Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
KASAN needs to know whether the allocation happens in an IRQ handler.
This lets us strip everything below the IRQ entry point to reduce the
number of unique stack traces needed to be stored.
Move the definition of __irq_entry to <linux/interrupt.h> so that the
users don't need to pull in <linux/ftrace.h>. Also introduce the
__softirq_entry macro which is similar to __irq_entry, but puts the
corresponding functions to the .softirqentry.text section.
Signed-off-by: Alexander Potapenko <glider@google.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Andrey Konovalov <adech.fo@gmail.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Konstantin Serebryany <kcc@google.com>
Cc: Dmitry Chernenkov <dmitryc@google.com>
Pull networking updates from David Miller:
"Highlights:
1) Support more Realtek wireless chips, from Jes Sorenson.
2) New BPF types for per-cpu hash and arrap maps, from Alexei
Starovoitov.
3) Make several TCP sysctls per-namespace, from Nikolay Borisov.
4) Allow the use of SO_REUSEPORT in order to do per-thread processing
of incoming TCP/UDP connections. The muxing can be done using a
BPF program which hashes the incoming packet. From Craig Gallek.
5) Add a multiplexer for TCP streams, to provide a messaged based
interface. BPF programs can be used to determine the message
boundaries. From Tom Herbert.
6) Add 802.1AE MACSEC support, from Sabrina Dubroca.
7) Avoid factorial complexity when taking down an inetdev interface
with lots of configured addresses. We were doing things like
traversing the entire address less for each address removed, and
flushing the entire netfilter conntrack table for every address as
well.
8) Add and use SKB bulk free infrastructure, from Jesper Brouer.
9) Allow offloading u32 classifiers to hardware, and implement for
ixgbe, from John Fastabend.
10) Allow configuring IRQ coalescing parameters on a per-queue basis,
from Kan Liang.
11) Extend ethtool so that larger link mode masks can be supported.
From David Decotigny.
12) Introduce devlink, which can be used to configure port link types
(ethernet vs Infiniband, etc.), port splitting, and switch device
level attributes as a whole. From Jiri Pirko.
13) Hardware offload support for flower classifiers, from Amir Vadai.
14) Add "Local Checksum Offload". Basically, for a tunneled packet
the checksum of the outer header is 'constant' (because with the
checksum field filled into the inner protocol header, the payload
of the outer frame checksums to 'zero'), and we can take advantage
of that in various ways. From Edward Cree"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits)
bonding: fix bond_get_stats()
net: bcmgenet: fix dma api length mismatch
net/mlx4_core: Fix backward compatibility on VFs
phy: mdio-thunder: Fix some Kconfig typos
lan78xx: add ndo_get_stats64
lan78xx: handle statistics counter rollover
RDS: TCP: Remove unused constant
RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket
net: smc911x: convert pxa dma to dmaengine
team: remove duplicate set of flag IFF_MULTICAST
bonding: remove duplicate set of flag IFF_MULTICAST
net: fix a comment typo
ethernet: micrel: fix some error codes
ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it
bpf, dst: add and use dst_tclassid helper
bpf: make skb->tc_classid also readable
net: mvneta: bm: clarify dependencies
cls_bpf: reset class and reuse major in da
ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c
ldmvsw: Add ldmvsw.c driver code
CONFIG_BUG=n && CONFIG_GENERIC_BUG=y make no sense and things break:
In file included from include/linux/page-flags.h:9:0,
from kernel/bounds.c:9:
include/linux/bug.h:91:47: warning: 'struct bug_entry' declared inside parameter list
static inline int is_warning_bug(const struct bug_entry *bug)
include/linux/bug.h:91:47: warning: its scope is only this definition or declaration, which is probably not what you want
include/linux/bug.h: In function 'is_warning_bug':
>> include/linux/bug.h:93:12: error: dereferencing pointer to incomplete type
return bug->flags & BUGFLAG_WARNING;
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Cc: Josh Triplett <josh@joshtriplett.org>
This patch updates all instances of csum_tcpudp_magic and
csum_tcpudp_nofold to reflect the types that are usually used as the source
inputs. For example the protocol field is populated based on nexthdr which
is actually an unsigned 8 bit value. The length is usually populated based
on skb->len which is an unsigned integer.
