path: root/arch/arm
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-20[ARM] 5212/1: pxa: fix build error when CPU_PXA310 is not definedMike Rapoport
Fix arch/arm/mach-pxa/pxa300.c:94: error: 'CKEN_MMC3' undeclared here (not in a function) when building for PXA300. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-19[ARM] 5208/1: fsg-setup.c fixesTomasz Chmielewski
This patch against 2.6.27-rc3 does the following changes to FSG-3 setup code: 1) Enable RTC on FSG-3 (proper name is needed). This change is needed due to a recent change in i2c. 2) i variable is only used when compiling for big endian. So move its declaration to ARMEB ifdef to silence the warning when compiling for LE. Mailing list link: http://lists.arm.linux.org.uk/lurker/message/20080813.091556.cae2917e.en.html Signed-off-by: Tomasz Chmielewski <mangoo@wpkg.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-18Merge branch 'for_rmk_17' of git://git.mnementh.co.uk/linux-2.6-imRussell King
2008-08-18[ARM] fix impd1.c build warningRussell King
CC arch/arm/mach-integrator/impd1.o arch/arm/mach-integrator/impd1.c: In function `impd1_probe': arch/arm/mach-integrator/impd1.c:408: warning: too few arguments for format Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-16Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (38 commits) [ARM] 5191/1: ARM: remove CVS keywords [ARM] pxafb: fix the warning of incorrect lccr when lcd_conn is specified [ARM] pxafb: add flag to specify output format on LDD pins when base is RGBT16 [ARM] pxafb: fix the incorrect configuration of GPIO77 as ACBIAS for TFT LCD [ARM] 5198/1: PalmTX: PCMCIA fixes [ARM] Fix a pile of broken watchdog drivers [ARM] update mach-types [ARM] 5196/1: fix inline asm constraints for preload [ARM] 5194/1: update .gitignore [ARM] add proc-macros.S include to proc-arm940 and proc-arm946 [ARM] 5192/1: ARM TLB: add v7wbi_{possible,always}_flags to {possible,always}_tlb_flags [ARM] 5193/1: Wire up missing syscalls [ARM] traps: don't call undef hook functions with spinlock held [ARM] 5183/2: Provide Poodle LoCoMo GPIO names [ARM] dma-mapping: provide sync_range APIs [ARM] dma-mapping: improve type-safeness of DMA translations [ARM] Kirkwood: instantiate the orion_spi driver in the platform code [ARM] prevent crashing when too much RAM installed [ARM] Kirkwood: Instantiate mv_xor driver [ARM] Orion: Instantiate mv_xor driver for 5182 ...
2008-08-16[ARM] 5191/1: ARM: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-16[ARM] pxafb: add flag to specify output format on LDD pins when base is RGBT16Eric Miao
Another fix of inconsistent shift of the LCD_BIAS_ACTIVE_* and LCD_PCLK_EDGE_* is also included. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-16[ARM] update mach-typesRussell King
2008-08-16[ARM] 5196/1: fix inline asm constraints for preloadNicolas Pitre
With gcc 4.3 and later, a pointer that has already been dereferenced is assumed not to be null since it should have caused a segmentation fault otherwise, hence any subsequent test against NULL is optimized away. Current inline asm constraint used in the implementation of prefetch() makes gcc believe that the pointer is dereferenced even though the PLD instruction does not load any data and does not cause a segmentation fault on null pointers, which causes all sorts of interesting results when reaching the end of a linked lists for example. Let's use a better constraint to properly represent the actual usage of the pointer value. Problem reported by Chris Steel. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-15kexec jump: rename KEXEC_CONTROL_CODE_SIZE to KEXEC_CONTROL_PAGE_SIZEHuang Ying
Rename KEXEC_CONTROL_CODE_SIZE to KEXEC_CONTROL_PAGE_SIZE, because control page is used for not only code on some platform. For example in kexec jump, it is used for data and stack too. [akpm@linux-foundation.org: unbreak powerpc and arm, finish conversion] Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-13usb: musb: pass configuration specifics via pdataFelipe Balbi
Use platform_data to pass musb configuration-specific details to musb driver. This patch will prevent that other platforms selecting HAVE_CLK and enabling musb won't break tree building. The other parts of it will come when linux-omap merge up more omap2/3 board-files. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-12[ARM] 5194/1: update .gitignoreNicolas Pitre
2008-08-12[ARM] add proc-macros.S include to proc-arm940 and proc-arm946Russell King
... otherwise these fail to build. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-12[ARM] 5192/1: ARM TLB: add v7wbi_{possible,always}_flags to ↵Paul Walmsley
