devel-stable
* 'msm-core' of git://codeaurora.org/quic/kernel/dwalker/linux-msm: (72 commits)
msm: 7x30 Kconfig and makefile changes
msm: clock support for the MSM7x30 CPU.
msm: physical offset for MSM7X30
msm: io: add io support for 7x30
msm: Add extern for 7x30 clock list.
msm: dma: add 7x30 security domain abstraction
msm: update basic board layout for MSM7x30
msm: add devices-msm7x30.c
msm: add msm_iomap-7x30.h for MSM7x30 support
msm: irqs: add irqs-7x30.h for MSM7x30 support
msm: 8x50 Kconfig changes
msm: physical offset for QSD8x50
msm: io: add io support for 8x50
msm: add extern for 8x50 clock list.
msm: add devices-qsd8x50.c
msm: update basic board layout for QSD8x50
msm: add msm_iomap-8x50.h for QSD8x50 support
msm: irqs: add irqs-8x50.h for QSD8x50 support
msm: timer: allow MSM_DGT_BASE to be overriden
msm: add Qualcomm 7x30 interrupt controller driver.
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci
* 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci: (48 commits)
Revert "rtc: omap: let device wakeup capability be configured from chip init logic"
DM365: Added more PINMUX configurations for AEMIF
DM365: Make CLKOUTx available
DM365: Added PINMUX definitions for GPIO30..32
Davinci: iotable based ioremap() interception
Davinci: pinmux - use ioremap()
Davinci: aintc/cpintc - use ioremap()
Davinci: psc - use ioremap()
Davinci: timer - use ioremap()
Davinci: jtag_id - use ioremap()
Davinci: da8xx: rtc - use ioremap
Davinci: gpio - use ioremap()
davinci: edma: fix coding style issue related to breaking lines
davinci: edma: use BIT() wherever possible
davinci: edma: fix coding style issue related to usage of braces
davinci: edma: use a more intuitive name for edma_info
Davinci: serial - conditional reset via pwremu
Davinci: serial - use ioremap()
Davinci: serial - remove unnecessary define
Davinci: watchdog reset separation across socs
Fix up trivial conflict in arch/arm/Kconfig due to removal of "select
GENERIC_TIME"
* 'for-linus/samsung4' of git://git.fluff.org/bjdooks/linux: (98 commits)
Input: s3c24xx_ts - depend on SAMSUNG_DEV_TS and update menu entry
Input: s3c24xx_ts - Add FEAT for Samsung touchscreen support
Input: s3c24xx_ts - Implement generic GPIO configuration callback
ARM: SAMSUNG: Move s3c64xx dev-ts.c to plat-samsung and rename configuration
ARM: SAMSUNG: Implements cfg_gpio function for Samsung touchscreen
ARM: S3C64XX: Add touchscreen platform device definition
ARM: SAMSUNG: Move mach/ts.h to plat/ts.h
ARM: S5PC100: Move i2c helpers from plat-s5pc1xx to mach-s5pc100
ARM: S5PC100: Move frame buffer helpers from plat-s5pc1xx to mach-s5pc100
ARM: S5PC100: gpio.h cleanup
ARM: S5PC100: Move gpio support from plat-s5pc1xx to mach-s5pc100
ARM: S5PC100: Use common functions for gpiolib implementation
drivers: serial: S5PC100 serial driver cleanup
ARM: S5PC100: Pre-requisite clock patch for plat-s5pc1xx to plat-s5p move
ARM: SAMSUNG: Copy common I2C0 device helpers to machine directories
ARM: SAMSUNG: move driver strength gpio configuration helper to common dir
ARM: S5PV210: Add GPIOlib support
ARM: SAMSUNGy: fix broken timer irq base
ARM: SMDK6440: Add audio devices on board
ARM: S5P6440: Add audio platform devices
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (224 commits)
ARM: remove 'select GENERIC_TIME'
ARM: 6136/1: ARCH_REQUIRE_GPIOLIB selects GENERIC_GPIO
ARM: 6074/1: oprofile: convert from sysdev to platform device
ARM: 6073/1: oprofile: remove old files and update KConfig
ARM: 6072/1: oprofile: use perf-events framework as backend
ARM: 6071/1: perf-events: allow modules to query the number of hardware counters
ARM: 6070/1: perf-events: add support for xscale PMUs
ARM: 6069/1: perf-events: use numeric ID to identify PMU
ARM: 6064/1: pmu: register IRQs at runtime
ARM: Optionally allow ARMv6 to use 'normal, bufferable' memory for DMA
ARM: 6134/1: Handle instruction cache maintenance fault properly
ARM: nwfpe: allow debugging output to be configured at runtime
ARM: rename mach_cpu_disable() to platform_cpu_disable()
ARM: 6132/1: PL330: Add common core driver
ARM: 6094/1: Extend cache-l2x0 to support the 16-way PL310
ARM: Move memory mapping into mmu.c
ARM: Ensure meminfo is sorted prior to sanity_check_meminfo
ARM: Remove useless linux/bootmem.h includes
ARM: convert /proc/cpu/aligment to seq_file
arm: use asm-generic/scatterlist.h
Signed-off-by: Alberto Panizzo <maramaopercheseimorto@gmail.com>
This patch adds also the pin definition helpers in iomux-mx3.h
Move the arch/arm/mach-s3c64xx/dev-ts.c file to arch/arm/plat-samsung and
rename the Kconfig entry appropriately.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
This patch implements cfg_gpio function for Samsung touchscreen.
