path: root/arch/arm
2005-07-04[PATCH] ARM: Fix non-standard PXA io_pg_offst initialisersRussell King
These didn't match my sed expression correctly, fix them up manually. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-04[PATCH] ARM: Change 'param_offset' to 'boot_params'Russell King
2005-07-03[PATCH] ARM: 2784/1: Fix the block cache flush operation rangeCatalin Marinas
Patch from Catalin Marinas The range for the ARMv6 block cache operations is inclusive but the kernel doesn't re-calculate the end address, causing a page fault when used (this only happens with support for cache aliasing, otherwise the blk_flush_kern_dcache_page() is not called). This patch subtracts L1_CACHE_BYTES from the end address. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-03[PATCH] ARM: Remove machine description macrosRussell King
Remove the pointless machine description macros, favouring C99 initialisers instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-01[PATCH] ARM: replace schedule_timeout() with msleep()Nishanth Aravamudan
Use msleep() instead of schedule_timeout() to guarantee the task delays as expected. Neither signals nor wait-queue events are important at this point in the code, I believe. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-01[PATCH] ARM: Make the magic values in head.S more obviousRussell King
Make the magic address values in head.S more obvious as to where they came from. Wrap all debug code in CONFIG_DEBUG_LL. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-01[PATCH] ARM: 2783/1: Remove omnimeter_defconfig as there is no kernel supportBen Dooks
Patch from Ben Dooks The omnimeter_defconfig does not define any machines and seems to have no other support in the current kernel. This patch removes the config file, as this is the only thing currently mentioning the ominmeter. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-01[PATCH] ARM: 2781/2: PXA27x Standby mode take 2Todd Poynor
Patch from Todd Poynor Add support for PXA27x Standby mode, a low-power mode that retains CPU and some peripheral state (the existing "sleep" mode is a power-power mode that retains less state). Activated via: echo -n standby > /sys/power/state From: David Burrage and Todd Poynor Signed-off-by: Todd Poynor <tpoynor@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-30[PATCH] ARM: 2779/1: Fix the V bit setting for the ARM1020x CPUsCatalin Marinas
Patch from Catalin Marinas This patch fixes the V bit setting for the ARM1020x processors. At reset, this bit is automatically set to the value of the HIVECSINIT input signal which just happened to be 1 but it is not mandatory. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-30[PATCH] ARM: 2778/1: Add -mno-thumb-interwork to CFLAGS_ABICatalin Marinas
Patch from Catalin Marinas The new EABI gcc adds -mthumb-interwork by default, even if -mabi=apcs-gnu is passed. This causes a warning for every compiled C file when -march=armv4 is used. The patch adds -mno-thumb-interwork if the option is supported. This is also useful since we don't need any ARM/Thumb interworking in the kernel Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-30[PATCH] ARM: 2777/1: Fix broken comment arch/arm/mm/proc-arm1020.SCatalin Marinas
Patch from Catalin Marinas This patch fixes a broken comment in the proc-arm1020.S file which prevents the file compilation Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-30[PATCH] ARM: Don't try to send a signal to pid0Russell King
If we receive an unrecognised abort during boot, don't try to send a signal to pid0, but instead report the current state. This leads to less confusing debug reports. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29[PATCH] ARM: Don't force SIGFPERussell King
We were forcing SIGFPE on to a user program for no good reason. Use send_sig_info() instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29[PATCH] ARM: Fix VFP to use do_div()Russell King
VFP used __divdi3 64-bit division needlessly. Convert it to use our 64-bit by 32-bit division instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29[PATCH] ARM: 2771/1: Dynamic Tick support for OMAP, take 4Tony Lindgren
Patch from Tony Lindgren This patch adds support for Dynamic Tick Timer for OMAP. This patch is an updated version of ARM patch 2642/1 to make it work with the already integrated generic ARM dyntick support. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29[PATCH] ARM: Remove nmi_tick from integrator platformsRussell King
The nmi watchdog code hasn't been merged for this platform yet. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29[PATCH] ARM: 2723/2: remove __udivdi3 and __umoddi3 from the kernelNicolas Pitre
Patch from Nicolas Pitre Those are big, slow and generally not recommended for kernel code. They are even not present on i386. So it should be concluded that one could as well get away with do_div() alone. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29[PATCH] ARM: 2769/1: cpu_init() stack setup fixCatalin Marinas
