path: root/arch/cris
2015-04-29vm: add VM_FAULT_SIGSEGV handling supportLinus Torvalds
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream. The core VM already knows about VM_FAULT_SIGBUS, but cannot return a "you should SIGSEGV" error, because the SIGSEGV case was generally handled by the caller - usually the architecture fault handler. That results in lots of duplication - all the architecture fault handlers end up doing very similar "look up vma, check permissions, do retries etc" - but it generally works. However, there are cases where the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV. In particular, when accessing the stack guard page, libsigsegv expects a SIGSEGV. And it usually got one, because the stack growth is handled by that duplicated architecture fault handler. However, when the generic VM layer started propagating the error return from the stack expansion in commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page"), that now exposed the existing VM_FAULT_SIGBUS result to user space. And user space really expected SIGSEGV, not SIGBUS. To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those duplicate architecture fault handlers about it. They all already have the code to handle SIGSEGV, so it's about just tying that new return value to the existing code, but it's all a bit annoying. This is the mindless minimal patch to do this. A more extensive patch would be to try to gather up the mostly shared fault handling logic into one generic helper routine, and long-term we really should do that cleanup. Just from this patch, you can generally see that most architectures just copied (directly or indirectly) the old x86 way of doing things, but in the meantime that original x86 model has been improved to hold the VM semaphore for shorter times etc and to handle VM_FAULT_RETRY and other "newer" things, so it would be a good idea to bring all those improvements to the generic case and teach other architectures about them too. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [shengyong: Backport to 3.10 - adjust context - ignore modification for arch nios2, because 3.10 does not support it - ignore modification for driver lustre, because 3.10 does not support it - ignore VM_FAULT_FALLBACK in VM_FAULT_ERROR, becase 3.10 does not support this flag - add SIGSEGV handling to powerpc/cell spu_fault.c, because 3.10 does not separate it to copro_fault.c - add SIGSEGV handling in mm/memory.c, because 3.10 does not separate it to gup.c ] Signed-off-by: Sheng Yong <shengyong1@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21arch: mm: pass userspace fault flag to generic fault handlerJohannes Weiner
commit 759496ba6407c6994d6a5ce3a5e74937d7816208 upstream. Unlike global OOM handling, memory cgroup code will invoke the OOM killer in any OOM situation because it has no way of telling faults occuring in kernel context - which could be handled more gracefully - from user-triggered faults. Pass a flag that identifies faults originating in user space from the architecture-specific fault handlers to generic code so that memcg OOM handling can be improved. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29cris: media platform drivers: fix buildMauro Carvalho Chehab
commit 72a0c5571351f5184195754d23db3e14495b2080 upstream. On cris arch, the functions below aren't defined: drivers/media/platform/sh_veu.c: In function 'sh_veu_reg_read': drivers/media/platform/sh_veu.c:228:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration] drivers/media/platform/sh_veu.c: In function 'sh_veu_reg_write': drivers/media/platform/sh_veu.c:234:2: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration] drivers/media/platform/vsp1/vsp1.h: In function 'vsp1_read': drivers/media/platform/vsp1/vsp1.h:66:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration] drivers/media/platform/vsp1/vsp1.h: In function 'vsp1_write': drivers/media/platform/vsp1/vsp1.h:71:2: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration] drivers/media/platform/vsp1/vsp1.h: In function 'vsp1_read': drivers/media/platform/vsp1/vsp1.h:66:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration] drivers/media/platform/vsp1/vsp1.h: In function 'vsp1_write': drivers/media/platform/vsp1/vsp1.h:71:2: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration] drivers/media/platform/soc_camera/rcar_vin.c: In function 'rcar_vin_setup': drivers/media/platform/soc_camera/rcar_vin.c:284:3: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration] drivers/media/platform/soc_camera/rcar_vin.c: In function 'rcar_vin_request_capture_stop': drivers/media/platform/soc_camera/rcar_vin.c:353:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration] Yet, they're available, as CONFIG_GENERIC_IOMAP is defined. What happens is that asm/io.h was not including asm-generic/iomap.h. Suggested-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-09Merge