path: root/arch/cris
2007-07-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (33 commits) xtensa: use DATA_DATA in xtensa powerpc: add missing DATA_DATA to powerpc cris: use DATA_DATA in cris kallsyms: remove usage of memmem and _GNU_SOURCE from scripts/kallsyms.c kbuild: use -fno-optimize-sibling-calls unconditionally kconfig: reset generated values only if Kconfig and .config agree. kbuild: fix the warning when running make tags kconfig: strip 'CONFIG_' automatically in kernel configuration search kbuild: use POSIX BRE in headers install target Whitelist references from __dbe_table to .init modpost white list pattern adjustment kbuild: do section mismatch check on full vmlinux kbuild: whitelist references from variables named _timer to .init.text kbuild: remove hardcoded _logo names from modpost kbuild: remove hardcoded apic_es7000 from modpost kbuild: warn about references from .init.text to .exit.text kbuild: consolidate section checks kbuild: refactor code in modpost to improve maintainability kbuild: ignore section mismatch warnings originating from .note section kbuild: .paravirtprobe section is obsolete, so modpost doesn't need to handle it ...
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19define new percpu interface for shared dataFenghua Yu
per cpu data section contains two types of data. One set which is exclusively accessed by the local cpu and the other set which is per cpu, but also shared by remote cpus. In the current kernel, these two sets are not clearely separated out. This can potentially cause the same data cacheline shared between the two sets of data, which will result in unnecessary bouncing of the cacheline between cpus. One way to fix the problem is to cacheline align the remotely accessed per cpu data, both at the beginning and at the end. Because of the padding at both ends, this will likely cause some memory wastage and also the interface to achieve this is not clean. This patch: Moves the remotely accessed per cpu data (which is currently marked as ____cacheline_aligned_in_smp) into a different section, where all the data elements are cacheline aligned. And as such, this differentiates the local only data and remotely accessed data cleanly. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Christoph Lameter <clameter@sgi.com> Cc: <linux-arch@vger.kernel.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19unregister_chrdev(): ignore the return valueAkinobu Mita
unregister_chrdev() always returns 0. There is no need to check the return value. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fault feedback #2Nick Piggin
This patch completes Linus's wish that the fault return codes be made into bit flags, which I agree makes everything nicer. This requires requires all handle_mm_fault callers to be modified (possibly the modifications should go further and do things like fault accounting in handle_mm_fault -- however that would be for another patch). [akpm@linux-foundation.org: fix alpha build] [akpm@linux-foundation.org: fix s390 build] [akpm@linux-foundation.org: fix sparc build] [akpm@linux-foundation.org: fix sparc64 build] [akpm@linux-foundation.org: fix ia64 build] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Still apparently needs some ARM and PPC loving - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17PTRACE_POKEDATA consolidationAlexey Dobriyan
Identical implementations of PTRACE_POKEDATA go into generic_ptrace_pokedata() function. AFAICS, fix bug on xtensa where successful PTRACE_POKEDATA will nevertheless return EPERM. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17PTRACE_PEEKDATA consolidationAlexey Dobriyan
Identical implementations of PTRACE_PEEKDATA go into generic_ptrace_peekdata() function. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17cris: use DATA_DATA in crisMathieu Desnoyers
* Sam Ravnborg (sam@ravnborg.org) wrote: > From your patch it looks like I originally missed out > powerpc + xtensa when introducing DATA_DATA - would be nice if > you could fix that. > Use DATA_DATA in CRIS Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16Remove the last few UMSDOS leftoversJesper Juhl
The UMSDOS filesystem was removed back in 2.6.11, but some tiny bits stuck around. This patch removes the few remaining leftovers. The only things left behind after this are the entries in the CREDITS file and the ioctl number in Documentation/ioctl-number.txt as documentation. This third (hopefully final) version of the patch doesn't edit the arch/um/config.release file, since Jeff Dike pointed out to me that it should die completely, and asked me to remove it from my patch as he'll send in a seperate patch removing the file completely. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16CRIS: replace old-style member inits with designated initsRobert P. J. Day
