path: root/arch/blackfin/mach-bf561
2016-09-05Merge 4.8-rc5 into char-misc-nextGreg Kroah-Hartman
We want the fixes in here for merging and testing. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-31miscdevice: Add helper macro for misc device boilerplatePrasannaKumar Muralidharan
Many modules call misc_register and misc_deregister in its module init and exit methods without any additional code. This ends up being boilerplate. This patch adds helper macro module_misc_device(), that replaces module_init()/ module_exit() with template functions. This patch also converts drivers to use new macro. Change since v1: Add device.h include in miscdevice.h as module_driver macro was not available from other include files in some architectures. Signed-off-by: PrasannaKumar Muralidharan <prasannatsmkumar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-28net: smc91x: fix SMC accessesRussell King
Commit b70661c70830 ("net: smc91x: use run-time configuration on all ARM machines") broke some ARM platforms through several mistakes. Firstly, the access size must correspond to the following rule: (a) at least one of 16-bit or 8-bit access size must be supported (b) 32-bit accesses are optional, and may be enabled in addition to the above. Secondly, it provides no emulation of 16-bit accesses, instead blindly making 16-bit accesses even when the platform specifies that only 8-bit is supported. Reorganise smc91x.h so we can make use of the existing 16-bit access emulation already provided - if 16-bit accesses are supported, use 16-bit accesses directly, otherwise if 8-bit accesses are supported, use the provided 16-bit access emulation. If neither, BUG(). This exactly reflects the driver behaviour prior to the commit being fixed. Since the conversion incorrectly cut down the available access sizes on several platforms, we also need to go through every platform and fix up the overly-restrictive access size: Arnd assumed that if a platform can perform 32-bit, 16-bit and 8-bit accesses, then only a 32-bit access size needed to be specified - not so, all available access sizes must be specified. This likely fixes some performance regressions in doing this: if a platform does not support 8-bit accesses, 8-bit accesses have been emulated by performing a 16-bit read-modify-write access. Tested on the Intel Assabet/Neponset platform, which supports only 8-bit accesses, which was broken by the original commit. Fixes: b70661c70830 ("net: smc91x: use run-time configuration on all ARM machines") Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-16locking/atomic, arch/blackfin: Implement atomic_fetch_{add,sub,and,or,xor}()Peter Zijlstra
Implement FETCH-OP atomic primitives, these are very similar to the existing OP-RETURN primitives we already have, except they return the value of the atomic variable _before_ modification. This is especially useful for irreversible operations -- such as bitops (because it becomes impossible to reconstruct the state prior to modification). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Miao <realmz6@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: adi-buildroot-devel@lists.sourceforge.net Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-01-13Merge tag 'for-linus-20160112' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: "Generic MTD: - populate the MTD device 'of_node' field (and get a proper 'of_node' symlink in sysfs) This yielded some new helper functions, and changes across a variety of drivers - partitioning cleanups, to prepare for better device-tree based partitioning in the future Eliminate a lot of boilerplate for drivers that want to use OF-based partition parsing The DT bindings for this didn't settle yet, so most non-cleanup portions are deferred for a future release NAND: - embed a struct mtd_info inside struct nand_chip This is really long overdue; too many drivers have to do the same silly boilerplate to allocate and link up two "independent" structs, when in fact, everyone is assuming there is an exact 1:1 relationship between a NAND chips struct and its underlying MTD. This aids improved helpers and should make certain abstractions easier in the future. Also causes a lot of churn, helped along by some automated code transformations - add more core support for detecting (and "correcting") bitflips in erased pages; requires opt-in by drivers, but at least we kill a few bad implementations