{possible,always}_tlb_flags Commit 2ccdd1e77da52ad494e9af46bf272d816830cb28 doesn't add v7wbi_possible_flags and v7wbi_always_flags to possible_tlb_flags and always_tlb_flags. This causes the L2 cache flush in clean_pmd_entry() (intended for Feroceon only) to execute on ARMv7, and the CPU hangs. This patch is required for OMAP3 boards to boot. Signed-off-by: Paul Walmsley <paul@pwsan.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-12[ARM] 5193/1: Wire up missing syscallsStefan Schmidt
Setup some missing syscall pointed out by the checksyscalls.sh script. Fix two small whitespace issues while being there. Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-12[ARM] traps: don't call undef hook functions with spinlock heldRussell King
Calling the undefined instruction handler functions with a spinlock held is a recipe for must_sleep() warnings. Avoid it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-12[ARM] 5183/2: Provide Poodle LoCoMo GPIO namesDmitry Baryshkov
Fix Poodle ASoC compilation by providing Poodle LoCoMo GPIO names. Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-12[ARM] e400 config use MFPIan Molton
This patch updates e400 to use the new MFP GPIO setup code. Signed-off-by: Ian Molton <spyro@f2s.com>
2008-08-12[ARM] e740 config use MFPIan Molton
This patch updates e740 to use the new MFP GPIO setup code. Signed-off-by: Ian Molton <spyro@f2s.com>
2008-08-12[ARM] Fix eseries IRQ limitIan Molton
The max IRQ is too small for all e-series machines which have at least one GPIO expander chip in them. Signed-off-by: Ian Molton <spyro@f2s.com>
2008-08-12[ARM] clocklib: Update users of aliases to new APIIan Molton
This patch removes the hardcoded alias array from pxa25x.c and reimplements its functionality using the new clock alias call. Signed-off-by: Ian Molton <spyro@f2s.com>
2008-08-12[ARM] clocklib: Allow dynamic alias creationIan Molton
This patch allows dynamic creation of clock aliases in order to make it possible to have platform independent clock names for use in device drivers. Signed-off-by: Ian Molton <spyro@f2s.com>
2008-08-12[ARM] eseries: whitespace fixes and cleanupIan Molton
2008-08-10[ARM] dma-mapping: provide sync_range APIsRussell King
Convert the existing dma_sync_single_for_* APIs to the new range based APIs, and make the dma_sync_single_for_* API a superset of it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-10[ARM] dma-mapping: improve type-safeness of DMA translationsRussell King
OMAP at least gets the return type(s) for the DMA translation functions wrong, which can lead to subtle errors. Avoid this by moving the DMA translation functions to asm/dma-mapping.h, and converting them to inline functions. Fix the OMAP DMA translation macros to use the correct argument and result types. Also, remove the unnecessary casts in dmabounce.c. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-09Merge branch 'for-rmk' of git://git.marvell.com/orionRussell King
2008-08-09[ARM] Kirkwood: instantiate the orion_spi driver in the platform codeLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-09[ARM] prevent crashing when too much RAM installedLennert Buytenhek
This patch will truncate and/or ignore memory banks if their kernel direct mappings would (partially) overlap with the vmalloc area or the mappings between the vmalloc area and the address space top, to prevent crashing during early boot if there happens to be more RAM installed than we are expecting. Since the start of the vmalloc area is not at a fixed address (but the vmalloc end address is, via the per-platform VMALLOC_END define), a default area of 128M is reserved for vmalloc mappings, which can be shrunk or enlarged by passing an appropriate vmalloc= command line option as it is done on x86. On a board with a 3:1 user:kernel split, VMALLOC_END at 0xfe000000, two 512M RAM banks and vmalloc=128M (the default), this patch gives: Truncating RAM at 20000000-3fffffff to -35ffffff (vmalloc region overlap). Memory: 512MB 352MB = 864MB total On a board with a 3:1 user:kernel split, VMALLOC_END at 0xfe800000, two 256M RAM banks and vmalloc=768M, this patch gives: Truncating RAM at 00000000-0fffffff to -0e7fffff (vmalloc region overlap). Ignoring RAM at 10000000-1fffffff (vmalloc region overlap). Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Tested-by: Riku Voipio <riku.voipio@iki.fi>
2008-08-09[ARM] Kirkwood: Instantiate mv_xor driverSaeed Bishara
Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-09[ARM] Orion: Instantiate mv_xor driver for 5182Saeed Bishara
2008-08-09[ARM] Orion: enable CONFIG_RTC_DRV_S35390A in the defconfg for QNAP devicesMartin Michlmayr
The QNAP TS-109/TS-209 and TS-409 devices need RTC_DRV_S35390A. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-09[ARM] Orion: enable RTC_DRV_PCF8563 in the defconfig for HP mv2120Martin Michlmayr
