Add a v7 defconfig enabling highbank, socfpga, mvebu, and vexpress
platforms and their drivers. Most other options are left to the default.
The existing individual platform defconfigs are kept for now as they are
a bit different. In some cases, the choices look pretty arbitrary and
just copied from other defconfigs.
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Pawel Moll <pawel.moll@arm.com>
The removal of bcmring has non-obvious commits with the way the
multiplatform configuration works, so merge it in here.
arch/arm/Kconfig
arch/arm/Makefile
arch/arm/mach-bcmring/arch.c
Doing a large-scale cleaning and removing the platform in another
branch don't mix well, so do the trivial merge here.
Remove mach-bcmring as this is no longer maintained or used.
Signed-off-by: Christian Daudt <csd@broadcom.com>
Reviewed-by: Jiandong Zheng <jdzheng@broadcom.com>
Acked-by: Will Deacon <will.deacon@arm.com>
* multiplatform/platform-data:
ARM: spear: move platform_data definitions
ARM: samsung: move platform_data definitions
ARM: orion: move platform_data definitions
ARM: nomadik: move platform_data definitions
ARM: w90x900: move platform_data definitions
ARM: vt8500: move platform_data definitions
ARM: tegra: move sdhci platform_data definition
ARM: sa1100: move platform_data definitions
ARM: pxa: move platform_data definitions
ARM: netx: move platform_data definitions
ARM: msm: move platform_data definitions
ARM: imx: move platform_data definitions
ARM: ep93xx: move platform_data definitions
ARM: davinci: move platform_data definitions
ARM: at91: move platform_data definitions
Conflicts due to removed files:
arch/arm/mach-tegra/board-harmony.c
arch/arm/mach-tegra/board-trimslice.c
Conflicts due to code removal:
arch/arm/mach-tegra/board-paz00.c
Context conflicts in:
drivers/mmc/host/sdhci-tegra.c
drivers/net/irda/pxaficp_ir.c
No real need to have a separate core.h from the common.h file. Fold
these two prototypes into the common header file.
Signed-off-by: David Brown <davidb@codeaurora.org>
* multiplatform/smp_ops:
ARM: consolidate pen_release instead of having per platform definitions
ARM: smp: Make SMP operations mandatory
ARM: SoC: convert spear13xx to SMP operations
ARM: SoC: convert imx6q to SMP operations
ARM: SoC: convert highbank to SMP operations
ARM: SoC: convert shmobile SMP to SMP operations
ARM: SoC: convert ux500 to SMP operations
ARM: SoC: convert MSM to SMP operations
ARM: SoC: convert Exynos4 to SMP operations
ARM: SoC: convert Tegra to SMP operations
ARM: SoC: convert OMAP4 to SMP operations
ARM: SoC: convert VExpress/RealView to SMP operations
ARM: SoC: add per-platform SMP operations
Conflicts due to file moves or removals in:
arch/arm/mach-msm/board-msm8960.c
arch/arm/mach-msm/board-msm8x60.c
Conflicts due to board file cleanup:
Conflicts due to cpu hotplug addition:
arch/arm/mach-tegra/hotplug.c
Being a module_init call, highbank_pm_init will cause problem with
multi-platform build running on other platforms. Call it from
.init_machine instead.
Reported-by: Shawn Guo <shawn.guo@linaro.org>
Since the dtb targets have moved to arch/arm/boot/dts/Makefile, sweep
the platforms that have had new targets added recently and move them over.
While I was at it, I also made the dtb generation more generic, i.e. if
the platform is enabled then all dtbs for that platform will be created.
Cc: Tony Lindgren <tony@atomide.com>
Cc: David Brown <davidb@codeaurora.com>
Cc: Barry Song <Baohua.Song@csr.com>
Cc: Simon Horman <horms@verge.net.au>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
into next/multiplatform
Enable initial ARM multi-platform support for highbank, mvebu,
socfpga, picoxcell, and vexpress.
Multi-platform support is dependent on mach/gpio.h removal and
restructuring of DEBUG_LL and dtb build rules included in this branch.