tag 'for-linus-20130509' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD update from David Woodhouse: - Lots of cleanups from Artem, including deletion of some obsolete drivers - Support partitions larger than 4GiB in device tree - Support for new SPI chips * tag 'for-linus-20130509' of git://git.infradead.org/linux-mtd: (83 commits) mtd: omap2: Use module_platform_driver() mtd: bf5xx_nand: Use module_platform_driver() mtd: denali_dt: Remove redundant use of of_match_ptr mtd: denali_dt: Change return value to fix smatch warning mtd: denali_dt: Use module_platform_driver() mtd: denali_dt: Fix incorrect error check mtd: nand: subpage write support for hardware based ECC schemes mtd: omap2: use msecs_to_jiffies() mtd: nand_ids: use size macros mtd: nand_ids: improve LEGACY_ID_NAND macro a bit mtd: add 4 Toshiba nand chips for the full-id case mtd: add the support to parse out the full-id nand type mtd: add new fields to nand_flash_dev{} mtd: sh_flctl: Use of_match_ptr() macro mtd: gpio: Use of_match_ptr() macro mtd: gpio: Use devm_kzalloc() mtd: davinci_nand: Use of_match_ptr() mtd: dataflash: Use of_match_ptr() macro mtd: remove h720x flash support mtd: onenand: remove OneNAND simulator ...
2013-05-07proc: Use PDE attribute setting accessor functionsGeert Uytterhoeven
arch/arm/mach-msm/last_radio_log.c: In function 'msm_init_last_radio_log': arch/arm/mach-msm/last_radio_log.c:69:7: error: dereferencing pointer to incomplete type arch/cris/kernel/profile.c: In function 'init_cris_profile': arch/cris/kernel/profile.c:79:8: error: dereferencing pointer to incomplete type Use proc_set_size(), cfr. commit 271a15eabe094538d958dc68ccfc9c36b699247a ("proc: Supply PDE attribute setting accessor functions") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-05cris: single_open() leaksAl Viro
Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull compat cleanup from Al Viro: "Mostly about syscall wrappers this time; there will be another pile with patches in the same general area from various people, but I'd rather push those after both that and vfs.git pile are in." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: syscalls.h: slightly reduce the jungles of macros get rid of union semop in sys_semctl(2) arguments make do_mremap() static sparc: no need to sign-extend in sync_file_range() wrapper ppc compat wrappers for add_key(2) and request_key(2) are pointless x86: trim sys_ia32.h x86: sys32_kill and sys32_mprotect are pointless get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC merge compat sys_ipc instances consolidate compat lookup_dcookie() convert vmsplice to COMPAT_SYSCALL_DEFINE switch getrusage() to COMPAT_SYSCALL_DEFINE switch epoll_pwait to COMPAT_SYSCALL_DEFINE convert sendfile{,64} to COMPAT_SYSCALL_DEFINE switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect make HAVE_SYSCALL_WRAPPERS unconditional consolidate cond_syscall and SYSCALL_ALIAS declarations teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long get rid of duplicate logics in __SC_....[1-6] definitions
2013-04-30Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge third batch of fixes from Andrew Morton: "Most of the rest. I still have two large patchsets against AIO and IPC, but they're a bit stuck behind other trees and I'm about to vanish for six days. - random fixlets - inotify - more of the MM queue - show_stack() cleanups - DMI update - kthread/workqueue things - compat cleanups - epoll udpates - binfmt updates - nilfs2 - hfs - hfsplus - ptrace - kmod - coredump - kexec - rbtree - pids - pidns - pps - semaphore tweaks - some w1 patches - relay updates - core Kconfig changes - sysrq tweaks" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (109 commits) Documentation/sysrq: fix inconstistent help message of sysrq key ethernet/emac/sysrq: fix inconstistent help message of sysrq key sparc/sysrq: fix inconstistent help message of sysrq key powerpc/xmon/sysrq: fix inconstistent help message of sysrq key ARM/etm/sysrq: fix inconstistent help message of sysrq key power/sysrq: fix inconstistent help message of sysrq key kgdb/sysrq: fix inconstistent help message of sysrq key lib/decompress.c: fix initconst notifier-error-inject: fix module names in Kconfig kernel/sys.c: make prctl(PR_SET_MM) generally available UAPI: remove empty Kbuild files menuconfig: print more info for symbol without prompts init/Kconfig: re-order CONFIG_EXPERT options to fix menuconfig display kconfig menu: move Virtualization drivers near other virtualization options Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKS relay: use macro PAGE_ALIGN instead of FIX_SIZE kernel/relay.c: move FIX_SIZE macro into relay.c kernel/relay.c: remove unused function argument actor drivers/w1/slaves/w1_ds2760.c: fix the error handling in w1_ds2760_add_slave() drivers/w1/slaves/w1_ds2781.c: fix the error handling in w1_ds2781_add_slave() ...