Enable RTC_DRV_PCF8563 in the Orion defconfig since this driver is needed by the HP mv2120. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-09[ARM] Orion: enable KEYBOARD_GPIO in the defconfgMartin Michlmayr
Enable KEYBOARD_GPIO in the Orion defconfig because a number of Orion devices, such as the HP mv2120, define gpio-keys buttons. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-09[ARM] Orion: Export the reset button of the QNAP TS-409Martin Michlmayr
The reset button on the QNAP TS-409 is available through gpio. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-09[ARM] Orion: use better key codes for the TS-209/TS-409 buttonsMartin Michlmayr
Use key codes for the buttons on the TS-209/TS-409 that make more sense than the current values. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Acked-by: Byron Bradley <byron.bbradley@gmail.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-09[ARM] Orion: export red SATA lights on TS-409, fix SATA presence/activityMartin Michlmayr
Export the four red SATA LEDs on the QNAP TS-409 that are connected through gpio. Since the boot loader apparently sets the SATA LEDs 2-4 to red and the SATA LED can only be red or green (but not both), exporting the red SATA LEDs (which automatically turns them off upon boot) makes the green SATA presence/activity indication visible. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Acked-by: Sylver Bruneau <sylver.bruneau@googlemail.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-09[ARM] Orion: support D0 5281 siliconLennert Buytenhek
On D0 5281 SoCs, we need to disable the wait-for-interrupt instruction due to an erratum. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com> Acked-by: Martin Michlmayr <tbm@cyrius.com>
2008-08-09[ARM] S3C24XX: Fix section mismatch for s3c_lookup_cpuBen Dooks
s3c_lookup_cpu is only used at init time, so make it __init. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-09[ARM] CATS: Do not try and map bad PCI IRQ numbersBen Dooks
The cats_map_irq() function in the Simtec CATS support code is mapping IRQ 255 (invalid IRQ) into what is a supposedly valid interrupt numner which can cause problems with other devices then seeing an interrupt they cannot claim. If the IRQ number if >= 255, then return -1 as this is not something we can map. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-09[ARM] JIVE: Remove duplicated mtd includesHuang Weiyi
Removed duplicated include file <linux/mtd/mtd.h> and <linux/mtd/partitions.h> in arch/arm/mach-s3c2412/mach-jive.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-09[ARM] Move include/asm-arm/plat-orion to arch/arm/plat-orion/include/platLennert Buytenhek
This patch performs the equivalent include directory shuffle for plat-orion, and fixes up all users. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-08Merge http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm ↵Ben Dooks
into for-rmk
2008-08-08[ARM] 5177/1: arm/mach-sa1100/Makefile: remove CONFIG_SA1100_USBAdrian Bunk
This patch removes the commented out line for the not available CONFIG_SA1100_USB option. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-08[ARM] fix pnx4008 build errorsRussell King
include/linux/i2c-pnx.h was missed when moving the include files. Fix it now; it doesn't really need to include mach/i2c.h at all. Successfully build tested with pnx4008_defconfig, which had failed in linux-next. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Fix SMP booting with non-zero PHYS_OFFSETRussell King
The existing code tries to get the pmd for the temporary page table by doing: pgd = pgd_alloc(&init_mm); pmd = pmd_offset(pgd, PHYS_OFFSET); Since we have a two level page table, pmd_offset() is a no-op, so this just has a casting effect from a pgd to a pmd - the address argument is unused. So this can't work. Normally, we'd do: pgd = pgd_offset(&init_mm, PHYS_OFFSET); ... pmd = pmd_offset(pgd, PHYS_OFFSET); to get the pmd you want. However, pgd_offset() takes the mm_struct, not the (unattached) pgd we just allocated. So, instead use: pgd = pgd_alloc(&init_mm); pmd = pmd_offset(pgd + pgd_index(PHYS_OFFSET), PHYS_OFFSET); Reported-by: Antti P Miettinen <ananaza@iki.fi> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 Conflicts: arch/arm/mach-pxa/generic.c arch/arm/mach-pxa/pxa25x.c arch/arm/mach-pxa/pxa27x.c arch/arm/mach-pxa/pxa2xx.c arch/arm/mach-pxa/pxa3xx.c arch/arm/mach-pxa/reset.c arch/arm/mach-pxa/spitz.c arch/arm/mach-pxa/tosa.c drivers/watchdog/sa1100_wdt.c
2008-08-07[ARM] 5185/1: Fix spi num_chipselect for lubbockJonathan Cameron
Change num_chipselect for lubbock ssp master to reflect requirement of spi subsystem that all buses have at least 1 chip select. Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Acked-by: Eric Miao <eric.miao@marvell.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesRussell King
