Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela,
ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version
into asm-generic/module.h for all arches bar MIPS.
Also, use the generic definition mod_arch_specific where possible.
To this end, I've defined three new config bools:
(*) HAVE_MOD_ARCH_SPECIFIC
Arches define this if they don't want to use the empty generic
mod_arch_specific struct.
(*) MODULES_USE_ELF_RELA
Arches define this if their modules can contain RELA records. This causes
the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be
defined by the arch rather than have the core emit an error message.
Arches define this if their modules can contain REL records. This causes
the Elf_Rel mapping to be emitted and allows apply_relocate() to be
Note that it is possible to allow both REL and RELA records: m68k and mips are
two arches that do this.
With this, some arch asm/module.h files can be deleted entirely and replaced
with a generic-y marker in the arch Kbuild file.
Additionally, I have removed the bits from m32r and score that handle the
unsupported type of relocation record as that's now handled centrally.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Pull C6X atomic64 support from Mark Salter:
"Enable atomic64 ops in C6X
- define L1_CACHE_SHIFT
- select GENERIC_ATOMIC64"
* tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming:
C6X: select GENERIC_ATOMIC64
C6X: add Lx_CACHE_SHIFT defines
The generic atomic64 support came in 2009 to support the perf subsystem
with the expectation that all architectures would implement atomic64
support. Since then, other optional parts of the generic kernel have
also come to expect atomic64 support. This patch enables generic atomic64
support for C6X architecture.
Signed-off-by: Mark Salter <msalter@redhat.com>
C6X currently lacks Lx_CACHE_SHIFT defines which are needed in a
few places in the generic kernel. This patch adds _SHIFT defines
for the various caches and bases the Lx_CACHE_BYTES defines on
them.
Pull networking changes from David S Miller:
1) Remove the ipv4 routing cache. Now lookups go directly into the FIB
trie and use prebuilt routes cached there.
No more garbage collection, no more rDOS attacks on the routing
cache. Instead we now get predictable and consistent performance,
no matter what the pattern of traffic we service.
This has been almost 2 years in the making. Special thanks to
Julian Anastasov, Eric Dumazet, Steffen Klassert, and others who
have helped along the way.
I'm sure that with a change of this magnitude there will be some
kind of fallout, but such things ought the be simple to fix at this
point. Luckily I'm not European so I'll be around all of August to
fix things :-)
The major stages of this work here are each fronted by a forced
merge commit whose commit message contains a top-level description
of the motivations and implementation issues.
2) Pre-demux of established ipv4 TCP sockets, saves a route demux on
input.
3) TCP SYN/ACK performance tweaks from Eric Dumazet.
4) Add namespace support for netfilter L4 conntrack helpers, from Gao
Feng.
5) Add config mechanism for Energy Efficient Ethernet to ethtool, from
Yuval Mintz.
6) Remove quadratic behavior from /proc/net/unix, from Eric Dumazet.
7) Support for connection tracker helpers in userspace, from Pablo
Neira Ayuso.
8) Allow userspace driven TX load balancing functions in TEAM driver,
from Jiri Pirko.
9) Kill off NLMSG_PUT and RTA_PUT macros, more gross stuff with
embedded gotos.
10) TCP Small Queues, essentially minimize the amount of TCP data queued
up in the packet scheduler layer. Whereas the existing BQL (Byte
Queue Limits) limits the pkt_sched --> netdevice queuing levels,
this controls the TCP --> pkt_sched queueing levels.
From Eric Dumazet.
11) Reduce the number of get_page/put_page ops done on SKB fragments,
from Alexander Duyck.
12) Implement protection against blind resets in TCP (RFC 5961), from
Eric Dumazet.
13) Support the client side of TCP Fast Open, basically the ability to
send data in the SYN exchange, from Yuchung Cheng.
Basically, the sender queues up data with a sendmsg() call using
MSG_FASTOPEN, then they do the connect() which emits the queued up
fastopen data.
14) Avoid all the problems we get into in TCP when timers or PMTU events
hit a locked socket. The TCP Small Queues changes added a
tcp_release_cb() that allows us to queue work up to the
release_sock() caller, and that's what we use here too. From Eric
Dumazet.
