path: root/arch/blackfin
2010-01-07blackfin,kgdb: Do not put PC in gdb_regs into retx.Sonic Zhang
In blackfin, kgdb is running in delayed exception IRQ5 other than in exception IRQ3 directly. Register reti other than retx in pt_regs is the kgdb return address. So, don't put PC in gdb_regs into retx. CC: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-01-07blackfin,kgdb,probe_kernel: Cleanup probe_kernel_read/writeJason Wessel
Blackfin needs it own arch specific probe_kernel_read() and probe_kernel_write(). This was moved out of the kgdb code and into the arch/blackfin/maccess.c, because it is a generic kernel api. The arch specific kgdb.c for blackfin was cleaned of all functions which exist in the kgdb core that do the same thing after resolving the probe_kernel_read() and probe_kernel_write(). This also eliminated the need for most of the #include's. CC: Sonic Zhang <sonic.adi@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-06FDPIC: Respect PT_GNU_STACK exec protection markings when creating NOMMU stackMike Frysinger
The current code will load the stack size and protection markings, but then only use the markings in the MMU code path. The NOMMU code path always passes PROT_EXEC to the mmap() call. While this doesn't matter to most people whilst the code is running, it will cause a pointless icache flush when starting every FDPIC application. Typically this icache flush will be of a region on the order of 128KB in size, or may be the entire icache, depending on the facilities available on the CPU. In the case where the arch default behaviour seems to be desired (EXSTACK_DEFAULT), we probe VM_STACK_FLAGS for VM_EXEC to determine whether we should be setting PROT_EXEC or not. For arches that support an MPU (Memory Protection Unit - an MMU without the virtual mapping capability), setting PROT_EXEC or not will make an important difference. It should be noted that this change also affects the executability of the brk region, since ELF-FDPIC has that share with the stack. However, this is probably irrelevant as NOMMU programs aren't likely to use the brk region, preferring instead allocation via mmap(). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (88 commits) Blackfin: Convert BUG() to use unreachable() Blackfin: define __NR_recvmmsg Blackfin: drop duplicate sched_clock Blackfin: NOMPU: skip DMA ICPLB hole when it is redundant Blackfin: MPU: add missing __init markings Blackfin: add support for TIF_NOTIFY_RESUME Blackfin: kgdb_test: clean up code a bit Blackfin: convert kgdbtest to proc_fops Blackfin: convert cyc2ns() to clocksource_cyc2ns() Blackfin: ip0x: pull in asm/portmux.h for P_xxx defines Blackfin: drop unused ax88180 resources Blackfin: bf537-stamp: add ADF702x network driver resources Blackfin: bf537-stamp: add CAN resources Blackfin: bf537-stamp: add AD5258 i2c address Blackfin: bf537-stamp: add adau1761 i2c address Blackfin: bf537-stamp: add adau1371 i2c address Blackfin: bf537-stamp: add ADP8870 resources Blackfin: bf537-stamp: kill AD714x board-specific Kconfigs Blackfin: bf537-stamp: update ADP5520 resources Blackfin: bf537-stamp: add ADXL346 orientation sensing support ...
