Part of the series to unify the irq remapping mechanisms in the
kernel. A follow up patch will copy the powerpc implementation into
kernel/irq/irqdomain.c, which will be a lot easier if the structures
are identical.
Where they differ, I've chose to use the powerpc names since there is
a lot more code using those names.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Milton Miller <miltonm@bga.com>
Tested-by: Olof Johansson <olof@lixom.net>
This set of changes are fixing various section mismatch warnings which
look to be completely valid. Primerily, those which are fixed are those
which can cause oopses by manipulation of driver binding via sysfs. For
example: calling code marked __init from driver probe __devinit
functions.
Some of these changes will be reworked at the next merge window when the
underlying reasons are sorted out. In the mean time, I think it's
important to have this fixed for correctness.
Also included in this set are fixes to various error messages in OMAP -
including making them gramatically correct, fixing a few spelling
errors, and more importantly, making them greppable by unwrapping them.
Tony Lindgren has acked all these patches, put them out for testing a
week ago, and I've tested them on the platforms I have.
* 'omap-fixes-warnings' of git://git.linaro.org/people/rmk/linux-arm:
ARM: omap: resolve nebulous 'Error setting wl12xx data'
ARM: omap: fix wrapped error messages in omap_hwmod.c
ARM: omap: fix section mismatch warnings in mux.c caused by hsmmc.c
ARM: omap: fix section mismatch warning for sdp3430_twl_gpio_setup()
ARM: omap: fix section mismatch error for omap_4430sdp_display_init()
ARM: omap: fix section mismatch warning for omap_secondary_startup()
ARM: omap: preemptively fix section mismatch in omap4_sdp4430_wifi_mux_init()
ARM: omap: fix section mismatch warning in mux.c
ARM: omap: fix section mismatch errors in TWL PMIC driver
ARM: omap: fix uninformative vc/i2c configuration error message
ARM: omap: fix vc.c PMIC error message
ARM: omap: fix prm44xx.c OMAP44XX_IRQ_PRCM build error
This pull request covers the major oopsing issues with OMAP, caused by
the lack of the TWL driver. Even when the TWL driver is not built in,
we shouldn't oops.
* 'omap-fixes-urgent' of git://git.linaro.org/people/rmk/linux-arm:
ARM: omap: fix broken twl-core dependencies and ifdefs
ARM: omap: fix oops in drivers/video/omap2/dss/dpi.c
ARM: omap: fix oops in arch/arm/mach-omap2/vp.c when pmic is not found
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: 7322/1: Print BUG instead of undefined instruction on BUG_ON()
ARM: 7321/1: cache-v7: Disable preemption when reading CCSIDR
ARM: 7320/1: Fix proc_info table alignment
It's useful to print the error code when a called function fails so a
diagnosis of why it failed is possible. In this case, it fails because
we try to register some data for the wl12xx driver, but as the driver
is not configured, a stub function is used which simply returns -ENOSYS.
Let's do the simple thing for -rc and print the error code.
Also, the return code from platform_register_device() at each of these
sites was not being checked. Add some checking, and again print the
error code.
This should be fixed properly for the next merge window so we don't
issue error messages merely because a driver is not configured.
While trying to debug my OMAP platforms, they emitted this message:
omap_hwmod: %s: enabled state can only be entered from initialized, idle, or disabled state
The following backtrace said it was from a function called '_enable',
which didn't provide much clue. Grepping didn't find it either.
The message is wrapped, so unwrap the message so grep can find it. Do
the same for three other messages in this file.
Acked-by: Paul Walmsley <paul@pwsan.com>
The previous commit causes new section mismatch warnings:
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdb30): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_gpio()
The function omap_init_hsmmc() references
the function __init omap_mux_init_gpio().
This is often because omap_init_hsmmc lacks a __init
annotation or the annotation of omap_mux_init_gpio is wrong.
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdb4c): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_gpio()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdb60): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
the function __init omap_mux_init_signal().
annotation or the annotation of omap_mux_init_signal is wrong.
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdb6c): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdb78): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdb90): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdb9c): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdba8): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdbc0): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdbcc): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdbd8): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdbf8): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdc04): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdc10): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdc28): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdc34): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdc40): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdc58): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdc64): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdc70): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xdc7c): Section mismatch in reference from the function omap_init_hsmmc() to the function .init.text:omap_mux_init_signal()
Again, as for omap2_hsmmc_init(), these functions are callable at
runtime via the gpio-twl4030.c driver, and so these can't be marked
__init.
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xd0f0): Section mismatch in reference from the function sdp3430_twl_gpio_setup() to the function .init.text:omap2_hsmmc_init()
The function sdp3430_twl_gpio_setup() references
the function __init omap2_hsmmc_init().
