* 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (165 commits)
reiserfs: Properly display mount options in /proc/mounts
vfs: prevent remount read-only if pending removes
vfs: count unlinked inodes
vfs: protect remounting superblock read-only
vfs: keep list of mounts for each superblock
vfs: switch ->show_options() to struct dentry *
vfs: switch ->show_path() to struct dentry *
vfs: switch ->show_devname() to struct dentry *
vfs: switch ->show_stats to struct dentry *
switch security_path_chmod() to struct path *
vfs: prefer ->dentry->d_sb to ->mnt->mnt_sb
vfs: trim includes a bit
switch mnt_namespace ->root to struct mount
vfs: take /proc/*/mounts and friends to fs/proc_namespace.c
vfs: opencode mntget() mnt_set_mountpoint()
vfs: spread struct mount - remaining argument of next_mnt()
vfs: move fsnotify junk to struct mount
vfs: move mnt_devname
vfs: move mnt_list to struct mount
vfs: switch pnode.h macros to struct mount *
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1958 commits)
net: pack skb_shared_info more efficiently
net_sched: red: split red_parms into parms and vars
net_sched: sfq: extend limits
cnic: Improve error recovery on bnx2x devices
cnic: Re-init dev->stats_addr after chip reset
net_sched: Bug in netem reordering
bna: fix sparse warnings/errors
bna: make ethtool_ops and strings const
xgmac: cleanups
net: make ethtool_ops const
vmxnet3" make ethtool ops const
xen-netback: make ops structs const
virtio_net: Pass gfp flags when allocating rx buffers.
ixgbe: FCoE: Add support for ndo_get_fcoe_hbainfo() call
netdev: FCoE: Add new ndo_get_fcoe_hbainfo() call
igb: reset PHY after recovering from PHY power down
igb: add basic runtime PM support
igb: Add support for byte queue limits.
e1000: cleanup CE4100 MDIO registers access
e1000: unmap ce4100_gbe_mdio_base_virt in e1000_remove
... some still remain weird :-/
git://git.linaro.org/people/jstultz/linux into timers/core
This converts the cris architecture to use clocksource_register_khz
This is untested, so any help from maintainers would be appreciated.
CC: Mikael Starvik <starvik@axis.com>
CC: Jesper Nilsson <jesper.nilsson@axis.com>
CC: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: John Stultz <johnstul@us.ibm.com>
The forcedeth changes had a conflict with the conversion over
to atomic u64 statistics in net-next.
The libertas cfg.c code had a conflict with the bss reference
counting fix by John Linville in net-next.
drivers/net/ethernet/nvidia/forcedeth.c
drivers/net/wireless/libertas/cfg.c
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
include/net/bluetooth/bluetooth.h
Change them over to plain "ETHERNET"
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
The 802.1X EAPOL handshake hostapd does requires
knowing whether the frame was ack'ed by the peer.
Currently, we fudge this pretty badly by not even
transmitting the frame as a normal data frame but
injecting it with radiotap and getting the status
out of radiotap monitor as well. This is rather
complex, confuses users (mon.wlan0 presence) and
doesn't work with all hardware.
To get rid of that hack, introduce a real wifi TX
status option for data frame transmissions.
This works similar to the existing TX timestamping
in that it reflects the SKB back to the socket's
error queue with a SCM_WIFI_STATUS cmsg that has
an int indicating ACK status (0/1).
Since it is possible that at some point we will
want to have TX timestamping and wifi status in a
single errqueue SKB (there's little point in not
doing that), redefine SO_EE_ORIGIN_TIMESTAMPING
to SO_EE_ORIGIN_TXSTATUS which can collect more
than just the timestamp; keep the old constant
as an alias of course. Currently the internal APIs
don't make that possible, but it wouldn't be hard
to split them up in a way that makes it possible.
Thanks to Neil Horman for helping me figure out
the functions that add the control messages.
* git://git.infradead.org/mtd-2.6: (226 commits)
mtd: tests: annotate as DANGEROUS in Kconfig
mtd: tests: don't use mtd0 as a default
mtd: clean up usage of MTD_DOCPROBE_ADDRESS
jffs2: add compr=lzo and compr=zlib options
jffs2: implement mount option parsing and compression overriding
mtd: nand: initialize ops.mode
mtd: provide an alias for the redboot module name
mtd: m25p80: don't probe device which has status of 'disabled'
mtd: nand_h1900 never worked
mtd: Add DiskOnChip G3 support
mtd: m25p80: add EON flash EN25Q32B into spi flash id table
mtd: mark block device queue as non-rotational
mtd: r852: make r852_pm_ops static
mtd: m25p80: add support for at25df321a spi data flash
mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks
mtd: nand: switch `check_pattern()' to standard `memcmp()'
mtd: nand: invalidate cache on unaligned reads
mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set
mtd: nand: wait to set BBT version
mtd: nand: scrub BBT on ECC errors
Fix up trivial conflicts:
- arch/arm/mach-at91/board-usb-a9260.c
Merged into board-usb-a926x.c
- drivers/mtd/maps/lantiq-flash.c
add_mtd_partitions -> mtd_device_register vs changed to use
mtd_device_parse_register.