2009-12-16Merge branch 'module' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'module' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: modpost: fix segfault with short symbol names module: handle ppc64 relocating kcrctabs when CONFIG_RELOCATABLE=y Kbuild: clear marker out of modpost module: make MODULE_SYMBOL_PREFIX into a CONFIG option ARM: unexport symbols used to implement floating point emulation ARM: use unified discard definition in linker script x86: don't export inline function sparc64: don't export static inline pci_ functions
2009-12-16elf: kill USE_ELF_CORE_DUMPChristoph Hellwig
Currently all architectures but microblaze unconditionally define USE_ELF_CORE_DUMP. The microblaze omission seems like an error to me, so let's kill this ifdef and make sure we are the same everywhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <linux-arch@vger.kernel.org> Cc: Michal Simek <michal.simek@petalogix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16fbdev: bfin-lq035q1-fb: new Blackfin Landscape LCD EZ-Extender driverMichael Hennerich
Framebuffer driver for the Landscape LCD EZ-Extender (ADZS-BFLLCD-EZEXT) http://docs.blackfin.uclinux.org/doku.php?id=hw:cards:landscape_lcd_ez-extender Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15Blackfin: Convert BUG() to use unreachable()David Daney
Use the new unreachable() macro instead of for(;;); Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: define __NR_recvmmsgMike Frysinger
Commit a2e2725541f added recvmmsg to a bunch of arches (including the Blackfin entry.S), but didn't actually add the new __NR_ define for it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15module: make MODULE_SYMBOL_PREFIX into a CONFIG optionAlan Jenkins
The next commit will require the use of MODULE_SYMBOL_PREFIX in .tmp_exports-asm.S. Currently it is mixed in with C structure definitions in "asm/module.h". Move the definition of this arch option into Kconfig, so it can be easily accessed by any code. This also lets modpost.c use the same definition. Previously modpost relied on a hardcoded list of architectures in mk_elfconfig.c. A build test for blackfin, one of the two MODULE_SYMBOL_PREFIX archs, showed the generated code was unchanged. vmlinux was identical save for build ids, and an apparently randomized suffix on a single "__key" symbol in the kallsyms data). Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Acked-by: Mike Frysinger <vapier@gentoo.org> (blackfin) CC: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-12-15Blackfin: drop duplicate sched_clockMike Frysinger
The Blackfin sched_clock() func is pretty much a duplicate of the common version, so just punt it. Reported-by: David Miller <davem@davemloft.net> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: NOMPU: skip DMA ICPLB hole when it is redundantMike Frysinger
Normally there is no user-reserved memory after the DMA region which means there is no user-reserved ICPLB coverage. So the DMA hole can be covered by the large hole that is always added to cover up to the async bank. We only need an explicit DMA whole when we also add an explicit mapping for the user-reserved memory. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: MPU: add missing __init markingsMike Frysinger
2009-12-15Blackfin: add support for TIF_NOTIFY_RESUMEBarry Song
Signed-off-by: Barry Song <barry.song@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: kgdb_test: clean up code a bitMike Frysinger
- document simple global symbols - convert printk to pr_* - clean up spurious whitespace - use min_t() Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: convert kgdbtest to proc_fopsAlexey Dobriyan
The read_proc and write_proc interfaces are going to be removed in the common kernel code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: convert cyc2ns() to clocksource_cyc2ns()Mike Frysinger
The former no longer exists. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: ip0x: pull in asm/portmux.h for P_xxx definesMike Frysinger
2009-12-15Blackfin: drop unused ax88180 resourcesMike Frysinger
The ax88180 driver was never merged, so drop the corresponding resources. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: bf537-stamp: add ADF702x network driver resourcesMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: bf537-stamp: add CAN resourcesBarry Song
2009-12-15Blackfin: bf537-stamp: add AD5258 i2c addressMichael Hennerich
2009-12-15Blackfin: bf537-stamp: add adau1761 i2c addressCliff Cai
Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: bf537-stamp: add adau1371 i2c addressCliff Cai
2009-12-15Blackfin: bf537-stamp: add ADP8870 resourcesMichael Hennerich
2009-12-15Blackfin: bf537-stamp: kill AD714x board-specific KconfigsMike Frysinger
Include the AD714x SPI/I2C resources based on what is possible. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: bf537-stamp: update ADP5520 resourcesMichael Hennerich
Matches feedback for driver changes. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: bf537-stamp: add ADXL346 orientation sensing supportMichael Hennerich
The ADXL34x driver was updated to include orientation sensing, so have the bf537-stamp use it by default. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: bf537-stamp/bf548-ezkit: update ADXL34x resourcesMichael Hennerich
2009-12-15Blackfin: BF51x: unify def/cdef headersMike Frysinger
Whole lot of duplicated code here just went bye bye. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: BF52x: unify def/cdef headersMike Frysinger