This is often because sdp3430_twl_gpio_setup lacks a __init
annotation or the annotation of omap2_hsmmc_init is wrong.
sdp3430_twl_gpio_setup() is called via platform data from the
gpio-twl4030 module, which can be inserted and removed at runtime.
This makes sdp3430_twl_gpio_setup() callable at runtime, and prevents
it being marked with an __init annotation.
As it calls omap2_hsmmc_init() unconditionally, the only resolution to
this warning is to remove the __init markings from omap2_hsmmc_init()
and its called functions. This addresses the functions in hsmmc.c.
WARNING: arch/arm/mach-omap2/built-in.o(.text+0xb798): Section mismatch in reference from the function omap_4430sdp_display_init() to the function .init.text:omap_display_init()
The function omap_4430sdp_display_init() references
the function __init omap_display_init().
This is often because omap_4430sdp_display_init lacks a __init
annotation or the annotation of omap_display_init is wrong.
Fix this by adding __init to omap_4430sdp_display_init().
WARNING: vmlinux.o(.text+0x1c664): Section mismatch in reference from the function omap_secondary_startup() to the function .cpuinit.text:secondary_startup()
The function omap_secondary_startup() references
the function __cpuinit secondary_startup().
This is often because omap_secondary_startup lacks a __cpuinit
annotation or the annotation of secondary_startup is wrong.
Unfortunately, fixing this causes a new warning which is harder to
solve:
WARNING: arch/arm/mach-omap2/built-in.o(.text+0x5328): Section mismatch in reference from the function omap4_hotplug_cpu() to the function .cpuinit.text:omap_secondary_startup()
The function omap4_hotplug_cpu() references
the function __cpuinit omap_secondary_startup().
This is often because omap4_hotplug_cpu lacks a __cpuinit
annotation or the annotation of omap_secondary_startup is wrong.
because omap4_hotplug_cpu() is used by power management code as well,
which may not end up using omap_secondary_startup().
Found by review.
omap4_sdp4430_wifi_mux_init() is called by an __init marked function,
and only calls omap_mux_init_gpio() and omap_mux_init_signal() which
are both also an __init marked functions.
The only reason this doesn't issue a warning is because the compiler
inlines omap4_sdp4430_wifi_mux_init() into omap4_sdp4430_wifi_init().
So, lets add the __init annotation to ensure this remains safe should
the compiler choose not to inline.
WARNING: arch/arm/mach-omap2/built-in.o(.text+0x15a4): Section mismatch in reference from the function omap_mux_init_signals() to the function .init.text:omap_mux_init_signal()
The function omap_mux_init_signals() references
This is often because omap_mux_init_signals lacks a __init
On my OMAP4 platform, I'm getting this error message repeated several
times at boot:
omap_vc_i2c_init: I2C config for all channels must match.
This doesn't help identify what the problem is. Fix this message to
be more informative:
omap_vc_i2c_init: I2C config for vdd_iva does not match other channels (0).
omap_vc_i2c_init: I2C config for vdd_mpu does not match other channels (0).
This allows us to identify which voltage domains have a problem, and
what the I2C configuration state (a boolean, i2c_high_speed) setting
being used actually is.
From this we find that omap4_core_pmic has i2c_high_speed false, but
omap4_iva_pmic and omap4_mpu_pmic both have it set true.
Acked-by: Kevin Hilman <khilman@ti.com>
While testing on my OMAP3430 platform, this error message was emitted:
omap_vc_init_channel: PMIC info requried to configure vc forvdd_core not populated.Hence cannot initialize vc
Trying to find this message was difficult because it was wrapped across
several lines. It also mis-spells "required", doesn't read very well,
and has spaces lacking. Let's replace it with a more concise:
omap_vc_init_channel: No PMIC info for vdd_core
While we're here, fix a simple spelling error in a comment.
When CONFIG_OF is disabled, the compile fails with:
arch/arm/mach-omap2/prm44xx.c:41: error: 'OMAP44XX_IRQ_PRCM' undeclared here (not in a function)
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Serial/TTY fixes for the 3.3-rc3 tree
Just a few new device ids, omap serial driver regression fixes, and a
build fix for the 8250 driver movement.
