<linux/sched/debug.h>
We are going to split <linux/sched/debug.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/debug.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma
Pull rdma DMA mapping updates from Doug Ledford:
"Drop IB DMA mapping code and use core DMA code instead.
Bart Van Assche noted that the ib DMA mapping code was significantly
similar enough to the core DMA mapping code that with a few changes it
was possible to remove the IB DMA mapping code entirely and switch the
RDMA stack to use the core DMA mapping code.
This resulted in a nice set of cleanups, but touched the entire tree
and has been kept separate for that reason."
* tag 'for-next-dma_ops' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (37 commits)
IB/rxe, IB/rdmavt: Use dma_virt_ops instead of duplicating it
IB/core: Remove ib_device.dma_device
nvme-rdma: Switch from dma_device to dev.parent
RDS: net: Switch from dma_device to dev.parent
IB/srpt: Modify a debug statement
IB/srp: Switch from dma_device to dev.parent
IB/iser: Switch from dma_device to dev.parent
IB/IPoIB: Switch from dma_device to dev.parent
IB/rxe: Switch from dma_device to dev.parent
IB/vmw_pvrdma: Switch from dma_device to dev.parent
IB/usnic: Switch from dma_device to dev.parent
IB/qib: Switch from dma_device to dev.parent
IB/qedr: Switch from dma_device to dev.parent
IB/ocrdma: Switch from dma_device to dev.parent
IB/nes: Remove a superfluous assignment statement
IB/mthca: Switch from dma_device to dev.parent
IB/mlx5: Switch from dma_device to dev.parent
IB/mlx4: Switch from dma_device to dev.parent
IB/i40iw: Remove a superfluous assignment statement
IB/hns: Switch from dma_device to dev.parent
This file was only including module.h for exception table related
functions. We've now separated that content out into its own file
"extable.h" so now move over to that and avoid all the extra header
content in module.h that we don't really need to compile this file.
Reported-by: kbuild test robot <lkp@intel.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: linux-cris-kernel@axis.com
Most dma_map_ops structures are never modified. Constify these
structures such that these can be write-protected. This patch
has been generated as follows:
git grep -l 'struct dma_map_ops' |
xargs -d\\n sed -i \
-e 's/struct dma_map_ops/const struct dma_map_ops/g' \
-e 's/const struct dma_map_ops {/struct dma_map_ops {/g' \
-e 's/^const struct dma_map_ops;$/struct dma_map_ops;/' \
-e 's/const const struct dma_map_ops /const struct dma_map_ops /g';
sed -i -e 's/const \(struct dma_map_ops intel_dma_ops\)/\1/' \
$(git grep -l 'struct dma_map_ops intel_dma_ops');
sed -i -e 's/const \(struct dma_map_ops dma_iommu_ops\)/\1/' \
$(git grep -l 'struct dma_map_ops' | grep ^arch/powerpc);
sed -i -e '/^struct vmd_dev {$/,/^};$/ s/const \(struct dma_map_ops[[:blank:]]dma_ops;\)/\1/' \
-e '/^static void vmd_setup_dma_ops/,/^}$/ s/const \(struct dma_map_ops \*dest\)/\1/' \
-e 's/const \(struct dma_map_ops \*dest = \&vmd->dma_ops\)/\1/' \
drivers/pci/host/*.c
sed -i -e '/^void __init pci_iommu_alloc(void)$/,/^}$/ s/dma_ops->/intel_dma_ops./' arch/ia64/kernel/pci-dma.c
sed -i -e 's/static const struct dma_map_ops sn_dma_ops/static struct dma_map_ops sn_dma_ops/' arch/ia64/sn/pci/pci_dma.c
sed -i -e 's/(const struct dma_map_ops \*)//' drivers/misc/mic/bus/vop_bus.c
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: x86@kernel.org
Signed-off-by: Doug Ledford <dledford@redhat.com>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
It is the reasonable expectation that if an executable file is not
readable there will be no way for a user without special privileges to
read the file. This is enforced in ptrace_attach but if ptrace
is already attached before exec there is no enforcement for read-only
executables.
As the only way to read such an mm is through access_process_vm
spin a variant called ptrace_access_vm that will fail if the
target process is not being ptraced by the current process, or
the current process did not have sufficient privileges when ptracing
began to read the target processes mm.
In the ptrace implementations replace access_process_vm by
ptrace_access_vm. There remain several ptrace sites that still use
access_process_vm as they are reading the target executables
instructions (for kernel consumption) or register stacks. As such it
does not appear necessary to add a permission check to those calls.