2013-04-30dump_stack: unify debug information printed by show_regs()Tejun Heo
show_regs() is inherently arch-dependent but it does make sense to print generic debug information and some archs already do albeit in slightly different forms. This patch introduces a generic function to print debug information from show_regs() so that different archs print out the same information and it's much easier to modify what's printed. show_regs_print_info() prints out the same debug info as dump_stack() does plus task and thread_info pointers. * Archs which didn't print debug info now do. alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r, metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc, um, xtensa * Already prints debug info. Replaced with show_regs_print_info(). The printed information is superset of what used to be there. arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86 * s390 is special in that it used to print arch-specific information along with generic debug info. Heiko and Martin think that the arch-specific extra isn't worth keeping s390 specfic implementation. Converted to use the generic version. Note that now all archs print the debug info before actual register dumps. An example BUG() dump follows. kernel BUG at /work/os/work/kernel/workqueue.c:4841! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000 RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6 RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246 RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650 0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760 Call Trace: [<ffffffff81000312>] do_one_initcall+0x122/0x170 [<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8 [<ffffffff81c47760>] ? rest_init+0x140/0x140 [<ffffffff81c4776e>] kernel_init+0xe/0xf0 [<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0 [<ffffffff81c47760>] ? rest_init+0x140/0x140 ... v2: Typo fix in x86-32. v3: CPU number dropped from show_regs_print_info() as dump_stack_print_info() has been updated to print it. s390 specific implementation dropped as requested by s390 maintainers. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30dump_stack: consolidate dump_stack() implementations and unify their behaviorsTejun Heo
Both dump_stack() and show_stack() are currently implemented by each architecture. show_stack(NULL, NULL) dumps the backtrace for the current task as does dump_stack(). On some archs, dump_stack() prints extra information - pid, utsname and so on - in addition to the backtrace while the two are identical on other archs. The usages in arch-independent code of the two functions indicate show_stack(NULL, NULL) should print out bare backtrace while dump_stack() is used for debugging purposes when something went wrong, so it does make sense to print additional information on the task which triggered dump_stack(). There's no reason to require archs to implement two separate but mostly identical functions. It leads to unnecessary subtle information. This patch expands the dummy fallback dump_stack() implementation in lib/dump_stack.c such that it prints out debug information (taken from x86) and invokes show_stack(NULL, NULL) and drops arch-specific dump_stack() implementations in all archs except blackfin. Blackfin's dump_stack() does something wonky that I don't understand. Debug information can be printed separately by calling dump_stack_print_info() so that arch-specific dump_stack() implementation can still emit the same debug information. This is used in blackfin. This patch brings the following behavior changes. * On some archs, an extra level in backtrace for show_stack() could be printed. This is because the top frame was determined in dump_stack() on those archs while generic dump_stack() can't do that reliably. It can be compensated by inlining dump_stack() but not sure whether that'd be necessary. * Most archs didn't use to print debug info on dump_stack(). They do now. An example WARN dump follows. WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505() Hardware name: empty Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9 0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48 ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c 0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58 Call Trace: [<ffffffff81c614dc>] dump_stack+0x19/0x1b [<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20 [<ffffffff8234a071>] init_workqueues+0x35/0x505 ... v2: CPU number added to the generic debug info as requested by s390 folks and dropped the s390 specific dump_stack(). This loses %ksp from the debug message which the maintainers think isn't important enough to keep the s390-specific dump_stack() implementation. dump_stack_print_info() is moved to kernel/printk.c from lib/dump_stack.c. Because linkage is per objecct file, dump_stack_print_info() living in the same lib file as generic dump_stack() means that archs which implement custom dump_stack() - at this point, only blackfin - can't use dump_stack_print_info() as that will bring in the generic version of dump_stack() too. v1 The v1 patch broke build on blackfin due to this issue. The build breakage was reported by Fengguang Wu. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits] Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge tag 'pm+acpi-3.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI updates from Rafael J Wysocki: - ARM big.LITTLE cpufreq driver from Viresh Kumar. - exynos5440 cpufreq driver from Amit Daniel Kachhap. - cpufreq core cleanup and code consolidation from Viresh Kumar and Stratos Karafotis. - cpufreq scalability improvement from Nathan Zimmer. - AMD "frequency sensitivity feedback" powersave bias for the ondemand cpufreq governor from Jacob Shin. - cpuidle code consolidation and cleanups from Daniel Lezcano. - ARM OMAP cpuidle fixes from Santosh Shilimkar and Daniel Lezcano. - ACPICA fixes and other improvements from Bob Moore, Jung-uk Kim, Lv Zheng, Yinghai Lu, Tang Chen, Colin Ian King, and Linn Crosetto. - ACPI core updates related to hotplug from Toshi Kani, Paul Bolle, Yasuaki Ishimatsu, and Rafael J Wysocki. - Intel Lynxpoint LPSS (Low-Power Subsystem) support improvements from Rafael J Wysocki and Andy Shevchenko. * tag 'pm+acpi-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (192 commits) cpufreq: Revert incorrect commit 5800043 cpufreq: MAINTAINERS: Add co-maintainer cpuidle: add maintainer entry ACPI / thermal: do not always return THERMAL_TREND_RAISING for active trip points ARM: s3c64xx: cpuidle: use init/exit common routine cpufreq: pxa2xx: initialize variables ACPI: video: correct acpi_video_bus_add error processing SH: cpuidle: use init/exit common routine ARM: S5pv210: compiling issue, ARM_S5PV210_CPUFREQ needs CONFIG_CPU_FREQ_TABLE=y ACPI: Fix wrong parameter passed to memblock_reserve cpuidle: fix comment format pnp: use %*phC to dump small buffers isapnp: remove debug leftovers ARM: imx: cpuidle: use init/exit common routine ARM: davinci: cpuidle: use init/exit common routine ARM: kirkwood: cpuidle: use init/exit common routine ARM: calxeda: cpuidle: use init/exit common routine ARM: tegra: cpuidle: use init/exit common routine for tegra3 ARM: tegra: cpuidle: use init/exit common routine for tegra2 ARM: OMAP4: cpuidle: use init/exit common routine ...
2013-04-30Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull SMP/hotplug changes from Ingo Molnar: "This is a pretty large, multi-arch series unifying and generalizing the various disjunct pieces of idle routines that architectures have historically copied from each other and have grown in random, wildly inconsistent and sometimes buggy directions: 101 files changed, 455 insertions(+), 1328 deletions(-) this went through a number of review and test iterations before it was committed, it was tested on various architectures, was exposed to linux-next for quite some time - nevertheless it might cause problems on architectures that don't read the mailing lists and don't regularly test linux-next. This cat herding excercise was motivated by the -rt kernel, and was brought to you by Thomas "the Whip" Gleixner." * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) idle: Remove GENERIC_IDLE_LOOP config switch um: Use generic idle loop ia64: Make sure interrupts enabled when we "safe_halt()" sparc: Use generic idle loop idle: Remove unused ARCH_HAS_DEFAULT_IDLE bfin: Fix typo in arch_cpu_idle() xtensa: Use generic idle loop x86: Use generic idle loop unicore: Use generic idle loop tile: Use generic idle loop tile: Enter idle with preemption disabled sh: Use generic idle loop score: Use generic idle loop s390: Use generic idle loop powerpc: Use generic idle loop parisc: Use generic idle loop openrisc: Use generic idle loop mn10300: Use generic idle loop mips: Use generic idle loop microblaze: Use generic idle loop ...