This addresses an issue in which the IPv6 function csum_ipv6_magic was
generating a checksum using the full 32b of skb->len while
csum_tcpudp_magic was only using the lower 16 bits. As a result we could
run into issues when attempting to adjust the checksum as there was no
protocol agnostic way to update it.
With this change the value is still truncated as many architectures use
"(len + proto) << 8", however this truncation only occurs for values
greater than 16776960 in length and as such is unlikely to occur as we stop
the inner headers at ~64K in size.
I did have to make a few minor changes in the arm, mn10300, nios2, and
score versions of the function in order to support these changes as they
were either using things such as an OR to combine the protocol and length,
or were using ntohs to convert the length which would have truncated the
value.
I also updated a few spots in terms of whitespace and type differences for
the addresses. Most of this was just to make sure all of the definitions
were in sync going forward.
Signed-off-by: Alexander Duyck <aduyck@mirantis.com>
Lockdep is initialized at compile time now. Get rid of lockdep_init().
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Mike Krinkin <krinkin.m.u@gmail.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: mm-commits@vger.kernel.org
Move the generic implementation to <linux/dma-mapping.h> now that all
architectures support it and remove the HAVE_DMA_ATTR Kconfig symbol now
that everyone supports them.
[valentinrothberg@gmail.com: remove leftovers in Kconfig]
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Helge Deller <deller@gmx.de>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com>
[dan.carpenter@oracle.com: C6X: fix build breakage]
git://linux-c6x.org/git/projects/linux-c6x-upstreaming
Pull tiny c6x update from Mark Salter.
* 'for-linux-next' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming:
c6x: Use generic clkdev.h header
It seems that commit 5dc12ddee93 ("Remove tas()") missed some files.
Correct this and fully drop this macro, for which we should be using
cmpxchg() like calls.
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Cc: <linux-arch@vger.kernel.org>
Cc: David Howells <dhowells@re hat.com>
Cc: dave@stgolabs.net
Link: http://lkml.kernel.org/r/1445975631-17047-2-git-send-email-dave@stgolabs.net
The struct irq_domain contains a "struct device_node *" field
(of_node) that is almost the only link between the irqdomain
and the device tree infrastructure.
In order to prepare for the removal of that field, convert all
users to use irq_domain_get_of_node() instead.
Reviewed-and-tested-by: Hanjun Guo <hanjun.guo@linaro.org>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: <linux-arm-kernel@lists.infradead.org>
Cc: Tomasz Nowicki <tomasz.nowicki@linaro.org>
Cc: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com>
Cc: Graeme Gregory <graeme@xora.org.uk>
Cc: Jake Oshins <jakeo@microsoft.com>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Link: http://lkml.kernel.org/r/1444737105-31573-2-git-send-email-marc.zyngier@arm.com
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull strscpy string copy function implementation from Chris Metcalf.
Chris sent this during the merge window, but I waffled back and forth on
the pull request, which is why it's going in only now.
The new "strscpy()" function is definitely easier to use and more secure
than either strncpy() or strlcpy(), both of which are horrible nasty
interfaces that have serious and irredeemable problems.
strncpy() has a useless return value, and doesn't NUL-terminate an
overlong result. To make matters worse, it pads a short result with
zeroes, which is a performance disaster if you have big buffers.
strlcpy(), by contrast, is a mis-designed "fix" for strlcpy(), lacking
the insane NUL padding, but having a differently broken return value
which returns the original length of the source string. Which means
that it will read characters past the count from the source buffer, and
you have to trust the source to be properly terminated. It also makes
error handling fragile, since the test for overflow is unnecessarily
subtle.
strscpy() avoids both these problems, guaranteeing the NUL termination
(but not excessive padding) if the destination size wasn't zero, and
making the overflow condition very obvious by returning -E2BIG. It also
doesn't read past the size of the source, and can thus be used for
untrusted source data too.
