path: root/arch/arm
2008-10-20Merge branch 'master' into for-upstreamDavid Vrabel
Conflicts: Documentation/ABI/testing/sysfs-bus-usb drivers/Makefile
2008-10-16Merge branch 'personality' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'personality' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [PATCH] remove unused ibcs2/PER_SVR4 in SET_PERSONALITY
2008-10-16Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (51 commits) [ARM] 5308/1: Fix Viper ISA IRQ handling [ARM] 5307/1: pxa: fix CM-X2XX PCMCIA build error [ARM] 5306/1: pxa: fix build error on CM-X270 [ARM] 5302/1: ARM: OMAP: Revert omap3 WDT changes to avoid merge conflict [ARM] 5305/1: ARM: OMAP: Fix compile of McBSP by removing unnecessary check [ARM] 5301/1: ARM: OMAP: Add missing irq defines ARM: OMAP3: Add default kernel config for OMAP LDP ARM: OMAP3: Add basic board support for OMAP LDP ARM: OMAP3: Defconfig for the Gumstix Overo board (rev 3) ARM: OMAP3: Add support for the Gumstix Overo board (rev 3) ARM: OMAP3: Add Beagle defconfig ARM: OMAP3: Add minimal Beagle board support ARM: OMAP3: Add minimal omap3430 support ARM: OMAP2: Fix sparse, checkpatch warnings in OMAP2/3 IRQ code ARM: OMAP: Fixes to omap_mcbsp_request function ARM: OMAP: Add support for OMAP2430 in McBSP ARM: OMAP: Add support for McBSP devices 3 - 5 on 34xx ARM: OMAP: Allocate McBSP devices dynamically Fix sections for omap-mcbsp platform driver [ARM] S3C24XX: Additional include moves ...
2008-10-16spi_s3c24xx: pin configuration updatesBen Dooks
Add a pin configuration callback for the s3c24xx SPI driver, as there are several options depending on the channel and the chip in use. This is needed as the controller may not have been setup by the initial bootloader and the fact that the SPI controller gets reset over suspend/resume into slave mode but the GPIO function registers do not. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16[PATCH] remove unused ibcs2/PER_SVR4 in SET_PERSONALITYMartin Schwidefsky
The SET_PERSONALITY macro is always called with a second argument of 0. Remove the ibcs argument and the various tests to set the PER_SVR4 personality. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-15cpufreq: remove policy->governor setting in drivers initializationDominik Brodowski
As policy->governor is already set to CPUFREQ_DEFAULT_GOVERNOR in the (always built-in) cpufreq core, we do not need to set it in the drivers. This fixes the sparc64 allmodconfig build failure. Also, remove a totally useles setting of ->policy in cpufreq-pxa3xx.c. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-15Merge branch 'fixes' into for-linusRussell King
Conflicts: arch/arm/mach-versatile/core.c
2008-10-15[ARM] 5308/1: Fix Viper ISA IRQ handlingMarc Zyngier
The ISA IRQ renumbering broke the Viper ISA code in interesting ways. It originally assumed that ISA interrupt were numbered in the order that is defined by the CPLD registers. Unfortunately, this is no longer the case. Furthermore, the viper_irq_handler() function being a chained IRQ handler, it must ACK the interrupt by itself, or the handler will be immediately reentered, with the expected damages. This fix was made possible thanks to the help of David Raeman, who provided debug information and tested each version of this patch. Tested-by: David Raeman <david.raeman@gmail.com> Signed-off-by: Marc Zyngier <maz@misterjones.org> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-15[ARM] 5306/1: pxa: fix build error on CM-X270Mike Rapoport
Fix build for CM-X2XX with CONFIG_RTC_DRV_V3020 unset: CC arch/arm/mach-pxa/cm-x270.o /mnt/sdb1/git/linux-2.6-arm/arch/arm/mach-pxa/cm-x270.c: In function 'cmx270_init': /mnt/sdb1/git/linux-2.6-arm/arch/arm/mach-pxa/cm-x270.c:338: error: implicit declaration of function 'cmx270_init_rtc' make[2]: *** [arch/arm/mach-pxa/cm-x270.o] Error 1 Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-14Merge branch 's3c-move' into develRussell King
2008-10-14Merge branch 'omap-all' into develRussell King
Conflicts: arch/arm/mach-omap2/gpmc.c arch/arm/mach-omap2/irq.c
2008-10-14[ARM] 5302/1: ARM: OMAP: Revert omap3 WDT changes to avoid merge conflictTony Lindgren
With the upcoming WDT patches OMAP_WDT_BASE is no longer needed in devices.c. Revert some earlier omap3 changes to avoid merge conflicts with the WDT patches. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-14[ARM] 5305/1: ARM: OMAP: Fix compile of McBSP by removing unnecessary checkTony Lindgren
Recent McBSP patches changed to allocating devices dynamically and the check for OMAP_MAX_MCBSP_COUNT became unnecessary. The check for OMAP_MAX_MCBSP_COUNT should have been removed with the earlier McBSP patches in devices.c but was accidentally left out. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-14[ARM] 5301/1: ARM: OMAP: Add missing irq definesTony Lindgren