Replace the old-style structure member initializers with designated initializers. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Fix trivial typos in Kconfig* filesDavid Sterba
Fix several typos in help text in Kconfig* files. Signed-off-by: David Sterba <dave@jikos.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08dma_declare_coherent_memory wrong allocationGuennadi Liakhovetski
dma_declare_coherent_memory() allocates a bitmap 1 bit per page, it calculates the bitmap size based on size of long, but allocates bytes... Thanks to James Bottomley for clarifications and corrections. Signed-off-by: G. Liakhovetski <g.liakhovetski@gmx.de> Acked-by: James Bottomley <James.Bottomley@SteelEye.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07CRIS: remove code related to pre-2.2 kernelRobert P. J. Day
Remove conditionals and code related to checking for a pre-2.2 kernel. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07CRIS: check for memory allocationCyrill Gorcunov
Add checking for allocated memory. Indents and spaces are added to be familiar with the kernel coding style. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Acked-by: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] x86: Allow percpu variables to be page-alignedJeremy Fitzhardinge
Let's allow page-alignment in general for per-cpu data (wanted by Xen, and Ingo suggested KVM as well). Because larger alignments can use more room, we increase the max per-cpu memory to 64k rather than 32k: it's getting a little tight. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-03-28[PATCH] MSI-X: fix resume crashEric W. Biederman
So I think the right solution is to simply make pci_enable_device just flip enable bits and move the rest of the work someplace else. However a thorough cleanup is a little extreme for this point in the release cycle, so I think a quick hack that makes the code not stomp the irq when msi irq's are enabled should be the first fix. Then we can later make the code not change the irqs at all. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] fix memory leak in dma_declare_coherent_memory()Yoichi Yuasa
When it goes to free1_out, dev->dma_mem has not been freed. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-17arch/cris: typo in KERN_INFONicolas Kaiser
Typo in KERN_INFO. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-12[PATCH] mark struct file_operations const 2Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@osdl.org: sparc64 fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Dynamic kernel command-line: crisAlon Bar-Lev
1. Rename saved_command_line into boot_command_line. 2. Set cris_command_line as __initdata. Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] sort the devres mess outAl Viro
* Split the implementation-agnostic stuff in separate files. * Make sure that targets using non-default request_irq() pull kernel/irq/devres.o * Introduce new symbols (HAS_IOPORT and HAS_IOMEM) defaulting to positive; allow architectures to turn them off (we needed these symbols anyway for dependencies of quite a few drivers). * protect the ioport-related parts of lib/devres.o with CONFIG_HAS_IOPORT. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Consolidate default sched_clock()Alexey Dobriyan
Use attribute(weak). Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] disable init/initramfs.c: architecturesJean-Paul Saman
Update all arch/*/kernel/vmlinux.lds.S to not include space for initramfs when CONFIG_BLK_DEV_INITRAMFS is not selected. This saves another 4 kbytes on most platfoms (some reserve PAGE_SIZE for initramfs). Signed-off-by: Jean-Paul Saman <jean-paul.saman@nxp.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] CRIS: TLB handling: turn local_save_flags() + local_irq_disable() ↵Jiri Kosina
into local_irq_save() TLB handling for CRIS contains local_irq_disable() after local_save_flags(). Turn this into local_irq_save(). Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] CRIS: user ARRAY_SIZE macro when appropriateAhmed S. Darwish
Use ARRAY_SIZE macro already defined in linux/kernel.h Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] CRIS: local_irq_disable() is redundant after local_irq_save()Jiri Kosina
arch/cris/arch-v10/kernel/time.c::get_ns_in_jiffie() contains local_irq_disable() call after local_irq_save(). This looks redundant. arch/cris/kernel/time.c::do_gettimeofday() contains local_irq_disable() call after local_irq_save(). This looks redundant. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] optional ZONE_DMA: introduce CONFIG_ZONE_DMAChristoph Lameter
