path: root/arch/cris/arch-v32
2012-10-12vfs: define struct filename and have getname() return itJeff Layton
getname() is intended to copy pathname strings from userspace into a kernel buffer. The result is just a string in kernel space. It would however be quite helpful to be able to attach some ancillary info to the string. For instance, we could attach some audit-related info to reduce the amount of audit-related processing needed. When auditing is enabled, we could also call getname() on the string more than once and not need to recopy it from userspace. This patchset converts the getname()/putname() interfaces to return a struct instead of a string. For now, the struct just tracks the string in kernel space and the original userland pointer for it. Later, we'll add other information to the struct as it becomes convenient. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-03Merge tag 'cris-for-linus-3.7' of git://jni.nu/crisLinus Torvalds
Pull CRIS changes from Jesper Nilsson: "Removal of some unused code from the CRIS port" * tag 'cris-for-linus-3.7' of git://jni.nu/cris: CRIS: Remove VCS simulator specific code cris/PCI: remove pcibios_assign_resources()
2012-10-03CRIS: Remove VCS simulator specific codeJesper Nilsson
The VCS simulator was a tool used in the development of the chip and is no longer used or necessary. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2012-10-03cris/PCI: remove pcibios_assign_resources()Bjorn Helgaas
There's no caller of pcibios_assign_resources() in the tree. It is exported, so an out-of-tree module *could* call it, but no other arch exports pcibios_assign_resources(), so it would have to be a CRIS-specific module. I doubt such a caller exists. CC: Mikael Starvik <starvik@axis.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2012-07-05cris/PCI: factor out pcibios_setup()Myron Stowe
The PCI core provides a generic pcibios_setup() routine. Drop this architecture-specific version in favor of that. This patch fixes what looks like a bug in cris, which implements pcibios_setup() such that pci_setup() doesn't look for any generic options. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-01new helper: signal_delivered()Al Viro
Does block_sigmask() + tracehook_signal_handler(); called when sigframe has been successfully built. All architectures converted to it; block_sigmask() itself is gone now (merged into this one). I'm still not too happy with the signature, but that's a separate story (IMO we need a structure that would contain signal number + siginfo + k_sigaction, so that get_signal_to_deliver() would fill one, signal_delivered(), handle_signal() and probably setup...frame() - take one). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01most of set_current_blocked() callers want SIGKILL/SIGSTOP removed from setAl Viro
Only 3 out of 63 do not. Renamed the current variant to __set_current_blocked(), added set_current_blocked() that will exclude unblockable signals, switched open-coded instances to it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01pull clearing RESTORE_SIGMASK into block_sigmask()Al Viro
2012-06-01new helper: sigmask_to_save()Al Viro
replace boilerplate "should we use ->saved_sigmask or ->blocked?" with calls of obvious inlined helper... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01new helper: restore_saved_sigmask()Al Viro
first fruits of ..._restore_sigmask() helpers: now we can take boilerplate "signal didn't have a handler, clear RESTORE_SIGMASK and restore the blocked mask from ->saved_mask" into a common helper. Open-coded instances switched... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-25Merge tag 'cris-for-linus' of git://jni.nu/crisLinus Torvalds
Pull CRIS changes from Jesper Nilsson: "No major changes here, but fixes some compile errors for CRIS, some small style issues, some documentation and as a bonus nukes a couple of obsolete rtc-files and related code." * tag 'cris-for-linus' of git://jni.nu/cris: cris: Remove old legacy "-traditional" flag from arch-v10/lib/Makefile CRIS: Remove legacy RTC drivers cris/mm/fault.c: Port OOM changes to do_page_fault cris:fix the wrong function declear CRIS: Add _sdata to vmlinux.lds.S cris: posix_types.h, include asm-generic/posix_types.h CRIS: Update documentation cris/arch-v32: cryptocop: Use kzalloc net:removed the unused variable cris:removed the unused variable CRISv32: Correct name of read_mostly section.
