path: root/arch/blackfin
2011-07-26ptrace: unify show_regs() prototypeMike Frysinger
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-23Blackfin: boards: fix pcm device nameScott Jiang
The pcm driver name has been changed, but the device name has not. Signed-off-by: Scott Jiang <scott.jiang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: SMP: punt unused atomic_test_mask helperMike Frysinger
No one uses this func, so just punt it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: irqs: do not trace arch_local_{*,irq_*} functionsSteven Rostedt
Do not trace arch_local_save_flags(), arch_local_irq_*() and friends. Although they are marked inline, gcc may still make a function out of them and add it to the pool of functions that are traced by the function tracer. This can cause undesirable results (kernel panic, triple faults, etc). Add the notrace notation to prevent them from ever being traced. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: bf526: restrict reboot workaround to 0.0 siliconMike Frysinger
The bug in the BF526 rom when doing a software reset exists only in older silicon versions, so don't clear SWRST on newer parts. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: bf51x: fix alternative portmux optionsMike Frysinger
The BF51x's alternative portmux Kconfig options were copy & pasted from the BF52x, but never tweaked to reflect it. So drop the old options as they were never used (and were simply wrong), and add the BF51x specific pieces to the Kconfig and header. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: bf54x: fix GPIO resume codeMike Frysinger
Back in commit c03c2a87347b849ec927d, we fixed logic in the non-bf54x GPIO resume code to set the data levels properly before the direction to avoid spurious line glitches. But we missed the bf54x code paths. So add the same fix there. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: dpmc: optimize SDRAM programming slightlyMike Frysinger
No need to reload these registers constantly since they're always available (we're not making any function calls in between). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: dpmc: don't save/restore scratch registersMike Frysinger
The Blackfin C ABI says we do not need to save/restore R0-R3 and P0-P2 as they are available as scratch registers. So don't bother. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: bf538: pull gpio/port logic out of core hibernate pathsMike Frysinger
Re-architect how we save/restore the gpio/port logic that only pertains to bf538/bf539 parts by pulling it out of the core code paths and pushing it out to bf538-specific locations. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: dpmc: optimize hibernate/resume pathMike Frysinger
The current save logic used in hibernation is to do a MMR load (base + offset) into a register, and then push that onto the stack. Then when restoring, pop off the stack into a register followed by a MMR store (base + offset). These use plenty of 32bit insns rather than 16bit, are pretty long winded, and full of pipeline bubbles. So, by taking advantage of MMRs that are contiguous, the multi-register push/pop insn, and register abuse, we can shrink this code considerably. When saving, the new logic does a lot of loads into the data and pointer registers before executing a single multi-register push insn. Then when restoring, we do a single multi-register pop insn followed by a lot of stores. Overall, this allows us to cut the insn count by ~30%, the code size by ~45%, and drastically reduce the register hazards that trigger bubbles in the pipeline. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: dpmc: do not save/restore EVT0/EVT1/EVT4 when hibernatingMike Frysinger
EVT0 is for emulation, EVT1 is for reset, and EVT4 is the "global int disable" region. None of these are used by software (or even hardware), so don't bother saving/restoring them when we hibernate since nothing ever uses these in Linux (the only thing they would be useful for is core-memory scratch, but that's just crazy talk). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: dpmc: relocate hibernate helper macrosMike Frysinger
This defines only get used in the hibernate code, so remove them from the global dpmc header as no one else cares. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: dpmc: omit RETE/RETN when hibernatingMike Frysinger
The RETE/RETN registers are only used in emulation(JTAG) and NMI nodes, or as scratch registers, neither of which need to be saved/restored as this code doesn't execute at those core event levels. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: dpmc: optimize SIC_IWR programming a littleMike Frysinger
For parts with more than one SIC_IWR, we can optimize the writing a little bit using better Blackfin insns. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: gpio/ints: generalize pint logicMike Frysinger
Have the logic that uses peripheral interrupt blocks key off of pint defines rather than CPU names so that things are generalized across families. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: dpmc: bind to MMR names and not CPUsMike Frysinger
Have the code work off of MMR names rather than CPU defines so there is less code to tweak in the future with new parts. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: debug-mmrs: generalize pint logicMike Frysinger
Don't bind the code to specific CPU defines. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: bf54x: switch to common pint MMR structMike Frysinger
We have a struct in the headers describing the register layout, so drop the local duplicate one. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: bf54x: tweak MMR pint namesMike Frysinger
The hardware block uses the name "request" rather than "irq", so update the struct accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: bf54x: constify pint register arrayMike Frysinger
The array of pointers to register blocks never changes, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: gpio: punt unused GPIO_# definesMike Frysinger