2013-04-29mm/cris: use common help functions to free reserved pagesJiang Liu
Use common help functions to free reserved pages. Also include <asm/sections.h> to avoid local declaration. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29cris: Don't use create_proc_read_entry()David Howells
Don't use create_proc_read_entry() as that is deprecated, but rather use proc_create_data() and seq_file instead. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> cc: Mikael Starvik <starvik@axis.com> cc: linux-cris-kernel@axis.com Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-17idle: Remove GENERIC_IDLE_LOOP config switchThomas Gleixner
All archs are converted over. Remove the config switch and the fallback code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-10cpufreq: cris: move cpufreq driver to drivers/cpufreqViresh Kumar
This patch moves cpufreq drivers of CRIS architecture to drivers/cpufreq. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-09get rid of a bunch of open-coded create_proc_read_entry()Al Viro
2013-04-08cris: Use generic idle loopThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Link: http://lkml.kernel.org/r/20130321215234.148829489@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-08arch: Cleanup enable/disable_hltThomas Gleixner
enable/disable_hlt() does not need to be exported and can be killed on architectures which do not use it at all. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Link: http://lkml.kernel.org/r/20130321215233.377959540@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-05arch: cris: amend Kconfig after mtdchar mergeArtem Bityutskiy
The mtdchar module was merged with the mtdcore module, which means that the MTD_CHAR Kconfig symbol does not exist any more. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-02cpufreq: Notify all policy->cpus in cpufreq_notify_transition()Viresh Kumar
policy->cpus contains all online cpus that have single shared clock line. And their frequencies are always updated together. Many SMP system's cpufreq drivers take care of this in individual drivers but the best place for this code is in cpufreq core. This patch modifies cpufreq_notify_transition() to notify frequency change for all cpus in policy->cpus and hence updates all users of this API. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-03-31net: add option to enable error queue packets waking selectKeller, Jacob E
Currently, when a socket receives something on the error queue it only wakes up the socket on select if it is in the "read" list, that is the socket has something to read. It is useful also to wake the socket if it is in the error list, which would enable software to wait on error queue packets without waking up for regular data on the socket. The main use case is for receiving timestamped transmit packets which return the timestamp to the socket via the error queue. This enables an application to select on the socket for the error queue only instead of for the regular traffic. -v2- * Added the SO_SELECT_ERR_QUEUE socket option to every architechture specific file * Modified every socket poll function that checks error queue Signed-off-by: Jacob Keller <jacob.e.keller@intel.com> Cc: Jeffrey Kirsher <jeffrey.t.kirsher@intel.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Matthew Vick <matthew.vick@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-12Select VIRT_TO_BUS directly where neededStephen Rothwell
In commit 887cbce0adea ("arch Kconfig: centralise ARCH_NO_VIRT_TO_BUS") I introduced the config sybmol HAVE_VIRT_TO_BUS and selected that where needed. I am not sure what I was thinking. Instead, just directly select VIRT_TO_BUS where it is needed. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-03consolidate cond_syscall and SYSCALL_ALIAS declarationsAl Viro
take them to asm/linkage.h, with default in linux/linkage.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-27arch Kconfig: centralise CONFIG_ARCH_NO_VIRT_TO_BUSStephen Rothwell
Change it to CONFIG_HAVE_VIRT_TO_BUS and set it in all architecures that already provide virt_to_bus(). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: H Hartley Sweeten <hartleys@visionengravers.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26default SET_PERSONALITY() in linux/elf.hAl Viro
2013-02-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "This is the first pile; another one will come a bit later and will contain SYSCALL_DEFINE-related patches. - a bunch of signal-related syscalls (both native and compat) unified. - a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE (fixing several potential problems with missing argument validation, while we are at it) - a lot of now-pointless wrappers killed - a couple of architectures (cris and hexagon) forgot to save altstack settings into sigframe, even though they used the (uninitialized) values in sigreturn; fixed. - microblaze fixes for delivery of multiple signals arriving at once - saner set of helpers for signal delivery introduced, several architectures switched to using those." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits) x86: convert to ksignal sparc: convert to ksignal arm: switch to struct ksignal * passing alpha: pass k_sigaction and siginfo_t using ksignal pointer burying unused conditionals make do_sigaltstack() static arm64: switch to generic old sigaction() (compat-only) arm64: switch to generic compat rt_sigaction() arm64: switch compat to generic old sigsuspend arm64: switch to generic compat rt_sigqueueinfo() arm64: switch to generic compat rt_sigpending() arm64: switch to generic compat rt_sigprocmask() arm64: switch to generic sigaltstack sparc: switch to generic old sigsuspend sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE sparc: kill sign-extending wrappers for native syscalls kill sparc32_open() sparc: switch to use of generic old sigaction sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE mips: switch to generic sys_fork() and sys_clone() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-21Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge misc patches from Andrew Morton: - Florian has vanished so I appear to have become fbdev maintainer again :( - Joel and Mark are distracted to welcome to the new OCFS2 maintainer - The backlight queue - Small core kernel changes - lib/ updates - The rtc queue - Various random bits * akpm: (164 commits) rtc: rtc-davinci: use devm_*() functions rtc: rtc-max8997: use devm_request_threaded_irq() rtc: rtc-max8907: use devm_request_threaded_irq() rtc: rtc-da9052: use devm_request_threaded_irq() rtc: rtc-wm831x: use devm_request_threaded_irq() rtc: rtc-tps80031: use devm_request_threaded_irq() rtc: rtc-lp8788: use devm_request_threaded_irq() rtc: rtc-coh901331: use devm_clk_get() rtc: rtc-vt8500: use devm_*() functions rtc: rtc-tps6586x: use devm_request_threaded_irq() rtc: rtc-imxdi: use devm_clk_get() rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug() rtc: rtc-pcf8583: use dev_warn() instead of printk() rtc: rtc-sun4v: use pr_warn() instead of printk() rtc: rtc-vr41xx: use dev_info() instead of printk() rtc: rtc-rs5c313: use pr_err() instead of printk() rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug() rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug() rtc: rtc-ds2404: use dev_err() instead of printk() rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk() ...
2013-02-21cris: use "int" for ssize_t to match size_tGeert Uytterhoeven
On cris-linux-gcc, __SIZE_TYPE__ expands to "unsigned int", as gcc-4.6.3-nolibc/cris-linux/lib/gcc/cris-linux/4.6.3/plugin/include/config/cris/linux.h has #define SIZE_TYPE "unsigned int" Hence __kernel_size_t is also "unsigned int". But __kernel_ssize_t is "long", which has a different base type, causing compiler warnings like: fs/quota/quota_tree.c:372:4: warning: format '%zd' expects argument of type 'signed size_t', but argument 4 has type 'ssize_t' [-Wformat] To fix this, __kernel_ssize_t should be changed to "int". Hence cris can just use the generic 32-bit versions from include/asm-generic/posix_types.h for all size-related types. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Mikael Starvik <starvik@axis.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Hans-Peter Nilsson <hans-peter.nilsson@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups from Arnd Bergmann: "A large number of cleanups, all over the platforms. This is dominated largely by the Samsung platforms (s3c, s5p, exynos) and a few of the others moving code out of arch/arm into more appropriate subsystems. The clocksource and irqchip drivers are now abstracted to the point where platforms that are already cleaned up do not need to even specify the driver they use, it can all get configured from the device tree as we do for normal device drivers. The clocksource changes basically touch every single platform in the process. We further clean up the use of platform specific header files here, with the goal of turning more of the platforms over to being "multiplatform" enabled, which implies that they cannot expose their headers to architecture independent code any more. It is expected that no functional changes are part of the cleanup. The overall reduction in total code lines is mostly the result of removing broken and obsolete code." * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits) ARM: mvebu: correct gated clock documentation ARM: kirkwood: add missing include for nsa310 ARM: exynos: move exynos4210-combiner to drivers/irqchip mfd: db8500-prcmu: update resource passing drivers/db8500-cpufreq: delete dangling include ARM: at91: remove NEOCORE 926 board sunxi: Cleanup the reset code and add meaningful registers defines ARM: S3C24XX: header mach/regs-mem.h local ARM: S3C24XX: header mach/regs-power.h local ARM: S3C24XX: header mach/regs-s3c2412-mem.h local ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/ ARM: S3C24XX: transform s3c2443 subirqs into new structure ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs ARM: S3C24XX: move s3c2443 irq code to irq.c ARM: S3C24XX: transform s3c2416 irqs into new structure ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs ARM: S3C24XX: move s3c2416 irq init to common irq code ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property ARM: S3C24XX: Move irq syscore-ops to irq-pm clocksource: always define CLOCKSOURCE_OF_DECLARE ...