Patch from Catalin Marinas The compiler allocates r14 for the stk variable in the __asm__ directive. This is a shadowed register and gets changed when the mode is changed, causing random values in the SP register. The patch adds a clobber for the r14 register. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29[PATCH] ARM: Convert ARM timer implementations to use readl/writelRussell King
Convert ARMs timer implementations to use readl/writel instead of accessing the registers via a struct. People have recently asked if accessing timers via a structure is the "right way" and its not the Linux way. So fix this code to conform to "The Linux Way"(tm). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Catalin Marinas <catalin.marinas@arm.com>
2005-06-29[PATCH] ARM: 2765/1: S3C24XX - small cleanups in arch/arm/mach-s3c2410Ben Dooks
Patch from Ben Dooks Re-tab the devs.c file, and change the initialiser for the mach-vr1000.c to use `.xxx = yyy` form. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29[PATCH] ARM: 2764/1: S3C24XX - Common PM functions for Simtec boardsBen Dooks
Patch from Ben Dooks All current S3C24XX implementations from Simtec share the same requirements for suspend/resume information. This patch moves the save code out of the mach-bast.c file, and into it's own so it can be shared by all the current Simtec S3C24XX implementations. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29Merge with ../linux-2.6-smpRussell King
2005-06-28[PATCH] ARM: 2763/1: S3C24XX - mark IRQ_LCD as validBen Dooks
Patch from Ben Dooks Fix the IRQ_LCD so that it is marked as valid since we no longer de-mux this in the main IRQ handler. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-28[PATCH] ARM: 2760/1: Add a warning on dynamic tick timekeeping on some platformsTony Lindgren
Patch from Tony Lindgren This patch was suggested by RMK, and adds a warning on the accuracy of timekeeping when using dynamic tick on some platforms. Depending on the timer implementation, dynamic tick may affect the accuracy of timekeeping. Currently at least OMAP is known to have accurate timekeeping with dynamic tick. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-28[PATCH] ARM: 2761/1: OProfile: Add call graphing support for armRichard Purdie
Patch from Richard Purdie Add functions to generate backtraces of both kernel and user processes which allows oprofile's call graphing functionality to be used on arm. This requires unstripped binaries/libs which use a frame pointer. Signed-off-by: Richard Purdie Signed-off-by: Zwane Mwaikambo <zwane@arm.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-28[PATCH] ARM SMP: Add IPI support code for SMP TLB flushingRussell King
2005-06-28[PATCH] ARM SMP: Use local_flush_tlb* where we really want to be localRussell King
2005-06-27Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
2005-06-27[PATCH] USB: omap_udc updates (mostly cleanups)David Brownell
Various USB patches, mostly for portability: - Fifo mode 1 didn't work previously (oopsed), so now it's fixed and (why not) defines even more endpoints for composite devices. - OMAP 1710 doesn't have an internal transceiver. - Small PM update: if the USB link is suspended, don't disconnect on entry to deep sleep. - Be more correct about handling zero length control reads. OMAP seems to mis-handle that protocol peculiarity though; best avoided. - Platform device resources (for UDC and OTG controllers) now use physical addresses, so /proc/iomem is more consistent. - Minor cleanups, notably (by volume) for "sparse" NULL warnings. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2005-06-27[PATCH] ARM: Update mach-typesRussell King
2005-06-27[PATCH] ARM: Move memmap freeing into init.cRussell King
It doesn't make sense for this to be in mm-armv.c now that 26-bit ARM support is no longer integrated into arch/arm. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-27[PATCH] ARM: Move PGD kernel page table initialisationRussell King
It doesn't make sense to have the PGD kernel pointers initialisation separate from the PGD user pointers, especially when we clean the data cache over the whole range. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-27[PATCH] ARM: Add VST idle loop callRussell King
This call allows the dynamic tick support to reprogram the timer immediately before the CPU idles. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-27[PATCH] ARM: Add missed AAEC2000 fileRussell King
My scripts missed committing this file. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-26Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-06-26[PATCH] ARM: 2757/1: remove ixdp2400_init_irq from ixdp2800 codeLennert Buytenhek
Patch from Lennert Buytenhek Compiling one kernel that supports both ixdp2400 and ixdp2800 gives an error, as a copy of the ixdp2400 irq init routing accidentally ended up in ixdp2800.c somehow. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-26[PATCH] ARM: 2756/1: add ixp2000 msf mappingLennert Buytenhek