15) Zero copy on TX support for TUN driver, from Michael S. Tsirkin.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1870 commits)
genetlink: define lockdep_genl_is_held() when CONFIG_LOCKDEP
r8169: revert "add byte queue limit support".
ipv4: Change rt->rt_iif encoding.
net: Make skb->skb_iif always track skb->dev
ipv4: Prepare for change of rt->rt_iif encoding.
ipv4: Remove all RTCF_DIRECTSRC handliing.
ipv4: Really ignore ICMP address requests/replies.
decnet: Don't set RTCF_DIRECTSRC.
net/ipv4/ip_vti.c: Fix __rcu warnings detected by sparse.
ipv4: Remove redundant assignment
rds: set correct msg_namelen
openvswitch: potential NULL deref in sample()
tcp: dont drop MTU reduction indications
bnx2x: Add new 57840 device IDs
tcp: avoid oops in tcp_metrics and reset tcpm_stamp
niu: Change niu_rbr_fill() to use unlikely() to check niu_rbr_add_page() return value
niu: Fix to check for dma mapping errors.
net: Fix references to out-of-scope variables in put_cmsg_compat()
net: ethernet: davinci_emac: add pm_runtime support
net: ethernet: davinci_emac: Remove unnecessary #include
commit a610d6e6: pull clearing RESTORE_SIGMASK into block_sigmask()
left behind a compiler warning:
arch/c6x/kernel/signal.c:252:6: warning: unused variable 'ret'
This patch cleans up the warning by removing the unused variable.
This patch adds support for the TMS320C6678 SoC on an EVMC6678LE
evaluation board. The 6678 is a C66x family CPU which is very similar
to the already supported C64x CPUs with the addition of floating point
instructions.
Signed-off-by: Ken Cox <jkc@redhat.com>
CC: Aurelien Jacquiot <a-jacquiot@ti.com>
CC: linux-c6x-dev@linux-c6x.org
The core priority PIC code uses legacy irq support to facilitate direct
mapping of core hw interrupt numbers to linux interrupt numbers. This
patch removes the legacy irq usage and replaces it with a generic linear
mapping.
The megamodule PIC cascades a number of interrupt sources into the core
priority PIC. The megamodule code depends on the core hardware interrupt
numbers being mapped one-to-one with regard to linux interrupt numbers.
This patch removes that dependence in order to pave the way for removing
the direct mapping in the core PIC code.
Convert the existing uses of random_ether_addr to
the new eth_random_addr.
Does block_sigmask() + tracehook_signal_handler(); called when
sigframe has been successfully built. All architectures converted
to it; block_sigmask() itself is gone now (merged into this one).
I'm still not too happy with the signature, but that's a separate
story (IMO we need a structure that would contain signal number +
siginfo + k_sigaction, so that get_signal_to_deliver() would fill one,
signal_delivered(), handle_signal() and probably setup...frame() -
take one).
Only 3 out of 63 do not. Renamed the current variant to __set_current_blocked(),
added set_current_blocked() that will exclude unblockable signals, switched
open-coded instances to it.
replace boilerplate "should we use ->saved_sigmask or ->blocked?"
with calls of obvious inlined helper...
first fruits of ..._restore_sigmask() helpers: now we can take
boilerplate "signal didn't have a handler, clear RESTORE_SIGMASK
and restore the blocked mask from ->saved_mask" into a common
helper. Open-coded instances switched...
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull second pile of signal handling patches from Al Viro:
"This one is just task_work_add() series + remaining prereqs for it.
There probably will be another pull request from that tree this
cycle - at least for helpers, to get them out of the way for per-arch
fixes remaining in the tree."
Fix trivial conflict in kernel/irq/manage.c: the merge of Andrew's pile
had brought in commit 97fd75b7b8e0 ("kernel/irq/manage.c: use the
pr_foo() infrastructure to prefix printks") which changed one of the
pr_err() calls that this merge moves around.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
keys: kill task_struct->replacement_session_keyring
keys: kill the dummy key_replace_session_keyring()
keys: change keyctl_session_to_parent() to use task_work_add()
genirq: reimplement exit_irq_thread() hook via task_work_add()
task_work_add: generic process-context callbacks
avr32: missed _TIF_NOTIFY_RESUME on one of do_notify_resume callers
parisc: need to check NOTIFY_RESUME when exiting from syscall
move key_repace_session_keyring() into tracehook_notify_resume()
TIF_NOTIFY_RESUME is defined on all targets now
Pull KVM changes from Avi Kivity:
"Changes include additional instruction emulation, page-crossing MMIO,
faster dirty logging, preventing the watchdog from killing a stopped
guest, module autoload, a new MSI ABI, and some minor optimizations
and fixes. Outside x86 we have a small s390 and a very large ppc
update.