* tag 'tty-3.3-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
tty: serial: omap-serial: wakeup latency constraint is in microseconds, not milliseconds
tty: serial: OMAP: block idle while the UART is transferring data in PIO mode
tty: serial: OMAP: use a 1-byte RX FIFO threshold in PIO mode
m32r: relocate drivers back out of 8250 dir
tty: fix a build failure on sparc
serial: samsung: Add support for EXYNOS5250
serial: samsung: Add support for EXYNOS4212 and EXYNOS4412
drivers/tty/vt/vt_ioctl.c: fix KDFONTOP 32bit compatibility layer
Prevent OMAP UARTs from going idle while they are still transferring
data in PIO mode. This works around an oversight in the OMAP UART
hardware present in OMAP34xx and earlier: an idle UART won't send a
wakeup when the TX FIFO threshold is reached. This causes long delays
during data transmission when the MPU powerdomain enters a low-power
mode. The MPU interrupt controller is not able to respond to
interrupts when it's in a low-power state, so the TX buffer is not
refilled until another wakeup event occurs.
This fix changes the erratum i291 DMA idle workaround. Rather than
toggling between force-idle and no-idle, it will toggle between
smart-idle and no-idle. The important part of the workaround is the
no-idle part, so this shouldn't result in any change in behavior.
This fix should work on all OMAP UARTs. Future patches intended for
the 3.4 merge window will make this workaround conditional on a
"feature" flag, and will use the OMAP36xx+ TX event wakeup support.
Thanks to Kevin Hilman <khilman@ti.com> for mentioning the erratum i291
workaround, which led to the development of this approach.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Alan Cox <alan@linux.intel.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Acked-by: Govindraj.R <govindraj.raja@ti.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
Tested-by: Kevin Hilman <khilman@ti.com>
When the PMIC is not found, voltdm->pmic will be NULL. vp.c's
initialization function tries to dereferences this, which causes an
oops:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT
Modules linked in:
CPU: 0 Not tainted (3.3.0-rc2+ #204)
PC is at omap_vp_init+0x5c/0x15c
LR is at omap_vp_init+0x58/0x15c
pc : [<c03db880>] lr : [<c03db87c>] psr: 60000013
sp : c181ff30 ip : c181ff68 fp : c181ff64
r10: c0407808 r9 : c040786c r8 : c0407814
r7 : c0026868 r6 : c00264fc r5 : c040ad6c r4 : 00000000
r3 : 00000040 r2 : 000032c8 r1 : 0000fa00 r0 : 000032c8
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 80004019 DAC: 00000015
Process swapper (pid: 1, stack limit = 0xc181e2e8)
Stack: (0xc181ff30 to 0xc1820000)
ff20: c0381d00 c02e9c6d c0383582 c040786c
ff40: c040ad6c c00264fc c0026868 c0407814 00000000 c03d9de4 c181ff8c c181ff68
ff60: c03db448 c03db830 c02e982c c03fdfb8 c03fe004 c0039988 00000013 00000000
ff80: c181ff9c c181ff90 c03d9df8 c03db390 c181ffdc c181ffa0 c0008798 c03d9df0
ffa0: c181ffc4 c181ffb0 c0055a44 c0187050 c0039988 c03fdfb8 c03fe004 c0039988
ffc0: 00000013 00000000 00000000 00000000 c181fff4 c181ffe0 c03d1284 c0008708
ffe0: 00000000 c03d1208 00000000 c181fff8 c0039988 c03d1214 1077ce40 01f7ee08
Backtrace:
[<c03db824>] (omap_vp_init+0x0/0x15c) from [<c03db448>] (omap_voltage_late_init+0xc4/0xfc)
[<c03db384>] (omap_voltage_late_init+0x0/0xfc) from [<c03d9df8>] (omap2_common_pm_late_init+0x14/0x54)
r8:00000000 r7:00000013 r6:c0039988 r5:c03fe004 r4:c03fdfb8
[<c03d9de4>] (omap2_common_pm_late_init+0x0/0x54) from [<c0008798>] (do_one_initcall+0x9c/0x164)
[<c00086fc>] (do_one_initcall+0x0/0x164) from [<c03d1284>] (kernel_init+0x7c/0x120)
[<c03d1208>] (kernel_init+0x0/0x120) from [<c0039988>] (do_exit+0x0/0x2cc)
r5:c03d1208 r4:00000000
Code: e5ca300b e5900034 ebf69027 e5994024 (e5941000)
---[ end trace aed617dddaf32c3d ]---
Kernel panic - not syncing: Attempted to kill init!
