path: root/arch/cris/mm
2008-04-28cris: remove redundant display of free swap space in show_mem()Johannes Weiner
show_mem() has no need to print the amount of free swap space manually because show_free_areas() does this already and is called by the former. The two outputs only differ in text formatting: printk("Free swap = %lukB\n", ...); printk("Free swap: %6ldkB\n", ...); Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: Mikael Starvik <mikael.starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08CRIS: Minor fixes to mm/fault.cJesper Nilsson
- Only disallow oops if we're in_interrupt context (was in_atomic before) - Use the generic oops_in_progress instead of the raw_printk hack. - Fix whitespace/formatting. - Remove CVS log entries.
2008-02-08CRIS: Remove unnecessary CVS log from cris/mm/init.cJesper Nilsson
2007-10-20spelling fixes: arch/cris/Simon Arlott
Spelling fixes in arch/cris/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16During VM oom condition, kill all threads in process groupWill Schmidt
We have had complaints where a threaded application is left in a bad state after one of it's threads is killed when we hit a VM: out_of_memory condition. Killing just one of the process threads can leave the application in a bad state, whereas killing the entire process group would allow for the application to restart, or be otherwise handled, and makes it very obvious that something has gone wrong. This change allows the entire process group to be taken down, rather than just the one thread. Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fault feedback #2Nick Piggin
This patch completes Linus's wish that the fault return codes be made into bit flags, which I agree makes everything nicer. This requires requires all handle_mm_fault callers to be modified (possibly the modifications should go further and do things like fault accounting in handle_mm_fault -- however that would be for another patch). [akpm@linux-foundation.org: fix alpha build] [akpm@linux-foundation.org: fix s390 build] [akpm@linux-foundation.org: fix sparc build] [akpm@linux-foundation.org: fix sparc64 build] [akpm@linux-foundation.org: fix ia64 build] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Still apparently needs some ARM and PPC loving - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] CRIS: user ARRAY_SIZE macro when appropriateAhmed S. Darwish
Use ARRAY_SIZE macro already defined in linux/kernel.h Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] mm: arch do_page_fault() vs in_atomic()Peter Zijlstra
In light of the recent pagefault and filemap_copy_from_user work I've gone through all the arch pagefault handlers to make sure the inc_preempt_count() 'feature' works as expected. Several sections of code (including the new filemap_copy_from_user) rely on the fact that faults do not take locks under increased preempt count. arch/x86_64 - good arch/powerpc - good arch/cris - fixed arch/i386 - good arch/parisc - fixed arch/sh - good arch/sparc - good arch/s390 - good arch/m68k - fixed arch/ppc - good arch/alpha - fixed arch/mips - good arch/sparc64 - good arch/ia64 - good arch/arm - fixed arch/um - good arch/avr32 - good arch/h8300 - NA arch/m32r - good arch/v850 - good arch/frv - fixed arch/m68knommu - NA arch/arm26 - fixed arch/sh64 - fixed arch/xtensa - good Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Generic ioremap_page_range: cris conversionHaavard Skinnemoen
Convert CRIS to use generic ioremap_page_range() Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] remove set_page_count() outside mm/Nick Piggin
set_page_count usage outside mm/ is limited to setting the refcount to 1. Remove set_page_count from outside mm/, and replace those users with init_page_count() and set_page_refcounted(). This allows more debug checking, and tighter control on how code is allowed to play around with page->_count. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] cris: "extern inline" -> "static inline"Adrian Bunk
"extern inline" doesn't make much sense. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: init_mm without ptlockHugh Dickins
First step in pushing down the page_table_lock. init_mm.page_table_lock has been used throughout the architectures (usually for ioremap): not to serialize kernel address space allocation (that's usually vmlist_lock), but because pud_alloc,pmd_alloc,pte_alloc_kernel expect caller holds it. Reverse that: don't lock or unlock init_mm.page_table_lock in any of the architectures; instead rely on pud_alloc,pmd_alloc,pte_alloc_kernel to take and drop it when allocating a new one, to check lest a racing task already did. Similarly no page_table_lock in vmalloc's map_vm_area. Some temporary ugliness in __pud_alloc and __pmd_alloc: since they also handle user mms, which are converted only by a later patch, for now they have to lock differently according to whether or not it's init_mm. If sources get muddled, there's a danger that an arch source taking init_mm.page_table_lock will be mixed with common source also taking it (or neither take it). So break the rules and make another change, which should break the build for such a mismatch: remove the redundant mm arg from pte_alloc_kernel (ppc64 scrapped its distinct ioremap_mm in 2.6.13). Exceptions: arm26 used pte_alloc_kernel on user mm, now pte_alloc_map; ia64 used pte_alloc_map on init_mm, now pte_alloc_kernel; parisc had bad args to pmd_alloc and pte_alloc_kernel in unused USE_HPPA_IOREMAP code; ppc64 map_io_page forgot to unlock on failure; ppc mmu_mapin_ram and ppc64 im_free took page_table_lock for no good reason. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-04It wasn't just x86-64 that had hardcoded VM_FAULT_xxx numbersLinus Torvalds
Fix up arm26, cris, frv, m68k, parisc and sh64 too..
2005-07-27[PATCH] CRIS update: mmMikael Starvik
Memory management patches. * SMP support. * Non-executable stack (on v32). * 4-level page tables. * Added simple Thread Local Storage support. Signed-off-by: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