So why did I waffle about this for so long?
Every time we introduce a new-and-improved interface, people start doing
these interminable series of trivial conversion patches.
And every time that happens, somebody does some silly mistake, and the
conversion patch to the improved interface actually makes things worse.
Because the patch is mindnumbing and trivial, nobody has the attention
span to look at it carefully, and it's usually done over large swatches
of source code which means that not every conversion gets tested.
So I'm pulling the strscpy() support because it *is* a better interface.
But I will refuse to pull mindless conversion patches. Use this in
places where it makes sense, but don't do trivial patches to fix things
that aren't actually known to be broken.
* 'strscpy' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
tile: use global strscpy() rather than private copy
string: provide strscpy()
Make asm/word-at-a-time.h available on all architectures
The c6x clkdev.h header is the same as the asm-generic header, so
just use the asm-generic one.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Mark Salter <msalter@redhat.com>
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Pull irq updates from Thomas Gleixner:
"This updated pull request does not contain the last few GIC related
patches which were reported to cause a regression. There is a fix
available, but I let it breed for a couple of days first.
The irq departement provides:
- new infrastructure to support non PCI based MSI interrupts
- a couple of new irq chip drivers
- the usual pile of fixlets and updates to irq chip drivers
- preparatory changes for removal of the irq argument from interrupt
flow handlers
- preparatory changes to remove IRQF_VALID"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits)
irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources
irqchip: Add bcm2836 interrupt controller for Raspberry Pi 2
irqchip: Add documentation for the bcm2836 interrupt controller
irqchip/bcm2835: Add support for being used as a second level controller
irqchip/bcm2835: Refactor handle_IRQ() calls out of MAKE_HWIRQ
PCI: xilinx: Fix typo in function name
irqchip/gic: Ensure gic_cpu_if_up/down() programs correct GIC instance
irqchip/gic: Only allow the primary GIC to set the CPU map
PCI/MSI: pci-xgene-msi: Consolidate chained IRQ handler install/remove
unicore32/irq: Prepare puv3_gpio_handler for irq argument removal
tile/pci_gx: Prepare trio_handle_level_irq for irq argument removal
m68k/irq: Prepare irq handlers for irq argument removal
C6X/megamode-pic: Prepare megamod_irq_cascade for irq argument removal
blackfin: Prepare irq handlers for irq argument removal
arc/irq: Prepare idu_cascade_isr for irq argument removal
sparc/irq: Use access helper irq_data_get_affinity_mask()
sparc/irq: Use helper irq_data_get_irq_handler_data()
parisc/irq: Use access helper irq_data_get_affinity_mask()
mn10300/irq: Use access helper irq_data_get_affinity_mask()
irqchip/i8259: Prepare i8259_irq_dispatch for irq argument removal
Migrate c6x driver to the new 'set-state' interface provided by
clockevents core, the earlier 'set-mode' interface is marked obsolete
now.
This also enables us to implement callbacks for new states of clockevent
devices, for example: ONESHOT_STOPPED.
We weren't doing anything in ->set_mode(RESUME) and so tick_resume()
isn't implemented.
Cc: linux-c6x-dev@linux-c6x.org
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Pull in upstream fixes before applying conflicting changes
Chained irq handlers usually set up handler data as well. We now have
a function to set both under irq_desc->lock. Replace the two calls
with one.
Search and conversion was done with coccinelle.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Link: http://lkml.kernel.org/r/20150713130429.697731509@linutronix.de
Commit 2ae416b142b6 ("mm: new mm hook framework") introduced an empty
header file (mm-arch-hooks.h) for every architecture, even those which
doesn't need to define mm hooks.
As suggested by Geert Uytterhoeven, this could be cleaned through the use
of a generic header file included via each per architecture
asm/include/Kbuild file.
