path: root/arch/arm
2007-02-17[ARM] 4186/1: iop: remove cp6_enable/disable routinesDan Williams
This functionality is replaced by cp6_trap Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17[ARM] 4185/2: entry: introduce get_irqnr_preamble and arch_ret_to_userDan Williams
get_irqnr_preamble allows machines to take some action before entering the get_irqnr_and_base loop. On iop we enable cp6 access. arch_ret_to_user is added to the userspace return path to allow individual architectures to take actions, like disabling coprocessor access, before the final return to userspace. Per Nicolas Pitre's note, there is no need to cp_wait on the return to user as the latency to return is sufficient. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4184/1: iop: cp6 access handler (undef_hook)Dan Williams
Enable svc access to cp6 via an undefined instruction hook. Do not enable access for usr code. This patch also makes iop13xx select PLAT_IOP, this requires a small change to drivers/i2c/busses/i2c-iop3xx.c. Per Lennert Buytenhek's note, the cp6 trap routine is moved to arch/arm/plat-iop Per Nicolas Pitre's note, the cp_wait is skipped since the latency to return to the faulting function is longer than cp_wait. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4183/1: do_undefinstr: read svc undefined instructions with svc privilegesDan Williams
do_undefinstr currently does not expect undefined instructions in kernel code, since it always uses get_user() to read the instruction. Dereference the 'pc' pointer directly in the SVC case. Per Nicolas Pitre's note, kernel code is never in thumb mode. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4182/1: iop3xx: fix the ioremap implementation to not remap static rangesDan Williams
Implement a custom ioremap implementation for iop3xx. This saves establishing new mappings. It also cleans up the PCI IO resource to be a physical address rather than a virtual address as Russell pointed out on the original iop13xx port. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] Move processor_modes[] to .../process.cRussell King
bad_mode() currently prints the mode which caused the exception, and then causes an oops dump to be printed which again displays this information (since the CPSR in the struct pt_regs is correct.) This leads to processor_modes[] being shared between traps.c and process.c with a local declaration of it. We can clean this up by moving processor_modes[] to process.c and removing the duplication, resulting in processor_modes[] becoming static. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] 4047/1: Add initial board support for Contec Hypercontrol Micro9 boards.Manfred Gruber
Contec Micro9 (H/M/L) boards based on Cirrus Logic ep93xx (ep9315/ep9307/ep9302). Signed-off-by: Manfred Gruber <m.gruber@tirol.com> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] 4032/1: Add platform resources required for CF driverMichael-Luke Jones
This patch adds the platform resources required to support the ixp4xx-pata-cf libata driver on Avila Gateworks boards. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] 4033/1: Add separate Avila board setup codeMichael-Luke Jones
This patch adds support for the Gateworks Avila Network Platform in a separate set of setup files to the IXDP425. This is necessary now that a driver for the Avila CF card slot is available. It also adds support for a minor variant on the Avila board known as the Loft, which has a different number of maximum PCI devices. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] 4031/1: Remove references to the Avila in ixdp425 setup codeMichael-Luke Jones
This patch removes references to the Gateworks Avila Network Platform in the ixdp425 setup code. Avila setup should occur separately now that a CF ATA device driver is available. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] oprofile: add ARM11 SMP supportRussell King
Add the glue for ARM11 SMP oprofile support, which also supports the performance monitor in the coherency unit. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] oprofile: add ARM11 UP supportRussell King
Add oprofile glue for ARM11 (ARMv6) oprofile support. This connects the ARM11 core profiling support to the oprofile code for uniprocessor configurations. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] oprofile: add ARM11 core supportRussell King
Add basic support for the ARM11 profiling hardware. This is shared between the ARM11 UP and ARM11 SMP oprofile support code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-29[ARM] 4117/1: S3C2412: Fix writel() usage in selection codeBen Dooks
The S3C2412 DMA selection code has the arguments to writel() the wrong way around. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-25[ARM] 4111/1: Allow VFP to work with thread migration on SMPCatalin Marinas
The current lazy saving of the VFP registers is no longer possible with thread migration on SMP. This patch implements a per-CPU vfp-state pointer and the saving of the VFP registers at every context switch. The registers restoring is still performed in a lazy way. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-25[ARM] 4112/1: Only ioremap to supersections if DOMAIN_IO is zeroCatalin Marinas
