path: root/arch/blackfin/mach-bf537
2016-03-15Merge tag 'v4.5' into nextDmitry Torokhov
Merge with Linux 4.5 to get PROPERTY_ENTRY_INTEGER() that is needed to fix pxa/raumfeld rotary encoder properties.
2016-03-08Input: ad7879 - move header to platform_data directoryStefan Agner
The header file is used by the SPI and I2C variant of the driver. Therefore, move it to a more generic place under platform_data. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2015-12-08blackfin: nand: make use of mtd_to_nand() where appropriateBoris BREZILLON
mtd_to_nand() was recently introduced to avoid direct accesses to the mtd->priv field. Update all blackfin specific implementations to use this helper. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-07-31blackfin: Prepare irq handlers for irq argument removalThomas Gleixner
The irq argument of most interrupt flow handlers is unused or merily used instead of a local variable. The handlers which need the irq argument can retrieve the irq number from the irq descriptor. Search and update was done with coccinelle and the invaluable help of Julia Lawall. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Steven Miao <realmz6@gmail.com> Cc: adi-buildroot-devel@lists.sourceforge.net
2014-08-23pata_platform: Remove useless irq_flags fieldAlexander Shiyan
IRQ flags can be obtained from resource structure, there are no need to use additional field in the platform_data to store these values. This patch removes this field and convert existing users of this driver to use IRQ flags from the resources. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-26blackfin: fix some bf5xx boards build for missing <linux/gpio.h>Steven Miao
Signed-off-by: Steven Miao <realmz6@gmail.com>
2014-04-12blackfin: cleanup board filesSteven Miao
using IS_ENABLED() macro instead of defined(CONFIG_XXX) || defined(CONFIG_XXX_MODULE) Signed-off-by: Steven Miao <realmz6@gmail.com>
2014-04-12Blackfin: bf537: rename "CONFIG_ADT75"Paul Bolle
In v3.2 the Analog Devices ADT75 temperature sensor driver was removed as an IIO driver and support for it was added to the LM75 HWMON driver. But it was apparently overlooked to rename one reference to CONFIG_ADT75 to CONFIG_SENSORS_LM75. Do so now. Use the IS_ENABLED() macro, while we're at it. Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
2014-04-12Blackfin: bf537: rename "CONFIG_AD7314"Paul Bolle
In v3.2 the Analog Devices AD7314 temperature sensor driver was removed as an IIO driver and added as a HWMON driver. But it was apparently overlooked to rename two references to CONFIG_AD7314 to CONFIG_SENSORS_AD7314. Do so now. Use the IS_ENABLED() macro, while we're at it. Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
2014-04-12Blackfin: bf537: rename ad2s120x ->ad2s1200Paul Bolle
In v3.2 the Analog Devices ad2s1200/ad2s1205 driver was renamed from ad2s120x to ad2s1200. But it apparently forgot to rename the references to this driver in the BF537-STAMP code. Rename these now, and use the IS_ENABLED() macro, while we're at it. Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
2014-04-12blackfin: bf537: fix typo "CONFIG_SND_SOC_ADV80X_MODULE"Paul Bolle
There's a (rather subtle) typo in "CONFIG_SND_SOC_ADV80X_MODULE". Fix it once and for all by using IS_ENABLED(), which is designed to avoid issues like this. Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
2013-05-30blackfin: Remove references to the bf5x_tdm driverLars-Peter Clausen
The bf5x_tdm driver has been removed. Remove all references to it from board code. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-30ASoC: blackfin: Switch bf5xx-ad1836 from bf5xx-tdm to bf5xx-i2sLars-Peter Clausen
The bf5xx-i2s driver now has support for TDM mode and the bf5xx-tdm driver is going to be removed soon, so switch the driver over to bf5xx-i2s. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-07Platform Nand: Set the GPIO for NAND read as inputAaron Wu
This patch is from Frank.Shew,fshew@geometrics.com to fix the following problem:having extremely slow responses with the NAND due to timeouts on the ready status signal, which eventually caused the watchdog to time out. Signed-off-by: Aaron Wu <Aaron.Wu@analog.com> Signed-off-by: Steven Miao <realmz6@gmail.com>
2012-12-13blackfin: anomaly: add anomaly 16000030 for bf5xxSonic Zhang
