SO Rename sysctl_net_ll_{read,poll} to sysctl_busy_{read,poll} Fix up users of these variables. Fix documentation for sysctl. a patch for the socket.7 man page will follow separately, because of limitations of my mail setup. Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "This is a re-do of the net-next pull request for the current merge window. The only difference from the one I made the other day is that this has Eliezer's interface renames and the timeout handling changes made based upon your feedback, as well as a few bug fixes that have trickeled in. Highlights: 1) Low latency device polling, eliminating the cost of interrupt handling and context switches. Allows direct polling of a network device from socket operations, such as recvmsg() and poll(). Currently ixgbe, mlx4, and bnx2x support this feature. Full high level description, performance numbers, and design in commit 0a4db187a999 ("Merge branch 'll_poll'") From Eliezer Tamir. 2) With the routing cache removed, ip_check_mc_rcu() gets exercised more than ever before in the case where we have lots of multicast addresses. Use a hash table instead of a simple linked list, from Eric Dumazet. 3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski, Marek Puzyniak, Michal Kazior, and Sujith Manoharan. 4) Support reporting the TUN device persist flag to userspace, from Pavel Emelyanov. 5) Allow controlling network device VF link state using netlink, from Rony Efraim. 6) Support GRE tunneling in openvswitch, from Pravin B Shelar. 7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from Daniel Borkmann and Eric Dumazet. 8) Allow controlling of TCP quickack behavior on a per-route basis, from Cong Wang. 9) Several bug fixes and improvements to vxlan from Stephen Hemminger, Pravin B Shelar, and Mike Rapoport. In particular, support receiving on multiple UDP ports. 10) Major cleanups, particular in the area of debugging and cookie lifetime handline, to the SCTP protocol code. From Daniel Borkmann. 11) Allow packets to cross network namespaces when traversing tunnel devices. From Nicolas Dichtel. 12) Allow monitoring netlink traffic via AF_PACKET sockets, in a manner akin to how we monitor real network traffic via ptype_all. From Daniel Borkmann. 13) Several bug fixes and improvements for the new alx device driver, from Johannes Berg. 14) Fix scalability issues in the netem packet scheduler's time queue, by using an rbtree. From Eric Dumazet. 15) Several bug fixes in TCP loss recovery handling, from Yuchung Cheng. 16) Add support for GSO segmentation of MPLS packets, from Simon Horman. 17) Make network notifiers have a real data type for the opaque pointer that's passed into them. Use this to properly handle network device flag changes in arp_netdev_event(). From Jiri Pirko and Timo Teräs. 18) Convert several drivers over to module_pci_driver(), from Peter Huewe. 19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a O(1) calculation instead. From Eric Dumazet. 20) Support setting of explicit tunnel peer addresses in ipv6, just like ipv4. From Nicolas Dichtel. 21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet. 22) Prevent a single high rate flow from overruning an individual cpu during RX packet processing via selective flow shedding. From Willem de Bruijn. 23) Don't use spinlocks in TCP md5 signing fast paths, from Eric Dumazet. 24) Don't just drop GSO packets which are above the TBF scheduler's burst limit, chop them up so they are in-bounds instead. Also from Eric Dumazet. 25) VLAN offloads are missed when configured on top of a bridge, fix from Vlad Yasevich. 26) Support IPV6 in ping sockets. From Lorenzo Colitti. 27) Receive flow steering targets should be updated at poll() time too, from David Majnemer. 28) Fix several corner case regressions in PMTU/redirect handling due to the routing cache removal, from Timo Teräs. 29) We have to be mindful of ipv4 mapped ipv6 sockets in upd_v6_push_pending_frames(). From Hannes Frederic Sowa. 30) Fix L2TP sequence number handling bugs, from James Chapman." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits) drivers/net: caif: fix wrong rtnl_is_locked() usage drivers/net: enic: release rtnl_lock on error-path vhost-net: fix use-after-free in vhost_net_flush net: mv643xx_eth: do not use port number as platform device id net: sctp: confirm route during forward progress virtio_net: fix race in RX VQ processing virtio: support unlocked queue poll net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit Documentation: Fix references to defunct linux-net@vger.kernel.org net/fs: change busy poll time accounting net: rename low latency sockets functions to busy poll bridge: fix some kernel warning in multicast timer sfc: Fix memory leak when discarding scattered packets sit: fix tunnel update via netlink dt:net:stmmac: Add dt specific phy reset callback support. dt:net:stmmac: Add support to dwmac version 3.610 and 3.710 dt:net:stmmac: Allocate platform data only if its NULL. net:stmmac: fix memleak in the open method ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available net: ipv6: fix wrong ping_v6_sendmsg return value ...