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking update from David Miller: 1) Checkpoint/restarted TCP sockets now can properly propagate the TCP timestamp offset. From Andrey Vagin. 2) VMWARE VM VSOCK layer, from Andy King. 3) Much improved support for virtual functions and SR-IOV in bnx2x, from Ariel ELior. 4) All protocols on ipv4 and ipv6 are now network namespace aware, and all the compatability checks for initial-namespace-only protocols is removed. Thanks to Tom Parkin for helping deal with the last major holdout, L2TP. 5) IPV6 support in netpoll and network namespace support in pktgen, from Cong Wang. 6) Multiple Registration Protocol (MRP) and Multiple VLAN Registration Protocol (MVRP) support, from David Ward. 7) Compute packet lengths more accurately in the packet scheduler, from Eric Dumazet. 8) Use per-task page fragment allocator in skb_append_datato_frags(), also from Eric Dumazet. 9) Add support for connection tracking labels in netfilter, from Florian Westphal. 10) Fix default multicast group joining on ipv6, and add anti-spoofing checks to 6to4 and 6rd. From Hannes Frederic Sowa. 11) Make ipv4/ipv6 fragmentation memory limits more reasonable in modern times, rearrange inet frag datastructures for better cacheline locality, and move more operations outside of locking. From Jesper Dangaard Brouer. 12) Instead of strict master <--> slave relationships, allow arbitrary scenerios with "upper device lists". From Jiri Pirko. 13) Improve rate limiting accuracy in TBF and act_police, also from Jiri Pirko. 14) Add a BPF filter netfilter match target, from Willem de Bruijn. 15) Orphan and delete a bunch of pre-historic networking drivers from Paul Gortmaker. 16) Add TSO support for GRE tunnels, from Pravin B SHelar. Although this still needs some minor bug fixing before it's %100 correct in all cases. 17) Handle unresolved IPSEC states like ARP, with a resolution packet queue. From Steffen Klassert. 18) Remove TCP Appropriate Byte Count support (ABC), from Stephen Hemminger. This was long overdue. 19) Support SO_REUSEPORT, from Tom Herbert. 20) Allow locking a socket BPF filter, so that it cannot change after a process drops capabilities. 21) Add VLAN filtering to bridge, from Vlad Yasevich. 22) Bring ipv6 on-par with ipv4 and do not cache neighbour entries in the ipv6 routes, from YOSHIFUJI Hideaki. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1538 commits) ipv6: fix race condition regarding dst->expires and dst->from. net: fix a wrong assignment in skb_split() ip_gre: remove an extra dst_release() ppp: set qdisc_tx_busylock to avoid LOCKDEP splat atl1c: restore buffer state net: fix a build failure when !CONFIG_PROC_FS net: ipv4: fix waring -Wunused-variable net: proc: fix build failed when procfs is not configured Revert "xen: netback: remove redundant xenvif_put" net: move procfs code to net/core/net-procfs.c qmi_wwan, cdc-ether: add ADU960S bonding: set sysfs device_type to 'bond' bonding: fix bond_release_all inconsistencies b44: use netdev_alloc_skb_ip_align() xen: netback: remove redundant xenvif_put net: fec: Do a sanity check on the gpio number ip_gre: propogate target device GSO capability to the tunnel device ip_gre: allow CSUM capable devices to handle packets bonding: Fix initialize after use for 3ad machine state spinlock bonding: Fix race condition between bond_enslave() and bond_3ad_update_lacp_rate() ...