This has been built for all defconfigs, and booted on highbank with
all 5 platforms enabled.
By Rob Herring (18) and Arnd Bergmann (1)
via Rob Herring
* tag 'multi-platform-for-3.7' of git://sources.calxeda.com/kernel/linux:
ARM: vexpress: convert to multi-platform
ARM: initial multiplatform support
ARM: mvebu: move armada-370-xp.h in mach dir
ARM: vexpress: remove dependency on mach/* headers
ARM: picoxcell: remove dependency on mach/* headers
ARM: move all dtb targets out of Makefile.boot
ARM: picoxcell: move debug macros to include/debug
ARM: socfpga: move debug macros to include/debug
ARM: mvebu: move debug macros to include/debug
ARM: vexpress: move debug macros to include/debug
ARM: highbank: move debug macros to include/debug
ARM: move debug macros to common location
ARM: make mach/gpio.h headers optional
ARM: orion: move custom gpio functions to orion-gpio.h
ARM: shmobile: move custom gpio functions to sh-gpio.h
ARM: pxa: use gpio_to_irq for sharppm_sl
net: pxaficp_ir: add irq resources
usb: pxa27x_udc: remove IRQ_USB define
staging: ste_rmi4: remove gpio.h include
Conflicts due to addition of bcm2835 and removal of pnx4008 in:
arch/arm/Kconfig
arch/arm/Makefile
Conflicts due to new dtb targets, moved to arch/arm/boot/dts/Makefile in:
arch/arm/mach-imx/Makefile.boot
arch/arm/mach-mxs/Makefile.boot
arch/arm/mach-tegra/Makefile.boot
* next/soc: (50 commits)
ARM: OMAP: AM33xx hwmod: fixup SPI after platform_data move
MAINTAINERS: add an entry for the BCM2835 ARM sub-architecture
ARM: bcm2835: instantiate console UART
ARM: bcm2835: add stub clock driver
ARM: bcm2835: add system timer
ARM: bcm2835: add interrupt controller driver
ARM: add infra-structure for BCM2835 and Raspberry Pi
ARM: tegra20: add CPU hotplug support
ARM: tegra30: add CPU hotplug support
ARM: tegra: clean up the common assembly macros into sleep.h
ARM: tegra: replace the CPU CAR access code by tegra_cpu_car_ops
ARM: tegra: introduce tegra_cpu_car_ops structures
ARM: Tegra: Add smp_twd clock for Tegra20
ARM: AM33XX: clock: Add dcan clock aliases for device-tree
ARM: OMAP2+: dpll: Add missing soc_is_am33xx() check for common functions
ARM: OMAP: omap_device: idle devices with no driver bound
ARM: OMAP: omap_device: don't attempt late suspend if no driver bound
ARM: OMAP: omap_device: keep track of driver bound status
ARM: OMAP3+: hwmod: Add AM33XX HWMOD data
ARM: OMAP2+: hwmod: Hook-up am33xx support in omap_hwmod framework
Change/remove conflict in arch/arm/mach-ux500/clock.c resolved.
* next/dt: (182 commits)
ARM: tegra: Add Avionic Design Tamonten Evaluation Carrier support
ARM: tegra: Add Avionic Design Medcom-Wide support
ARM: tegra: Add Avionic Design Plutux support
ARM: tegra: Add Avionic Design Tamonten support
ARM: tegra: dts: Add pwm label
ARM: dt: tegra: whistler: configure power off
ARM: mxs: m28evk: Disable OCOTP OUI loading
ARM: imx6q: use pll2_pfd2_396m as the enfc_sel's parent
ARM: dts: imx6q-sabrelite: add usbotg pinctrl support
ARM: dts: imx23-olinuxino: Add USB host support
ARM: dts: imx6q-sabrelite: add usbmisc device
ARM: dts: mx23: Add USB resources
ARM: dts: mxs: Add ethernetX to macX aliases
ARM: msm: Remove non-DT targets from 8960
ARM: msm: Add DT support for 8960
ARM: msm: Move io mapping prototypes to common.h
ARM: msm: Rename board-msm8x60 to signify its DT only status
ARM: msm: Make 8660 a DT only target
ARM: msm: Move 8660 to DT timer
ARM: msm: Add DT support to msm_timer
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup
From Tony Lindgren:
This branch contains mostly scripted changes to make omap
header files local where possible to get us closer to supporting
the ARM single zImage. After these changes mach includes are
pretty much out of the way for omap2+, but still lots of manual
work remains to sort through the remaining plat includes.