Supersections do not have a field for the domain and it is always 0. This patch prevents the creation of supersections during ioremap when DOMAIN_IO is not zero (i.e. !defined(CONFIG_IO_36)). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4102/1: Allow for PHYS_OFFSET on any valid 2MiB addressLinus Walleij
This patchs allows the offset to the first page of physical memory to be on any 2MB boundary whereas the previous code could only handle psysical offset to any 16MB boundary (0xNN000000) or any 1MB boundary below 0x01000000 (e.g. 0x00N00000). The problem is a consequence of the orr one-byte syntax, so we fix this and we can place the first bank of memory at 0x28e00000. I have also included an explicit check that disallow compilation when PHYS_OFFSET is not on a 2MiB boundary. head.S would be the proper place to have this at since this is the first file that attempts to use PHYS_OFFSET during compile. Signed-off-by: Linus Walleij <triad@df.lth.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4100/1: iop3xx: fix cpu mask for iop333Dan Williams
cosmetic fix so iop333 is not reported as ixp46x iop333 cpuid = 0x69054210 Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] Update mach-typesRussell King
2007-01-24[ARM] Fix show_mem() for discontigmemRussell King
show_mem() was assuming incorrectly that the mem_map for any node started at PFN 0. This is obviously wrong; fix it to take account of node_start_pfn. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4096/1: S3C24XX: change return code form s3c2410_gpio_getcfg()Ben Dooks
The s3c2410_gpio_getcfg() currently returns a value which is dependant on the GPIO no passed in. Now we have more generic constants it is sensible to use those as return codes so that any function dealing with >1 GPIO does not need to do it's own number processing. Since this function is only currently used in pm.c, it is easy to fixup (and correct pm.c to use the generic constants) Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4095/1: S3C24XX: Fix GPIO set for Bank ABen Dooks
GPIO bank A can only be output or a special function, and the regs-gpio.h header has mistakenly got this as input or output. The mistake is carried on into the gpio.c s3c2410_gpio_cfgpin() call which will set the wrong value if S3C2410_GPIO_OUTPUT is passed. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4092/1: i.MX/MX1 CPU Frequency scaling latency definitionPavel Pisa
The transition latency has to be defined and reasonably small to allow on-demand and conservative governors. The value has been defined according to manual. The imx_set_target() protected against seen out of range requests now. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4089/1: AT91: GPIO wake IRQ cleanupAndrew Victor
Cleanup of at91 platform level gpio wake and suspend/resume logic. The GPIO core now delegates wakeups to the parent AIC by refcounting, and delegates clock management to the clock API. This makes these system modules more independent of each other, which is cleaner and will also help with the AT91SAM9263 (where some GPIO controllers share the same irq and clock). Original patch by David Brownell. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4087/1: AT91: CPU reset for SAM9x processorsAndrew Victor
This patch implements CPU and peripheral reset on AT91SAM9260 and AT91SAM9261. Original patch from Wojtek Kaniewski. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4086/1: AT91: Whitespace cleanupAndrew Victor
A couple of whitespace cleanups, mainly in the AT91 header files. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-24[ARM] 4084/1: Remove CONFIG_DEBUG_WAITQAndrew Victor
Remove the legacy CONFIG_DEBUG_WAITQ from the SAM9260-EK and SAM9261-EK default configuration files. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-08[ARM] Provide basic printk_clock() implementationRussell King
Current sched_clock() implementations on ARM cause unbootable kernels with PRINTK_TIME support enabled. To avoid this, provide a basic printk_clock() implementation which avoids sched_clock() being called before the page tables have been set up. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-08[ARM] Resolve fuse and direct-IO failures due to missing cache flushesRussell King
fuse does not work on ARM due to cache incoherency issues - fuse wants to use get_user_pages() to copy data from the current process into kernel space. However, since this accesses userspace via the kernel mapping, the kernel mapping can be out of date wrt data written to userspace. This can lead to unpredictable behaviour (in the case of fuse) or data corruption for direct-IO. This resolves debian bug #402876 Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-06[ARM] Fix kernel-mode undefined instruction abortsRussell King
If the kernel attempts to execute a CP1 or CP2 instruction and it aborts, and a FP emulator is not loaded, we try to return as if to a user context, instead of the proper kernel context. Since the fault came from kernel mode, we must use the kernel return paths. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-06[ARM] 4070/1: arch/arm/kernel: fix warnings from missing includesBen Dooks