and hopefully stave off future ones - pxa3xx_nand: cleanups, a few fixes, and PM improvements - new JZ4780 NAND driver SPI NOR: - provide default erase function, for controllers that just want to send the SECTOR_ERASE command directly - fix some module auto-loading issues with device tree ("jedec,spi-nor") - error handling fixes - new Mediatek QSPI flash driver Other: - cfi: force valid geometry Kconfig (finally!) This one used to trip up randconfigs occasionally, since bots aren't deterred by big scary "advanced configuration" menus More? Probably. See the commit logs" * tag 'for-linus-20160112' of git://git.infradead.org/linux-mtd: (168 commits) mtd: jz4780_nand: replace if/else blocks with switch/case mtd: nand: jz4780: Update ecc correction error codes mtd: nandsim: use nand_get_controller_data() mtd: jz4780_nand: remove useless mtd->priv = chip assignment staging: mt29f_spinand: make use of nand_set/get_controller_data() helpers mtd: nand: make use of nand_set/get_controller_data() helpers ARM: make use of nand_set/get_controller_data() helpers mtd: nand: add helpers to access ->priv mtd: nand: jz4780: driver for NAND devices on JZ4780 SoCs mtd: nand: jz4740: remove custom 'erased check' implementation mtd: nand: diskonchip: remove custom 'erased check' implementation mtd: nand: davinci: remove custom 'erased check' implementation mtd: nand: use nand_check_erased_ecc_chunk in default ECC read functions mtd: nand: return consistent error codes in ecc.correct() implementations doc: dt: mtd: new binding for jz4780-{nand,bch} mtd: cfi_cmdset_0001: fixing memory leak and handling failed kmalloc mtd: spi-nor: wait until lock/unlock operations are ready mtd: tests: consolidate kmalloc/memset 0 call to kzalloc jffs2: use to_delayed_work mtd: nand: assign reasonable default name for NAND drivers ...
2015-12-08blackfin: nand: make use of mtd_to_nand() where appropriateBoris BREZILLON
mtd_to_nand() was recently introduced to avoid direct accesses to the mtd->priv field. Update all blackfin specific implementations to use this helper. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2015-11-17[media] include/media: split I2C headers from V4L2 coreMauro Carvalho Chehab
Currently, include/media is messy, as it contains both the V4L2 core headers and some driver-specific headers on the same place. That makes harder to identify what core headers should be documented and what headers belong to I2C drivers that are included only by bridge/main drivers that would require the functions provided by them. Let's move those i2c specific files to its own subdirectory. The files to move were produced via the following script: mkdir include/media/i2c (cd include/media; for i in *.h; do n=`echo $i|sed s/.h$/.c/`; if [ -e ../../drivers/media/i2c/$n ]; then echo $i; git mv $i i2c/; fi; done) (cd include/media; for i in *.h; do n=`echo $i|sed s/.h$/.c/`; if [ -e ../../drivers/media/*/i2c/$n ]; then echo $i; git mv $i i2c/; fi; done) for i in include/media/*.h; do n=`basename $i`; (for j in $(git grep -l $n); do dirname $j; done)|sort|uniq|grep -ve '^.$' > list; num=$(wc -l list|cut -d' ' -f1); if [ $num == 1 ]; then if [ "`grep i2c list`" != "" ]; then git mv $i include/media/i2c; fi; fi; done And the references corrected via this script: MAIN_DIR="media/" PREV_DIR="media/" DIRS="i2c/" echo "Checking affected files" >&2 for i in $DIRS; do for j in $(find include/$MAIN_DIR/$i -type f -name '*.h'); do n=`basename $j` git grep -l $n done done|sort|uniq >files && ( echo "Handling files..." >&2; echo "for i in \$(cat files|grep -v Documentation); do cat \$i | \\"; ( cd include/$MAIN_DIR; for j in $DIRS; do for i in $(ls $j); do echo "perl -ne 's,(include [\\\"\\<])$PREV_DIR($i)([\\\"\\>]),\1$MAIN_DIR$j\2\3,; print \$_' |\\"; done; done; echo "cat > a && mv a \$i; done"; ); echo "Handling documentation..." >&2; echo "for i in MAINTAINERS \$(cat files); do cat \$i | \\"; ( cd include/$MAIN_DIR; for j in $DIRS; do for i in $(ls $j); do echo " perl -ne 's,include/$PREV_DIR($i)\b,include/$MAIN_DIR$j\1,; print \$_' |\\"; done; done; echo "cat > a && mv a \$i; done" ); ) >script && . ./script Merged Sakari Ailus patch that moves smiapp.h to include/media/i2c. Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2015-07-27blackfin: Provide atomic_{or,xor,and}Peter Zijlstra
