The previous commit that changed this code to the common GPIO layers
forgot to delete the local and now unused "i" variable.
The SPORT/UART driver doesn't use the secondary channel pins, so don't
try and request them thus keeping other drivers from using them.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
We don't want people banging on MMRs directly. As for the ip0x board,
it shouldn't need to muck with the CS pin directly as the Blackfin SPI
bus master driver takes care of driving this.
Now that the common 8250 serial driver supports an "irqflags" field,
we don't need to patch in a custom define into the code.
Signed-off-by: steven miao <realmz6@gmail.com>
Rather than use raw numbers for the GPIO pins, use proper GPIO defines.
With the recent kernel update the isp1362-hcd driver evaluates the
IORESOURCE_IRQ resource flags and requests the irq with the given
polarity/edge settings. However the ISP1362 config requires low
level/edge interrupts. Most of the Blackfin boards use some random
flag or no flag at all. Make all boards use a know good flag
IORESOURCE_IRQ_LOWEDGE.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Make sure we use the right Kconfig names and platform strings.
Signed-off-by: Barry Song <barry.song@analog.com>
Split the BF532 machine type BFIN_*_FIO_FLAG() functions to their own header
file to avoid circular #include problems as these functions require IRQ flag
handling, which requires asm/blackfin.h, which otherwise requires the header
file that defines these functions.
For good measure, also get rid of the inclusion of asm/blackfin.h from
mach/cdefBF532.h (which is circular) and defBF532.h (which is included by
asm/blackfin.h before including this header).
The ASoC codec driver was generalized and renamed, so update the board
resources accordingly.
This lets people easily select the UART/SPORT consoles for early printk
while leveraging the pins declared in the boards file.
Rather than keeping the pins in the actual driver and worrying about a
mess of Kconfig options, declare all the desired pin resources in the
boards file. This lets people easily select the specific pins/ports for
the normal emulated UART as well as GPIOs for CTS/RTS.
the normal UART as well as GPIOs for CTS/RTS.
No need to set MSTR in .ctl_reg as the Blackfin SPI bus driver does this
already for all parts.
Now that the driver has been updated, convert the board resources to the
new i2c framework for managing slaves.
For boards that don't actually hook up to this hardware, simply drop the
resources altogether.
The simple-gpio has been replaced by the gpio sysfs interface, so drop the
unused simple-gpio resources from all Blackfin boards.
Structs get initialized to 0 already, and we want to punt this field, so
scrub it from all of our boards.
Reported-by: David Brownell <dbrownell@users.sourceforge.net>
Now that the common jedec_probe supports the ST PSD4256G6V, no need to
use the custom stm_flash driver.
Bill Gatliff & David Brownell pointed out we were missing some
copyrights, and licensing terms in some of the files in
./arch/blackfin, so this fixes things, and cleans them up.
It also removes:
- verbose GPL text(refer to the top level ./COPYING file)
- file names (you are looking at the file)
- bug url (it's in the ./MAINTAINERS file)
- "or later" on GPL-2, when we did not have that right
It also allows some Blackfin-specific assembly files to be under a BSD
like license (for people to use them outside of Linux).
Signed-off-by: Robin Getz <robin.getz@analog.com>
Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at>
The ASoC drivers have dropped the redundant "-spi" suffix in the driver
name, so update the board resources accordingly.
These hardware devices are dead and the drivers never cleaned up/merged,
so punt the useless board resource info.
Latest smc91x driver allows you to specify settings in board resources
rather than needing CONFIG_BLACKFIN in the drivers/net/smc91x.h header.
One too many zeros means we run way faster than the codec can handle.
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
Signed-off-by: Yi Li <yi.li@analog.com>
The "TWI_KEYPAD" driver was renamed to "INPUT_PCF8574", so update the
defines in the board resources accordingly.
The sed used to rename the bfin-twi-lcd only replaced the first instance
rather than all which led to the resources not being enabled when the
driver was built as a module.
The BF533-EZKIT has two Flash In-System Programming devices hooked up to
the async memory bus, so add resources for the primary flashes and the
SRAMs on the devices.
The Blackfin SPI driver can be driven by an IRQ now, so declare it in
the board resources.
Try to keep the naming conventions consistent, so:
SPI_ADC_BF533 -> BFIN_SPI_ADC
TWI_LCD -> BFIN_TWI_LCD
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Drop CONFIG_I2C_BOARDINFO ifdefs as the common i2c header handles this
already by stubbing things out
Signed-off-by: Grace Pan <grace.pan@analog.com>
Bug: Boot kernel in BF533-EZKIT without set ip during boot,
it stops at initial console.
Restore serial platform_device data to fix this issue.
Signed-off-by: Graf Yang <graf.yang@analog.com>
Turn to use the mmc_spi driver in mainline kernel.
Cc: Graf Yang <graf.yang@analog.com>
Signed-off-by: Javier Herrero <jherrero@hvsistemas.es>
Signed-off-by: Benjamin Matthews <bmat@lle.rochester.edu>
these are highly board specific, so putting into generic doesnt make much sense
identified
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org>
The dm9000 driver accepts either 2 or 3 resources to describe the platform
devices. The 2 resources case abuses the ioresource mechanism by passing
ioremap()ed memory through the platform device resources. This patch removes
converts boards that were using it to the 3 resources scheme.
CC: Bryan Wu <cooloney@kernel.org>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com>
- move all kconfig board settings into board resources
- fixup casting style according to lkml feedback
- rewrite driver so that it can handle arbitrary
of instances according to the declared platform resources
Cc: Joern Engel <joern@logfs.org>