2009-12-15Blackfin: BF537: push down error masks to avoid namespace pollutionMike Frysinger
The error masks are only needed in the BF537 demux error code, so instead of needing all the short peripheral defines in global space, push these masks into the one file where they are actually needed. This fixes a bunch of define collisions with common code (can/serial/etc...). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Barry Song <barry.song@analog.com>
2009-12-15Blackfin: SMP: don't start up core b until its state has been completely onlinedYi Li
When testing PREEMPT_RT kernel on BF561-EZKit, the kernel blocks while booting. When the kernel initializes the ethernet driver, it sleeps and never wakes up. The issue happens when the kernel waits for a timer for Core B to timeout (the timers are per-cpu based: static DEFINE_PER_CPU(struct tvec_base *, tvec_bases) = &boot_tvec_bases). However, the ksoftirqd thread for Core B (note, the ksoftirqd thread is also per-cpu based) cannot work properly, and the timers for Core B never times out. When ksoftirqd() for the first time runs on core B, it is possible core A is still initializing core B (see smp_init() -> cpu_up() -> __cpu_up()). So the "cpu_is_offline()" check may return true and ksoftirqd moves to "wait_to_die". So delay the core b start up until the per-cpu timers have been set up fully. Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: convert to asm-generic pci headersBarry Song
2009-12-15Blackfin: io.h: fix random busted whitespaceMike Frysinger
2009-12-15Blackfin: dma-mapping.h: flesh out missing DMA mapping functionsBarry Song
2009-12-15Blackfin: workaround anomaly 05000310Barry Song
While fetching instructions at the boundary of L1 instruction SRAM, a false External Memory Addressing Error might be triggered. We should ignore this and continue on our way to avoid random crashes. Because hardware errors are not exact in the Blackfin architecture, we need to catch a few more common cases when the code flow changes and the signal is finally delivered. Signed-off-by: Barry Song <barry.song@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: drop ptrace() write support for fixed code/bootromMike Frysinger
These regions are either read-only and won't work anyways (bootrom), or we don't want people screwing with them because they're shared between all processes (fixed code). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: MPU: support XIP in async flash memoryBarry Song
The NOMPU code already supported executing in the async banks, so this brings the MPU code in line. Signed-off-by: Barry Song <barry.song@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: drop 4KB reserve at end of memoryBarry Song
The point of this small chunk was to avoid anomaly 05000310. This never really seemed to do what it was intended though -- no valid CPLBs exist over the reserved memory, and there is often memory before it anyways (due to the uClinux MTD and/or reserved DMA region). Plus, it doesn't address the L1 instruction case. So drop this chunk as it wastes memory and is affront to humanity. Signed-off-by: Barry Song <barry.song@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: support smaller uncached DMA chunks for memory constrained systemsBarry Song
When working with 8 meg systems, forcing a 1 meg DMA chunk heavily cuts into the available resources. So support smaller chunks to better cover needs for these systems. Signed-off-by: Barry Song <barry.song@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: push BF5Xx configs down into mach-specific KconfigsMike Frysinger
While we're moving the BF54x code, have the BF54xM variants select the normal BF54x values so that the rest of the Kconfig tree doesn't need to check the BF54xM variant everytime it wants to check the BF54x. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: finish_atomic_sections: optimize the RTS stepMike Frysinger
No point in returning to userspace just to have it immediately perform the RTS step. We have to update the PC anyways, so do the RTS too. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: kgdb: punt dead codeSonic Zhang
None of these vars/funcs were being used. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: reject NULL callback in set_dma_callback()Mike Frysinger
It makes no sense to call this function with a NULL callback. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: punt dead/unused flash mem_init settingsMike Frysinger
I don't think these defines were ever used. At any rate, we have common bit defines for all parts as well as a Kconfig option to declare the EBIU async timings, and no one has really complained about this so far. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: gptimers: use unsigned timer/group idsMike Frysinger
Since we always use these ids as unsigned values, and we have some assert code to make sure they don't exceed a limit, avoid signed issues. Reported-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: don't walk VMAs when oopsingRobin Getz
If we're double faulting, then we have to assume the VMAs are not safe as broken pointers here will prevent full trace output for the double fault. Shouldn't be a big problem though as rarely is a double fault caused by code in userspace. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: force BFD target when linking modulesMike Frysinger
This allows us to use any Blackfin toolchain to create kernel modules (such as the FDPIC bfin-linux-uclibc toolchain). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