Some McBSP irq defines were missing that should have been added with the earlier McBSP patches. Add the missing McBSP irqs, and a few other missing irqs as defined in linux-omap tree. Also add a blank line to separate irq defines from the irq line calculations. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-14i2c/isp1301_omap: Convert to a new-style i2c driver, part 2Jean Delvare
Based on David Brownell's patch for tps65010 and previous work by Felipe Balbi, this patch finishes converting isp1301_omap to a new-style i2c driver. There's definitely room for further drivers cleanups, but these are out of the scope of this patch. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Tony Lindgren <tony@atomide.com>
2008-10-13Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (313 commits) V4L/DVB (9186): Added support for Prof 7300 DVB-S/S2 cards V4L/DVB (9185): S2API: Ensure we have a reasonable ROLLOFF default V4L/DVB (9184): cx24116: Change the default SNR units back to percentage by default. V4L/DVB (9183): S2API: Return error of the caller provides 0 commands. V4L/DVB (9182): S2API: Added support for DTV_HIERARCHY V4L/DVB (9181): S2API: Add support fot DTV_GUARD_INTERVAL and DTV_TRANSMISSION_MODE V4L/DVB (9180): S2API: Added support for DTV_CODE_RATE_HP/LP V4L/DVB (9179): S2API: frontend.h cleanup V4L/DVB (9178): cx24116: Add module parameter to return SNR as ESNO. V4L/DVB (9177): S2API: Change _8PSK / _16APSK to PSK_8 and APSK_16 V4L/DVB (9176): Add support for DvbWorld USB cards with STV0288 demodulator. V4L/DVB (9175): Remove NULL pointer in stb6000 driver. V4L/DVB (9174): Allow custom inittab for ST STV0288 demodulator. V4L/DVB (9173): S2API: Remove the hardcoded command limit during validation V4L/DVB (9172): S2API: Bugfix related to DVB-S / DVB-S2 tuning for the legacy API. V4L/DVB (9171): S2API: Stop an OOPS if illegal commands are dumped in S2API. V4L/DVB (9170): cx24116: Sanity checking to data input via S2API to the cx24116 demod. V4L/DVB (9169): uvcvideo: Support two new Bison Electronics webcams. V4L/DVB (9168): Add support for MSI TV@nywhere Plus remote V4L/DVB: v4l2-dev: remove duplicated #include ...
2008-10-13Merge branch 'proc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc * 'proc' of git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc: proc: remove kernel.maps_protect proc: remove now unneeded ADDBUF macro [PATCH] proc: show personality via /proc/pid/personality [PATCH] signal, procfs: some lock_task_sighand() users do not need rcu_read_lock() proc: move PROC_PAGE_MONITOR to fs/proc/Kconfig proc: make grab_header() static proc: remove unused get_dma_list() proc: remove dummy vmcore_open() proc: proc_sys_root tweak proc: fix return value of proc_reg_open() in "too late" case Fixed up trivial conflict in removed file arch/sparc/include/asm/dma_32.h
2008-10-13Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: include/asm-x86/statfs.h
2008-10-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] orion5x_wdt.c: add spinlocking [WATCHDOG] Orion: add hardware watchdog support [WATCHDOG] omap_wdt.c: cleanup a bit omap_wdt.c [WATCHDOG] omap_wdt.c: another ioremap() fix [WATCHDOG] omap_wdt.c: sync linux-omap changes [WATCHDOG] Add AT91SAM9X watchdog [WATCHDOG] Add driver for winbond w83697ug/uf watchdog feature [WATCHDOG] add watchdog driver IT8716 IT8726 IT8712J/K
2008-10-12V4L/DVB (8687): soc-camera: Move .power and .reset from soc_camera host to ↵Stefan Herbrechtsmeier
sensor driver Make .power and .reset callbacks per camera instead of per host, also move their invocation to camera drivers. .arch/arm/mach-pxa/include/mach/camera.h | 2 - Signed-off-by: Stefan Herbrechtsmeier <hbmeier@hni.uni-paderborn.de> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-11Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (236 commits) [ARM] 5300/1: fixup spitz reset during boot [ARM] 5295/1: make ZONE_DMA optional [ARM] 5239/1: Palm Zire 72 power management support [ARM] 5298/1: Drop desc_handle_irq() [ARM] 5297/1: [KS8695] Fix two compile-time warnings [ARM] 5296/1: [KS8695] Replace macro's with trailing underscores. [ARM] pxa: allow multi-machine PCMCIA builds [ARM] pxa: add preliminary CPUFREQ support for PXA3xx [ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.h [ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.c [ARM] pxa/zylonite: add support for USB OHCI [ARM] ohci-pxa27x: use ioremap() and offset for register access [ARM] ohci-pxa27x: introduce pxa27x_clear_otgph() [ARM] ohci-pxa27x: use platform_get_{irq,resource} for the resource [ARM] ohci-pxa27x: move OHCI controller specific registers into the driver [ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registers [ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.c [ARM] pxa: simplify DMA register definitions [ARM] pxa: make additional DCSR bits valid for PXA3xx [ARM] pxa: move i2c register and bit definitions into i2c-pxa.c ... Fixed up conflicts in arch/arm/mach-versatile/core.c sound/soc/pxa/pxa2xx-ac97.c sound/soc/pxa/pxa2xx-i2s.c manually.