* tag 'omap-cleanup-local-headers-for-v3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (26 commits)
ARM: OMAP2+: Make omap4-keypad.h local
ARM: OMAP2+: Make l4_3xxx.h local
ARM: OMAP2+: Make l4_2xxx.h local
ARM: OMAP2+: Make l3_3xxx.h local
ARM: OMAP2+: Make l3_2xxx.h local
ARM: OMAP1: Move irda.h from plat to mach
ARM: OMAP2+: Make hdq1w.h local
ARM: OMAP2+: Make gpmc-smsc911x.h local
ARM: OMAP2+: Make gpmc-smc91x.h local
ARM: OMAP1: Move flash.h from plat to mach
ARM: OMAP2+: Make debug-devices.h local
ARM: OMAP1: Move board-voiceblue.h from plat to mach
ARM: OMAP1: Move board-sx1.h from plat to mach
ARM: OMAP2+: Make omap-wakeupgen.h local
ARM: OMAP2+: Make omap-secure.h local
ARM: OMAP2+: Make ctrl_module_wkup_44xx.h local
ARM: OMAP2+: Make ctrl_module_pad_wkup_44xx.h local
ARM: OMAP2+: Make ctrl_module_pad_core_44xx.h local
ARM: OMAP2+: Make ctrl_module_core_44xx.h local
ARM: OMAP2+: Make board-rx51.h local
into next/dt
From Shawn Guo:
This is the second round of imx-dt patches for 3.7. It's based on
and imx-dt-3.7 and imx-clk-dt-lookup which have already been pulled.
* tag 'imx-dt-3.7-2' of git://git.linaro.org/people/shawnguo/linux-2.6:
into next/dt
From Shawn Guo:
This is the second round of mxs-dt patches for 3.7. It's based on
mxs-dt-3.7 and mxs-clk-dt-lookup which have been pulled into arm-soc.
* tag 'mxs-dt-3.7-2' of git://git.linaro.org/people/shawnguo/linux-2.6:
git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra into next/cleanup
ARM: tegra: switch to dmaengine
The Tegra code-base has contained both a legacy DMA and a dmaengine
driver since v3.6-rcX. This series flips Tegra's defconfig to enable
dmaengine rather than the legacy driver, and removes the legacy driver
and all client code.
* tag 'tegra-for-3.7-dmaengine' of git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra:
ASoC: tegra: remove support of legacy DMA driver based access
spi: tegra: remove support of legacy DMA driver based access
ARM: tegra: apbio: remove support of legacy DMA driver based access
ARM: tegra: dma: remove legacy APB DMA driver
ARM: tegra: config: enable dmaengine based APB DMA driver
+ sync to 3.6-rc6
On Harmony, LDO7 does not feed vdd_fuse. Correct the regulator name.
This issue was probably the result of copying Ventana's regulator setup
when creating the Harmony .dts file. No other naming issues appear to
exist.
Reported-by: Thierry Reding <thierry.reding@avionic-design.de>
git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra into next/dt
ARM: tegra: second round of device tree changes
This branch includes some late device tree changes for Tegra:
A property is added to Whistler's device tree to enable the PMIC to
act as the pm_power_off() implementation.
A number of new device tree are added for boards from Avionic Design.
* tag 'tegra-for-3.7-dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-tegra:
git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-rpi into next/soc
ARM: add basic BCM2835 SoC and Raspberry Pi board support
The BCM2835 is an ARM SoC from Broadcom. This patch adds very basic
support for this SoC; enough to boot the system into an initrd with
UART console, interrupt controller, timers, and a stub clock driver.