There is no functional change.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Jason Wessel <jason.wessel@windriver.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits)
dp83640: free packet queues on remove
dp83640: use proper function to free transmit time stamping packets
ipv6: Do not use routes from locally generated RAs
|PATCH net-next] tg3: add tx_dropped counter
be2net: don't create multiple RX/TX rings in multi channel mode
be2net: don't create multiple TXQs in BE2
be2net: refactor VF setup/teardown code into be_vf_setup/clear()
be2net: add vlan/rx-mode/flow-control config to be_setup()
net_sched: cls_flow: use skb_header_pointer()
ipv4: avoid useless call of the function check_peer_pmtu
TCP: remove TCP_DEBUG
net: Fix driver name for mdio-gpio.c
ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT
rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces
ipv4: fix ipsec forward performance regression
jme: fix irq storm after suspend/resume
route: fix ICMP redirect validation
net: hold sock reference while processing tx timestamps
tcp: md5: add more const attributes
Add ethtool -g support to virtio_net
Fix up conflicts in:
- drivers/net/Kconfig:
The split-up generated a trivial conflict with removal of a
stale reference to Documentation/networking/net-modules.txt.
Remove it from the new location instead.
- fs/sysfs/dir.c:
Fairly nasty conflicts with the sysfs rb-tree usage, conflicting
with Eric Biederman's changes for tagged directories.
Commit 3f50c0673cf5edd2c6bb76243410c3cd59b3b62d ("CRIS v32: Update
boot/rescue/head.S code") removed the last reference to that file. So
this file is unused since v2.6.25.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
This patch fixes file references to moved or deleted files
outside of Documentation/.
Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net>
MAINTAINERS
drivers/net/Kconfig
drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c
drivers/net/ethernet/broadcom/tg3.c
drivers/net/wireless/iwlwifi/iwl-pci.c
drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c
drivers/net/wireless/rt2x00/rt2800usb.c
drivers/net/wireless/wl12xx/main.c
MII Kconfig option is apart of the core networking drivers and
by default NET_CORE is enabled so drivers selecting MII will
have MII enabled as well. It was found using the randconfig
option during testing, MII would be selected but NET_CORE
could be disabled. This caused a dependency error.
Resolved the dependency by selecting NET_CORE when MII is
selected.
Reported-by: Emil Tantilov <emil.s.tantilov@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
Recall the recently added prefix requirements:
* "NAND_" for flags in nand.h, used in nand_chip.options
* "NAND_BBT_" for flags in bbm.h, used in nand_chip.bbt_options
or in nand_bbt_descr.options
Thus, I am changing NAND_USE_FLASH_BBT to NAND_BBT_USE_FLASH.
Again, this flag is found in bbm.h and so should NOT be used in the
"nand_chip.options" field.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
This patch works with the following three flags from two headers (nand.h
and bbm.h):
(1) NAND_USE_FLASH_BBT (nand.h)
(2) NAND_USE_FLASH_BBT_NO_OOB (nand.h)
(3) NAND_BBT_NO_OOB (bbm.h)
These flags are all related and interdependent, yet they were in
different headers. Flag (2) is simply the combination of (1) and (3) and
can be eliminated.
This patch accomplishes the following:
* eliminate NAND_USE_FLASH_BBT_NO_OOB (i.e., flag (2))
* move NAND_USE_FLASH_BBT (i.e., flag (1)) to bbm.h
It's important to note that because (1) and (3) are now both found in
bbm.h, they should NOT be used in the "nand_chip.options" field.
I removed a small section from the mtdnand DocBook because it referes to
NAND_USE_FLASH_BBT in nand.h, which has been moved to bbm.h.
The nfsservctl system call is now gone, so we should remove all
linkage for it.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Fix the following build errors:
drivers/tty/serial/8250_early.c:160: error: 'BASE_BAUD' undeclared (first use in this function): 1 errors in 1 logs
drivers/tty/serial/8250_early.c:37:24: error: asm/serial.h: No such file or directory: 1 errors in 1 logs
I am not sure if (1843200 / 16) is suitable for cris, but most other
arch's define it as this value.