2008-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1075 commits) myri10ge: update driver version number to 1.4.3-1.369 r8169: add shutdown handler r8169: preliminary 8168d support r8169: support additional 8168cp chipset r8169: change default behavior for mildly identified 8168c chipsets r8169: add a new 8168cp flavor r8169: add a new 8168c flavor (bis) r8169: add a new 8168c flavor r8169: sync existing 8168 device hardware start sequences with vendor driver r8169: 8168b Tx performance tweak r8169: make room for more specific 8168 hardware start procedure r8169: shuffle some registers handling around (8168 operation only) r8169: new phy init parameters for the 8168b r8169: update phy init parameters r8169: wake up the PHY of the 8168 af_key: fix SADB_X_SPDDELETE response ath9k: Fix return code when ath9k_hw_setpower() fails on reset ath9k: remove nasty FAIL macro from ath9k_hw_reset() gre: minor cleanups in netlink interface gre: fix copy and paste error ...
2008-10-11Merge branch 'for-linus' of git://git.alsa-project.org/alsa-kernelLinus Torvalds
* 'for-linus' of git://git.alsa-project.org/alsa-kernel: (258 commits) ALSA: hda: VREF powerdown for headphones ALSA: hda: STAC_HP_M4 ALSA: ASoC: Check for machine type in GTA01 machine driver ALSA: mtpav - Fix race in probe ALSA: usb-audio: dynamic detection of MIDI interfaces in uaxx-quirk ALSA: Add a note on dependency of RTC stuff ALSA: ASoC: add new param mux to dapm_mux_update_power ALSA: Increase components array size ALSA: ASoC: Correct inverted Mic PGA Switch control in wm8510 driver ALSA: hda: comment typo fix ALSA: hda: comment typo fix ALSA: hda - Fix PCI SSID for ASROCK K18N78FullHD-hSLI ALSA: snd-usb-audio: support for Edirol UA-4FX device ALSA: usb - Fix possible Oops at USB-MIDI disconnection ALSA: hda - Fix another ALC889A (rev 0x100101) ALSA: hda: add more board-specific information for Realtek ALC662 rev1 ALSA: Correct Vladimir Barinov's e-mail address ALSA: cs46xx: Add PCI IDs for TerraTec and Hercules cards ALSA: hda: SPDIF stream muting support ALSA: hda: appletv support ...
2008-10-11[ARM] 5300/1: fixup spitz reset during bootDmitry Baryshkov
Some machines don't have the pullup/down on their reset pin, so configuring the reset generating pin as input makes them reset immediately. Fix that by making reset pin direction configurable. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-10Merge branch 'omap3-upstream' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into omap-all
2008-10-10[WATCHDOG] Orion: add hardware watchdog supportSylver Bruneau
This patch allows the use of the hardware watchdog in the Marvell Orion series of ARM SoCs. Signed-off-by: Sylver Bruneau <sylver.bruneau@googlemail.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-10-10[WATCHDOG] omap_wdt.c: sync linux-omap changesFelipe Balbi
These are changes that have been sitting in linux-omap and were never sent upstream. Hopefully, it'll never happen again at least for this driver. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-10-10ALSA: Correct Vladimir Barinov's e-mail addressVladimir Barinov
Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-10-10Merge branch 'for-upstream' of ↵David Vrabel
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb into for-upstream
2008-10-10ARM: OMAP3: Add default kernel config for OMAP LDPNishant Kamat
This patch adds a default config for the OMAP LDP platform. Signed-off-by: Nishant Kamat <nskamat@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-10ARM: OMAP3: Add basic board support for OMAP LDPNishant Kamat
This adds minimal board support for the OMAP3430 LDP development platform. Signed-off-by: Nishant Kamat <nskamat@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-10ARM: OMAP3: Defconfig for the Gumstix Overo board (rev 3)Steve Sakoman
Add defconfig for the Gumstix Overo board Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-10proc: remove unused get_dma_list()Alexey Dobriyan
2008-10-09Merge branch 'for-rmk' of git://git.marvell.com/orionRussell King
Merge branch 'orion-devel' into devel
2008-10-09Merge branch 'for-rmk' of git://source.mvista.com/git/linux-davinci-2.6.gitRussell King
Merge branch 'davinci' into devel