Also provided is a similarly basic device tree for the Raspberry Pi
Model B board.
This series was written by Simon Arlott, Chris Boot, and Dom Cobley
downstream, with reference to a Broadcom tree, and modified for upstream
and submitted by Stephen Warren.
* tag 'rpi-for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-rpi:
From Kukjin Kim:
Here, there are cleanup patches for Samsung v3.7 and most of them are
related to cleanup Samsung specific gpio API.
* samsung/cleanup:
gpio: samsung: Update documentation
ARM: S3C24XX: Use module_platform_driver macro in mach-osiris-dvs.c
ARM: S3C24XX: Use module_platform_driver macro in h1940-bluetooth.c
gpio-samsung: Remove now unused s3c2410_gpio* API
ARM: S3C24XX: Remove obsolete GPIO API declarations
ARM: S3C24XX: Convert users of s3c2410_gpio_setpin to gpiolib API
ARM: EXYNOS: cleanup unused code related to GPS
AM33xx hwmod data includes "mcspi.h" which has now been moved after
the platform_data move. Fix it.
Signed-off-by: Kevin Hilman <khilman@ti.com>
This can be local to mach-omap2.
This is only used by omap1.
And to fix things properly, this should not be included
from the drivers at all.
Acked-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: linux-fbdev@vger.kernel.org
Cc: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
Cc: linux-mtd@lists.infradead.org
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: linux-input@vger.kernel.org
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Liam Girdwood <lrg@ti.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: alsa-devel@alsa-project.org
We are moving omap2+ to use the device tree based pinctrl-single.c
and will be removing the old mux framework. This will remove the
omap1 specific parts from plat-omap.
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: linux-usb@vger.kernel.org
Cc: linux-pcmcia@lists.infradead.org
Cc: spi-devel-general@lists.sourceforge.net
This is no longer needed.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt
Device tree related changes for omaps.
Note that this branch is based on omap-cleanup-sparseirq-for-v3.7
to avoid merge conflicts with the sparseirq changes for gpio-twl4030
driver.
* tag 'omap-devel-dt-merged-for-v3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
arm/dts: Mux uart pins for omap4-sdp
ARM: OMAP2+: select PINCTRL in Kconfig
arm/dts: Add pinctrl driver entries for omap2/3/4
arm/dts: Add omap36xx.dtsi file and rename omap3-beagle to omap3-beagle-xm
ARM: dts: omap3-overo: Add support for the blue LED
Documentation: dt: Update the OMAP documentation with Overo/Toby
ARM: dts: OMAP3: Add support for Gumstix Overo with Tobi expansion board
ARM: dts: OMAP4: Add reg and interrupts for every nodes
ARM: dts: AM33XX: Specify reg and interrupt property for all nodes
ARM: dts: AM33XX: Convert all hex numbers to lower-case
ARM: dts: omap3-beagle: Enable audio support
ARM: dts: omap5: Add McPDM and DMIC section to the dtsi file
ARM: dts: omap5: Add McBSP entries
ARM: dts: omap4: Add reg-names for McPDM and DMIC
ARM: dts: omap4: Add McBSP entries
ARM: dts: omap3: Add McBSP entries
ARM: dts: omap2420-h4: Include omap2420.dtsi file instead the common omap2
ARM: dts: omap2: Add McBSP entries for OMAP2420 and OMAP2430 SoC
ARM: dts: omap3-beagle: Add heartbeat and mmc LEDs support
ARM: dts: omap3: Add gpio-twl4030 properties for BeagleBoard and omap3-EVM
The Tamonten Evaluation Carrier is an evaluation board for the Tamonten
SOM. More information is available here:
http://www.avionic-design.de/en/products/nvidia-tegra-tamonten-system-en/nvidia-tegra-tamonten-evboard-en.html
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
The Medcom is a 16:9 15" terminal that is used for patient infotainment
in hospitals.