Regarding the new (for kvm) rebaseless workflow, some of the patches
that were merged before we switch trees had to be rebased, while
others are true pulls. In either case the signoffs should be correct
now."
Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
arch/powerpc/kvm/book3s_segment.S and arch/x86/include/asm/kvm_para.h.
I suspect the kvm_para.h resolution ends up doing the "do I have cpuid"
check effectively twice (it was done differently in two different
commits), but better safe than sorry ;)
* 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (125 commits)
KVM: make asm-generic/kvm_para.h have an ifdef __KERNEL__ block
KVM: s390: onereg for timer related registers
KVM: s390: epoch difference and TOD programmable field
KVM: s390: KVM_GET/SET_ONEREG for s390
KVM: s390: add capability indicating COW support
KVM: Fix mmu_reload() clash with nested vmx event injection
KVM: MMU: Don't use RCU for lockless shadow walking
KVM: VMX: Optimize %ds, %es reload
KVM: VMX: Fix %ds/%es clobber
KVM: x86 emulator: convert bsf/bsr instructions to emulate_2op_SrcV_nobyte()
KVM: VMX: unlike vmcs on fail path
KVM: PPC: Emulator: clean up SPR reads and writes
KVM: PPC: Emulator: clean up instruction parsing
kvm/powerpc: Add new ioctl to retreive server MMU infos
kvm/book3s: Make kernel emulated H_PUT_TCE available for "PR" KVM
KVM: PPC: bookehv: Fix r8/r13 storing in level exception handler
KVM: PPC: Book3S: Enable IRQs during exit handling
KVM: PPC: Fix PR KVM on POWER7 bare metal
KVM: PPC: Fix stbux emulation
KVM: PPC: bookehv: Use lwz/stw instead of PPC_LL/PPC_STL for 32-bit fields
Pull timer updates from Thomas Gleixner.
Various trivial conflict fixups in arch Kconfig due to addition of
unrelated entries nearby. And one slightly more subtle one for sparc32
(new user of GENERIC_CLOCKEVENTS), fixed up as per Thomas.
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits)
timekeeping: Fix a few minor newline issues.
time: remove obsolete declaration
ntp: Fix a stale comment and a few stray newlines.
ntp: Correct TAI offset during leap second
timers: Fixup the Kconfig consolidation fallout
x86: Use generic time config
unicore32: Use generic time config
um: Use generic time config
tile: Use generic time config
sparc: Use: generic time config
sh: Use generic time config
score: Use generic time config
s390: Use generic time config
openrisc: Use generic time config
powerpc: Use generic time config
mn10300: Use generic time config
mips: Use generic time config
microblaze: Use generic time config
m68k: Use generic time config
m32r: Use generic time config
Pull first series of signal handling cleanups from Al Viro:
"This is just the first part of the queue (about a half of it);
assorted fixes all over the place in signal handling.
This one ends with all sigsuspend() implementations switched to
generic one (->saved_sigmask-based).
With this, a bunch of assorted old buglets are fixed and most of the
missing bits of NOTIFY_RESUME hookup are in place. Two more fixes sit
in arm and um trees respectively, and there's a couple of broken ones
that need obvious fixes - parisc and avr32 check TIF_NOTIFY_RESUME
only on one of two codepaths; fixes for that will happen in the next
series"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (55 commits)
unicore32: if there's no handler we need to restore sigmask, syscall or no syscall
xtensa: add handling of TIF_NOTIFY_RESUME
microblaze: drop 'oldset' argument of do_notify_resume()
microblaze: handle TIF_NOTIFY_RESUME
score: add handling of NOTIFY_RESUME to do_notify_resume()
m68k: add TIF_NOTIFY_RESUME and handle it.
sparc: kill ancient comment in sparc_sigaction()
h8300: missing checks of __get_user()/__put_user() return values
frv: missing checks of __get_user()/__put_user() return values
cris: missing checks of __get_user()/__put_user() return values
powerpc: missing checks of __get_user()/__put_user() return values
sh: missing checks of __get_user()/__put_user() return values
sparc: missing checks of __get_user()/__put_user() return values
avr32: struct old_sigaction is never used
m32r: struct old_sigaction is never used
xtensa: xtensa_sigaction doesn't exist
alpha: tidy signal delivery up
score: don't open-code force_sigsegv()
cris: don't open-code force_sigsegv()
blackfin: don't open-code force_sigsegv()
Pull fpu state cleanups from Ingo Molnar:
"This tree streamlines further aspects of FPU handling by eliminating
the prepare_to_copy() complication and moving that logic to
arch_dup_task_struct().