The ARM kernel uses undefined instructions to implement
BUG/BUG_ON(). This leads to problems where people don't read one
line above the Oops message and see the "kernel BUG at ..."
message and so they wrongly assume the kernel has hit an
undefined instruction.
Instead of printing:
Internal error: Oops - undefined instruction: 0 [#1] PREEMPT SMP
print
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
This should prevent people from thinking the BUG_ON was an
undefined instruction when it was actually intentional.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
armv7's flush_cache_all() flushes caches via set/way. To
determine the cache attributes (line size, number of sets,
etc.) the assembly first writes the CSSELR register to select a
cache level and then reads the CCSIDR register. The CSSELR register
is banked per-cpu and is used to determine which cache level CCSIDR
reads. If the task is migrated between when the CSSELR is written and
the CCSIDR is read the CCSIDR value may be for an unexpected cache
level (for example L1 instead of L2) and incorrect cache flushing
could occur.
Disable interrupts across the write and read so that the correct
cache attributes are read and used for the cache flushing
routine. We disable interrupts instead of disabling preemption
because the critical section is only 3 instructions and we want
to call v7_dcache_flush_all from __v7_setup which doesn't have a
full kernel stack with a struct thread_info.
This fixes a problem we see in scm_call() when flush_cache_all()
is called from preemptible context and sometimes the L2 cache is
not properly flushed out.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Cc: stable@vger.kernel.org
With an admittedly exotic choice of configuration options
(CC_OPTIMIZE_FOR_SIZE, THUMB2, some other size-minimizing ones)
and compiler, the proc_info table can end up being misaligned,
and the kernel being unbootable (Error: unrecognized/unsupported
processor variant).
Forcing the alignement to 4 bytes in the linker script fixes the
issue.
fbdev fixes for 3.3
It includes:
- compile fix for fsl-diu-fb
- fix for a suspend/resume issue in atmel_lcdfb
- fix for a suspend/resume issue in OMAP
- workaround for a hardware bug to avoid physical damage in OMAP
- really trivial dead code removal in intelfb
* tag 'fbdev-fixes-for-3.3-1' of git://github.com/schandinat/linux-2.6:
atmel_lcdfb: fix usage of CONTRAST_CTR in suspend/resume
intelfb: remove some dead code
drivers/video: compile fixes for fsl-diu-fb.c
OMAPDSS: HDMI: PHY burnout fix
OMAP: 4430SDP/Panda: add HDMI HPD gpio
OMAP: 4430SDP/Panda: setup HDMI GPIO muxes
OMAPDSS: remove wrong HDMI HPD muxing
OMAP: 4430SDP/Panda: rename HPD GPIO to CT_CP_HPD
OMAP: 4430SDP/Panda: use gpio_free_array to free HDMI gpios
OMAPDSS: use sync versions of pm_runtime_put
arm-soc fixes for 3.3-rc
* A series of OMAP regression fixes for merge window fallout
* Two patches for Davinci, one removes some misdefined clocks, the other
is a regression fix for merge window fallout
* Two patches that makes Broadcom bcmring build again (and removes a
bunch of unused code in the process)
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: bcmring: fix build failure in mach-bcmring/arch.c
ARM: bcmring: remove unused DMA map code
ARM: davinci: update mdio bus name
ARM: OMAP2+: arch/arm/mach-omap2/smartreflex.c: add missing iounmap
ARM: OMAP2+: arch/arm/mach-omap2/devices.c: introduce missing kfree
ARM: OMAP: fix MMC2 loopback clock handling
ARM: OMAP: fix erroneous mmc2 clock change on mmc3 setup
ARM: OMAP2+: GPMC: fix device size setup
ARM: OMAP2+: timer: Fix crash due to wrong arg to __omap_dm_timer_read_counter
ARM: OMAP3: hwmod data: register dss hwmods after dss_core
ARM: OMAP2/3: PRM: fix missing plat/irqs.h build breakage
ARM: OMAP2+: io: fix compilation breakage on 2420-only configs
ARM: OMAP4: hwmod data: Add names for DMIC memory address space
ARM: OMAP3: hwmod data: add SYSC_HAS_ENAWAKEUP for dispc
ARM: OMAP2+: hwmod data: split omap2/3 dispc hwmod class
ARM: davinci: DA850: remove non-existing pll1_sysclk4-7 clocks
ARM: OMAP2: fix regulator warnings
ARM: OMAP2: fix omap3 touchbook kconfig warning
i2c: OMAP: Fix OMAP1 build error
Upstream commit d1fce9c115eeb93e01c01732dfe9a86cf76009cf
"ARM: restart: bcmring: use new restart hook"
breaks building of this platform, since what used to be the
last field of the MACHINE_START/END block didn't have a
trailing comma. Once another field was added below, we get:
arch/arm/mach-bcmring/arch.c:198: error: request for member 'restart' in something not a structure or union
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
Remove BCMRING DMA map code which is no longer used.