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Fix:
arch/cris/arch-v10/kernel/irq.c:239: error: implicit declaration of function 'kgdb_init'
arch/cris/arch-v10/kernel/irq.c:240: error: implicit declaration of function 'breakpoint'
Declare these two functions.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: <stable@kernel.org>
Fix:
arch/cris/arch-v10/drivers/sync_serial.c:961: error: conflicting types for 'sync_serial_ioctl'
Fix:
arch/cris/arch-v10/drivers/sync_serial.c:628: error: 'ret' undeclared (first use in this function)
'ret' should be 'err'.
Fix this error:
kernel/fork.c:267: error: implicit declaration of function 'alloc_thread_info_node'
This is due to renaming alloc_thread_info() to alloc_thread_info_node().
After changing all consumers of atomics to include <linux/atomic.h>, we
ran into some compile time errors due to this dependency chain:
linux/atomic.h
-> asm/atomic.h
-> asm-generic/atomic-long.h
where atomic-long.h could use funcs defined later in linux/atomic.h
without a prototype. This patches moves the code that includes
asm-generic/atomic*.h to linux/atomic.h.
Archs that need <asm-generic/atomic64.h> need to select
CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it
unconditionally).
Compile tested on i386 and x86_64 with allnoconfig.
Signed-off-by: Arun Sharma <asharma@fb.com>
This is in preparation for more generic atomic primitives based on
__atomic_add_unless.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
The majority of architectures implement ext2 atomic bitops as
test_and_{set,clear}_bit() without spinlock.
This adds this type of generic implementation in ext2-atomic-setbit.h and
use it wherever possible.
Suggested-by: Andreas Dilger <adilger@dilger.ca>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ]
Cc: Tejun Heo <tj@kernel.org>
The address limit is already set in flush_old_exec() so those calls to
set_fs(USER_DS) are redundant.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Fix some harmless warnings such as
arch/cris/arch-v32/mach-a3/pinmux.c:273: warning: ISO C90 forbids mixed declarations and code:
This patch removes all the module loader hook implementations in the
architecture specific code where the functionality is the same as that
now provided by the recently added default hooks.
Signed-off-by: Jonas Bonn <jonas@southpole.se>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Michal Simek <monstr@monstr.eu>
* setns:
ns: Wire up the setns system call
Done as a merge to make it easier to fix up conflicts in arm due to
addition of sendmmsg system call
32bit and 64bit on x86 are tested and working. The rest I have looked
at closely and I can't find any problems.
setns is an easy system call to wire up. It just takes two ints so I
don't expect any weird architecture porting problems.
While doing this I have noticed that we have some architectures that are
very slow to get new system calls. cris seems to be the slowest where
the last system calls wired up were preadv and pwritev. avr32 is weird
in that recvmmsg was wired up but never declared in unistd.h. frv is
behind with perf_event_open being the last syscall wired up. On h8300
the last system call wired up was epoll_wait. On m32r the last system
call wired up was fallocate. mn10300 has recvmmsg as the last system
call wired up. The rest seem to at least have syncfs wired up which was
new in the 2.6.39.
v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com>
v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com>
v4: Moved wiring up of the system call to another patch
v5: ported to v2.6.39-rc6
v6: rebased onto parisc-next and net-next to avoid syscall conflicts.
v7: ported to Linus's latest post 2.6.39 tree.
> arch/blackfin/include/asm/unistd.h | 3 ++-
> arch/blackfin/mach-common/entry.S | 1 +
Oh - ia64 wiring looks good.
Acked-by: Tony Luck <tony.luck@intel.com>
* git://git.infradead.org/mtd-2.6: (97 commits)
mtd: kill CONFIG_MTD_PARTITIONS
mtd: remove add_mtd_partitions, add_mtd_device and friends
mtd: convert remaining users to mtd_device_register()
mtd: samsung onenand: convert to mtd_device_register()
mtd: omap2 onenand: convert to mtd_device_register()
mtd: txx9ndfmc: convert to mtd_device_register()
mtd: tmio_nand: convert to mtd_device_register()
mtd: socrates_nand: convert to mtd_device_register()
mtd: sharpsl: convert to mtd_device_register()
mtd: s3c2410 nand: convert to mtd_device_register()
mtd: ppchameleonevb: convert to mtd_device_register()
mtd: orion_nand: convert to mtd_device_register()
mtd: omap2: convert to mtd_device_register()
mtd: nomadik_nand: convert to mtd_device_register()
mtd: ndfc: convert to mtd_device_register()
mtd: mxc_nand: convert to mtd_device_register()
mtd: mpc5121_nfc: convert to mtd_device_register()
mtd: jz4740_nand: convert to mtd_device_register()
mtd: h1910: convert to mtd_device_register()
mtd: fsmc_nand: convert to mtd_device_register()
Fixed up trivial conflicts in
- drivers/mtd/maps/integrator-flash.c: removed in ARM tree
- drivers/mtd/maps/physmap.c: addition of afs partition probe type
clashing with removal of CONFIG_MTD_PARTITIONS
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT,
CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used
to test for existence of find bitops anymore.