These defines don't accomplish much as GPIO_# is the same thing as #. Each CPU already provides helpful symbolic defines like GPIO_<PIN> which everyone uses, so just punt these # ones. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: convert unicode space gremlinsMike Frysinger
Not sure how these guys slipped in, but they're annoying me. So bring these unicode space gremlins down to earth to normal ascii spaces. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: pwm: implement linux/pwm.h APIMike Frysinger
For now, this only supports gptimers. Support for dedicated PWM devices as found on newer parts to come. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: gptimers: add enable/disable by timer idMike Frysinger
The API is geared around timer ids, except for the act of enabling and disabling timers. So add a small helper to fill out the gap. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: make sure percpu section is aligned in XIP buildsSteven Miao
The alignment is normally handled by PERCPU(), but we need to do it ourselves in the XIP build due to the custom layout. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: gptimers: use bfin read/write helpersMike Frysinger
Use proper helper macros for reading/writing the MMRs rather than volatile markings on the struct. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: gptimers: use register structs from common headerMike Frysinger
Now that asm/gptimers.h has the hardware register struct layout, there's no need to duplicate things locally. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: debug-mmrs: use new gptimer_group layout to simplify codeMike Frysinger
2011-07-23Blackfin: debug-mmrs: prevent macro arg from expandingMike Frysinger
Passing a non-simple expression in as the addr arg could incorrectly apply the pointer cast resulting in misbehavior. Add proper paren. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: gptimers: add group structure for hardware register layoutMike Frysinger
2011-07-23Blackfin: exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so this set_fs(USER_DS) is redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: update anomaly lists to latest public infoMike Frysinger
2011-07-23Blackfin: bf561-ezkit: change parallel flash from M to Y in defconfigMike Frysinger
These flashes are always on the board, so might as well enable them by default rather than a module. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: debug-mmrs: disable PERIPHERAL_MAP for IMDMA channelsMike Frysinger
The documentation for the IMDMA channels appears to be incorrect. These DMA blocks don't actually have PERIPHERAL_MAP MMRs for us to access. Attempts to do so lead to system mmr hardware errors. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: debug-mmrs: fix typo in single dmac setupMike Frysinger
2011-07-23Blackfin: convert to asm-generic/mutex-dec.h for all systemsMike Frysinger
The Blackfin mutex.h is merely a copy of an older asm-generic/mutex-dec.h, so punt it and just use the common one directly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: optimize double fault boot checkingMike Frysinger
This moves the double fault data used at boot time into a single struct which can then easily be addressed with indexed loads rather than having to explicitly load multiple addresses. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: time: replace magic numbers with definesMike Frysinger
2011-07-23Blackfin: SMP: optimize start up code a bitMike Frysinger
This just imports all of the optimization work done in the common startup code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: boards: clean up redundant/dead spi resourcesMike Frysinger
The default for the Blackfin SPI driver is 8 bits and dma disabled, so many of the bfin5xx_spi_chip resources are redundant. So punt those parts. Further, drivers should themselves be declaring 16 bit transfers, so for those that do, and for the ones which no longer do 16 bit transfers, drop the bfin5xx_spi_chip resources. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: net2272: move pin setup to boards filesMike Frysinger
2011-07-23Blackfin: convert to kbuild asm-generic supportMike Frysinger
No need for one line header stubs. Just declare it in Kbuild. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-15rtc: fix build warnings in defconfigsWanlong Gao
RTC_CLASS is changed to bool, so 'm' is invalid. Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-03Blackfin: strncpy: fix handling of zero lengthsSteven Miao
The jump to 4f will cause the NUL padding loop to run at least one time, so if string length is zero just jump to the end. Otherwise we wrongly write one NUL byte when size==0. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-28Blackfin: debug-mmrs: include RSI_PID[4567] MMRsMike Frysinger
The documentation is a little iffy as to whether these are actual MMRs, but reading them on the hardware works, and the previous version of this logic (the SDH) had PID[4567]. So add it for RSI too. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-28Blackfin: bf51x: fix up RSI_PID# MMR definesMike Frysinger
Looks like the copying of MMR defines from the SDH block missed updating the addresses of the RSI_PID# registers. So tweak them to reflect the actual hardware. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-28Blackfin: bf52x/bf54x: fix up usb MMR definesMike Frysinger
The bf52x/bf54x have the incorrect addresses for USB_EP_NI7_RXINTERVAL and USB_EP_NI7_TXCOUNT, so adjust those. Further, the bf54x header puts the USB defines in the wrong place, so shuffle them back to the right grouping. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-28Blackfin: debug-mmrs: fix typos with gptimers/mdma/ppiMike Frysinger
This code was mostly developed against a BF54x, so some BF537-specific issues were missed. The PPI block starts at PPI_CONTROL, not PPI_STATUS (which is the reverse of the EPPI block). The MDMA block starts at MDMA_NEXT_DESC_PTR, not MDMA_CONFIG. Seems the sim does not catch misreads here so that'll need to get fixed. The gptimer block is mostly 32bit regs, not 16bit. Use the gptimer struct to figure that out rather than hardcoding it locally. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