2013-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual stuff from trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) treewide: relase -> release Documentation/cgroups/memory.txt: fix stat file documentation sysctl/net.txt: delete reference to obsolete 2.4.x kernel spinlock_api_smp.h: fix preprocessor comments treewide: Fix typo in printk doc: device tree: clarify stuff in usage-model.txt. open firmware: "/aliasas" -> "/aliases" md: bcache: Fixed a typo with the word 'arithmetic' irq/generic-chip: fix a few kernel-doc entries frv: Convert use of typedef ctl_table to struct ctl_table sgi: xpc: Convert use of typedef ctl_table to struct ctl_table doc: clk: Fix incorrect wording Documentation/arm/IXP4xx fix a typo Documentation/networking/ieee802154 fix a typo Documentation/DocBook/media/v4l fix a typo Documentation/video4linux/si476x.txt fix a typo Documentation/virtual/kvm/api.txt fix a typo Documentation/early-userspace/README fix a typo Documentation/video4linux/soc-camera.txt fix a typo lguest: fix CONFIG_PAE -> CONFIG_x86_PAE in comment ...
2013-07-04Merge branch 'kconfig-diet' from Dave HansenLinus Torvalds
Merge Kconfig menu diet patches from Dave Hansen: "I think the "Kernel Hacking" menu has gotten a bit out of hand. It is over 120 lines long on my system with everything enabled and options are scattered around it haphazardly. http://sr71.net/~dave/linux/kconfig-horror.png Let's try to introduce some sanity. This set takes that 120 lines down to 55 and makes it vastly easier to find some things. It's a start. This set stands on its own, but there is plenty of room for follow-up patches. The arch-specific debug options still end up getting stuck in the top-level "kernel hacking" menu. OPTIMIZE_INLINING, for instance, could obviously go in to the "compiler options" menu, but the fact that it is defined in arch/ in a separate Kconfig file keeps it on its own for the moment. The Signed-off-by's in here look funky. I changed employers while working on this set, so I have signoffs from both email addresses" * emailed patches from Dave Hansen <dave@sr71.net>: hang and lockup detection menu kconfig: consolidate printk options group locking debugging options consolidate compilation option configs consolidate runtime testing configs order memory debugging Kconfig options consolidate per-arch stack overflow debugging options
2013-07-04consolidate per-arch stack overflow debugging optionsDave Hansen
Original posting: http://lkml.kernel.org/r/20121214184202.F54094D9@kernel.stglabs.ibm.com Several architectures have similar stack debugging config options. They all pretty much do the same thing, some with slightly differing help text. This patch changes the architectures to instead enable a Kconfig boolean, and then use that boolean in the generic Kconfig.debug to present the actual menu option. This removes a bunch of duplication and adds consistency across arches. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [for tile] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03Merge branch 'akpm' (updates from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - various misc bits - I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been distracted. There has been quite a bit of activity. - About half the MM queue - Some backlight bits - Various lib/ updates - checkpatch updates - zillions more little rtc patches - ptrace - signals - exec - procfs - rapidio - nbd - aoe - pps - memstick - tools/testing/selftests updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits) tools/testing/selftests: don't assume the x bit is set on scripts selftests: add .gitignore for kcmp selftests: fix clean target in kcmp Makefile selftests: add .gitignore for vm selftests: add hugetlbfstest self-test: fix make clean selftests: exit 1 on failure kernel/resource.c: remove the unneeded assignment in function __find_resource aio: fix wrong comment in aio_complete() drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode drivers/memstick/host/r592.c: convert to module_pci_driver drivers/memstick/host/jmb38x_ms: convert to module_pci_driver pps-gpio: add device-tree binding and support drivers/pps/clients/pps-gpio.c: convert to module_platform_driver drivers/pps/clients/pps-gpio.c: convert to devm_* helpers drivers/parport/share.c: use kzalloc Documentation/accounting/getdelays.c: avoid strncpy in accounting tool aoe: update internal version number to v83 aoe: update copyright date aoe: perform I/O completions in parallel ...
