path: root/arch/avr32/boards
2008-02-13avr32: Use correct config symbol in atstk1004 board codeHaavard Skinnemoen
CONFIG_BOARD_ATSTK1002_SW2_CUSTOM should be CONFIG_BOARD_ATSTK100X_SW2_CUSTOM. Spotted by Robert P. J. Day. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-25[AVR32] Kconfig: Choose daughterboard instead of CPUHaavard Skinnemoen
Remove the CPU selection menu and instead let it be selected by the board or daughterboard option. Add daughterboard selection for ATSTK1000 (this was previously determined based on CPU type.) Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-25[AVR32] Add support for ATSTK1003 and ATSTK1004Haavard Skinnemoen
ATSTK1003 and ATSTK1004 are CPU daughterboards for ATSTK1000 featuring the AT32AP7001 and AT32AP7002 CPUs, respectively. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-25[AVR32] Clean up external DAC setup codeHaavard Skinnemoen
Reduce the ridiculous amount of #ifdef clutter in atstk1002.c a bit by moving all the extdac stuff into its own function and providing an empty stub for the case when it isn't wanted. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-25[AVR32] ATSTK1000: Move gpio-leds setup to setup.cHaavard Skinnemoen
There may be other boards than STK1002 that want to use the leds on STK1000. Move it to stk1000 common code to make it easier to reuse. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-25[AVR32] Add support for AT32AP7001 and AT32AP7002Haavard Skinnemoen
These are derivatives of the AT32AP7000 chip, which means that most of the code stays the same. Rename a few files, functions, definitions and config symbols to reflect that they apply to all AP700x chips, and exclude some platform devices from chips where they aren't present. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-23[AVR32] Wire up AT73C213 sound driver on ATSTK1000 boardHans-Christian Egtvedt
Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-11[AVR32] ngw100 i2c-gpio tweaksDavid Brownell
Make the NGW100 bitbang i2c use open drain signaling. Also, speed it up, so it's closer to 100 kHz ... the code paths seem to be long enough that the udelay isn't dominating bit times. The peak bit rate I observed was around 125 kHz, but that's with large delays (usually before ACK/NAK) which hold the overall rate down to around 80 kHz (call it 100 usec/byte on average). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-11[AVR32] SMC configuration in clock cyclesKristoffer Nyborg Gregertsen
This patch makes the SMC configuration take timings in clock cycles instead of nanoseconds. A function to calculate timings in clock cycles is added. This patch removes the rounding troubles of the previous SMC configuration method. [hskinnemoen@atmel.com: fix atstk1002/atngw100 flash config] Signed-off-by: Kristoffer Nyborg Gregertsen <gregerts@stud.ntnu.no> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-11[AVR32] Wire up USBA deviceHaavard Skinnemoen
Implement at32_add_device_usba() and use it to wire up the USBA device on ATSTK1000 and ATNGW100. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-08-15[AVR32] Wire up i2c-gpio on the ATNGW100 boardHaavard Skinnemoen
The NGW100 has a board controller which is hooked up to the TWI lines on AP7000. Since the TWI driver isn't in mainline, use the i2c-gpio driver in the mean time. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-08-15[AVR32] leds-gpio for stk1000David Brownell
Add GPIO led support: J2 to either block of LEDs on the STK1000. This uses the new LEDS_GPIO driver, and sets up a heartbeat trigger by default ... either bright (!!) amber, or a more interesting purple. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-07-22Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-ledsLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-leds: leds: Convert from struct class_device to struct device leds: leds-gpio for ngw100 leds: Add warning printks in error paths leds: Fix trigger unregister_simple if register_simple fails leds: Use menuconfig objects II - LED leds: Teach leds-gpio to handle timer-unsafe GPIOs leds: Add generic GPIO LED driver
2007-07-18[AVR32] Initialize phy_mask for both macb devicesHaavard Skinnemoen
The STK1000 uses pullups on the MDIO lines to the PHY, but they are too weak. This causes the PHY layer to detect PHYs on all possible MII addresses. Mask out all but the correct address to prevent this from happening. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-07-18[AVR32] Don't wire up macb0 unless SW6 is in default positionKristoffer Nyborg Gregertsen
If the user wants to sacrifice macb0 for more GPIOs, let him. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-07-18[AVR32] Wire up SSC platform device 0 as TX on ATSTK1000 boardHans-Christian Egtvedt
2007-07-18[AVR32] Make STK1000 mux settings configurableDavid Brownell
This adds some STK1002-specific config options covering the jumper settings, so the kernel can automatically be configured to include the relevant devices. One of them replaces the previous internal SW2_DEFAULT setting; SPI config is affected by two of the jumpers; and a fourth one switches between LCD and the second Ethernet connector. (There's more that to be done.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-07-16leds: leds-gpio for ngw100David Brownell
Add GPIO leds to the NGW100 platform and its defconfig. Access through /sys/class/leds/{a,b,sys}/* files; one defaults to a heartbeat. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-06-23[AVR32] NGW100, Remove relics of the old USART mapping schemeben.nizette@iinet.net.au
USART mapping used to be accomplished by the manual filling of at32_usart_map[] and at32_nr_usarts. This has now been replaced with at32_map_usart() so we can remove these variables. Signed-off-by: Ben Nizette <ben.nizette@iinet.net.au> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-06-14[AVR32] STK1000: Set SPI_MODE_3 in the ltv350qv board infoHaavard Skinnemoen
In the latest incarnation of the ltv350qv driver the call to spi_setup() has been removed. So we need to initialize things more carefully in the board info struct. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-05-15[AVR32] Implement platform hooks for atmel_lcdfb driverHaavard Skinnemoen
This modifies and extends the existing lcdc platform code to support the new atmel_lcdfb driver. The ATSTK1000 board code is set up to use the on-board Samsung LTV350QV LCD panel. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-27[AVR32] Board code for ATNGW100Haavard Skinnemoen