This patch simply defines CONFIG_ZONE_DMA for all arches. We later do special things with CONFIG_ZONE_DMA after the VM and an arch are prepared to work without ZONE_DMA. CONFIG_ZONE_DMA can be defined in two ways depending on how an architecture handles ISA DMA. First if CONFIG_GENERIC_ISA_DMA is set by the arch then we know that the arch needs ZONE_DMA because ISA DMA devices are supported. We can catch this in mm/Kconfig and do not need to modify arch code. Second, arches may use ZONE_DMA in an unknown way. We set CONFIG_ZONE_DMA for all arches that do not set CONFIG_GENERIC_ISA_DMA in order to insure backwards compatibility. The arches may later undefine ZONE_DMA if their arch code has been verified to not depend on ZONE_DMA. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11[PATCH] Change cpu_up and co from __devinit to __cpuinitGautham R Shenoy
Compiling the kernel with CONFIG_HOTPLUG = y and CONFIG_HOTPLUG_CPU = n with CONFIG_RELOCATABLE = y generates the following modpost warnings WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141b7d) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141b9c) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.text:__cpu_up from .text between '_cpu_up' (at offset 0xc0141bd8) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141c05) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141c26) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141c37) and 'cpu_up' This is because cpu_up, _cpu_up and __cpu_up (in some architectures) are defined as __devinit AND __cpu_up calls some __cpuinit functions. Since __cpuinit would map to __init with this kind of a configuration, we get a .text refering .init.data warning. This patch solves the problem by converting all of __cpu_up, _cpu_up and cpu_up from __devinit to __cpuinit. The approach is justified since the callers of cpu_up are either dependent on CONFIG_HOTPLUG_CPU or are of __init type. Thus when CONFIG_HOTPLUG_CPU=y, all these cpu up functions would land up in .text section, and when CONFIG_HOTPLUG_CPU=n, all these functions would land up in .init section. Tested on a i386 SMP machine running linux-2.6.20-rc3-mm1. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] LOG2: Implement a general integer log2 facility in the kernelDavid Howells
This facility provides three entry points: ilog2() Log base 2 of unsigned long ilog2_u32() Log base 2 of u32 ilog2_u64() Log base 2 of u64 These facilities can either be used inside functions on dynamic data: int do_something(long q) { ...; y = ilog2(x) ...; } Or can be used to statically initialise global variables with constant values: unsigned n = ilog2(27); When performing static initialisation, the compiler will report "error: initializer element is not constant" if asked to take a log of zero or of something not reducible to a constant. They treat negative numbers as unsigned. When not dealing with a constant, they fall back to using fls() which permits them to use arch-specific log calculation instructions - such as BSR on x86/x86_64 or SCAN on FRV - if available. [akpm@osdl.org: MMC fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Howells <dhowells@redhat.com> Cc: Wojtek Kaniewski <wojtekka@toxygen.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert crisJosef Sipek
2006-12-07[PATCH] mm: arch do_page_fault() vs in_atomic()Peter Zijlstra
In light of the recent pagefault and filemap_copy_from_user work I've gone through all the arch pagefault handlers to make sure the inc_preempt_count() 'feature' works as expected. Several sections of code (including the new filemap_copy_from_user) rely on the fact that faults do not take locks under increased preempt count. arch/x86_64 - good arch/powerpc - good arch/cris - fixed arch/i386 - good arch/parisc - fixed arch/sh - good arch/sparc - good arch/s390 - good arch/m68k - fixed arch/ppc - good arch/alpha - fixed arch/mips - good arch/sparc64 - good arch/ia64 - good arch/arm - fixed arch/um - good arch/avr32 - good arch/h8300 - NA arch/m32r - good arch/v850 - good arch/frv - fixed arch/m68knommu - NA arch/arm26 - fixed arch/sh64 - fixed arch/xtensa - good Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-02[NET]: Cris checksum annotations and cleanups.Al Viro
* sanitize prototypes and annotate * kill cast-as-lvalue abuses in csum_partial() * usual ntohs-equals-shift for checksum purposes Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-30Fix misc .c/.h comment typosMatt LaPlante