The PowerPC architecture is not impacted here since this architecture has
to defined the arch_remap MM hook.
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Added the x86 implementation of word-at-a-time to the
generic version, which previously only supported big-endian.
Omitted the x86-specific load_unaligned_zeropad(), which in
any case is also not present for the existing BE-only
implementation of a word-at-a-time, and is only used under
CONFIG_DCACHE_WORD_ACCESS.
Added as a "generic-y" to the Kbuilds of all architectures
that didn't previously have it.
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
Pull asm/scatterlist.h removal from Jens Axboe:
"We don't have any specific arch scatterlist anymore, since parisc
finally switched over. Kill the include"
* 'for-4.2/sg' of git://git.kernel.dk/linux-block:
remove scatterlist.h generation from arch Kbuild files
remove <asm/scatterlist.h>
CRIU is recreating the process memory layout by remapping the checkpointee
memory area on top of the current process (criu). This includes remapping
the vDSO to the place it has at checkpoint time.
However some architectures like powerpc are keeping a reference to the
vDSO base address to build the signal return stack frame by calling the
vDSO sigreturn service. So once the vDSO has been moved, this reference
is no more valid and the signal frame built later are not usable.
This patch serie is introducing a new mm hook framework, and a new
arch_remap hook which is called when mremap is done and the mm lock still
hold. The next patch is adding the vDSO remap and unmap tracking to the
powerpc architecture.
This patch (of 3):
This patch introduces a new set of header file to manage mm hooks:
- per architecture empty header file (arch/x/include/asm/mm-arch-hooks.h)
- a generic header (include/linux/mm-arch-hooks.h)
The architecture which need to overwrite a hook as to redefine it in its
header file, while architecture which doesn't need have nothing to do.
The default hooks are defined in the generic header and are used in the
case the architecture is not defining it.
In a next step, mm hooks defined in include/asm-generic/mm_hooks.h should
be moved here.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Jens Axboe <axboe@fb.com>
Pull arch/c6x fixes from Mark Salter.
* tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming:
c6x: platforms: cache: Export symbol L1P_cache_block_invalidate and L1D_cache_block_writeback
c6x: kernel: setup: Export symbol memory_end
c6x: kernel: setup: Add screen_info global variable
c6x: include: asm: Kbuild: Add generic serial.h
c6x: include: asm: dma-mapping: Add dummy dma_sync_single_range_for_device
c6x: include: asm: setup: Include "linux/types.h"
c6x: asm: Add default flat.h according to xtensa architecture
c6x: kernel: setup: Remove 'const' for local variables in machine_init
c6x: Makefile: Add -D__linux__
C6x: time: Ensure consistency in __init
c6x: kernel: setup: Include "linux/console.h"
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc
Pull exec domain removal from Richard Weinberger:
"This series removes execution domain support from Linux.
The idea behind exec domains was to support different ABIs. The
feature was never complete nor stable. Let's rip it out and make the
kernel signal handling code less complicated"
* 'exec_domain_rip_v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (27 commits)
arm64: Removed unused variable
sparc: Fix execution domain removal
Remove rest of exec domains.
arch: Remove exec_domain from remaining archs
arc: Remove signal translation and exec_domain
xtensa: Remove signal translation and exec_domain
xtensa: Autogenerate offsets in struct thread_info
x86: Remove signal translation and exec_domain
unicore32: Remove signal translation and exec_domain
um: Remove signal translation and exec_domain
tile: Remove signal translation and exec_domain
sparc: Remove signal translation and exec_domain
sh: Remove signal translation and exec_domain
s390: Remove signal translation and exec_domain
mn10300: Remove signal translation and exec_domain
microblaze: Remove signal translation and exec_domain
m68k: Remove signal translation and exec_domain
m32r: Remove signal translation and exec_domain
m32r: Autogenerate offsets in struct thread_info
frv: Remove signal translation and exec_domain
Signed-off-by: Richard Weinberger <richard@nod.at>
flush_old_exec() has already done that. Back on 2011 a bunch of
instances like that had been kicked out, but that hadn't taken
care of then-out-of-tree architectures, obviously, and they served
as reinfection vector...