It also fixes the FPU dumps in threaded core dumps, removes and old
(and now invalid) assumption plus micro-optimizes the exit path by
avoiding an FPU save for dead tasks."
Fixed up trivial add-add conflict in arch/sh/kernel/process.c that came
in because we now do the FPU handling in arch_dup_task_struct() rather
than the legacy (and now gone) prepare_to_copy().
* 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, fpu: drop the fpu state during thread exit
x86, xsave: remove thread_has_fpu() bug check in __sanitize_i387_state()
coredump: ensure the fpu state is flushed for proper multi-threaded core dump
fork: move the real prepare_to_copy() users to arch_dup_task_struct()
Pull smp hotplug cleanups from Thomas Gleixner:
"This series is merily a cleanup of code copied around in arch/* and
not changing any of the real cpu hotplug horrors yet. I wish I'd had
something more substantial for 3.5, but I underestimated the lurking
horror..."
Fix up trivial conflicts in arch/{arm,sparc,x86}/Kconfig and
arch/sparc/include/asm/thread_info_32.h
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits)
um: Remove leftover declaration of alloc_task_struct_node()
task_allocator: Use config switches instead of magic defines
sparc: Use common threadinfo allocator
score: Use common threadinfo allocator
sh-use-common-threadinfo-allocator
mn10300: Use common threadinfo allocator
powerpc: Use common threadinfo allocator
mips: Use common threadinfo allocator
hexagon: Use common threadinfo allocator
m32r: Use common threadinfo allocator
frv: Use common threadinfo allocator
cris: Use common threadinfo allocator
x86: Use common threadinfo allocator
c6x: Use common threadinfo allocator
fork: Provide kmemcache based thread_info allocator
tile: Use common threadinfo allocator
fork: Provide weak arch_release_[task_struct|thread_info] functions
fork: Move thread info gfp flags to header
fork: Remove the weak insanity
sh: Remove cpu_idle_wait()
Sigh, I missed to check which architecture Kconfig files actually
include the core Kconfig file. There are a few which did not. So we
broke them.
Instead of adding the includes to those, we are better off to move the
include to init/Kconfig like we did already with irqs and others.
This does not change anything for the architectures using the old
style periodic timer mode. It just solves the build wreckage there.
For those architectures which use the clock events infrastructure it
moves the include of the core Kconfig file to "General setup" which is
a way more logical place than having it at random locations specified
by the architecture specific Kconfigs.
Reported-by: Ingo Molnar <mingo@kernel.org>
Cc: Anna-Maria Gleixner <anna-maria@glx-um.de>
Signed-off-by: Anna-Maria Gleixner <anna-maria@glx-um.de>
Acked-by: Mark Salter <msalter@redhat.com>
Link: http://lkml.kernel.org/r/20120518163105.156595383@glx-um.de
Historical prepare_to_copy() is mostly a no-op, duplicated for majority of
the architectures and the rest following the x86 model of flushing the extended
register state like fpu there.
Remove it and use the arch_dup_task_struct() instead.
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Link: http://lkml.kernel.org/r/1336692811-30576-1-git-send-email-suresh.b.siddha@intel.com
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
C6x userspace supports a shared library mechanism called DSBT for systems with
no MMU. DSBT is similar to FDPIC in allowing shared text segments and private
copies of data segments without an MMU. Both methods access data using a base
register and offset. With FDPIC, the caller of an external function sets up the
base register for the callee. With DSBT, the called function sets up its own
base register. Other details differ but both userspaces need the same thing
from the kernel loader: a map of where each ELF segment was loaded. The FDPIC
loader already provides this, so DSBT just uses it.
This patch enables BINFMT_ELF_FDPIC by default for C6X and provides the
necessary architecture hooks for the generic loader.
There is no functional difference. __get_free_pages() ends up calling
alloc_pages_node().
Link: http://lkml.kernel.org/r/20120505150141.621728944@linutronix.de
Now that all archs except ia64 are converted, replace the config and
let the ia64 select CONFIG_ARCH_INIT_TASK
Link: http://lkml.kernel.org/r/20120503085035.867948914@linutronix.de
Same code. Use the generic version.
