Signed-off-by: Steven Miao <realmz6@gmail.com>
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Display the total time when kernel resumes normal from standby or suspend to mem
mode.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Support select the wakeup source for power management on bf60x.
Add bf60x cpu pm callbacks and change blackfin pm framework to support bf60x.
The current save logic used in hibernation is to do a MMR load (base +
offset) into a register, and then push that onto the stack. Then when
restoring, pop off the stack into a register followed by a MMR store
(base + offset). These use plenty of 32bit insns rather than 16bit,
are pretty long winded, and full of pipeline bubbles.
So, by taking advantage of MMRs that are contiguous, the multi-register
push/pop insn, and register abuse, we can shrink this code considerably.
When saving, the new logic does a lot of loads into the data and pointer
registers before executing a single multi-register push insn. Then when
restoring, we do a single multi-register pop insn followed by a lot of
stores. Overall, this allows us to cut the insn count by ~30%, the code
size by ~45%, and drastically reduce the register hazards that trigger
bubbles in the pipeline.
This defines only get used in the hibernate code, so remove them from the
global dpmc header as no one else cares.
Re-use some of the existing cpu hotplugging code in the process.
Signed-off-by: Graf Yang <graf.yang@analog.com>
Any consumer of dpmc.h expects to use VR_CTL, so also pull in the new
mach/pll.h header for those functions.
Bill Gatliff & David Brownell pointed out we were missing some
copyrights, and licensing terms in some of the files in
./arch/blackfin, so this fixes things, and cleans them up.
It also removes:
- verbose GPL text(refer to the top level ./COPYING file)
- file names (you are looking at the file)
- bug url (it's in the ./MAINTAINERS file)
- "or later" on GPL-2, when we did not have that right
It also allows some Blackfin-specific assembly files to be under a BSD
like license (for people to use them outside of Linux).
Signed-off-by: Robin Getz <robin.getz@analog.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