They are needed by other modules, the related error with allmodconfig:
MODPOST 3327 modules
ERROR: "L1P_cache_block_invalidate" [drivers/misc/lkdtm.ko] undefined!
ERROR: "L1D_cache_block_writeback" [drivers/misc/lkdtm.ko] undefined!
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
It is needed by several modules, the related error with allmodconfig:
ERROR: "memory_end" [net/wireless/lib80211_crypt_tkip.ko] undefined!
ERROR: "memory_end" [net/sunrpc/sunrpc.ko] undefined!
ERROR: "memory_end" [net/sunrpc/auth_gss/rpcsec_gss_krb5.ko] undefined!
ERROR: "memory_end" [net/rxrpc/rxkad.ko] undefined!
ERROR: "memory_end" [net/mac802154/mac802154.ko] undefined!
ERROR: "memory_end" [net/mac80211/mac80211.ko] undefined!
ERROR: "memory_end" [net/ipv6/esp6.ko] undefined!
ERROR: "memory_end" [net/ipv6/ah6.ko] undefined!
ERROR: "memory_end" [net/ipv4/esp4.ko] undefined!
ERROR: "memory_end" [net/ipv4/ah4.ko] undefined!
ERROR: "memory_end" [net/ceph/libceph.ko] undefined!
ERROR: "memory_end" [net/9p/9pnet_virtio.ko] undefined!
ERROR: "memory_end" [drivers/usb/wusbcore/wusbcore.ko] undefined!
ERROR: "memory_end" [drivers/usb/misc/usbtest.ko] undefined!
ERROR: "memory_end" [drivers/usb/core/usbcore.ko] undefined!
ERROR: "memory_end" [drivers/target/target_core_file.ko] undefined!
ERROR: "memory_end" [drivers/net/wireless/brcm80211/brcmfmac/brcmfmac.ko] undefined!
ERROR: "memory_end" [drivers/net/wireless/ath/ath6kl/ath6kl_sdio.ko] undefined!
ERROR: "memory_end" [drivers/net/virtio_net.ko] undefined!
ERROR: "memory_end" [drivers/net/usb/usbnet.ko] undefined!
ERROR: "memory_end" [drivers/net/ppp/ppp_mppe.ko] undefined!
ERROR: "memory_end" [drivers/mtd/nand/nand.ko] undefined!
ERROR: "memory_end" [drivers/mmc/card/mmc_block.ko] undefined!
ERROR: "memory_end" [drivers/crypto/qce/qcrypto.ko] undefined!
ERROR: "memory_end" [drivers/block/drbd/drbd.ko] undefined!
ERROR: "memory_end" [drivers/block/aoe/aoe.ko] undefined!
ERROR: "memory_end" [crypto/tcrypt.ko] undefined!
ERROR: "memory_end" [crypto/gcm.ko] undefined!
ERROR: "memory_end" [crypto/cts.ko] undefined!
ERROR: "memory_end" [crypto/ccm.ko] undefined!
ERROR: "memory_end" [crypto/authencesn.ko] undefined!
ERROR: "memory_end" [crypto/authenc.ko] undefined!
Or can not pass building with allmodconfig:
LD init/built-in.o
drivers/built-in.o: In function `vgacon_switch':
vgacon.c:(.text+0x47f8): undefined reference to `screen_info'
vgacon.c:(.text+0x4810): undefined reference to `screen_info'
drivers/built-in.o: In function `vgacon_resize':
vgacon.c:(.text+0x4ac8): undefined reference to `screen_info'
vgacon.c:(.text+0x4acc): undefined reference to `screen_info'
drivers/built-in.o: In function `vgacon_save_screen':
vgacon.c:(.text+0x4cc8): undefined reference to `screen_info'
drivers/built-in.o:vgacon.c:(.text+0x4cd0): more undefined references to `screen_info' follow
Or it will cause building break with allmodconfig:
CC [M] drivers/tty/serial/8250/8250_core.o
drivers/tty/serial/8250/8250_core.c:102:24: fatal error: asm/serial.h: No such file or directory
c6x does not implement get_dma_ops() for dma-mapping-common.h. And in
dma-mapping-common.h, dma_sync_single_range_for_device() may be dummy.