2013-02-18Merge branch 'release' of ↵Rafael J. Wysocki
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (35 commits) PM idle: remove global declaration of pm_idle unicore32 idle: delete stray pm_idle comment openrisc idle: delete pm_idle mn10300 idle: delete pm_idle microblaze idle: delete pm_idle m32r idle: delete pm_idle, and other dead idle code ia64 idle: delete pm_idle cris idle: delete idle and pm_idle ARM64 idle: delete pm_idle ARM idle: delete pm_idle blackfin idle: delete pm_idle sparc idle: rename pm_idle to sparc_idle sh idle: rename global pm_idle to static sh_idle x86 idle: rename global pm_idle to static x86_idle APM idle: register apm_cpu_idle via cpuidle tools/power turbostat: display SMI count by default intel_idle: export both C1 and C1E cpuidle: remove vestage definition of cpuidle_state_usage.driver_data x86 idle: remove 32-bit-only "no-hlt" parameter, hlt_works_ok flag x86 idle: remove mwait_idle() and "idle=mwait" cmdline param ... Conflicts: arch/x86/kernel/process.c (with PM / tracing commit 43720bd) drivers/acpi/processor_idle.c (with ACPICA commit 4f84291)
2013-02-17cris idle: delete idle and pm_idleLen Brown
pm_idle() and idle() served no purpose on cris -- invoke default_idle() directly. Signed-off-by: Len Brown <len.brown@intel.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
2013-02-14burying unused conditionalsAl Viro
__ARCH_WANT_SYS_RT_SIGACTION, __ARCH_WANT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} - can be assumed always set.
2013-02-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Synchronize with 'net' in order to sort out some l2tp, wireless, and ipv6 GRE fixes that will be built on top of in 'net-next'. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-03cris: kill weird arguments of sys_{rt_,}sigreturn()Al Viro
It's cheaper to call current_pt_regs() than bother fetching the damn thing from stack. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-03cris: switch to generic old sigaction()Al Viro
2013-02-03cris: switch to generic old sigsuspendAl Viro
2013-02-03cris: don't leave ->uc_stack unitialized - we'll use its contents on sigreturnAl Viro
2013-02-03cris: switch to generic sigaltstackAl Viro
2013-02-03consolidate kernel-side struct sigaction declarationsAl Viro
2013-02-03consolidate declarations of k_sigactionAl Viro
Only alpha and sparc are unusual - they have ka_restorer in it. And nobody needs that exposed to userland. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-01-29cris: Provide dma_mmap_coherent() and dma_get_sgtable()Geert Uytterhoeven
cris/allmodconfig: drivers/media/v4l2-core/videobuf2-dma-contig.c: In function ‘vb2_dc_mmap’: drivers/media/v4l2-core/videobuf2-dma-contig.c:204: error: implicit declaration of function ‘dma_mmap_coherent’ drivers/media/v4l2-core/videobuf2-dma-contig.c: In function ‘vb2_dc_get_base_sgt’: drivers/media/v4l2-core/videobuf2-dma-contig.c:387: error: implicit declaration of function ‘dma_get_sgtable’ For architectures using dma_map_ops, dma_mmap_coherent() and dma_get_sgtable() are provided in <asm-generic/dma-mapping-common.h>. Cris does not use dma_map_ops, hence it should implement them as inline stubs using dma_common_mmap() and dma_common_get_sgtable(). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: linux-cris-kernel@axis.com Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2013-01-23soreuseport: infrastructureTom Herbert
Definitions and macros for implementing soreusport. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-17sk-filter: Add ability to lock a socket filter programVincent Bernat
While a privileged program can open a raw socket, attach some restrictive filter and drop its privileges (or send the socket to an unprivileged program through some Unix socket), the filter can still be removed or modified by the unprivileged program. This commit adds a socket option to lock the filter (SO_LOCK_FILTER) preventing any modification of a socket filter program. This is similar to OpenBSD BIOCLOCK ioctl on bpf sockets, except even root is not allowed change/drop the filter. The state of the lock can be read with getsockopt(). No error is triggered if the state is not changed. -EPERM is returned when a user tries to remove the lock or to change/remove the filter while the lock is active. The check is done directly in sk_attach_filter() and sk_detach_filter() and does not affect only setsockopt() syscall. Signed-off-by: Vincent Bernat <bernat@luffy.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