2012-05-21cris: missing checks of __get_user()/__put_user() return valuesAl Viro
2012-05-21cris: don't open-code force_sigsegv()Al Viro
2012-05-21cris: SA_ONESHOT handling is done by get_signal_to_deliver()Al Viro
... and resetting sa_handler in local copy filled by get_signal_to_deliver() is obviously pointless anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-21cris: use set_current_blocked() and block_sigmask()Matt Fleming
As described in e6fa16ab ("signal: sigprocmask() should do retarget_shared_pending()") the modification of current->blocked is incorrect as we need to check whether the signal we're about to block is pending in the shared queue. Also, use the new helper function introduced in commit 5e6292c0f28f ("signal: add block_sigmask() for adding sigmask to current->blocked") which centralises the code for updating current->blocked after successfully delivering a signal and reduces the amount of duplicate code across architectures. In the past some architectures got this code wrong, so using this helper function should stop that from happening again. Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-21new helper: sigsuspend()Al Viro
guts of saved_sigmask-based sigsuspend/rt_sigsuspend. Takes kernel sigset_t *. Open-coded instances replaced with calling it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-04-26cris: Use generic idle thread allocationThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Link: http://lkml.kernel.org/r/20120420124557.789657793@linutronix.de
2012-04-26smp: Add task_struct argument to __cpu_up()Thomas Gleixner
Preparatory patch to make the idle thread allocation for secondary cpus generic. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Richard Weinberger <richard@nod.at> Cc: x86@kernel.org Link: http://lkml.kernel.org/r/20120420124556.964170564@linutronix.de
2012-04-05CRIS: Remove legacy RTC driversJesper Nilsson
These old drivers are not used anymore, we use the ones in drivers/rtc. This allows us to remove some cruft in the CRIS timekeeping code. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2012-04-03cris/arch-v32: cryptocop: Use kzallocJesper Nilsson
This avoids unnecessary explicit initialization by allocating zeroed memory. Signed-off-by: Maxin B. John<maxin.john@gmail.com> Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2012-04-03cris:removed the unused variableWanlong Gao
removed the unused variable "unsigned long tmp". Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com> Signed-off-by: Jesper Nilsson <jespern@axis.com>
2012-03-28Disintegrate asm/system.h for CRISDavid Howells
Disintegrate asm/system.h for CRIS. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> cc: linux-cris-kernel@axis.com
2012-01-10Merge tag 'for-linus-3.3' of git://git.infradead.org/mtd-2.6Linus Torvalds
MTD pull for 3.3 * tag 'for-linus-3.3' of git://git.infradead.org/mtd-2.6: (113 commits) mtd: Fix dependency for MTD_DOC200x mtd: do not use mtd->block_markbad directly logfs: do not use 'mtd->block_isbad' directly mtd: introduce mtd_can_have_bb helper mtd: do not use mtd->suspend and mtd->resume directly mtd: do not use mtd->lock, unlock and is_locked directly mtd: do not use mtd->sync directly mtd: harmonize mtd_writev usage mtd: do not use mtd->lock_user_prot_reg directly mtd: mtd->write_user_prot_reg directly mtd: do not use mtd->read_*_prot_reg directly mtd: do not use mtd->get_*_prot_info directly mtd: do not use mtd->read_oob directly mtd: mtdoops: do not use mtd->panic_write directly romfs: do not use mtd->get_unmapped_area directly mtd: do not use mtd->get_unmapped_area directly mtd: do use mtd->point directly mtd: introduce mtd_has_oob helper mtd: mtdcore: export symbols cleanup mtd: clean-up the default_mtd_writev function ... Fix up trivial edit/remove conflict in drivers/staging/spectra/lld_mtd.c
2012-01-09mtd: introduce mtd_block_isbad interfaceArtem Bityutskiy
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-01-09mtd: introduce mtd_read interfaceArtem Bityutskiy
2011-12-05Merge branch 'fortglx/3.3/tip/timers/core' of ↵Thomas Gleixner
git://git.linaro.org/people/jstultz/linux into timers/core
2011-11-21clocksource: cris: Convert to clocksource_register_khzJohn Stultz
This converts the cris architecture to use clocksource_register_khz This is untested, so any help from maintainers would be appreciated. CC: Mikael Starvik <starvik@axis.com> CC: Jesper Nilsson <jesper.nilsson@axis.com> CC: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <johnstul@us.ibm.com>
2011-11-09net: Fix references to deleted NET_ETHERNET Kconfig setting.David S. Miller
Change them over to plain "ETHERNET" Reported-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-11-07Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (226 commits) mtd: tests: annotate as DANGEROUS in Kconfig mtd: tests: don't use mtd0 as a default mtd: clean up usage of MTD_DOCPROBE_ADDRESS jffs2: add compr=lzo and compr=zlib options jffs2: implement mount option parsing and compression overriding mtd: nand: initialize ops.mode mtd: provide an alias for the redboot module name mtd: m25p80: don't probe device which has status of 'disabled' mtd: nand_h1900 never worked mtd: Add DiskOnChip G3 support mtd: m25p80: add EON flash EN25Q32B into spi flash id table mtd: mark block device queue as non-rotational mtd: r852: make r852_pm_ops static mtd: m25p80: add support for at25df321a spi data flash mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks mtd: nand: switch `check_pattern()' to standard `memcmp()' mtd: nand: invalidate cache on unaligned reads mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set mtd: nand: wait to set BBT version mtd: nand: scrub BBT on ECC errors ... Fix up trivial conflicts: - arch/arm/mach-at91/board-usb-a9260.c Merged into board-usb-a926x.c - drivers/mtd/maps/lantiq-flash.c add_mtd_partitions -> mtd_device_register vs changed to use mtd_device_parse_register.