2008-10-09Merge branch 'for-rmk' of ↵Russell King
git://pasiphae.extern.pengutronix.de/git/imx/linux-2.6.git Merge branch 'imx-devel' into devel
2008-10-09Merge branch 'pxa-all' into develRussell King
Conflicts: arch/arm/mach-pxa/Kconfig arch/arm/mach-pxa/corgi.c arch/arm/mach-pxa/include/mach/hardware.h arch/arm/mach-pxa/spitz.c
2008-10-09Merge branch 'at91' into develRussell King
2008-10-09Merge branch 'ptebits' into develRussell King
Conflicts: arch/arm/Kconfig
2008-10-09Merge branches 'machtypes', 'core', 'ep93xx', 'ks8695', 'netdev' and ↵Russell King
'sa1100' into devel
2008-10-09[ARM] 5295/1: make ZONE_DMA optionalNicolas Pitre
Most ARM machines don't need a special "DMA" memory zone, and when configured out, the kernel becomes a bit smaller: | text data bss dec hex filename |3826182 102384 111700 4040266 3da64a vmlinux |3823593 101616 111700 4036909 3d992d vmlinux.nodmazone This is because the system now has only one zone total which effect is to optimize away many conditionals in page allocation paths. So let's configure this zone only on machines that need split zones. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09Merge branch 'omap2-upstream' of ↵Russell King
2008-10-09ARM: OMAP3: Add support for the Gumstix Overo board (rev 3)Steve Sakoman
This patch adds minimal overo support. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-09ARM: OMAP3: Add Beagle defconfigSyed Mohammed, Khasim
Add Beagle defconfig Signed-off-by: Syed Mohammed, Khasim <khasim@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-09ARM: OMAP3: Add minimal Beagle board supportSyed Mohammed, Khasim
Add minimal Beagle board support. Based on earlier patches by Syed Mohammed Khasim with some fixes from linux-omap tree. Signed-off-by: Syed Mohammed Khasim <khasim@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-09ARM: OMAP3: Add minimal omap3430 supportSyed Mohammed, Khasim
Add minimal omap3430 support based on earlier patches from Syed Mohammed Khasim. Also merge in omap34xx SRAM support from Karthik Dasu and use consistent naming for sram init functions. Also do following changes that make 34xx support usable: - Remove unused sram.c functions for 34xx - Rename IRQ_SIR_IRQ to INTCPS_SIR_IRQ and define it locally in entry-macro.S - Update mach-omap2/io.c to support 2420, 2430, and 34xx - Also merge in 34xx GPMC changes to add fields wr_access and wr_data_mux_bus from Adrian Hunter - Remove memory initialization call omap2_init_memory() until until more generic memory initialization patches are posted. It's OK to rely on bootloader initialization until then. Signed-off-by: Syed Mohammed, Khasim <khasim@ti.com> Signed-off-by: Karthik Dasu<karthik-dp@ti.com> Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-09ARM: OMAP2: Fix sparse, checkpatch warnings in OMAP2/3 IRQ codePaul Walmsley
Fix sparse warnings in mach-omap2/irq.c. Fix by defining intc_bank_write_reg() and intc_bank_read_reg(), and convert INTC module register access to use them rather than __raw_{read,write}l. Also clear up some checkpatch warnings involving includes from asm/ rather than linux/. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-09[ARM] 5239/1: Palm Zire 72 power management supportSergey Lapin
This patch contains Palm Zire 72 power management support. Depends on #5238/1 Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09[ARM] 5298/1: Drop desc_handle_irq()Dmitry Baryshkov
desc_handle_irq() was declared as obsolete since long ago. Replace it with generic_handle_irq() Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09[ARM] 5297/1: [KS8695] Fix two compile-time warningsAndrew Victor
Fix two warnings when compiling for the KS8695 processor. arch/arm/include/asm/dma-mapping.h: In function 'dma_to_virt': arch/arm/include/asm/dma-mapping.h:40: warning: return makes pointer from integer without a cast Section mismatch in reference from the function pcibios_fixup_bus() to the (unknown reference) .devinit.text:(unknown) The function pcibios_fixup_bus() references the (unknown reference) __devinit (unknown). This is often because pcibios_fixup_bus lacks a __devinit annotation or the annotation of (unknown) is wrong. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
