path: root/arch/frv/mb93090-mb00
2006-07-10[PATCH] FRV: Fix FRV arch compile errorsDavid Howells
Fix some FRV arch compile errors, including: (*) Marking nr_kernel_pages as __meminitdata so that references to it end up being properly calculated rather than being assumed to be in the small data section (and thus calculated wrt the GP register). Not doing this causes the linker to emit errors as the offset is too big to fit into the load instruction. (*) Move pm_power_off into an unconditionally compiled .c file as it's now unconditionally accessed. (*) Declare frv_change_cmode() in a header file rather than in a .c file, and declare it asmlinkage. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit resource: change pci core and arch code to use resource_size_tGreg Kroah-Hartman
Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-23[PATCH] frv: misc sparse annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] PCI: arch: pci_find_device remove (frv/mb93090-mb00/pci-irq.c)Jiri Slaby
Signed-off-by: Jiri Slaby <xslaby@fi.muni.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI: pci_find_device remove (frv/mb93090-mb00/pci-frv.c)Jiri Slaby
2006-01-08[PATCH] frv: add pci_iomapDavid Howells
Implement pci_iomap() for FRV. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] frv: implement and export various things required by modulesDavid Howells
Export a number of features required to build all the modules. It also implements the following simple features: (*) csum_partial_copy_from_user() for MMU as well as no-MMU. (*) __ucmpdi2(). so that they can be exported too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-28[PATCH] FRV: Make the FRV arch work againDavid Howells
The attached patch implements a bunch of small changes to the FRV arch to make it work again. It deals with the following problems: (1) SEM_DEBUG should be SEMAPHORE_DEBUG. (2) The argument list to pcibios_penalize_isa_irq() has changed. (3) CONFIG_HIGHMEM can't be used directly in #if as it may not be defined. (4) page->private is no longer directly accessible. (5) linux/hardirq.h assumes asm/hardirq.h will include linux/irq.h (6) The IDE MMIO access functions are given pointers, not integers, and so get type casting errors. (7) __pa() is passed an explicit u64 type in drivers/char/mem.c, but that can't be cast directly to a pointer on a 32-bit platform. (8) SEMAPHORE_DEBUG should not be contingent on WAITQUEUE_DEBUG as that no longer exists. (9) PREEMPT_ACTIVE is too low a value. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: dma-mapping (frv)Al Viro
2005-07-12[ACPI] PNPACPI vs sound IRQDavid Shaohua Li
http://bugme.osdl.org/show_bug.cgi?id=4016 Written-by: David Shaohua Li <shaohua.li@intel.com> Acked-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com>