2013-07-03arch/frv/kernel/setup.c: use strncmp() instead of memcmp()Chen Gang
'cmdline' is a NUL terminated string, when its length < 4, memcmp() will cause memory access out of boundary. So use strncmp() instead of memcmp(). Signed-off-by: Chen Gang <gang.chen@asianux.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03arch/frv/kernel/traps.c: using vsnprintf() instead of vsprintf()Chen Gang
Since die_if_kernel() is an extern common used function, better always check the buffer length to avoid memory overflow by a long 'str'. Signed-off-by: Chen Gang <gang.chen@asianux.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm/frv: prepare for removing num_physpages and simplify mem_init()Jiang Liu
Prepare for removing num_physpages and simplify mem_init(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: David Howells <dhowells@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: concentrate modification of totalram_pages into the mm coreJiang Liu
Concentrate code to modify totalram_pages into the mm core, so the arch memory initialized code doesn't need to take care of it. With these changes applied, only following functions from mm core modify global variable totalram_pages: free_bootmem_late(), free_all_bootmem(), free_all_bootmem_node(), adjust_managed_page_count(). With this patch applied, it will be much more easier for us to keep totalram_pages and zone->managed_pages in consistence. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: David Howells <dhowells@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: enhance free_reserved_area() to support poisoning memory with zeroJiang Liu
Address more review comments from last round of code review. 1) Enhance free_reserved_area() to support poisoning freed memory with pattern '0'. This could be used to get rid of poison_init_mem() on ARM64. 2) A previous patch has disabled memory poison for initmem on s390 by mistake, so restore to the original behavior. 3) Remove redundant PAGE_ALIGN() when calling free_reserved_area(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: change signature of free_reserved_area() to fix building warningsJiang Liu
Change signature of free_reserved_area() according to Russell King's suggestion to fix following build warnings: arch/arm/mm/init.c: In function 'mem_init': arch/arm/mm/init.c:603:2: warning: passing argument 1 of 'free_reserved_area' makes integer from pointer without a cast [enabled by default] free_reserved_area(__va(PHYS_PFN_OFFSET), swapper_pg_dir, 0, NULL); ^ In file included from include/linux/mman.h:4:0, from arch/arm/mm/init.c:15: include/linux/mm.h:1301:22: note: expected 'long unsigned int' but argument is of type 'void *' extern unsigned long free_reserved_area(unsigned long start, unsigned long end, mm/page_alloc.c: In function 'free_reserved_area': >> mm/page_alloc.c:5134:3: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast [enabled by default] In file included from arch/mips/include/asm/page.h:49:0, from include/linux/mmzone.h:20, from include/linux/gfp.h:4, from include/linux/mm.h:8, from mm/page_alloc.c:18: arch/mips/include/asm/io.h:119:29: note: expected 'const volatile void *' but argument is of type 'long unsigned int' mm/page_alloc.c: In function 'free_area_init_nodes': mm/page_alloc.c:5030:34: warning: array subscript is below array bounds [-Warray-bounds] Also address some minor code review comments. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reported-by: Arnd Bergmann <arnd@arndb.