This bug has always existed in Linux.
Fixes: v1.0
Cc: stable@vger.kernel.org
Reported-by: Andy Lutomirski <luto@amacapital.net>
It makes the result hard to interpret correctly if a base 10 number is
prefixed by 0x. So change to a hex number.
Link: http://lkml.kernel.org/r/20161026125658.25728-6-u.kleine-koenig@pengutronix.de
This removes the 'write' argument from access_process_vm() and replaces
it with 'gup_flags' as use of this function previously silently implied
FOLL_FORCE, whereas after this patch callers explicitly pass this flag.
We make this explicit as use of FOLL_FORCE can result in surprising
behaviour (and hence bugs) within the mm subsystem.
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
This removes the 'write' and 'force' from get_user_pages() and replaces
them with 'gup_flags' to make the use of FOLL_FORCE explicit in callers
as use of this flag can result in surprising behaviour (and hence bugs)
Acked-by: Christian König <christian.koenig@amd.com>
Return value of class_create should be considered in module init function.
Signed-off-by: Zhouyi Zhou <zhouzhouyi@gmail.com>
Signed-off-by: Jesper Nilsson <jespern@axis.com>
We unlocked a few lines earlier so we can delete these unlocks.
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
arch/cris/arch-v32/drivers/pci/bios.c:3:35: fatal error: arch/hwregs/intr_vect.h: No such file or directory
#include <arch/hwregs/intr_vect.h>
Signed-off-by: Niklas Cassel <nks@flawful.org>
array "interrupt" only has 32 or 64 elements, depending on machine.
arch/cris/arch-v32/kernel/irq.c: In function ‘init_IRQ’:
arch/cris/arch-v32/kernel/irq.c:475:3: warning: iteration 32u invokes undefined behavior [-Waggressive-loop-optimizations]
set_exception_vector(i, interrupt[j]);
arch/cris/arch-v32/kernel/irq.c:474:2: note: containing loop
for (i = FIRST_IRQ, j = 0; j < NBR_INTR_VECT; i++, j++) {
arch/cris/arch-v32/kernel/fasttimer.c: In function ‘timer_trig_handler’:
arch/cris/arch-v32/kernel/fasttimer.c:353:2: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
fast_timer_function_type *f;
The code previously depended on list_head being defined
as the first item in struct intmem_allocation.
arch/cris/arch-v32/mm/intmem.c: In function ‘crisv32_intmem_free’:
arch/cris/arch-v32/mm/intmem.c:116:14: warning: comparison of distinct pointer types lacks a cast
if ((prev != &intmem_allocations) &&
arch/cris/arch-v32/mm/intmem.c:123:14: warning: comparison of distinct pointer types lacks a cast
if ((next != &intmem_allocations) &&
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cannot add __init macro to crisv32_intmem_init,
since the function is being called by other functions.
Creating a wrapper instead.
arch/cris/arch-v32/mm/intmem.c: At top level:
arch/cris/arch-v32/mm/intmem.c:148:17: warning: initialization from incompatible pointer type
device_initcall(crisv32_intmem_init);
include/linux/init.h:184:58: note: in definition of macro ‘__define_initcall’
__attribute__((__section__(".initcall" #id ".init"))) = fn; \
arch/cris/arch-v32/mm/intmem.c:148:1: note: in expansion of macro ‘device_initcall’
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
This has been unused, except as the condition for a fatal error, since
commit c13cbf3b5086 ("[MTD] mtdram: Quick cleanup of the driver:") in
2.6.13 (!).
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Pull MTD updates from Brian Norris:
"First cycle with Boris as NAND maintainer! Many (most) bullets stolen
from him.
Generic:
- Migrated NAND LED trigger to be a generic MTD trigger
NAND:
- Introduction of the "ECC algorithm" concept, to avoid overloading
the ECC mode field too much more
- Replaced the nand_ecclayout infrastructure with something a little
more flexible (finally!) and future proof
- Rework of the OMAP GPMC and NAND drivers; the TI folks pulled some
of this into their own tree as well
- Prepare the sunxi NAND driver to receive DMA support
- Handle bitflips in erased pages on GPMI revisions that do not
support this in hardware.