Acked-and-tested-by: Mark Salter <msalter@redhat.com>
Link: http://lkml.kernel.org/r/20120503085034.412398724@linutronix.de
Currently the c6x architecture uses CONFIG_TMS320C6X as the main
architecture symbol. Most architectures use a more intuitive name
based on the architecture directory name. There are no current
users of TMS320C6X so this patch simply changes CONFIG_TMS320C6X
to the more intuitive CONFIG_C6X.
Merge reason: development work has dependency on kvm patches merged
upstream.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
It makes no sense to export this trivial function. Make it a static inline
instead.
This patch also drops virq_to_hw from arch/c6x since it is unused by that
architecture.
v2: Move irq_hw_number_t into types.h to fix ARM build failure
When a host stops or suspends a VM it will set a flag to show this. The
watchdog will use these functions to determine if a softlockup is real, or the
result of a suspended VM.
Signed-off-by: Eric B Munson <emunson@mgebm.net>
asm-generic changes Acked-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Avi Kivity <avi@redhat.com>
Merge batch of fixes from Andrew Morton:
"The simple_open() cleanup was held back while I wanted for laggards to
merge things.
I still need to send a few checkpoint/restore patches. I've been
wobbly about merging them because I'm wobbly about the overall
prospects for success of the project. But after speaking with Pavel
at the LSF conference, it sounds like they're further toward
completion than I feared - apparently davem is at the "has stopped
complaining" stage regarding the net changes. So I need to go back
and re-review those patchs and their (lengthy) discussion."
* emailed from Andrew Morton <akpm@linux-foundation.org>: (16 patches)
memcg swap: use mem_cgroup_uncharge_swap fix
backlight: add driver for DA9052/53 PMIC v1
C6X: use set_current_blocked() and block_sigmask()
MAINTAINERS: add entry for sparse checker
MAINTAINERS: fix REMOTEPROC F: typo
alpha: use set_current_blocked() and block_sigmask()
simple_open: automatically convert to simple_open()
scripts/coccinelle/api/simple_open.cocci: semantic patch for simple_open()
libfs: add simple_open()
hugetlbfs: remove unregister_filesystem() when initializing module
drivers/rtc/rtc-88pm860x.c: fix rtc irq enable callback
fs/xattr.c:setxattr(): improve handling of allocation failures
fs/xattr.c:listxattr(): fall back to vmalloc() if kmalloc() failed
fs/xattr.c: suppress page allocation failure warnings from sys_listxattr()
sysrq: use SEND_SIG_FORCED instead of force_sig()
proc: fix mount -t proc -o AAA
As described in e6fa16ab9c1e ("signal: sigprocmask() should do
retarget_shared_pending()") the modification of current->blocked is
incorrect as we need to check whether the signal we're about to block is
pending in the shared queue.
Also, use the new helper function introduced in commit 5e6292c0f28f
("signal: add block_sigmask() for adding sigmask to current->blocked")
which centralises the code for updating current->blocked after
successfully delivering a signal and reduces the amount of duplicate
code across architectures. In the past some architectures got this code
wrong, so using this helper function should stop that from happening
again.
Acked-by: Oleg Nesterov <oleg@redhat.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Pull more ARM updates from Russell King.
This got a fair number of conflicts with the <asm/system.h> split, but
also with some other sparse-irq and header file include cleanups. They
all looked pretty trivial, though.
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (59 commits)
ARM: fix Kconfig warning for HAVE_BPF_JIT
ARM: 7361/1: provide XIP_VIRT_ADDR for no-MMU builds
ARM: 7349/1: integrator: convert to sparse irqs
ARM: 7259/3: net: JIT compiler for packet filters
ARM: 7334/1: add jump label support
ARM: 7333/2: jump label: detect %c support for ARM
ARM: 7338/1: add support for early console output via semihosting
ARM: use set_current_blocked() and block_sigmask()
ARM: exec: remove redundant set_fs(USER_DS)
ARM: 7332/1: extract out code patch function from kprobes
ARM: 7331/1: extract out insn generation code from ftrace
ARM: 7330/1: ftrace: use canonical Thumb-2 wide instruction format
ARM: 7351/1: ftrace: remove useless memory checks
ARM: 7316/1: kexec: EOI active and mask all interrupts in kexec crash path
ARM: Versatile Express: add NO_IOPORT
ARM: get rid of asm/irq.h in asm/prom.h
ARM: 7319/1: Print debug info for SIGBUS in user faults
ARM: 7318/1: gic: refactor irq_start assignment
ARM: 7317/1: irq: avoid NULL check in for_each_irq_desc loop
ARM: 7315/1: perf: add support for the Cortex-A7 PMU
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Delete all instances of asm/system.h as they should be redundant by this
point.