So c6x can just define a dummy function for allmodconfig building.
CC [M] drivers/net/ethernet/micrel/ks8851.o
drivers/net/ethernet/micrel/ks8842.c: In function 'ks8842_tx_frame_dma':
drivers/net/ethernet/micrel/ks8842.c:453:2: error: implicit declaration of function 'dma_sync_single_range_for_device' [-Werror=implicit-function-declaration]
dma_sync_single_range_for_device(adapter->dev,
Some modules may assume "asm/setup.h" already include all headers which
needed by itself. So need let "asm/setup.h" include "linux/types.h", the
related error:
C [M] drivers/input/joydev.o
In file included from include/asm-generic/page.h:23:0,
from ./arch/c6x/include/asm/page.h:9,
from include/asm-generic/io.h:14,
from arch/c6x/include/generated/asm/io.h:1,
from drivers/input/joydev.c:15:
./arch/c6x/include/asm/setup.h:17:27: error: unknown type name 'phys_addr_t'
extern int c6x_add_memory(phys_addr_t start, unsigned long size);
For supporting uClinux flat-format executables, c6x needs to define the
fewest features to support it, at present, xtensa architecture has the
fewest feature for it, so just copy xtensa flat.h. The related error:
CC fs/binfmt_flat.o
In file included from fs/binfmt_flat.c:36:0:
include/linux/flat.h:12:22: fatal error: asm/flat.h: No such file or directory
early_init_dt_scan() accepts "void *", the related warning:
CC arch/c6x/kernel/setup.o
arch/c6x/kernel/setup.c: In function 'machine_init':
arch/c6x/kernel/setup.c:290:21: warning: passing argument 1 of 'early_init_dt_scan' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
early_init_dt_scan(fdt);
In file included from arch/c6x/kernel/setup.c:19:0:
include/linux/of_fdt.h:75:13: note: expected 'void *' but argument is of type 'const void *'
extern bool early_init_dt_scan(void *params);
For gcc5 c6x raw compiler, at present, it may not define __linux__, so
c6x kernel still needs to define __linux__ just like another archs have
done. The related error:
CC [M] fs/coda/psdev.o
In file included from include/linux/coda.h:64:0,
from fs/coda/psdev.c:45:
include/uapi/linux/coda.h:221:2: error: unknown type name 'u_quad_t'
u_quad_t va_size; /* file size in bytes */
include/uapi/linux/coda.h:229:2: error: unknown type name 'u_quad_t'
u_quad_t va_bytes; /* bytes of disk space held by file */
include/uapi/linux/coda.h:230:2: error: unknown type name 'u_quad_t'
u_quad_t va_filerev; /* file modification number */
time_init invokes timer64_init (which is __init annotation)
since all of these are invoked at init time, lets maintain
consistency by ensuring time_init is marked appropriately
as well.
This fixes the following warning with CONFIG_DEBUG_SECTION_MISMATCH=y
WARNING: vmlinux.o(.text+0x3bfc): Section mismatch in reference from the function time_init() to the function .init.text:timer64_init()
The function time_init() references
the function __init timer64_init().
This is often because time_init lacks a __init
annotation or the annotation of timer64_init is wrong.