SPI NOR:
- Start using the spi_flash_read() API for SPI drivers that support
it (i.e., SPI drivers with special memory-mapped flash modes)
And other small scattered improvments"
* tag 'for-linus-20160523' of git://git.infradead.org/linux-mtd: (155 commits)
mtd: spi-nor: support GigaDevice gd25lq64c
mtd: nand_bch: fix spelling of "probably"
mtd: brcmnand: respect ECC algorithm set by NAND subsystem
gpmi-nand: Handle ECC Errors in erased pages
Documentation: devicetree: deprecate "soft_bch" nand-ecc-mode value
mtd: nand: add support for "nand-ecc-algo" DT property
mtd: mtd: drop NAND_ECC_SOFT_BCH enum value
mtd: drop support for NAND_ECC_SOFT_BCH as "soft_bch" mapping
mtd: nand: read ECC algorithm from the new field
mtd: nand: fsmc: validate ECC setup by checking algorithm directly
mtd: nand: set ECC algorithm to Hamming on fallback
staging: mt29f_spinand: set ECC algorithm explicitly
CRIS v32: nand: set ECC algorithm explicitly
mtd: nand: atmel: set ECC algorithm explicitly
mtd: nand: davinci: set ECC algorithm explicitly
mtd: nand: bf5xx: set ECC algorithm explicitly
mtd: nand: omap2: Fix high memory dma prefetch transfer
mtd: nand: omap2: Start dma request before enabling prefetch
mtd: nandsim: add __init attribute
mtd: nand: move of_get_nand_xxx() helpers into nand_base.c
We need to call exit_thread from copy_process in a fail path. So make it
accept task_struct as a parameter.
[v2]
* s390: exit_thread_runtime_instr doesn't make sense to be called for
non-current tasks.
* arm: fix the comment in vfp_thread_copy
* change 'me' to 'tsk' for task_struct
* now we can change only archs that actually have exit_thread
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Helge Deller <deller@gmx.de>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Rich Felker <dalias@libc.org>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Richard Weinberger <richard@nod.at>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
This is part of process deprecating NAND_ECC_SOFT_BCH (and switching to
enum nand_ecc_algo).
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Mikael Starvik <starvik@axis.com>
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
We will soon modify the vanilla get_user_pages() so it can no
longer be used on mm/tasks other than 'current/current->mm',
which is by far the most common way it is called. For now,
we allow the old-style calls, but warn when they are used.
(implemented in previous patch)
This patch switches all callers of:
get_user_pages()
get_user_pages_unlocked()
get_user_pages_locked()
to stop passing tsk/mm so they will no longer see the warnings.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Hansen <dave@sr71.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: jack@suse.cz
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20160212210156.113E9407@viggo.jf.intel.com
Merge third patch-bomb from Andrew Morton:
"I'm pretty much done for -rc1 now:
- the rest of MM, basically
- lib/ updates
- checkpatch, epoll, hfs, fatfs, ptrace, coredump, exit
- cpu_mask simplifications
- kexec, rapidio, MAINTAINERS etc, etc.
- more dma-mapping cleanups/simplifications from hch"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (109 commits)
MAINTAINERS: add/fix git URLs for various subsystems
mm: memcontrol: add "sock" to cgroup2 memory.stat
mm: memcontrol: basic memory statistics in cgroup2 memory controller
mm: memcontrol: do not uncharge old page in page cache replacement
Documentation: cgroup: add memory.swap.{current,max} description
mm: free swap cache aggressively if memcg swap is full
mm: vmscan: do not scan anon pages if memcg swap limit is hit
swap.h: move memcg related stuff to the end of the file
mm: memcontrol: replace mem_cgroup_lruvec_online with mem_cgroup_online
mm: vmscan: pass memcg to get_scan_count()
mm: memcontrol: charge swap to cgroup2
mm: memcontrol: clean up alloc, online, offline, free functions
mm: memcontrol: flatten struct cg_proto
mm: memcontrol: rein in the CONFIG space madness
net: drop tcp_memcontrol.c
mm: memcontrol: introduce CONFIG_MEMCG_LEGACY_KMEM
mm: memcontrol: allow to disable kmem accounting for cgroup2
mm: memcontrol: account "kmem" consumers in cgroup2 memory controller
mm: memcontrol: move kmem accounting code to CONFIG_MEMCG
mm: memcontrol: separate kmem code from legacy tcp accounting code
git://git.kernel.org/pub/scm/linux/kernel/git/jesper/cris
Pull CRIS updates from Jesper Nilsson:
"Just some fixups for section mismatches from Guenter"
* tag 'cris-for-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/jesper/cris:
cris: Fix section mismatches in architecture startup code
cris: debugport: Fix section mismatches
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
mtd_to_nand() now uses the container_of() approach to transform an
mtd_info pointer into a nand_chip one. Drop useless mtd->priv
assignments from NAND controller drivers.
struct nand_chip now embeds an mtd device. Patch all drivers to make use
of this mtd instance instead of using the instance embedded in their
private struct or dynamically allocated.