Move all declarations of free_initmem() to linux/mm.h so that there's only one
and it's used by everything.
cc: linux-c6x-dev@linux-c6x.org
cc: microblaze-uclinux@itee.uq.edu.au
cc: linux-sh@vger.kernel.org
cc: sparclinux@vger.kernel.org
cc: x86@kernel.org
cc: linux-mm@kvack.org
Disintegrate asm/system.h for C6X.
Commit 33bf56106d9b ("feature removal of io_remap_page_range()") removed
io_remap_page_range(), but it is still included in some arch header
files. It has no in-tree users.
Signed-off-by: Javi Merino <javi.merino@arm.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Pull irq_domain support for all architectures from Grant Likely:
"Generialize powerpc's irq_host as irq_domain
This branch takes the PowerPC irq_host infrastructure (reverse mapping
from Linux IRQ numbers to hardware irq numbering), generalizes it,
renames it to irq_domain, and makes it available to all architectures.
Originally the plan has been to create an all-new irq_domain
implementation which addresses some of the powerpc shortcomings such
as not handling 1:1 mappings well, but doing that proved to be far
more difficult and invasive than generalizing the working code and
refactoring it in-place. So, this branch rips out the 'new'
irq_domain and replaces it with the modified powerpc version (in a
fully bisectable way of course). It converts all users over to the
new API and makes irq_domain selectable on any architecture.
No architecture is forced to enable irq_domain, but the infrastructure
is required for doing OpenFirmware style irq translations. It will
even work on SPARC even though SPARC has it's own mechanism for
translating irqs at boot time. MIPS, microblaze, embedded x86 and c6x
are converted too.
The resulting irq_domain code is probably still too verbose and can be
optimized more, but that can be done incrementally and is a task for
follow-on patches."
* tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6: (31 commits)
dt: fix twl4030 for non-dt compile on x86
mfd: twl-core: Add IRQ_DOMAIN dependency
devicetree: Add empty of_platform_populate() for !CONFIG_OF_ADDRESS (sparc)
irq_domain: Centralize definition of irq_dispose_mapping()
irq_domain/mips: Allow irq_domain on MIPS
irq_domain/x86: Convert x86 (embedded) to use common irq_domain
ppc-6xx: fix build failure in flipper-pic.c and hlwd-pic.c
irq_domain/microblaze: Convert microblaze to use irq_domains
irq_domain/powerpc: Replace custom xlate functions with library functions
irq_domain/powerpc: constify irq_domain_ops
irq_domain/c6x: Use library of xlate functions
irq_domain/c6x: constify irq_domain structures
irq_domain/c6x: Convert c6x to use generic irq_domain support.
irq_domain: constify irq_domain_ops
irq_domain: Create common xlate functions that device drivers can use
irq_domain: Remove irq_domain_add_simple()
irq_domain: Remove 'new' irq_domain in favour of the ppc one
mfd: twl-core.c: Fix the number of interrupts managed by twl4030
of/address: add empty static inlines for !CONFIG_OF
irq_domain: Add support for base irq and hwirq in legacy mappings
The ENDPROC() on sys_fadvise64_c6x() in arch/c6x/kernel/entry.S is
outside of the conditional block with the matching ENTRY() macro. This
leads a newer (v2.22 vs. v2.20) assembler to complain:
/tmp/ccGZBaPT.s: Assembler messages:
/tmp/ccGZBaPT.s: Error: .size expression for sys_fadvise64_c6x does not evaluate to a constant
The conditional block became dead code when c6x switched to generic
unistd.h and should be removed along with the offending ENDPROC().
There was a latent typo in the C6X KSTK_EIP and KSTK_ESP macros which
caused a problem with a new patch which used them. The broken definitions
were of the form:
#define KSTK_FOO(tsk) (task_pt_regs(task)->foo)
Note the use of task vs tsk. This actually worked before because the
only place in the kernel which used these macros passed in a local
pointer named task.
The c6x irq controllers don't need to define custom .xlate hooks
Cc: Rob Herring <rob.herring@calxeda.com>
The C6X IRQ support was copied almost verbatim from the PowerPC virtual IRQ
code. The PowerPC code was used as the basis for generic irq_domain support,
so this patch mostly copies what what done to arch/powerpc by Grant Likely
in his irq_domain patch series.