This also fixes a build error with dma.c introduced by
bfcd2ea6a40b33270564d706396f1b514a988d3c.
Signed-off-by: Jiandong Zheng <jdzheng@broadcom.com>
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
i.MX SDMA: Fix burstsize settings
ARM: mach-shmobile: both USB DMAC instances on sh7372 are slave-only
dma: sh_dma: not all SH DMAC implementations support MEMCPY
at_hdmac: bugfix for enabling channel irq
dmaengine: fix missing 'cnt' in ?: in dmatest
ARM: 7314/1: kuser: consistently use usr_ret for returning from helpers
ARM: 7302/1: Add TLB flushing for both entries in a PMD
ARM: 7303/1: perf: add empty NODE event definitions for Cortex-A5 and Cortex-A15
ARM: 7308/1: vfp: flush thread hwstate before copying ptrace registers
ARM: 7307/1: vfp: fix ptrace regset modification race
ARM: 7306/1: vfp: flush thread hwstate before restoring context from sigframe
Revert "ARM: 7304/1: ioremap: fix boundary check when reusing static mapping"
__kuser_cmpxchg64 has a return path using bx lr to get back to the caller.
This is actually ok since the code in question is predicated on
CONFIG_CPU_32v6K, but for the sake of consistency using the usr_ret
macro is probably better.
Acked-by: Dave Martin <dave.martin@linaro.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Linux uses two PMD entries for a PTE with the classic page table format,
covering 2MB range. However, the __pte_free_tlb() function only adds a
single TLB flush corresponding to 1MB range covering 'addr'. On
Cortex-A15, level 1 entries can be cached by the TLB independently of
the level 2 entries and without additional flushing a PMD entry would be
left pointing at the wrong PTE. The patch limits the TLB flushing range
to two 4KB pages around the 1MB boundary within PMD.
Commit 89d6c0b5 ("perf, arch: Add generic NODE cache events") added
empty NODE event definitions for the ARM PMU implementations. This was
merged along with Cortex-A5 and Cortex-A15 PMU support, so they missed
out on the original patch.
This patch adds the empty definitions to Cortex-A5 and Cortex-A15.
If we are context switched whilst copying into a thread's
vfp_hard_struct then the partial copy may be corrupted by the VFP
context switching code (see "ARM: vfp: flush thread hwstate before
restoring context from sigframe").
This patch updates the ptrace VFP set code so that the thread state is
flushed before the copy, therefore disabling VFP and preventing
corruption from occurring.
Cc: stable <stable@vger.kernel.org>
In a preemptible kernel, vfp_set() can be preempted, causing the
hardware VFP context to be switched while the thread vfp state is
being read and modified. This leads to a race condition which can
cause the thread vfp state to become corrupted if lazy VFP context
save occurs due to preemption in between the time thread->vfpstate
is read and the time the modified state is written back.
This may occur if preemption occurs during the execution of a
ptrace() call which modifies the VFP register state of a thread.
Such instances should be very rare in most realistic scenarios --
none has been reported, so far as I am aware. Only uniprocessor
systems should be affected, since VFP context save is not currently
lazy in SMP kernels.
The problem was introduced by my earlier patch migrating to use
regsets to implement ptrace.
This patch does a vfp_sync_hwstate() before reading
thread->vfpstate, to make sure that the thread's VFP state is not
live in the hardware registers while the registers are modified.
Thanks to Will Deacon for spotting this.