Section mismatches can now result in build failures.
As result, cris:allnoconfig fails to build as follows.
WARNING: modpost: Found 7 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
FATAL: modpost: Section mismatches detected.
Set CONFIG_SECTION_MISMATCH_WARN_ONLY=y to allow them.
Part of the problem is that references from .text to .init.text
are not permitted, and such references are used in cris startup code.
Since references from .head.text to .init.text are permitted, move
cris startup code to a new section .head.text.
mtd_to_nand() was recently introduced to avoid direct accesses to the
mtd->priv field. Update all CRIS specific implementations to use this
helper.
Acked-by: Brian Norris <computersforpeace@gmail.com>
Drop all code related to Kconfigs that don't exist.
Fix one Kconfig where it was actually typo:ed (ETRAX_KGB_PORT2)
Drop content related to CRIS v32 SoCs from etraxgpio.h headerfile,
all use of GPIO for both ETRAX FS and ARTPEC-3 should now be through
standard gpiolib instead.
There are native helpers such as print_hex_byte() and %*ph specifier to dump
data in hex format. Re-use them instead of a custom approach.
Since we now have a gpiolib driver, remove this code:
The gpio-etraxfs driver (along with things like gpio-keys-polled for
polling support) replaces the GIO driver implementations in mach-a3 and
mach-fs. The various generic external chip drivers replace the "virtual
gpio" parts.
The generic gpio-leds driver replaces the LED handling.
Signed-off-by: Rabin Vincent <rabin@rab.in>
Now that we have a gpiolib GPIO driver, the generic i2c-gpio driver
provides this functionality.
Increase NR_IQRS so we can fit in GPIO interrupts.
There are kernel native helpers to convert hex ascii to the binary format:
hex_to_bin() and hex2bin(). Thus, no need to reimplement them customly.
Use a call to local_irq_enable() instead of incline asm so that the
irqsoff latency tracer knows that interrupts are enabled here.
Add support irqflags tracing, which is required for things like lockdep
and ftrace.
The exported ptrace.h header on CRIS references an "arch" directory
which does not exist. Fix this by having the variants in the same
directory and including them conditionally, similar to other
architectures.
Fix a number of small issues visible when GPIO is enabled:
- Correct missing default for !ETRAXFS in Kconfig
- Remove information on number of bits for some Kconfigs
related to the GPIO, they are different in ETRAX FS and ARTPEC-3
- Fix compile warning in ARTPEC-3 GPIO driver
Squash the followng warnings
arch/cris/arch-v32/mach-fs/pinmux.c: In function 'crisv32_pinmux_alloc_fixed':
arch/cris/arch-v32/mach-fs/pinmux.c:104:2: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
arch/cris/arch-v32/mach-fs/pinmux.c: In function 'crisv32_pinmux_dealloc_fixed':
arch/cris/arch-v32/mach-fs/pinmux.c:238:2: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
arch/cris/arch-v32/mach-fs/pinmux.c: In function '__crisv32_pinmux_alloc':
arch/cris/arch-v32/mach-fs/pinmux.c:49:1: warning: control reaches end of non-void function [-Wreturn-type]
The related warnings:
CALL scripts/checksyscalls.sh
<stdin>:1229:2: warning: #warning syscall sched_setattr not implemented [-Wcpp]
<stdin>:1232:2: warning: #warning syscall sched_getattr not implemented [-Wcpp]
<stdin>:1235:2: warning: #warning syscall renameat2 not implemented [-Wcpp]
<stdin>:1238:2: warning: #warning syscall seccomp not implemented [-Wcpp]
<stdin>:1241:2: warning: #warning syscall getrandom not implemented [-Wcpp]
<stdin>:1244:2: warning: #warning syscall memfd_create not implemented [-Wcpp]
<stdin>:1247:2: warning: #warning syscall bpf not implemented [-Wcpp]
<stdin>:1250:2: warning: #warning syscall execveat not implemented [-Wcpp]
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
Turn a kmalloc/memset into an equivalent kzalloc.
Doing so also move the zero'ing of the memory outside of a mutex.
Signed-off-by: Christophe Jaillet <christophe.jaillet@wanadoo.fr>
Migrate cris driver to the new 'set-state' interface provided by
clockevents core, the earlier 'set-mode' interface is marked obsolete
now.
This also enables us to implement callbacks for new states of clockevent
devices, for example: ONESHOT_STOPPED.
Cc: Rabin Vincent <rabin@rab.in>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
ktime_get_ts() is the proper interface today.