Fixes: 546a39546c64 ("C6X: time management")
Signed-off-by: Nishanth Menon <nm@ti.com>
When !MMU, asm-generic will not define default pgprot_writecombine, so c6x
needs to define it by itself. The related error:
CC [M] fs/pstore/ram_core.o
fs/pstore/ram_core.c: In function 'persistent_ram_vmap':
fs/pstore/ram_core.c:399:10: error: implicit declaration of function 'pgprot_writecombine' [-Werror=implicit-function-declaration]
prot = pgprot_writecombine(PAGE_KERNEL);
fs/pstore/ram_core.c:399:8: error: incompatible types when assigning to type 'pgprot_t {aka struct <anonymous>}' from type 'int'
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Or c6x will cause building break for allmodconfig, the related error:
arch/c6x/kernel/setup.c: In function 'setup_arch':
arch/c6x/kernel/setup.c:433:2: error: 'conswitchp' undeclared (first use in this function)
conswitchp = &dummy_con;
arch/c6x/kernel/setup.c:433:2: note: each undeclared identifier is reported only once for each function it appears in
arch/c6x/kernel/setup.c:433:16: error: 'dummy_con' undeclared (first use in this function)
[removed unnecessary #ifdef around include]
If an attacker can cause a controlled kernel stack overflow, overwriting
the restart block is a very juicy exploit target. This is because the
restart_block is held in the same memory allocation as the kernel stack.
Moving the restart block to struct task_struct prevents this exploit by
making the restart_block harder to locate.
Note that there are other fields in thread_info that are also easy
targets, at least on some architectures.
It's also a decent simplification, since the restart code is more or less
identical on all architectures.
[james.hogan@imgtec.com: metag: align thread_info::supervisor_stack]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
We've replaced remap_file_pages(2) implementation with emulation. Nobody
creates non-linear mapping anymore.
Acked-by: Mark Salter <msalter@redhat.com>
As there are now no remaining users of arch_fast_hash(), lets kill
it entirely.
This basically reverts commit 71ae8aac3e19 ("lib: introduce arch
optimized hash library") and follow-up work, that is f.e., commit
237217546d44 ("lib: hash: follow-up fixups for arch hash"),
commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for
asm-generic/hash.h") and last but not least commit 6a02652df511
("perf tools: Fix include for non x86 architectures").
Cc: Francesco Fusco <fusco@ntop.org>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
The nohz full code needs irq work to trigger its own interrupt so that
the subsystem can work even when the tick is stopped.
Lets introduce arch_irq_work_has_interrupt() that archs can override to
tell about their support for this ability.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Pull arch signal handling cleanup from Richard Weinberger:
"This patch series moves all remaining archs to the get_signal(),
signal_setup_done() and sigsp() functions.
Currently these archs use open coded variants of the said functions.
Further, unused parameters get removed from get_signal_to_deliver(),
tracehook_signal_handler() and signal_delivered().
At the end of the day we save around 500 lines of code."
* 'signal-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (43 commits)
powerpc: Use sigsp()
openrisc: Use sigsp()
mn10300: Use sigsp()
mips: Use sigsp()
microblaze: Use sigsp()
metag: Use sigsp()
m68k: Use sigsp()
m32r: Use sigsp()
hexagon: Use sigsp()
frv: Use sigsp()
cris: Use sigsp()
c6x: Use sigsp()
blackfin: Use sigsp()
avr32: Use sigsp()
arm64: Use sigsp()
arc: Use sigsp()
sas_ss_flags: Remove nested ternary if
Rip out get_signal_to_deliver()
Clean up signal_delivered()
tracehook_signal_handler: Remove sig, info, ka and regs
Use sigsp() instead of the open coded variant.
Use the more generic functions get_signal() signal_setup_done()
for signal delivery.
Tested-by: Mark Salter <msalter@redhat.com>
The arch_mutex_cpu_relax() function, introduced by 34b133f, is
hacky and ugly. It was added a few years ago to address the fact
that common cpu_relax() calls include yielding on s390, and thus
impact the optimistic spinning functionality of mutexes. Nowadays
we use this function well beyond mutexes: rwsem, qrwlock, mcs and
lockref. Since the macro that defines the call is in the mutex header,
any users must include mutex.h and the naming is misleading as well.