Signed-off-by: Dave Martin <dave.martin@linaro.org>
Following execution of a signal handler, we currently restore the VFP
context from the ucontext in the signal frame. This involves copying
from the user stack into the current thread's vfp_hard_struct and then
flushing the new data out to the hardware registers.
This is problematic when using a preemptible kernel because we could be
context switched whilst updating the vfp_hard_struct. If the current
thread has made use of VFP since the last context switch, the VFP
notifier will copy from the hardware registers into the vfp_hard_struct,
overwriting any data that had been partially copied by the signal code.
Disabling preemption across copy_from_user calls is a terrible idea, so
instead we move the VFP thread flush *before* we update the
vfp_hard_struct. Since the flushing is performed lazily, this has the
effect of disabling VFP and clearing the CPU's VFP state pointer,
therefore preventing the thread from being updated with stale data on
the next context switch.
Tested-by: Peter Maydell <peter.maydell@linaro.org>
This reverts commit 3c424f359898aff48c3d5bed608ac706f8a528c3.
Joachim Eastwood reports:
| Commit: 3c424f359898aff48c3d5bed608ac706f8a528c3 in Linus master
| Breaks booting on my custom AT91RM9200 board.
| There isn't any error messages or anything that indicates what goes
| wrong it just stops after; Uncompressing Linux... done, booting the
| kernel.
| Reverting it makes my board boot again.
and further debugging reveals:
ioremap: pfn=fffff phys=fffff000 offset=400 size=1000
ioremap: area c3ffdfc0: phys_addr=200000 pfn=200 size=4000
ioremap: found: addr fef74000 => fed73000 => fed73400
Clearly, an area for pfn 0x200, 16K can't ever satisfy a request for pfn
0xfffff. This happens because the changed if statement becomes:
if (0x00200 > 0xfffff ||
0xfffff000 + 0x400 + 0x1000-1 > 0x00200000 + 0x4000-1)
and therefore:
0x000003ff > 0x00203fff)
The if condition fails, and so we _believe_ that the SRAM mapping fits
our request. Clearly that's totally bogus.
Moreover, the original premise of the 'fix' patch was wrong:
| The condition checking boundaries of the requested and existing
| mappings didn't take in-page offset into consideration though,
| which lead to obscure and hard to debug problems when requested
| mapping crossed end of the static one.
as the code immediately above this loop does:
size = PAGE_ALIGN(offset + size);
so 'size' already contains the requested offset into the page.
So, revert the broken 'fix'.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
fixes
* 'fixes' of git://gitorious.org/linux-davinci/linux-davinci:
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm: (31 commits)
ARM: 7301/1: Rename the T() macro to TUSER() to avoid namespace conflicts
ARM: 7299/1: ftrace: clear zero bit in reported IPs for Thumb-2
ARM: 7298/1: realview: fix mapping of MPCore private memory region
PCMCIA: fix sa1111 oops on remove
ARM: 7288/1: mach-sa1100: add missing module_init() call
ARM: 7297/1: smp_twd: make sure timer is stopped before registering it
ARM: 7296/1: proc-v7.S: remove HARVARD_CACHE preprocessor guards
ARM: 7295/1: cortex-a7: move proc_info out of !CONFIG_ARM_LPAE block
ARM: 7293/1: logical_cpu_map: decouple CPU mapping from SMP
ARM: 7291/1: cache: assume 64-byte L1 cachelines for ARMv7 CPUs
ARM: 7290/1: vmlinux.lds.S: align the exception fixup table to a 4-byte boundary
ARM: 7289/1: vmlinux.lds.S: do not hardcode cacheline size as 32 bytes
MFD: ucb1x00-ts: fix resume failure
MFD: ucb1x00-core: fix gpiolib direction_output handling
MFD: ucb1x00-core: fix missing restore of io output data on resume
MFD: mcp-core: fix mcp_priv() to be more type safe
MFD: mcp-core: fix complaints from the genirq layer
Revert "ARM: sa11x0: Implement autoloading of codec and codec pdata for mcp bus."
Revert "ARM: sa1100: Refactor mcp-sa11x0 to use platform resources."