2011-10-31kgdb: follow rename pack_hex_byte() to hex_byte_pack()Andy Shevchenko
There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits) dp83640: free packet queues on remove dp83640: use proper function to free transmit time stamping packets ipv6: Do not use routes from locally generated RAs |PATCH net-next] tg3: add tx_dropped counter be2net: don't create multiple RX/TX rings in multi channel mode be2net: don't create multiple TXQs in BE2 be2net: refactor VF setup/teardown code into be_vf_setup/clear() be2net: add vlan/rx-mode/flow-control config to be_setup() net_sched: cls_flow: use skb_header_pointer() ipv4: avoid useless call of the function check_peer_pmtu TCP: remove TCP_DEBUG net: Fix driver name for mdio-gpio.c ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces ipv4: fix ipsec forward performance regression jme: fix irq storm after suspend/resume route: fix ICMP redirect validation net: hold sock reference while processing tx timestamps tcp: md5: add more const attributes Add ethtool -g support to virtio_net ... Fix up conflicts in: - drivers/net/Kconfig: The split-up generated a trivial conflict with removal of a stale reference to Documentation/networking/net-modules.txt. Remove it from the new location instead. - fs/sysfs/dir.c: Fairly nasty conflicts with the sysfs rb-tree usage, conflicting with Eric Biederman's changes for tagged directories.
2011-10-13cris: remove arch/cris/arch-v32/lib/nand_init.SPaul Bolle
Commit 3f50c0673cf5edd2c6bb76243410c3cd59b3b62d ("CRIS v32: Update boot/rescue/head.S code") removed the last reference to that file. So this file is unused since v2.6.25. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-09-22Merge branch 'master' of github.com:davem330/netDavid S. Miller
Conflicts: MAINTAINERS drivers/net/Kconfig drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c drivers/net/ethernet/broadcom/tg3.c drivers/net/wireless/iwlwifi/iwl-pci.c drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c drivers/net/wireless/rt2x00/rt2800usb.c drivers/net/wireless/wl12xx/main.c
2011-09-15MII: fix Kconfig dependencies for MIIJeff Kirsher
MII Kconfig option is apart of the core networking drivers and by default NET_CORE is enabled so drivers selecting MII will have MII enabled as well. It was found using the randconfig option during testing, MII would be selected but NET_CORE could be disabled. This caused a dependency error. Resolved the dependency by selecting NET_CORE when MII is selected. Reported-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-11mtd: nand: rename NAND_USE_FLASH_BBTBrian Norris
Recall the recently added prefix requirements: * "NAND_" for flags in nand.h, used in nand_chip.options * "NAND_BBT_" for flags in bbm.h, used in nand_chip.bbt_options or in nand_bbt_descr.options Thus, I am changing NAND_USE_FLASH_BBT to NAND_BBT_USE_FLASH. Again, this flag is found in bbm.h and so should NOT be used in the "nand_chip.options" field. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-09-11mtd: nand: consolidate redundant flash-based BBT flagsBrian Norris
This patch works with the following three flags from two headers (nand.h and bbm.h): (1) NAND_USE_FLASH_BBT (nand.h) (2) NAND_USE_FLASH_BBT_NO_OOB (nand.h) (3) NAND_BBT_NO_OOB (bbm.h) These flags are all related and interdependent, yet they were in different headers. Flag (2) is simply the combination of (1) and (3) and can be eliminated. This patch accomplishes the following: * eliminate NAND_USE_FLASH_BBT_NO_OOB (i.e., flag (2)) * move NAND_USE_FLASH_BBT (i.e., flag (1)) to bbm.h It's important to note that because (1) and (3) are now both found in bbm.h, they should NOT be used in the "nand_chip.options" field. I removed a small section from the mtdnand DocBook because it referes to NAND_USE_FLASH_BBT in nand.h, which has been moved to bbm.h. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-08-26All Arch: remove linkage for sys_nfsservctl system callNeilBrown
The nfsservctl system call is now gone, so we should remove all linkage for it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25cris: fix some build warnings in pinmux.cWANG Cong
Fix some harmless warnings such as arch/cris/arch-v32/mach-a3/pinmux.c:273: warning: ISO C90 forbids mixed declarations and code: Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28Merge branch 'setns'Linus Torvalds
* setns: ns: Wire up the setns system call Done as a merge to make it easier to fix up conflicts in arm due to addition of sendmmsg system call