Add board code and defconfig for the ATNGW100 Network Gateway kit. For more information about this board, see http://www.atmel.com/dyn/products/tools_card.asp?tool_id=4102 Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-27[AVR32] Get rid of board_setup_fbmem()Haavard Skinnemoen
Since the core setup code takes care of both allocation and reservation of framebuffer memory, there's no need for this board- specific hook anymore. Replace it with two global variables, fbmem_start and fbmem_size, which can be used directly. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-02-16[AVR32] Use per-controller spi_board_info structuresHaavard Skinnemoen
Set up one spi_board_info array per controller and pass this to at32_add_device_spi so that it can set up any GPIO pins for chip selects based on this information. Extracted from a patch by David Brownell and adapted slightly. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-02-09[AVR32] SPI platform code updateHaavard Skinnemoen
Move stuff in spi.c into ATSTK1002 board code and update SPI platform device definitions according to the new GPIO API. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-02-09[AVR32] Add PIOE device and reserve SDRAM pinsHaavard Skinnemoen
The PIOE device was left out before because it muxes SDRAM pins (and is therefore a bit dangerous to mess with) and because no existing drivers had any use for it. It is needed for CompactFlash, however, and now that we have a way to protect the SDRAM pins, it can be safely added. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-02-09[AVR32] fix serial port setup on ATSTK1000David Brownell
Fixes to USART setup on the stk-1000 ... don't configure USART 2, since its TXD/RXD are used for INT-A and INT-B buttons; and configure USART 0 (for IRDA, and with corrected IRQ) iff SW2 has a non-default setting. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-12-08[AVR32] Remove mii_phy_addr and eth_addr from eth_platform_dataHaavard Skinnemoen
The macb driver will probe for the PHY chip and read the mac address from the MACB registers, so we don't need them in eth_platform_data anymore. Since u-boot doesn't currently initialize the MACB registers with the mac addresses, the tag parsing code is kept but instead of sticking the information into eth_platform_data, it uses it to initialize the MACB registers (in case the boot loader didn't do it.) This code should be unnecessary at some point in the future. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-12-08[AVR32] Move ethernet tag parsing to board-specific codeHaavard Skinnemoen
By moving the ethernet tag parsing to the board-specific code we avoid the issue of figuring out which device we're supposed to attach the information to. The board specific code knows this because it's where the actual devices are instantiated. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-11-06AVR32: Get rid of board_early_initHaavard Skinnemoen
board_early_init() is left over from some early prototyping work where we had to initialize the SDRAM controller ourselves. This depends on the kernel being loaded into static RAM, which just isn't possible on any commercially available products today. In order to run without a boot loader, we need to create a zImage stub or have the debugger initialize the SDRAM for us (for really low-level debugging) Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-10-04[PATCH] AVR32: Allow renumbering of serial devicesHaavard Skinnemoen
Allow the board to remap actual USART peripheral devices to serial devices by calling at32_map_usart(hw_id, serial_line). This ensures that even though ATSTK1002 uses USART1 as the first serial port, it will still have a ttyS0 device. This also adds a board-specific early setup hook and moves the at32_setup_serial_console() call there from the platform code. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] AVR32 MTD: AT49BV6416 platform device for ATSTK1000Haavard Skinnemoen
FRegister a platform device for the AT49BV6416 NOR flash chip on the ATSTK1000 development board for use by the physmap MTD driver. The SMC timings are set up before the platform device is registered so that no board-specific mapping driver is necessary. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] avr32 architectureHaavard Skinnemoen
This adds support for the Atmel AVR32 architecture as well as the AT32AP7000 CPU and the AT32STK1000 development board. AVR32 is a new high-performance 32-bit RISC microprocessor core, designed for cost-sensitive embedded applications, with particular emphasis on low power consumption and high code density. The AVR32 architecture is not binary compatible with earlier 8-bit AVR architectures. The AVR32 architecture, including the instruction set, is described by the AVR32 Architecture Manual, available from http://www.atmel.com/dyn/resources/prod_documents/doc32000.pdf The Atmel AT32AP7000 is the first CPU implementing the AVR32 architecture. It features a 7-stage pipeline, 16KB instruction and data caches and a full Memory Management Unit. It also comes with a large set of integrated peripherals, many of which are shared with the AT91 ARM-based controllers from Atmel. Full data sheet is available from http://www.atmel.com/dyn/resources/prod_documents/doc32003.pdf while the CPU core implementation including caches and MMU is documented by the AVR32 AP Technical Reference, available from http://www.atmel.com/dyn/resources/prod_documents/doc32001.pdf Information about the AT32STK1000 development board can be found at http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3918 including a BSP CD image with an earlier version of this patch, development tools (binaries and source/patches) and a root filesystem image suitable for booting from SD card. Alternatively, there's a preliminary "getting started" guide available at http://avr32linux.org/twiki/bin/view/Main/GettingStarted which provides links to the sources and patches you will need in order to set up a cross-compiling environment for avr32-linux. This patch, as well as the other patches included with the BSP and the toolchain patches, is actively supported by Atmel Corporation. [dmccr@us.ibm.com: Fix more pxx_page macro locations] [bunk@stusta.de: fix `make defconfig'] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