Fix up conflict due to arch/arm/mach-mx5/Kconfig having been merged into
mach-imx5 (commit 784a90c0a7d8: "ARM i.MX: Merge i.MX5 support into
mach-imx"), but the ARM_L1_CACHE_SHIFT_6 entry was moved to be driven by
the CPU_V7 logic from it in the old location in rmk's branch (commit
a092f2b15399: "ARM: 7291/1: cache: assume 64-byte L1 cachelines for
ARMv7 CPUs").
arm-soc fixes for 3.3-rc:
AT91 needed reset fixes which resulted in some minor code refactoring,
it also adds a feature-removal for one of their platforms for 3.4.
The USB patches have been acked by Greg K-H.
i.MX and ux500 both have some minor fixes, nothing controversial.
arch/arm/mach-imx/mach-mx53_ard.c: add missing iounmap
ARM: imx: iomux-v1.h: Fix build error due to __init annotation
ARM: at91: Fix at91sam9g45 and at91cap9 reset
ARM: at91: make rstc soc independent
ARM: at91: introduce AT91_SAM9_ALT_RESET to select the at91sam9 alternative reset
ARM: at91: merge at91cap9_ddrsdr.h in at91sam9_ddrsdr.h
ARM: at91: fix cap9 ddrsdr register
ARM/USB: at91/ohci-at91: rename vbus_pin_inverted to vbus_pin_active_low
USB: at91: fix clk_get error handling
ARM: at91: removal of CAP9 SoC family
ARM: at91: fix at91rm9200 soc subtype handling
mach-ux500: no MMC_CAP_SD_HIGHSPEED on Snowball
mach-ux500: enable ARM errata 764369
mach-ux500: do not override outer.inv_all
mach-ux500: musb: now musb is always in OTG mode
ARM: imx6: add missing twd_clk for imx6q clock
Since commit 576d2f2525612ecb5af029a76f21f22a3b82563d "ARM: add
generic ioremap optimization by reusing static mappings" ioremap()
is trying to reuse existing static mapping when possible.
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
Commit 5a05a8200a4359ef2bfe9094c137dee35cfdd516 ("davinci_emac:
use an unique MDIO bus name") introduced during the v3.3 merge
window updated the davinci mdio bus name to make it unique.
Update the bus name in board files which use DaVinci MDIO bus
to match the new name. Without this PHY is not detected with
error like:
PHY 0:01 not found
net eth0: could not connect to phy 0:01
Tested on DM365 and DA850 EVMs.
Cc: Florian Fainelli <florian@openwrt.org>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
fixes
* 'imx-fixes' of git://git.pengutronix.de/git/imx/linux-2.6:
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson into fixes
* 'fixes-for-arm-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson:
into fixes
* 'imx6/fixes' of git://git.linaro.org/people/shawnguo/linux-2.6:
Add missing iounmap in error handling code, in a case where the function
already preforms iounmap on some other execution path.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression e;
statement S,S1;
int ret;
e = \(ioremap\|ioremap_nocache\)(...)
... when != iounmap(e)
if (<+...e...+>) S
... when any
when != iounmap(e)
*if (...)
{ ... when != iounmap(e)
return ...; }
... when any
iounmap(e);
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
pdata needs to be freed before leaving the function in an error case.
A simplified version of the semantic match that finds the problem is as
follows: (http://coccinelle.lip6.fr)
// <smpl>
@r exists@
local idexpression x;
statement S;
identifier f1;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f1
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
// </smpl>
Currently MMC2 setup code can only enable loopback clock and
relies on reset value for boards that need to have it disabled.
This causes a problem with certain bootloaders that always enable
that clock, resulting with unwanted bootloader dependencies.
Fix this by making it disable the clock if board data says so.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
hsmmc23_before_set_reg() can set MMCSDIO2ADPCLKISEL bit, which
enables internal clock for MMC2. Currently this function is also called
by code handling MMC3, and if .internal_clock is set in platform data
(by default it currently is), it will set MMCSDIO2ADPCLKISEL for MMC2
instead of MMC3 (MMC3 doesn't have such bit so nothing actually needs to
be done). This breaks 2nd SD slot on pandora.
Fix this by changing hsmmc23_before_set_reg() to only handle MMC2.
Note that this removes .remux() call for MMC3, but no board currently
needs it and it's also not called for MMC4 and MMC5.
following statement can only change device size from 8-bit(0) to 16-bit(1),
but not vice versa:
regval |= GPMC_CONFIG1_DEVICESIZE(wval);
so as this field has 1 reserved bit, that could be used in future,
just clear both bits and then OR with the desired value
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