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03Merge branch 'exotic-arch-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull "exotic" arch fixes from Geert Uytterhoeven: "This is a collection of several exotic architecture fixes, and a few other fixes for issues that were detected while doing the former" * 'exotic-arch-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: (35 commits) lib: Move fonts from drivers/video/console/ to lib/fonts/ console/font: Refactor font support code selection logic Revert "staging/solo6x10: depend on CONFIG_FONTS" input: cros_ec_keyb_clear_keyboard() depends on CONFIG_PM_SLEEP score: Wire up asm-generic/xor.h score: Remove unneeded <asm/dma-mapping.h> openrisc: Wire up asm-generic/xor.h h8300/boot: Use POSIX "$((..))" instead of bashism "$[...]" h8300: Mark H83002 and H83048 CPU support broken h8300: Switch h8300 to drivers/Kconfig h8300: Limit timer channel ranges in Kconfig h8300: Wire up asm-generic/xor.h h8300: Fill the system call table using a CALL() macro h8300: Fix <asm/tlb.h> h8300: Hardcode symbol prefixes in asm sources h8300: add missing definition for read_barries_depends() frv: head.S - Remove commented-out initialization code cris: Wire up asm-generic/vga.h parport: disable PC-style parallel port support on cris console: Disable VGA text console support on cris ...
2013-07-02Merge branch 'sched-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull voluntary preemption fixes from Ingo Molnar: "This tree contains a speedup which is achieved through better might_sleep()/might_fault() preemption point annotations for uaccess functions, by Michael S Tsirkin: 1. The only reason uaccess routines might sleep is if they fault. Make this explicit for all architectures. 2. A voluntary preemption point in uaccess functions means compiler can't inline them efficiently, this breaks assumptions that they are very fast and small that e.g. net code seems to make. Remove this preemption point so behaviour matches with what callers assume. 3. Accesses (e.g through socket ops) to kernel memory with KERNEL_DS like net/sunrpc does will never sleep. Remove an unconditinal might_sleep() in the might_fault() inline in kernel.h (used when PROVE_LOCKING is not set). 4. Accesses with pagefault_disable() return EFAULT but won't cause caller to sleep. Check for that and thus avoid might_sleep() when PROVE_LOCKING is set. These changes offer a nice speedup for CONFIG_PREEMPT_VOLUNTARY=y kernels, here's a network bandwidth measurement between a virtual machine and the host: before: incoming: 7122.77 Mb/s outgoing: 8480.37 Mb/s after: incoming: 8619.24 Mb/s [ +21.0% ] outgoing: 9455.42 Mb/s [ +11.5% ] I kept these changes in a separate tree, separate from scheduler changes, because it's a mixed MM and scheduler topic" * 'sched-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: mm, sched: Allow uaccess in atomic with pagefault_disable() mm, sched: Drop voluntary schedule from might_fault() x86: uaccess s/might_sleep/might_fault/ tile: uaccess s/might_sleep/might_fault/ powerpc: uaccess s/might_sleep/might_fault/ mn10300: uaccess s/might_sleep/might_fault/ microblaze: uaccess s/might_sleep/might_fault/ m32r: uaccess s/might_sleep/might_fault/ frv: uaccess s/might_sleep/might_fault/ arm64: uaccess s/might_sleep/might_fault/ asm-generic: uaccess s/might_sleep/might_fault/
2013-06-29consolidate io_remap_pfn_range definitionsAl Viro
2013-06-17net: add socket option for low latency pollingEliezer Tamir
adds a socket option for low latency polling. This allows overriding the global sysctl value with a per-socket one. Unexport sysctl_net_ll_poll since for now it's not needed in modules. Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-16frv: head.S - Remove commented-out initialization codeGeert Uytterhoeven
The commented-out calls to processor_init() and unit_init() seem to have been copied from mn10300, when starting the frv port. Remove them. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-06-14frv: Convert use of typedef ctl_table to struct ctl_tableJoe Perches
This typedef is unnecessary and should just be removed. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