Fix various .c/.h typos in comments (no code changes). Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-30Fix misc Kconfig typosMatt LaPlante
Fix various Kconfig typos. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-30[PATCH] cryptocop: double spin_lock_irqsave()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03more misc typo fixesMatt LaPlante
2006-10-02[PATCH] namespaces: utsname: use init_utsname when appropriateSerge E. Hallyn
In some places, particularly drivers and __init code, the init utsns is the appropriate one to use. This patch replaces those with a the init_utsname helper. Changes: Removed several uses of init_utsname(). Hope I picked all the right ones in net/ipv4/ipconfig.c. These are now changed to utsname() (the per-process namespace utsname) in the previous patch (2/7) [akpm@osdl.org: CIFS fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] cpumask: export cpu_online_map and cpu_possible_map consistentlyGreg Banks
cpumask: ensure that the cpu_online_map and cpu_possible_map bitmasks, and hence all the macros in <linux/cpumask.h> that require them, are available to modules for all supported combinations of architecture and CONFIG_SMP. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Generic ioremap_page_range: cris conversionHaavard Skinnemoen
Convert CRIS to use generic ioremap_page_range() Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] kill wall_jiffiesAtsushi Nemoto
With 2.6.18-rc4-mm2, now wall_jiffies will always be the same as jiffies. So we can kill wall_jiffies completely. This is just a cleanup and logically should not change any real behavior except for one thing: RTC updating code in (old) ppc and xtensa use a condition "jiffies - wall_jiffies == 1". This condition is never met so I suppose it is just a bug. I just remove that condition only instead of kill the whole "if" block. [heiko.carstens@de.ibm.com: s390 build fix and cleanup] Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] simplify update_times (avoid jiffies/jiffies_64 aliasing problem)Atsushi Nemoto
Pass ticks to do_timer() and update_times(), and adjust x86_64 and s390 timer interrupt handler with this change. Currently update_times() calculates ticks by "jiffies - wall_jiffies", but callers of do_timer() should know how many ticks to update. Passing ticks get rid of this redundant calculation. Also there are another redundancy pointed out by Martin Schwidefsky. This cleanup make a barrier added by 5aee405c662ca644980c184774277fc6d0769a84 needless. So this patch removes it. As a bonus, this cleanup make wall_jiffies can be removed easily, since now wall_jiffies is always synced with jiffies. (This patch does not really remove wall_jiffies. It would be another cleanup patch) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] pcf8563: remove MOD_INC_USE_COUNT, MOD_DEC_USE_COUNTIrwan Djajadi
It already has .owner. Signed-off-by: Irwan Djajadi <irwan.djajadi@iname.com> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] cris: switch to iminor/imajorEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] tty: Remove include of screen_info.h from tty.hJon Smirl
screen_info.h doesn't have anything to do with the tty layer and shouldn't be included by tty.h. This patches removes the include and modifies all users to directly include screen_info.h. struct screen_info is mainly used to communicate with the console drivers in drivers/video/console. Note that this patch touches every arch and I have no way of testing it. If there is a mistake the worst thing that will happen is a compile error. [akpm@osdl.org: fix arm build] [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: CRIS: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30typo fixes: bandwith -> bandwidthAdrian Bunk
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits) [PATCH] devfs: Remove it from the feature_removal.txt file [PATCH] devfs: Last little devfs cleanups throughout the kernel tree. [PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV [PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed [PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree [PATCH] devfs: Remove devfs_remove() function from the kernel tree [PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree [PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree [PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree [PATCH] devfs: Remove devfs support from the sound subsystem [PATCH] devfs: Remove devfs support from the ide subsystem. [PATCH] devfs: Remove devfs support from the serial subsystem [PATCH] devfs: Remove devfs from the init code [PATCH] devfs: Remove devfs from the partition code ...