Patch from Lennert Buytenhek Add a mapping for the ixp2400 and ixp2800 msf unit. The msf is the ixp2000's 'media and switch fabric' unit, which handles the networking part of the chip. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-26[PATCH] ARM: Add SA_TIMER flag to timer interruptsRussell King
VST needs to know which timer handler is for the timer interrupt. Mark all timer interrupts with the SA_TIMER flag. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-26[PATCH] arm: swsusp build fixAndrew Morton
Another swsusp fixup. Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] ARM: Generic Dynamic Tick Timer support for ARM, take 4Russell King
This patch adds support for Dynamic Tick Timer for ARM. Dynamic Tick is also known as VST (Variable Scheduling Timeouts). Dynamic Tick has been in use in the OMAP tree since last October. The patch is not intrusive, and does not do anything unless CONFIG_NO_IDLE_HZ is defined. This patch has the following fixed based on comments from RMK: - Time is updated before calling interrupt handlers. - Added new interrupt flag SA_TIMER to avoid duplicate timer interrupts - Moved struct dyn_tick_timer to time.h until we at some point probably have an arch independent dyn-tick.h - Cleaned up testing for DYN_TICK_ENABLED in irq.c I've cleaned up this patch to fix some remaining issues: - Call the timer tick handler with irqs disabled, as it would be from a normal interrupt - if we have a dyn_tick, we better implement all methods. - generic timer_dyn_reprogram() call, to be called before sleeping - added command line option - "dyntick=" to allow boot-time control of this feature -- rmk Signed-off-by: Tony Lindgren Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-25[PATCH] ARM: 2752/1: disable ixp2000 PCI I/O software workaround on chips ↵Lennert Buytenhek
that don't need it Patch from Lennert Buytenhek The later ixp2000 models don't need the PCI I/O workaround that we currently perform. Add a config option to disable the workaround, and panic on boot if a kernel without the workaround is booted on a buggy chip. As only pre-production ixp2000s need the workaround, the default is for it not to be configured in. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-25[PATCH] ARM: Fix discontigmemRussell King
The merge of sparsemem broke ARM discontigmem. Fix it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-25[PATCH] ARM: 2751/1: ixp2000 gpio cleanup broke ixdp2800 buildLennert Buytenhek
Patch from Lennert Buytenhek The ixp2000 gpio cleanup broke the ixdp2800 build as it moved some gpio-related functions from arch/platform.h to arch/gpio.h and the ixdp2x00 support code used those functions but didn't include the latter header file. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-25[PATCH] ARM: 2750/1: add i2c platform device for enp2611 on-board i2c busLennert Buytenhek
Patch from Lennert Buytenhek On the enp2611, GPIO 7 and 6 are connected to an on-board i2c bus that attaches to the SODIMM module slot (for SPD) and an LM84 temperature sensor. Add a platform device for this i2c bus. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-25[PATCH] ARM: 2749/1: update ixp2000 defconfigs to 2.6.12-git6Lennert Buytenhek
Patch from Lennert Buytenhek Update the defconfigs for the ixp2000 platforms to 2.6.12-git6. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-24[PATCH] ARM: 2698/1: Enable kernel r/w access to user pages on ARMv6Catalin Marinas
Patch from Catalin Marinas cpu_v6_set_pte() sets the kernel access rights to r/o for user pages (L_PTE_USER) when neither L_PTE_WRITE nor L_PTE_DIRTY are set. This causes a kernel data abort when writing the TLS value in the 0xffff0000 page. This patch enables the kernel r/w access. Signed-off-by: Catalin Marinas Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-24[PATCH] ARM: 2745/1: Fix IXP4xx debug macrosDeepak Saxena
Patch from Deepak Saxena Current IXP4xx debug macros do not work in the small window between the MMU being enabled and the call to map_io() b/c the standard peripheral mapping is not properly setup for use with the low-level debug code. This patch creates a new section-aligned mapping for the UART specifically for use with the debug macros. Signed-off-by: Deepak Saxena Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-24[PATCH] ARM: 2744/1: ixp2000 gpio irq supportLennert Buytenhek
Patch from Lennert Buytenhek This patch cleans up the ixp2000 gpio irq code and implements the set_irq_type method for gpio irqs so that users can select for which events (falling edge/rising edge/level low/level high) on the gpio pin they want the corresponding gpio irq to be triggered. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-23Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-06-23[PATCH] ARM: 2730/1: S3C2410 default configuration updateBen Dooks
Patch from Ben Dooks Add support for the DM9000 and bring default configuration up-to-date with the latest 2.6.12 kernel release Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