Implement atomic logic ops -- atomic_{or,xor,and}. These will replace the atomic_{set,clear}_mask functions that are available on some archs. TODO: use inline asm or at least asm macros to collapse the lot. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-03-05blackfin: fix up obsolete cpu function usage.Rusty Russell
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Steven Miao <realmz6@gmail.com> Cc: adi-buildroot-devel@lists.sourceforge.net
2014-08-23pata_platform: Remove useless irq_flags fieldAlexander Shiyan
IRQ flags can be obtained from resource structure, there are no need to use additional field in the platform_data to store these values. This patch removes this field and convert existing users of this driver to use IRQ flags from the resources. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-26blackfin: fix some bf5xx boards build for missing <linux/gpio.h>Steven Miao
Signed-off-by: Steven Miao <realmz6@gmail.com>
2014-04-12blackfin: cleanup board filesSteven Miao
using IS_ENABLED() macro instead of defined(CONFIG_XXX) || defined(CONFIG_XXX_MODULE) Signed-off-by: Steven Miao <realmz6@gmail.com>
2013-07-14blackfin: delete __cpuinit usage from all blackfin filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. Note that some harmless section mismatch warnings may result, since notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c) are flagged as __cpuinit -- so if we remove the __cpuinit from arch specific callers, we will also get section mismatch warnings. As an intermediate step, we intend to turn the linux/init.h cpuinit content into no-ops as early as possible, since that will get rid of these warnings. In any case, they are temporary and harmless. This removes all the arch/blackfin uses of the __cpuinit macros from all C files. Currently blackfin does not have any __CPUINIT used in assembly files. [1] https://lkml.org/lkml/2013/5/20/589 Cc: Mike Frysinger <vapier@gentoo.org> Cc: Bob Liu <lliubbo@gmail.com> Cc: Sonic Zhang <sonic.zhang@analog.com> Cc: uclinux-dist-devel@blackfin.uclinux.org Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-07-10Merge tag 'blackfin-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/realmz6/blackfin-linux Pull blackfin updates from Steven Miao: "blackfin updates for Linux 3.11" * tag 'blackfin-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/realmz6/blackfin-linux: smp: refine bf561 smpboot code bf609: stmmac: fix build after stmmac_mdio_bus_data changed bf609: add cpu revision 0.1 bf609: rename bfin6xx_spi to bfin_spi3 kgdb: blackfin: include irq_regs.h in kgdb.c
2013-07-09smp: refine bf561 smpboot codeSteven Miao
release boot lock earlier to let coreb do setup and calibrate set coreb online later after initialization ready add BFIN_IPI_NONE IPI type drop unnecesarry smp_mb() and using atomic type Signed-off-by: Steven Miao <realmz6@gmail.com>
2013-05-30blackfin: Remove references to the bf5x_tdm driverLars-Peter Clausen
The bf5x_tdm driver has been removed. Remove all references to it from board code. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-30ASoC: blackfin: Switch bf5xx-ad1836 from bf5xx-tdm to bf5xx-i2sLars-Peter Clausen
The bf5xx-i2s driver now has support for TDM mode and the bf5xx-tdm driver is going to be removed soon, so switch the driver over to bf5xx-i2s. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-13blackfin: anomaly: add anomaly 16000030 for bf5xxSonic Zhang
Drivers common to both bf5xx and bf60x chip families may use this anomaly id. So add it to bf5xx header files also. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-08-17blackfin: add platform device for ad1836 machine driverScott Jiang
2012-07-24bf561: add capabilities in adv7183_inputsScott Jiang
Add capabilities in adv7183_inputs to indicate that S_STD is supported. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-06-01Merge tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull mtd update from David Woodhouse: - More robust parsing especially of xattr data in JFFS2 - Updates to mxc_nand and gpmi drivers to support new boards and device tree - Improve consistency of information about ECC strength in NAND devices - Clean up partition handling of plat_nand - Support NAND drivers without dedicated access to OOB area - BCH hardware ECC support for OMAP - Other fixes and cleanups, and a few new device IDs Fixed trivial conflict in drivers/mtd/nand/gpmi-nand/gpmi-nand.c due to added include files next to each other. * tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtd: (75 commits) mtd: mxc_nand: move ecc strengh setup before nand_scan_tail mtd: block2mtd: fix recursive call of mtd_writev mtd: gpmi-nand: define ecc.strength mtd: of_parts: fix breakage in Kconfig mtd: nand: fix scan_read_raw_oob mtd: docg3 fix in-middle of blocks reads mtd: cfi_cmdset_0002: Slight cleanup of fixup messages mtd: add fixup for S29NS512P NOR flash. jffs2: allow to complete xattr integrity check on first GC scan jffs2: allow to discriminate between recoverable and non-recoverable errors mtd: nand: omap: add support for hardware BCH ecc ARM: OMAP3: gpmc: add BCH ecc api and modes mtd: nand: check the return code of 'read_oob/read_oob_raw' mtd: nand: remove 'sndcmd' parameter of 'read_oob/read_oob_raw' mtd: m25p80: Add support for Winbond W25Q80BW jffs2: get rid of jffs2_sync_super jffs2: remove unnecessary GC pass on sync jffs2: remove unnecessary GC pass on umount jffs2: remove lock_super mtd: gpmi: add gpmi support for mx6q ...
2012-05-21blackfin: license: Change ADI BSD licenseSonic Zhang
Change ADI BSD license to standart 3 clause BSD license for some blackfin arch code requested by ADI Legal. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-05-13blackfin: Use the plat_nand default partition parserH Hartley Sweeten
Use the default partition parser, cmdlinepart, provided by the plat_nand driver. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-03-21bf561: add ppi DLEN macro for 10bits to 16bitsScott Jiang
2012-03-21blackfin: bf561: forgot CSYNC in get_core_lock_noflushBob Liu
SMP kgdb runs into dead loop without this CSYNC when one core single steps over get_core_lock_noflush and the other executes get_core_lock as a slave node. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21BF561 MDMA : fixed BF561 DMA MMRs definition mismatchSteven Miao
MDMA io base defined in arch/blackfin/mach-bf561/dma.c do not match the definition of MDMA MMRs in arch/blackfin/mach-bf561/include/mach/defBF561.h Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-01-09blackfin: bf561: add adv7183 capture supportBob Liu
2012-01-09blackfin: i2c-lcd: change default clock rateAaron Wu
Change default clock rate of GPIO based I2C operation for BF533 and BF561 to bring up the I2C interface LCD display Signed-off-by: Aaron Wu <Aaron.Wu@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-01-09blackfin: config: update macro SPI_BFIN in board fileSonic Zhang
Macro name for spi controller driver has been modified, so update default board file accordingly. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-01-09blackfin: smp: cleanup smp codeBob Liu
move idle task point to percpu blackfin_cpudata and add smp_timer_broadcast interface. enable SUPPLE_1_WAKEUP and add BFIN_IPI_TIMER ipi support. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-01-09blackfin: smp: add suspend and wakeup irq flagsBob Liu
Add IRQF_NO_SUSPEND | IRQF_FORCE_RESUME to irq flags, supplement irq should not be disabled when system do suspend. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2011-11-14Blackfin: add serial TX IRQ in individual platform resourceSonic Zhang
The serial TX IRQ is not simply (RX IRQ + 1) on some Blackfin chips, so move the values to the platform resources. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2011-10-26Blackfin: irq: remove IRQF_DISABLEDYong Zhang
This flag is a NOOP and can be removed now. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Bob Liu <lliubbo@kernel.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: gpio: punt unused GPIO_# definesMike Frysinger
These defines don't accomplish much as GPIO_# is the same thing as #. Each CPU already provides helpful symbolic defines like GPIO_<PIN> which everyone uses, so just punt these # ones. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: update anomaly lists to latest public infoMike Frysinger
2011-07-23Blackfin: optimize double fault boot checkingMike Frysinger
This moves the double fault data used at boot time into a single struct which can then easily be addressed with indexed loads rather than having to explicitly load multiple addresses. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: SMP: optimize start up code a bitMike Frysinger
This just imports all of the optimization work done in the common startup code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: boards: clean up redundant/dead spi resourcesMike Frysinger