And also modifies the H1940 machine respectively.
Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This patch adds the touchscreen platform device definition for S3C64XX boards.
Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com>
This moves mach-s3c2410/include/mach/ts.h to plat-samsung/include/plat/ts.h in
order to prepare for s3c64xx support in the touchscreen driver.
Move i2c helpers from plat-s5pc1xx to mach-s5pc100.
Move frame buffer helpers from plat-s5pc1xx to mach-s5pc100.
This patch renames gpio related registers from s5pc1xx to s5pc100 to
better match the plat-s5p framework style. GPIO_MP* defines now used
anywhere thus has been removed.
Move gpio-lib support from plat-s5pc1xx to mach-s5pc100. Only basic gpio
functionality is now supported. Gpio interrupts are disabled temporarly
and will be added later.
GPIOlib helpers from plat-samsung already have functions for accessing
4bit gpio banks. This patch removes the duplicated functions from
plat-s5pc1xx/gpiolib.c.
This is a pre-requisite clock patch for the plat-s5pc1xx to plat-s5p
movement. The patches that perform the movement of the code from
plat-s5pc1xx to plat-s5p (and mach-s5pc100) should also enable the
build for the mach-s5pc100/clock.c code.
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
Driver strength parameter can be changed not only on S5PC100 but also
on S5PV210/S5PC110 platforms, so move the helper functions to the common
plat-samsung directory.
Merge branch 'for-2635/samsung-rtc' into for-linus/samsung2
arch/arm/mach-s3c64xx/include/mach/map.h
arch/arm/plat-samsung/Kconfig
arch/arm/plat-samsung/Makefile
Merge branch 'for-2635/samsung-ts' into for-linus/samsung2
Merge branch 'for-2635/s5p-audio' into for-linus/samsung2
Merge branch 'for-2635/s5p-dma' into for-linus/samsung2
arch/arm/mach-s5pv210/Makefile
Merge branch 'for-2635/fb-updates1' into for-linus/samsung2
Merge branch 'for-2635/s5pv210-clock' into for-linus/samsung2
Merge branch 'for-2635/s5p6440-clock' into for-linus/samsung2
Merge branch 'for-2635/s3c6410-clock' into for-linus/samsung2
Merge branch 'for-2635/gpio2' into for-linus/samsung2
Merge branch 'for-2635/rx1950' into for-linus/samsung2
Merge branch 'for-2635/acer-n35' into for-linus/samsung2
Merge branch 'for-2635/samsung-clock' into for-linus/samsung2
Merge branch 'for-2635/samsung-hwmon' into for-linus/samsung2
Merge branch 'for-2635/samsung-dma' into for-linus/samsung2
Merge branch 'for-2635/s5p-general' into for-linus/samsung2
Merge branch 'for-2635/s3c24xx-general' into for-linus/samsung2
This patch adds GPIOlib support for S5PV210.
Signed-off-by: Pannaga Bhushan <p.bhushan@samsung.com>
Timer interrupts range was defined as 43-47, what overlaps with VIC0 range
(32-64). This was caused probably by a typo while the common interrupts
definition was refactored. This patch moves timer interrupt range to safe
area of 11-15 (just before uart range).
This fixes the commit 87aef30eb3c5dac0491c83fe3b90bc61f1df24ec
("ARM: S5P: Change S5P_TIMER_IRQ based to 11 for SAMSUNG S5P series.")
which meant to move these into the old (and previously reserved)
ISA space.
[ben-linux@fluff.org: update description]
Add audio platform devices on the smdk by default.
Signed-off-by: Jassi Brar <jassi.brar@samsung.com>
Define platform devices for all audio devices found on S5P6440
Define platform devices for all audio devices found on S5P6442
Define platform devices for all audio devices found on S5PV210
The pm-gpio.c code was incrementing the gpio_nr from the nr_gpios
field and the bank-bank offset inside the loop, and also in the
for() loop with a ++.
Remove the ++, as the number is already at the next GPIO, thus
ensuring that we don't skip a gpio bank by accident.
Add a table for the GPIO bank sizes for each SoC
As part of the cleanup, remove the old macros mapping GPIO numbers
to the base of the register now we have gpiolib to manage the GPIO
mappings for us.
Update a couple of S3C24XX and S3C2412 files that are still
using the GPIO number to register mapping calls to get the
s3c_gpio_chip and use the base field from that.
Start cleaning up the numbering of GPIO banks by removing the old
bank start definitions currently being used by some of the header
files.
Increase GPIOs number for S3C244X, and make S3C_GPIO_END
point to BANKJ end, otherwise gpiolib refuses to register
BANKJ
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
[ben-linux@fluff.org: Move pm fix to new patch]