Acked-by: Greg Ungerer <gerg@uclinux.org>
Adapt to the new API.
Cc: Thiago Farina <tfransosi@gmail.com>
Fold all the mmu_gather rework patches into one for submission
Reported-by: Hugh Dickins <hughd@google.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS
preprocessor conditionals as partitioning is always available.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: Unify input section names
percpu: Avoid extra NOP in percpu_cmpxchg16b_double
percpu: Cast away printk format warning
percpu: Always align percpu output section to PAGE_SIZE
Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
Signed-off-by: Sarah Nadi <snadi@uwaterloo.ca>
For future rework of try_to_wake_up() we'd like to push part of that
function onto the CPU the task is actually going to run on.
In order to do so we need a generic callback from the existing scheduler IPI.
This patch introduces such a generic callback: scheduler_ipi() and
implements it as a NOP.
BenH notes: PowerPC might use this IPI on offline CPUs under rare conditions!
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Reviewed-by: Frank Rowand <frank.rowand@am.sony.com>
Link: http://lkml.kernel.org/r/20110405152728.744338123@chello.nl
* 'for-linus' of git://www.jni.nu/cris:
Correct auto-restart of syscalls via restartblock
CRISv10: Fix return before mutex_unlock in pcf8563
Drop the CRISv32 version of pcf8563
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus-1
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6: (9356 commits)
[media] rc: update for bitop name changes
fs: simplify iget & friends
fs: pull inode->i_lock up out of writeback_single_inode
fs: rename inode_lock to inode_hash_lock
fs: move i_wb_list out from under inode_lock
fs: move i_sb_list out from under inode_lock
fs: remove inode_lock from iput_final and prune_icache
fs: Lock the inode LRU list separately
fs: factor inode disposal
fs: protect inode->i_state with inode->i_lock
lib, arch: add filter argument to show_mem and fix private implementations
SLUB: Write to per cpu data when allocating it
slub: Fix debugobjects with lockless fastpath
autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd()
autofs4 - remove autofs4_lock
autofs4 - fix d_manage() return on rcu-walk
autofs4 - fix autofs4_expire_indirect() traversal
autofs4 - fix dentry leak in autofs4_expire_direct()
autofs4 - reinstate last used update on access
vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
NOTE!
This merge commit was created to fix compilation error. The block
tree was merged upstream and removed the 'elv_queue_empty()'
function which the new 'mtdswap' driver is using. So a simple
merge of the mtd tree with upstream does not compile. And the
mtd tree has already be published, so re-basing it is not an option.
To fix this unfortunate situation, I had to merge upstream into the
mtd-2.6.git tree without committing, put the fixup patch on top of
this, and then commit this. The result is that we do not have commits
which do not compile.
In other words, this merge commit "merges" 3 things: the MTD tree, the
upstream tree, and the fixup patch.
Percpu allocator honors alignment request upto PAGE_SIZE and both the
percpu addresses in the percpu address space and the translated kernel
addresses should be aligned accordingly. The calculation of the
former depends on the alignment of percpu output section in the kernel
image.
The linker script macros PERCPU_VADDR() and PERCPU() are used to
define this output section and the latter takes @align parameter.
Several architectures are using @align smaller than PAGE_SIZE breaking
percpu memory alignment.
This patch removes @align parameter from PERCPU(), renames it to
PERCPU_SECTION() and makes it always align to PAGE_SIZE. While at it,
add PCPU_SETUP_BUG_ON() checks such that alignment problems are
reliably detected and remove percpu alignment comment recently added
in workqueue.c as the condition would trigger BUG way before reaching
there.
For um, this patch raises the alignment of percpu area. As the area
is in .init, there shouldn't be any noticeable difference.
This problem was discovered by David Howells while debugging boot
failure on mn10300.
Cc: uclinux-dist-devel@blackfin.uclinux.org
Cc: user-mode-linux-devel@lists.sourceforge.net