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-27Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (97 commits) mtd: kill CONFIG_MTD_PARTITIONS mtd: remove add_mtd_partitions, add_mtd_device and friends mtd: convert remaining users to mtd_device_register() mtd: samsung onenand: convert to mtd_device_register() mtd: omap2 onenand: convert to mtd_device_register() mtd: txx9ndfmc: convert to mtd_device_register() mtd: tmio_nand: convert to mtd_device_register() mtd: socrates_nand: convert to mtd_device_register() mtd: sharpsl: convert to mtd_device_register() mtd: s3c2410 nand: convert to mtd_device_register() mtd: ppchameleonevb: convert to mtd_device_register() mtd: orion_nand: convert to mtd_device_register() mtd: omap2: convert to mtd_device_register() mtd: nomadik_nand: convert to mtd_device_register() mtd: ndfc: convert to mtd_device_register() mtd: mxc_nand: convert to mtd_device_register() mtd: mpc5121_nfc: convert to mtd_device_register() mtd: jz4740_nand: convert to mtd_device_register() mtd: h1910: convert to mtd_device_register() mtd: fsmc_nand: convert to mtd_device_register() ... Fixed up trivial conflicts in - drivers/mtd/maps/integrator-flash.c: removed in ARM tree - drivers/mtd/maps/physmap.c: addition of afs partition probe type clashing with removal of CONFIG_MTD_PARTITIONS
2011-05-25cris: convert old cpumask API into new oneKOSAKI Motohiro
Adapt to the new API. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Thiago Farina <tfransosi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mtd: cris: convert to mtd_device_register()Jamie Iles
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS preprocessor conditionals as partitioning is always available. Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-18cris: typo in mach-fs MakefileSarah Nadi
Signed-off-by: Sarah Nadi <snadi@uwaterloo.ca> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-14sched: Provide scheduler_ipi() callback in response to smp_send_reschedule()Peter Zijlstra
For future rework of try_to_wake_up() we'd like to push part of that function onto the CPU the task is actually going to run on. In order to do so we need a generic callback from the existing scheduler IPI. This patch introduces such a generic callback: scheduler_ipi() and implements it as a NOP. BenH notes: PowerPC might use this IPI on offline CPUs under rare conditions! Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110405152728.744338123@chello.nl
2011-03-28Merge branch 'for-linus' of git://www.jni.nu/crisLinus Torvalds
* 'for-linus' of git://www.jni.nu/cris: Correct auto-restart of syscalls via restartblock CRISv10: Fix return before mutex_unlock in pcf8563 Drop the CRISv32 version of pcf8563
2011-03-25Merge branch 'master' of ↵Artem Bityutskiy
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus-1 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6: (9356 commits) [media] rc: update for bitop name changes fs: simplify iget & friends fs: pull inode->i_lock up out of writeback_single_inode fs: rename inode_lock to inode_hash_lock fs: move i_wb_list out from under inode_lock fs: move i_sb_list out from under inode_lock fs: remove inode_lock from iput_final and prune_icache fs: Lock the inode LRU list separately fs: factor inode disposal fs: protect inode->i_state with inode->i_lock lib, arch: add filter argument to show_mem and fix private implementations SLUB: Write to per cpu data when allocating it slub: Fix debugobjects with lockless fastpath autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd() autofs4 - remove autofs4_lock autofs4 - fix d_manage() return on rcu-walk autofs4 - fix autofs4_expire_indirect() traversal autofs4 - fix dentry leak in autofs4_expire_direct() autofs4 - reinstate last used update on access vfs - check non-mountpoint dentry might block in __follow_mount_rcu() ... NOTE! This merge commit was created to fix compilation error. The block tree was merged upstream and removed the 'elv_queue_empty()' function which the new 'mtdswap' driver is using. So a simple merge of the mtd tree with upstream does not compile. And the mtd tree has already be published, so re-basing it is not an option. To fix this unfortunate situation, I had to merge upstream into the mtd-2.6.git tree without committing, put the fixup patch on top of this, and then commit this. The result is that we do not have commits which do not compile. In other words, this merge commit "merges" 3 things: the MTD tree, the upstream tree, and the fixup patch.