Include <asm/io.h> to fix the warning: arch/arm/kernel/traps.c:647:6: warning: symbol '__readwrite_bug' was not declared. Should it be static? Include <linux/mc146818rtc.h> to fix the warning: arch/arm/kernel/time.c:42:1: warning: symbol 'rtc_lock' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-02Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 4081/1: Add definition for TI Sync Serial Protocol [ARM] 4080/1: Fix for the SSCR0_SlotsPerFrm macro [ARM] Fix VFP initialisation issue for SMP systems [ARM] 4078/1: Fix ARM copypage cache coherency problems [ARM] 4077/1: iop13xx: fix __io() macro [ARM] 4074/1: Flat loader stack alignment [ARM] 4073/1: Prevent s3c24xx drivers from including asm/arch/hardware.h and asm/arch/irqs.h [ARM] 4071/1: S3C24XX: Documentation update [ARM] 4066/1: correct a comment about PXA's sched_clock range [ARM] 4065/1: S3C24XX: dma printk fixes [ARM] 4064/1: make pxa_get_cycles() static [ARM] 4063/1: ep93xx: fix IRQ_EP93XX_GPIO?MUX numbering
2007-01-02[ARM] Fix VFP initialisation issue for SMP systemsRussell King
When we install the handlers for context switching, we must enable VFP on all CPU cores, otherwise undefined (and random) effects occur. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-30[PATCH] ARM: OMAP: fix missing header on apollon boardKyungmin Park
Fix apollon board compiler error Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] ARM: OMAP: fix GPMC compiler errorsKyungmin Park
Fix GPMC compiler errors on OMAP2 Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[ARM] 4078/1: Fix ARM copypage cache coherency problemsRichard Purdie
If PG_dcache_dirty is set for a page, we need to flush the source page before performing any copypage operation using a different virtual address. This fixes the copypage implementations for XScale, StrongARM and ARMv6. This patch fixes segmentation faults seen in the dynamic linker under the usage patterns in glibc 2.4/2.5. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-30[ARM] 4077/1: iop13xx: fix __io() macroDan Williams
Since iop13xx defines the PCI I/O spaces with physical resource addresses the __io macro needs to perform the physical to virtual conversion. I incorrectly assumed that this would be handled by ioremap, but drivers (like e1000) directly dereference the address returned from __io. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-30[ARM] 4066/1: correct a comment about PXA's sched_clock rangeNicolas Pitre
Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-30[ARM] 4065/1: S3C24XX: dma printk fixesArnaud Patard
The commit 505788cccbb96cd496b646594c8a5fcdc26bc2d9 in linus kernel tree introduced some printks (for debugging ?) which are flooding the logs on my h1940. This patch replace them with pr_debug calls. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-30[ARM] 4064/1: make pxa_get_cycles() staticNicolas Pitre
... and fix a comment as well. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-19[ARM] 4062/1: S3C24XX: Anubis and Osiris shuld have CONFIG_PM_SIMTECBen Dooks
Both CONFIG_MACH_OSIRIS and CONFIG_MACH_ANUBIS should select CONFIG_PM_SIMTEC. This patch moves the selection of CONFIG_PM_SIMTEC to the machines that require it, as currently done with other machines in the S3C2410 architecture. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-19[ARM] 4060/1: update several ARM defconfigsLennert Buytenhek
Update the ep93xx, iop13xx, iop32x, iop33x, ixp2000, ixp23xx, lpd270 and onearm defconfigs to 2.6.20-rc1. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-19[ARM] 4061/1: xsc3: change of maintainerLennert Buytenhek
Deepak Saxena has agreed to hand xsc3 maintainership over to me. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-19[ARM] 4059/1: VR1000: fix LED3's platform device numberBen Dooks
LED 3 should have been registered with the platform deviceid of 3, instead of 1 (which was used for LED 1). Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-19[ARM] 4022/1: iop13xx: generic irq fixupsDan Williams
* use irq_chip * use handle_level_irq Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-18[ARM] 4015/1: s3c2410 cpu ifdefsKrzysztof Helt
The patch adds ifdefs around per cpu definitions. Otherwise, if not all cpu types are selected, the kernel does not link. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-18[ARM] 4056/1: iop13xx: fix resource.end off-by-one in flash setupLennert Buytenhek
The struct resource 'end' field is inclusive, the iop13xx flash setup code got this wrong. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-18[ARM] 4055/1: iop13xx: fix phys_io/io_pg_offst for iq81340mc/scLennert Buytenhek
The phys_io/io_pg_offst machine record variables were being set to bogus values, causing problems when enabling DEBUG_LL. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-18[ARM] 4054/1: ep93xx: add HWCAP_CRUNCHLennert Buytenhek
Add HWCAP_CRUNCH so that the dynamic linker knows whether it can use Crunch-optimised libraries or not. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-18[ARM] 4052/1: S3C24XX: Fix PM in arch/arm/mach-s3c2410/KconfigBen Dooks
Fix up the CONFIG_PM mixups in arch/arm/mach-s3c2410/Kconfig causing CONFIG_S3C2410_PM and CONFIG_PM_H1940 to get enabled permanently. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