This patch (i) renames the call to cpu_relax_lowlatency ("relax, but
only if you can do it with very low latency") and (ii) defines it in
each arch's asm/processor.h local header, just like for regular cpu_relax
functions. On all archs, except s390, cpu_relax_lowlatency is simply cpu_relax,
and thus we can take it out of mutex.h. While this can seem redundant,
I believe it is a good choice as it allows us to move out arch specific
logic from generic locking primitives and enables future(?) archs to
transparently define it, similarly to System Z.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Bharat Bhushan <r65777@freescale.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Cc: Dominik Dingel <dingel@linux.vnet.ibm.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Joe Perches <joe@perches.com>
Cc: Joseph Myers <joseph@codesourcery.com>
Cc: Michael Neuling <mikey@neuling.org>
Cc: Nicolas Pitre <nico@linaro.org>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Qais Yousef <qais.yousef@imgtec.com>
Cc: Qiaowei Ren <qiaowei.ren@intel.com>
Cc: Rafael Wysocki <rafael.j.wysocki@intel.com>
Cc: Steven Rostedt <srostedt@redhat.com>
Cc: Stratos Karafotis <stratosk@semaphore.gr>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Vasily Kulikov <segoon@openwall.com>
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: Waiman Long <Waiman.Long@hp.com>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: adi-buildroot-devel@lists.sourceforge.net
Cc: linux390@de.ibm.com
Cc: linux-alpha@vger.kernel.org
Cc: linux-am33-list@redhat.com
Cc: linux-cris-kernel@axis.com
Cc: linux-hexagon@vger.kernel.org
Cc: linux-ia64@vger.kernel.org
Cc: linux@lists.openrisc.net
Cc: linux-m32r-ja@ml.linux-m32r.org
Cc: linux-m32r@ml.linux-m32r.org
Cc: linux-m68k@lists.linux-m68k.org
Cc: linux-metag@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-parisc@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-s390@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: linux-xtensa@linux-xtensa.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/1404079773.2619.4.camel@buesod1.americas.hpqcorp.net
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux into next
Pull DeviceTree updates from Rob Herring:
- Another round of clean-up of FDT related code in architecture code.
This removes knowledge of internal FDT details from most
architectures except powerpc.
- Conversion of kernel's custom FDT parsing code to use libfdt.
- DT based initialization for generic serial earlycon. The
introduction of generic serial earlycon support went in through the
tty tree.
- Improve the platform device naming for DT probed devices to ensure
unique naming and use parent names instead of a global index.
- Fix a race condition in of_update_property.
- Unify the various linker section OF match tables and fix several
function prototype errors.
- Update platform_get_irq_byname to work in deferred probe cases.
- 2 binding doc updates
* tag 'devicetree-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (58 commits)
of: handle NULL node in next_child iterators
of/irq: provide more wrappers for !CONFIG_OF
devicetree: bindings: Document micrel vendor prefix
dt: bindings: dwc2: fix required value for the phy-names property
of_pci_irq: kill useless variable in of_irq_parse_pci()
of/irq: do irq resolution in platform_get_irq_byname()
of: Add a testcase for of_find_node_by_path()
of: Make of_find_node_by_path() handle /aliases
of: Create unlocked version of for_each_child_of_node()
lib: add glibc style strchrnul() variant
of: Handle memory@0 node on PPC32 only
pci/of: Remove dead code
of: fix race between search and remove in of_update_property()
of: Use NULL for pointers
of: Stop naming platform_device using dcr address
of: Ensure unique names without sacrificing determinism
tty/serial: pl011: add DT based earlycon support
of/fdt: add FDT serial scanning for earlycon
of/fdt: add FDT address translation support
serial: earlycon: add DT support
The architecture code does not need to access the internals of the FDT
blob, so make the pointer to it void *.
Signed-off-by: Rob Herring <robh@kernel.org>
Tested-by: Grant Likely <grant.likely@linaro.org>