Drivers common to both bf5xx and bf60x chip families may use this anomaly id. So add it to bf5xx header files also. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-10-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lliubbo/blackfin Pull blackfin update from Bob Liu. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lliubbo/blackfin: Blackfin: smp: add smp_mb() to keep coherency Blackfin: drop irq enable in init_arch_irq() Blackfin: fix wrong place disabled irq Blackfin: update defconfig for bf609-ezkit Blackfin: add bf548 v0.4 revision Blackfin: bf60x: Add bf608 and bf609 specific perpheral MMRs Blackfin: cpufreq: fix dpm_state_table Blackfin: bfin_gpio: proc: fix return value Blackfin: CM-BF537E: Update SPORT support in board file. Blackfin: bf537: fix lq035 platform device name Blackfin: bf533-ezkit: enable flash drivers by default
2012-10-08Blackfin: CM-BF537E: Update SPORT support in board file.Harald Krapfenbauer
Signed-off-by: Harald Krapfenbauer <harald.krapfenbauer@bluetechnix.at> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-10-08Blackfin: bf537: fix lq035 platform device nameScott Jiang
Lq035 fb driver uses KBUILD_MODNAME which is bf537_lq035 instead of bf537-lq035. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-08-17blackfin: add platform device for ad1836 machine driverScott Jiang
2012-07-16arch: Use eth_random_addrJoe Perches
Convert the existing uses of random_ether_addr to the new eth_random_addr. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-21blackfin: twi: Move TWI peripheral pin request array to platform dataSonic Zhang
2012-05-21blackfin: license: Change ADI BSD licenseSonic Zhang
Change ADI BSD license to standart 3 clause BSD license for some blackfin arch code requested by ADI Legal. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-05-21blackfin: bf537-stamp: update board file for platform bfin_sport deviceAaron Wu
Blackfin sport driver has been rewrited update board file according. Signed-off-by: Aaron Wu <Aaron.Wu@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-05-21blackfin: twi: move twi bit mask macro to twi head fileSonic Zhang
2012-03-21Blackfin: pnav: delete duplicate linux/export.h includeDanny Kukawka
arch/blackfin/mach-bf537/boards/pnav10.c includes 'linux/export.h' twice. No need to include the file a second time in a #ifdef block if already included at top. Remove the duplicate. Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21arch/blackfin: don't generate random mac in bfin_get_ether_addr()Danny Kukawka
Changed bfin_get_ether_addr() to return a state and to set no random mac address if the board don't provide one. Let the caller of bfin_get_ether_addr() set a random mac address if the return value is not 0. v2: don't set random mac in bfin_get_ether_addr() Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21bfin: add bfin_ad73311_machine platform deviceBob Liu
we can pass sport enable pin through platform data if customer board has reset pin, add it in ad73311_gpio array and modify id to 2 Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-21blackfin: bf537: stamp: update board file for 193xBob Liu
2012-01-09blackfin: bf537: add capture supportBob Liu
2012-01-09blackfin: bf537: change num_chipselect for spi-sportScott Jiang
spi sport driver can support any gpio as its cs pin. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-01-09blackfin: config: update macro SPI_BFIN in board fileSonic Zhang
Macro name for spi controller driver has been modified, so update default board file accordingly. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2011-11-14blackfin: Fixup export.h includesLars-Peter Clausen
Commit 8dc7a9c84 ("blackfin: Add export.h to files using EXPORT_SYMBOL/THIS_MODULE") inserted some of the include statements into sections protected by an unrelated #if CONFIG_... statement. This can cause, depending on the configuration used, warnings like this one: arch/blackfin/mach-bf537/boards/stamp.c:2940: warning: data definition has no type or storage class arch/blackfin/mach-bf537/boards/stamp.c:2940: warning: type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL’ arch/blackfin/mach-bf537/boards/stamp.c:2940: warning: parameter names (without types) in function declaration This patch fixes it by moving the includes out of the #if protected sections. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2011-11-14Blackfin: add serial TX IRQ in individual platform resourceSonic Zhang
The serial TX IRQ is not simply (RX IRQ + 1) on some Blackfin chips, so move the values to the platform resources. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2011-10-31blackfin: Add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