The default for the Blackfin SPI driver is 8 bits and dma disabled, so many of the bfin5xx_spi_chip resources are redundant. So punt those parts. Further, drivers should themselves be declaring 16 bit transfers, so for those that do, and for the ones which no longer do 16 bit transfers, drop the bfin5xx_spi_chip resources. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: net2272: move pin setup to boards filesMike Frysinger
2011-05-28Blackfin: mach/bfin_serial_5xx.h: punt now-unused headerMike Frysinger
Now that the serial code has been unified in bfin_serial.h, and the Blackfin UART driver pushed its resources to the boards files, we don't need these headers anymore. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-27Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (97 commits) mtd: kill CONFIG_MTD_PARTITIONS mtd: remove add_mtd_partitions, add_mtd_device and friends mtd: convert remaining users to mtd_device_register() mtd: samsung onenand: convert to mtd_device_register() mtd: omap2 onenand: convert to mtd_device_register() mtd: txx9ndfmc: convert to mtd_device_register() mtd: tmio_nand: convert to mtd_device_register() mtd: socrates_nand: convert to mtd_device_register() mtd: sharpsl: convert to mtd_device_register() mtd: s3c2410 nand: convert to mtd_device_register() mtd: ppchameleonevb: convert to mtd_device_register() mtd: orion_nand: convert to mtd_device_register() mtd: omap2: convert to mtd_device_register() mtd: nomadik_nand: convert to mtd_device_register() mtd: ndfc: convert to mtd_device_register() mtd: mxc_nand: convert to mtd_device_register() mtd: mpc5121_nfc: convert to mtd_device_register() mtd: jz4740_nand: convert to mtd_device_register() mtd: h1910: convert to mtd_device_register() mtd: fsmc_nand: convert to mtd_device_register() ... Fixed up trivial conflicts in - drivers/mtd/maps/integrator-flash.c: removed in ARM tree - drivers/mtd/maps/physmap.c: addition of afs partition probe type clashing with removal of CONFIG_MTD_PARTITIONS
2011-05-25Blackfin: don't touch cpu_possible_map and cpu_present_map directlyKOSAKI Motohiro
We plan to remove cpu_possible_map and cpu_present_map later and we have proper init_cpu_possible() and init_cpu_present() APIs. Therefore this patch rewrites platform_init_cpus and platform_prepare_cpus by their APIs. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-25Blackfin: bf548-ezkit/bf561-ezkit: update nor flash layoutMike Frysinger
Both the BF548-EZKIT and the BF561-EZKIT use top boot flashes, so now that Das U-Boot uses the last small sector for its environment, update their nor layout in the kernel accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-25Blackfin: update anomaly lists to latest public infoMike Frysinger
2011-05-25Blackfin: SMP: fix cpudata cache setupMike Frysinger
After some cache setup reordering changesets, the blackfin_cpudata init was left behind. While cpu0's data was correct, cpu1's data was not. Not that big of a deal as these are only used in the cpuinfo output, but should still be fixed. So move the setup of these fields to the common cache setup function to avoid this happening again in the future. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-25Blackfin: bf533/bf537/bf561: convert to BFIN_IRQ helperMike Frysinger
This brings the parts in line with newer ones, and makes things easier to read at a glance. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-25Blackfin: clean up style in irq definesMike Frysinger
These files had a lot of whitespace damage, mostly due to copying and pasting original files that had damage. The BF561 header also had a lot of unused CONFIG_DEF_xxx defines, so punt them all. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-25Blackfin: unify core IRQ definitionsMike Frysinger
Start a new common IRQ header and move all of the CEC pieces there. This lets the individual part headers worry just about its SIC defines. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-25mtd: bfin: convert to mtd_device_register()Jamie Iles
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS preprocessor conditionals as partitioning is always available. Cc: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-03-29bfin: Final irq cleanupThomas Gleixner
Use the trigger type in irq_data and check level type instead of looking at desc->handle_irq. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: uclinux-dist-devel@blackfin.uclinux.org