These particular files were just assuming that module.h was somehow in the include paths. Give them the more minimalist header file explicitly. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-26Blackfin: irq: remove IRQF_DISABLEDYong Zhang
This flag is a NOOP and can be removed now. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Bob Liu <lliubbo@kernel.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-25Blackfin: boards: clean up i2c_board_infoMichael Hennerich
Remove i2c_board_info for driver that doesn't exist anymore. Delete irq_flags for drivers that don't use them anymore. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-25Blackfin: bf537-stamp: register ASoC EVAL-ADAU1373 board driverLars-Peter Clausen
Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-25Blackfin: bf537-stamp: Register adav801 codec and ASoC machine driverLars-Peter Clausen
There is already an entry in the spi device table for the codec, but the modalias was wrong. Also the config symbol name for the codec is wrong, so this is fixed as well. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-25Blackfin: bf537-stamp: register adau1701 codec and asoc machine driverLars-Peter Clausen
2011-10-25Blackfin: bf537-stamp: fix ad73311 codec config macroScott Jiang
SND_BF5XX_SOC is for machine drivers while SND_SOC is for codec drivers. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-25Blackfin: bf537-stamp: fix ad1836 nameScott Jiang
The ASoC codec name is "ad1836" and not "ad183x" as the change to rename things ultimately did not get merged. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: boards: fix pcm device nameScott Jiang
The pcm driver name has been changed, but the device name has not. Signed-off-by: Scott Jiang <scott.jiang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: update anomaly lists to latest public infoMike Frysinger
2011-07-23Blackfin: boards: clean up redundant/dead spi resourcesMike Frysinger
The default for the Blackfin SPI driver is 8 bits and dma disabled, so many of the bfin5xx_spi_chip resources are redundant. So punt those parts. Further, drivers should themselves be declaring 16 bit transfers, so for those that do, and for the ones which no longer do 16 bit transfers, drop the bfin5xx_spi_chip resources. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: net2272: move pin setup to boards filesMike Frysinger
2011-05-28Blackfin: mach/bfin_serial_5xx.h: punt now-unused headerMike Frysinger
Now that the serial code has been unified in bfin_serial.h, and the Blackfin UART driver pushed its resources to the boards files, we don't need these headers anymore. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-27Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (97 commits) mtd: kill CONFIG_MTD_PARTITIONS mtd: remove add_mtd_partitions, add_mtd_device and friends mtd: convert remaining users to mtd_device_register() mtd: samsung onenand: convert to mtd_device_register() mtd: omap2 onenand: convert to mtd_device_register() mtd: txx9ndfmc: convert to mtd_device_register() mtd: tmio_nand: convert to mtd_device_register() mtd: socrates_nand: convert to mtd_device_register() mtd: sharpsl: convert to mtd_device_register() mtd: s3c2410 nand: convert to mtd_device_register() mtd: ppchameleonevb: convert to mtd_device_register() mtd: orion_nand: convert to mtd_device_register() mtd: omap2: convert to mtd_device_register() mtd: nomadik_nand: convert to mtd_device_register() mtd: ndfc: convert to mtd_device_register() mtd: mxc_nand: convert to mtd_device_register() mtd: mpc5121_nfc: convert to mtd_device_register() mtd: jz4740_nand: convert to mtd_device_register() mtd: h1910: convert to mtd_device_register() mtd: fsmc_nand: convert to mtd_device_register() ... Fixed up trivial conflicts in - drivers/mtd/maps/integrator-flash.c: removed in ARM tree - drivers/mtd/maps/physmap.c: addition of afs partition probe type clashing with removal of CONFIG_MTD_PARTITIONS
2011-05-25Blackfin: boards: update ASoC resources after machine driver overhaulScott Jiang
Now that the Blackfin machine drivers have been updated to the multicomponent support, update the resources to match. The pin settings are now a board issue and removed from the driver. Signed-off-by: Scott Jiang <scott.jiang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-25Blackfin: update anomaly lists to latest public infoMike Frysinger
